ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
DATE
APPROVED
C
DCN 42164
03/16
DAL
D
DCN 48135
11/18
STW
.477 12.10
.3440 8.74
.196 4.98
MATERIAL:
BODY, CONTACT &
RETAINING RING:
BERYLLIUM COPPER
INSULATOR:
PTFE
FERRULE:
BRASS
COMPRESSION
SPRING, SLEEVE
& WASHER:
STAINLESS STEEL
.207±.001 5.26±0.03
.1635±.0010 4.15±0.03
.184±.002 4.67±0.05
X 90 INCL.
FINISH:
.367±.001 9.32±0.03
BODY, CONTACT
& FERRULE:
GOLD OVER NICKEL
RETAINING RING:
NICKEL
COMPRESSION
SPRING, SLEEVE
& WASHER:
.392±.001 9.96±0.03
RECOMMENDED MOUNTING HOLE
PASSIVATED
MATERIAL:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
FINISH:
50 OHMS
DC TO 40.0 GHz.
1.30:1 DC TO 40.0 GHz.
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
JMC 11/05/10
CHECKED:
APPROVED:
STW 11/05/10
STW 11/05/10
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
VITA 67.1/2 PLUG-IN CONTACT
FOR Ø.047 CABLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 10:1
3221-40019
SHEET 1 OF 1
很抱歉,暂时无法提供与“3221-40019”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1232.225741+159.40721
- 10+1047.4795410+135.50747
- 25+981.9595325+127.03146
- 50+935.1514550+120.97612
- 100+890.58969100+115.21138
