A
B
C
D
E
SM16ML1*
SM16ML11*
VIEW F
VIEW G
VIEW H
F
G
H
I
J
K
L
M
N
O
P
B.6; Validé
SM20ML1*
SM24ML1*
8
8
2,5±0,5
2,7±0,5
1,7±0,4
E
1,9±0,4
C
D
H
E
3,2±0,5
2,4±0,4
G
SECTION
D
E-E
B
2,4±0,4
F
C
D-D
SECTION
COUPE
C-C
COUPE
B-B
B
7
7
SM20M1* / SM20M1*REV
AREA 1
AREA 2
AREA1
SM16M1* / SM16M1*REV
3,7±0,2
AREA 2
SM16M11* / SM16M11*REV
3,5±0,3
AREA 1
3,2±0,3
SM24M1* / SM24M1*REV
AREA 2
AREA1
AREA 2
AREA 4
2,9±0,3
AREA 3
2,4±0,3
AREA 4
2,1±0,3
2,9±0,3
6
6
AREA 3
AREA 3
AREA 4
5
5
AREA 3
AREA 4
SM14ML1*
FEMALE CONTACT
CAT. N°
WIRE SIZE
Package
4
SM24M1L*
SM20M1L*
SM16M11L*
SM16ML11* / SM16M11*REV
SM16M1L*
SM14M1L*
SM14M1* / SM14M1*REV
AWG
Loose contacts in plastic bag
Strip contacts on reel
WIRE STRIP
LENGTH
IN MM.
26/24
0.12/0.25
0.90/1.60
4.0
22/20
0.32/0.50
1.20/2.10
4.0
18/16
0.82/1.50
3.0 Max
4.65
18/16
0.82/1.50
3.2 Max
6.35
HAND CRIMP TOOLING
DIE SET
HANDTOOL FOR
LOOSE PIECE
S16SCM20
SHANDLES
S16SCM20
SHANDLES
S16SCML11
SHANDLES
S16SCML1
SHANDLES
EXTRACTION
TOOL
A
13.5/14.2
14
2.10/2.50
3.2 Max
S16SCML1
6.35
COUPE
4
A-A
28 REF
RX2025GE1
AREA 1
A
AREA 2
3
SHANDLES
3,3±0,3
3
MM²
WIRE INSUL.
DIAM. IN MM.
3,1±0,3
* PLATING
CONSTRUCTION :
- S6 = 0.75µ GOLD MIN. OVER Ni
GOLD FLASH OVER Ni
(AREA 1)
(AREA 2)
- D70 = 0.13µ GOLD MIN. OVER Ni
GOLD FLASH OVER Ni
(AREA 1)
(AREA 2)
- TK6 = 0.5-2.5µ Sn PRE-PLATED
(AREA 1+2)
2
For standard
winding
CONTACT BODY : HIGH CONDUCTIVITY COPPER ALLOY.
OUTER SPRING : STAINLESS STEEL.
See
View
2
PACKING CONTACTS ON STANDARD STRIP : 3000 PCS. PER REEL, E.G. SM16M11*
PACKING CONTACTS ON REVERSE STRIP : 3000 PCS. PER REEL, E.G. SM16M11*REV
FOR WINDING DIRECTION ON REEL (STANDARD OR REVERSE) : SEE BS.C.200178.003
AREA 4
PACKING LOOSE PIECE CONTACTS : 100 PCS PER STD. PACKING E.G. SM16ML11*
1
-S18 = 0.75µ GOLD MIN OVER Ni
1.3µ MINI Sn OVER Ni
1.3µ MINI Ni
(AREA 1)
(AREA 3)
(AREA 4)
-S31 = GOLD FLASH OVER Ni
1.3µ MINI Ni
(AREA 1)
(AREA 3)
(AREA 4)
-D70REV = 0.13µ GOLD MIN. OVER Ni
1.3µ MINI Ni
CONNECTOR ACCOMMODATION
(AREA 1)
(AREA 3)
(AREA 4)
See
Wiew
O
DATE
L
K
J
Update drawing
Latest modification - by:
COURTOIS L.
I
Date:
ROUILLARD Ch
CUSTOMER DRAWING
03/04/2019
SM--M--Dimensions in mm
General linear
Tolerances:
0.1
NPRDS / PROJECT
TRIM TRIO
www.esterline-connection-technologies.com
H
G
F
E
A1
C
B
Country
FR
1
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SOURIAU DRG N°
BS-C-200178-001
FORMAT
D
MOD N
MALE FORMED TWO PIECE CONTACT
4/1
CURRENT RATING : 13 A
CONTACT RETENTION IN BODY : 65 N MIN.
CONTACT RESISTANCE :
很抱歉,暂时无法提供与“SM16M11S6REV”相匹配的价格&库存,您可以联系我们找货
