SM14ML-1TK6
SM14ML-1TK6
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    Pin Contact Tin Crimp 14 AWG Stamped
SM14ML-1TK6 数据手册
A B C D E SM16ML1* SM16ML11* VIEW F VIEW G VIEW H F G H I J K L M N O P B.6; Validé SM20ML1* SM24ML1* 8 8 2,5±0,5 2,7±0,5 1,7±0,4 E 1,9±0,4 C D H E 3,2±0,5 2,4±0,4 G SECTION D E-E B 2,4±0,4 F C D-D SECTION COUPE C-C COUPE B-B B 7 7 SM20M1* / SM20M1*REV AREA 1 AREA 2 AREA1 SM16M1* / SM16M1*REV 3,7±0,2 AREA 2 SM16M11* / SM16M11*REV 3,5±0,3 AREA 1 3,2±0,3 SM24M1* / SM24M1*REV AREA 2 AREA1 AREA 2 AREA 4 2,9±0,3 AREA 3 2,4±0,3 AREA 4 2,1±0,3 2,9±0,3 6 6 AREA 3 AREA 3 AREA 4 5 5 AREA 3 AREA 4 SM14ML1* FEMALE CONTACT CAT. N° WIRE SIZE Package 4 SM24M1L* SM24M1* / SM24M1*REV SM20M1L* SM20M1* / SM20M1*REV SM16M11L* SM16ML11* / SM16M11*REV SM16M1L* SM16M1* / SM16M1*REV SM14M1L* SM14M1* / SM14M1*REV AWG Loose contacts in plastic bag Strip contacts on reel Loose contacts in plastic bag Strip contacts on reel Loose contacts in plastic bag Strip contacts on reel Loose contacts in plastic bag WIRE STRIP LENGTH IN MM. 26/24 0.12/0.25 0.90/1.60 4.0 22/20 0.32/0.50 1.20/2.10 4.0 18/16 0.82/1.50 3.0 Max 4.65 18/16 0.82/1.50 3.2 Max 6.35 HAND CRIMP TOOLING DIE SET HANDTOOL FOR LOOSE PIECE S16SCM20 SHANDLES S16SCM20 SHANDLES S16SCML11 SHANDLES S16SCML1 SHANDLES EXTRACTION TOOL A 13.5/14.2 14 Strip contacts on reel 2.10/2.50 3.2 Max S16SCML1 6.35 COUPE 4 A-A 28 REF RX2025GE1 SM14M1* / SM14M1*REV AREA 1 Loose contacts in plastic bag A AREA 2 3 SHANDLES 3,3±0,3 3 Strip contacts on reel MM² WIRE INSUL. DIAM. IN MM. 3,1±0,3 * PLATING CONSTRUCTION : - S6 = 0.75µ GOLD MIN. OVER Ni GOLD FLASH OVER Ni (AREA 1) (AREA 2) - D70 = 0.13µ GOLD MIN. OVER Ni GOLD FLASH OVER Ni (AREA 1) (AREA 2) - TK6 = 0.5-2.5µ Sn PRE-PLATED (AREA 1+2) 2 For standard winding CONTACT BODY : HIGH CONDUCTIVITY COPPER ALLOY. OUTER SPRING : STAINLESS STEEL. See View 2 PACKING CONTACTS ON STANDARD STRIP : 3000 PCS. PER REEL, E.G. SM16M11* PACKING CONTACTS ON REVERSE STRIP : 3000 PCS. PER REEL, E.G. SM16M11*REV FOR WINDING DIRECTION ON REEL (STANDARD OR REVERSE) : SEE BS.C.200178.003 AREA 4 PACKING LOOSE PIECE CONTACTS : 100 PCS PER STD. PACKING E.G. SM16ML11* 1 -S18 = 0.75µ GOLD MIN OVER Ni 1.3µ MINI Sn OVER Ni 1.3µ MINI Ni (AREA 1) (AREA 3) (AREA 4) -S31 = GOLD FLASH OVER Ni 1.3µ MINI Sn OVER Ni 1.3µ MINI Ni (AREA 1) (AREA 3) (AREA 4) -D70REV = 0.13µ GOLD MIN. OVER Ni 1.3µ MINI Sn OVER Ni 1.3µ MINI Ni CONNECTOR ACCOMMODATION (AREA 1) (AREA 3) (AREA 4) See Wiew O DATE L K J Update drawing Latest modification - by: COURTOIS L. I Date: ROUILLARD Ch CUSTOMER DRAWING 03/04/2019 SM--M--Dimensions in mm General linear Tolerances: 0.1 NPRDS / PROJECT TRIM TRIO www.esterline-connection-technologies.com H G F E A1 C B Country FR 1 This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° BS-C-200178-001 FORMAT D MOD N MALE FORMED TWO PIECE CONTACT 4/1 CURRENT RATING : 13 A CONTACT RETENTION IN BODY : 65 N MIN. CONTACT RESISTANCE :
SM14ML-1TK6 价格&库存
很抱歉,暂时无法提供与“SM14ML-1TK6”相匹配的价格&库存,您可以联系我们找货
