ROHS COMPLIANT
PRODUCT DATA DRAWING
B
.621 15.77 UNCOMPRESSED
(.560[14.22] COMPRESSED)
REVISION HISTORY
DESCRIPTION
REV
REV. DCN 3966
DATE
APPROVED
08/01/13
PJS
.425 10.78
COMPRESSED
.310 7.86
COMPRESSED
.031±.002 0.79±0.05
.3145±.0015 7.99±0.04
.286±.001 7.26±0.03
.120 3.05
.090±.001 2.29±0.03
RP
.374 9.50
COMPRESSED
.275
+0.03
+.001
6.99
- 0.05
- .002
MATERIAL:
BODY,
FERRULE & SLEEVE:
FERRULE:
CONTACT
RET. RING:
INSULATOR:
SPRING:
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
BRASS PER ASTM B16 ALLOY UNS No. 36000
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
STAINLESS STEEL PER ASTM A313, TYPE 631
ALLOY No. UNS17700.
FINISH:
BODY, SLEEVE,
& SPRING:
CONTACT & FERRULE:
RET. RING:
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
INSERTION LOSS:
DWV:
OPERATING TEMP.:
PASSIVATED PER AMS-2700, TYPE 2.
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
NICKEL PER AMS-QQ-N-290.
MATERIAL:
50 OHMS
DC TO 26.5 GHz
1.30:1 DC TO 26.5 GHz
.06 X SQRT(F(F IN GHz))
1000 VRMS
-55 C TO +125 C
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
JMC 02/11/08
CHECKED:
APPROVED:
PJS 05/05/10
PJS 05/05/10
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SIZE
B
M38999/BMA SOCKET
FOR TFLEX 405 CABLE
CAGE CODE DWG. NO.
SF9411-6000
95077
SCALE: 6:1
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF9411-6000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1451.234631+187.94963
- 10+1233.6718110+159.77303
- 25+1156.5199125+149.78108
- 50+1101.3971350+142.64212
