Han-Modular® HMC
Features
Technical characteristics
• Multi-faceted connector system consisting of
modules, contacts, frames, hoods and housings
• Designed for 10,000 mating cycles
• Numerous possible combinations of power,
data and signal
• Space saving due to combination of different
transmission media in one single connector
Specifications DIN EN 60 664-1
DIN EN 61 984
Approvals
Inserts
Number of contacts
2 ... 25
Rated current
4 ... 40 A
Rated voltage
50 ... 830 V
Pollution degree
3
Material Polycarbonate
Material outer conductor
Zinc alloy HMC
Limiting temperatures
- 40 °C ... +125 °C
Flammability acc. to UL 94
V0
Mechanical working life
- mating cycles
≥ 10,000
Contacts Han® C HMC
Material
Surface
Contact resistance
Crimp terminal
- mm²
- AWG
Copper alloy
HMC gold plated
≤ 1 mΩ
1.5 ... 10 mm²
16 ... 8
Contacts Han D® HMC
Material
Surface
Contact resistance
Crimp terminal
- mm²
- AWG
Copper alloy
HMC gold plated
≤ 3 mΩ
0.14 ... 2.5 mm²
26 ... 14
Contacts Han E® HMC
Material
Surface
Contact resistance
Crimp terminal
- mm²
- AWG
Copper alloy
HMC gold plated
≤ 1 mΩ
0.14 ... 4 mm²
26 ... 12
Contacts D-Sub HMC
Material
Surface
Contact resistance
Crimp terminal
- mm²
- AWG
Copper alloy
HMC gold plated
≤ 10 mΩ
0.08 ... 0.52 mm²
28 ... 20
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495
www.HARTING.com | electric@HARTING.com
Han®
2015-08-08
Data Sheet 0939
Summary Han-Modular® HMC
Series
Han E® module
Han® EE module
Han E® Protected module
Han® EEE module
6
8
6
Modules
Crimp terminal
Crimp terminal
Crimp terminal
Crimp terminal
Rated current
Rated voltage
Wire gauge
16 A
500 V
0.14 ... 4 mm²
16 A
400 V
0.14 ... 4 mm²
16 A
830 V
0.14 ... 4 mm²
16 A
500 V
0.14 ... 4 mm²
Male insert (M)
09 14 006 3001
09 14 008 3001
09 14 006 3041
09 14 020 3001
Female insert (F)
09 14 006 3101
09 14 008 3101
09 14 006 3141
09 14 020 3101
Han DD® module
Han® DDD module
Han® High Density module
12
17
25
Modules
Crimp terminal
Crimp terminal
Crimp terminal
Rated current
Rated voltage
Wire gauge
10 A
250 V
0.14 ... 2.5 mm²
10 A
160 V
0.14 ... 2.5 mm²
4A
50 V
0.08 ... 0.52 mm²
Male insert (M)
09 14 012 3001
09 14 017 3001
09 14 025 3001
Female insert (F)
09 14 012 3101
09 14 017 3101
09 14 025 3101
Han® 40 A Crimp module
Han® C module
Han® CC Protected module
Han® CD module
2
3
4
3/4
Modules
Crimp terminal
Crimp terminal
Crimp terminal
Crimp terminal
Rated current
Rated voltage
Wire gauge
40 A
1000 V
1.5 ... 10 mm²
40 A
690 V
1.5 ... 10 mm²
40 A
830 V
1.5 ... 6 mm²
40 A / 10 A
830 V / 830 V
0.15 ... 6 mm² / 0.14 … 2.5 mm²
Male insert (M)
09 14 002 3002
09 14 003 3001
09 14 004 3041
09 14 007 3001
Female insert (F)
09 14 002 3102
09 14 003 3101
09 14 004 3141
09 14 007 3101
Number of contacts
Series
Number of contacts
Series
Number of contacts
Series
Han® GigaBit HMC module
Han® MegaBit HMC module
Han® Shielded HMC module
8
2x4
2x4
Termination
Crimp termination
Crimp termination
Crimp termination
Crimp termination
Wire gauge
