09142083016
09142083016
    HARTING(浩亭)
    HANMEGABITHMCEINSATZSTI
09142083016 数据手册
Han-Modular® HMC Features Technical characteristics • Multi-faceted connector system consisting of modules, contacts, frames, hoods and housings • Designed for 10,000 mating cycles • Numerous possible combinations of power, data and signal • Space saving due to combination of different transmission media in one single connector Technical characteristics Specifications DIN EN 60 664-1 DIN EN 61 984 Approvals Inserts Number of contacts 2 ... 25 Rated current 4 ... 40 A Rated voltage 50 ... 830 V Pollution degree 3 Material Polycarbonate Material outer conductor Zinc alloy HMC Limiting temperatures - 40 °C ... +125 °C Flammability acc. to UL 94 V0 Mechanical working life - mating cycles ≥ 10,000 Contacts Han® C HMC Material Surface Contact resistance Crimp terminal - mm² - AWG Copper alloy HMC gold plated ≤ 1 mΩ 1.5 ... 10 mm² 16 ... 8 Contacts Han D® HMC Material Surface Contact resistance Crimp terminal - mm² - AWG Copper alloy HMC gold plated ≤ 3 mΩ 0.14 ... 2.5 mm² 26 ... 14 Contacts Han E® HMC Material Surface Contact resistance Crimp terminal - mm² - AWG Copper alloy HMC gold plated ≤ 1 mΩ 0.14 ... 4 mm² 26 ... 12 Contacts D-Sub HMC Material Surface Contact resistance Crimp terminal - mm² - AWG Copper alloy HMC gold plated ≤ 10 mΩ 0.08 ... 0.52 mm² 28 ... 20 HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com Han® 2015-08-08 Data Sheet 0939 Summary Han-Modular® HMC Series Han E® module Han® EE module Han E® Protected module Han® EEE module 6 8 6 20 Modules Crimp terminal Crimp terminal Crimp terminal Crimp terminal Rated current Rated voltage Wire gauge 16 A 500 V 0.14 ... 4 mm² 16 A 400 V 0.14 ... 4 mm² 16 A 830 V 0.14 ... 4 mm² 16 A 500 V 0.14 ... 4 mm² Male insert (M) 09 14 006 3001 09 14 008 3001 09 14 006 3041 09 14 020 3001 Female insert (F) 09 14 006 3101 09 14 008 3101 09 14 006 3141 09 14 020 3101 Han DD® module Han® DDD module Han® High Density module 12 17 25 Modules Crimp terminal Crimp terminal Crimp terminal Rated current Rated voltage Wire gauge 10 A 250 V 0.14 ... 2.5 mm² 10 A 160 V 0.14 ... 2.5 mm² 4A 50 V 0.08 ... 0.52 mm² Male insert (M) 09 14 012 3001 09 14 017 3001 09 14 025 3001 Female insert (F) 09 14 012 3101 09 14 017 3101 09 14 025 3101 Han® 40 A Crimp module Han® C module Han® CC Protected module Han® CD module 2 3 4 3/4 Modules Crimp terminal Crimp terminal Crimp terminal Crimp terminal Rated current Rated voltage Wire gauge 40 A 1000 V 1.5 ... 10 mm² 40 A 690 V 1.5 ... 10 mm² 40 A 830 V 1.5 ... 6 mm² 40 A / 10 A 830 V / 830 V 0.15 ... 6 mm² / 0.14 … 2.5 mm² Male insert (M) 09 14 002 3002 09 14 003 3001 09 14 004 3041 09 14 007 3001 Female insert (F) 09 14 002 3102 09 14 003 3101 09 14 004 3141 09 14 007 3101 Number of contacts Series Number of contacts Series Number of contacts Summary Han-Modular® HMC Series Han® GigaBit HMC module Han® MegaBit HMC module Han® MegaBit HMC module Han® Shielded HMC module 8 2x4 2x4 20 Termination Crimp termination Crimp termination Crimp termination Crimp termination Wire gauge Ethernet Cat. 6A 0.08 ... 