Ethernet Cat. 6A
0.08 ... 0.52 mm²
Ethernet Cat. 5e
0.14 ... 2.5 mm²
Ethernet Cat. 5e
0.14 ... 2.5 mm²
0.08 ... 0.52 mm²
Male insert (M)
09 14 208 3011
09 14 208 3016
09 14 208 3017
09 14 220 3013
Female insert (F)
09 14 208 3111
09 14 208 3116
09 14 208 3117
09 14 220 3113
Hinged frame HMC 6 B
Hinged frame HMC 10 B
Hinged frame HMC 16 B
Hinged frame HMC 24 B
2
3
4
6
Marking (A...F)
09 14 206 0303
09 14 210 0303
09 14 216 0303
09 14 224 0303
Marking (a...f)
09 14 206 0313
09 14 210 0313
09 14 216 0313
09 14 224 0313
Docking frame 6 B
Docking frame 10 B
Docking frame 16 B
Docking frame 24 B
2
3
4
6
Marking (A...F)
09 14 006 1701
09 14 010 1701
09 14 016 1701
09 14 024 1701
Marking (a...f)
09 14 006 1711
09 14 010 1711
09 14 016 1711
09 14 024 1711
Numbers of contacts
Series
Number of modules
Series
Number of modules
Han-Modular® HMC contacts
Wire gauge
Partnumber
Identification
mm²
Male contact
Female contact
Drawing
Dimensions in mm
Han® C HMC Crimp
contact
HMC gold plated for 40 A
1.5
2.5
4.0
6.0
10.0
09 32 200 6114
09 32 200 6115
09 32 200 6119
09 32 200 6118
09 32 200 6117
09 32 200 6224
09 32 200 6225
09 32 200 6229
09 32 200 6228
09 32 200 6227
Wire gauge
1.5 mm²
2.5 mm²
4 mm²
6 mm²
10 mm²
Han E® HMC Crimp
contact
HMC gold plated for 16 A
AWG 16
AWG 14
AWG 12
AWG 10
AWG 8
Ø
Stripping
length
1.75
2.25
2.85
3.5
4.3
9.5 mm
9.5 mm
9.5 mm
9.5 mm
15 mm
Operating contact
identification
0.14-0.37
0.5
0.75
1
1.5
2.5
4
09 33 200 6117
09 33 200 6122
09 33 200 6115
09 33 200 6118
09 33 200 6116
09 33 200 6123
09 33 200 6119
09 33 200 6217
09 33 200 6222
09 33 200 6215
09 33 200 6218
09 33 200 6216
09 33 200 6223
09 33 200 6221
Identification
Stripping
length
Wire gauge
no groove 0.14-0.37 mm² AWG 26-22
no groove
0.5 mm² AWG 20
1 groove*
0.75 mm² AWG 18
1 groove
1 mm² AWG 18
2 groove
1.5 mm² AWG 16
3 groove
2.5 mm² AWG 14
wide groove
3 mm² AWG 12
no groove
4 mm² AWG 12
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
* on the rear crimp collar
Han D® HMC Crimp
contact
HMC gold plated for 10 A
0.14-0.37
0.5
0.75
1
1.5
2.5
09 15 200 6124
09 15 200 6123
09 15 200 6125
09 15 200 6122
09 15 200 6121
09 15 200 6126
09 15 200 6224
09 15 200 6223
09 15 200 6225
09 15 200 6222
09 15 200 6221
09 15 200 6226
0.08-0.21
0.13-0.33
0.21-0.52
09 67 000 7570
09 67 000 5570
09 67 000 8570
09 67 000 7470
09 67 000 5470
09 67 000 8470
Wire gauge
0.14-0.37 mm²
0.5 mm²
0.75 mm²
1 mm²
1.5 mm²
2.5 mm²
AWG 26-22
AWG 20
AWG 18
AWG 18
AWG 16
AWG 14
Ø
Stripping
length
0.9
1.1
1.3
1.45
1.75
2.25
8 mm
8 mm
8 mm
8 mm
8 mm
6 mm
D-Sub HMC
Crimp contact
HMC gold plated for
data transmission
Wire gauge
Ø
Stripping
length
0.08 - 0.21 mm²
0.13 - 0.33 mm²
0.33 - 0.52 mm²
AWG 28-24
AWG 26-22
AWG 22-20
4 mm
4 mm
4 mm
很抱歉,暂时无法提供与“09142083111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+494.015661+61.73205
- 10+419.9046110+52.47116
- 25+393.6254325+49.18732
- 50+374.8528850+46.84151
- 100+356.98169100+44.60833
- 250+339.96454250+42.48187