0.52 mm² Ethernet Cat. 5e 0.14 ... 2.5 mm² Ethernet Cat. 5e 0.14 ... 2.5 mm² 0.08 ... 0.52 mm² Male insert (M) 09 14 208 3011 09 14 208 3016 09 14 208 3017 09 14 220 3013 Female insert (F) 09 14 208 3111 09 14 208 3116 09 14 208 3117 09 14 220 3113 Hinged frame HMC 6 B Hinged frame HMC 10 B Hinged frame HMC 16 B Hinged frame HMC 24 B 2 3 4 6 Marking (A...F) 09 14 206 0303 09 14 210 0303 09 14 216 0303 09 14 224 0303 Marking (a...f) 09 14 206 0313 09 14 210 0313 09 14 216 0313 09 14 224 0313 Docking frame 6 B Docking frame 10 B Docking frame 16 B Docking frame 24 B 2 3 4 6 Marking (A...F) 09 14 006 1701 09 14 010 1701 09 14 016 1701 09 14 024 1701 Marking (a...f) 09 14 006 1711 09 14 010 1711 09 14 016 1711 09 14 024 1711 Numbers of contacts Series Number of modules Series Number of modules Han-Modular® HMC contacts Wire gauge Partnumber Identification mm² Male contact Female contact Drawing Dimensions in mm Han® C HMC Crimp contact HMC gold plated for 40 A 1.5 2.5 4.0 6.0 10.0 09 32 200 6114 09 32 200 6115 09 32 200 6119 09 32 200 6118 09 32 200 6117 09 32 200 6224 09 32 200 6225 09 32 200 6229 09 32 200 6228 09 32 200 6227 Wire gauge 1.5 mm² 2.5 mm² 4 mm² 6 mm² 10 mm² Han E® HMC Crimp contact HMC gold plated for 16 A AWG 16 AWG 14 AWG 12 AWG 10 AWG 8 Ø Stripping length 1.75 2.25 2.85 3.5 4.3 9.5 mm 9.5 mm 9.5 mm 9.5 mm 15 mm Operating contact identification 0.14-0.37 0.5 0.75 1 1.5 2.5 4 09 33 200 6117 09 33 200 6122 09 33 200 6115 09 33 200 6118 09 33 200 6116 09 33 200 6123 09 33 200 6119 09 33 200 6217 09 33 200 6222 09 33 200 6215 09 33 200 6218 09 33 200 6216 09 33 200 6223 09 33 200 6221 Identification Stripping length Wire gauge no groove 0.14-0.37 mm² AWG 26-22 no groove 0.5 mm² AWG 20 1 groove* 0.75 mm² AWG 18 1 groove 1 mm² AWG 18 2 groove 1.5 mm² AWG 16 3 groove 2.5 mm² AWG 14 wide groove 3 mm² AWG 12 no groove 4 mm² AWG 12 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm * on the rear crimp collar Han D® HMC Crimp contact HMC gold plated for 10 A 0.14-0.37 0.5 0.75 1 1.5 2.5 09 15 200 6124 09 15 200 6123 09 15 200 6125 09 15 200 6122 09 15 200 6121 09 15 200 6126 09 15 200 6224 09 15 200 6223 09 15 200 6225 09 15 200 6222 09 15 200 6221 09 15 200 6226 0.08-0.21 0.13-0.33 0.21-0.52 09 67 000 7570 09 67 000 5570 09 67 000 8570 09 67 000 7470 09 67 000 5470 09 67 000 8470 Wire gauge 0.14-0.37 mm² 0.5 mm² 0.75 mm² 1 mm² 1.5 mm² 2.5 mm² AWG 26-22 AWG 20 AWG 18 AWG 18 AWG 16 AWG 14 Ø Stripping length 0.9 1.1 1.3 1.45 1.75 2.25 8 mm 8 mm 8 mm 8 mm 8 mm 6 mm D-Sub HMC Crimp contact HMC gold plated for data transmission Wire gauge Ø Stripping length 0.08 - 0.21 mm² 0.13 - 0.33 mm² 0.33 - 0.52 mm² AWG 28-24 AWG 26-22 AWG 22-20 4 mm 4 mm 4 mm
09142083016 价格&库存
很抱歉,暂时无法提供与“09142083016”相匹配的价格&库存,您可以联系我们找货
