09142083012
    HARTING(浩亭)
    HANGIGABITHMCINSERTMALE(SHI
09142083012 数据手册
Han® GigaBit HMC module Features Technical characteristics • Designed for 10,000 mating cycles thanks to HMC surface in mating area • Shielding bus separate from housing potential • Ideal for the transmission of sensitive signals • Suitable for Gigabit Ethernet Cat. 6A Specifications DIN EN 60 664-1 DIN EN 61 984 Han® module adapter Number of contacts 8 Insulation resistance ≥ 1010 Ω Material Polycarbonate Limiting temperatures -40 °C ... +85 °C Flammability acc. to UL 94 V0 Mechanical working life ≥ 10,000 mating cycles Han® GigaBit HMC insert Number of contacts Electrical data acc. to DIN EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree Rated voltage acc. to UL 8 + shielding 5 A 50 V 0.8 kV 3 5A 50 V 0.8 kV 3 < 30 V Material - Insulator - Outer conductor Polycarbonate Zinc alloy HMC Contact resistance ≤ 4 mΩ Limiting temperatures -40 °C ... +85 °C Mechanical working life Flammability acc. to UL 94 ≥ 10,000 mating cycles V0 Outer surface finish Nickel Cable diameter 5 ... 12 mm Han® D-Sub HMC crimp contacts Crimp terminal - mm² - AWG 0.08 ... 0.52 mm² 28 ... 20 HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com 2015-09-07 Han® Data Sheet 0959 Han® GigaBit HMC Module 50 V  5 A Number of contacts 8 Part number Identification Male insert (M) Female insert (F) Drawing Dimensions in mm Han® module adapter M 09 14 001 3011 09 14 001 3111 Identification F Wire gauge Part number mm² Male contact Female contact Drawing Dimensions in mm Han® GigaBit HMC module insert 09 14 208 3011 20 + shield Contact arrangement View termination side 09 14 208 3111 crimp contacts order separately M With additional shield connection to the hinged frame 09 14 208 3012 09 14 208 3112 F crimp contacts order separately Han® D-Sub HMC crimp contacts gold plated HMC 0,08-0,21 09 67 000 7570 09 67 000 7470 0,13-0,33 09 67 000 5570 09 67 000 5470 0,33-0,52 09 67 000 8570 09 67 000 8470 Wire gauge ø Stripping length of stranded wire 0.08 - 0.21 mm² 0.13 - 0.33 mm² 0.33 - 0.52 mm² AWG 28-24 AWG 26-22 AWG 22-20 4 mm 4 mm 4 mm Han® GigaBit Module / Accessories Identification Part number Drawing Dimensions in mm Crimp flange Crimp ferrule D1 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 D2 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 61 03 000 0062 61 03 000 0063 61 03 000 0064 61 03 000 0065 61 03 000 0066 61 03 000 0166 61 03 000 0067 61 03 000 0068 61 03 000 0069 61 03 000 0070 61 03 000 0071 61 03 000 0165 61 03 000 0072 D3 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.0 11.5 12.0 12.5 13.0 D4 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.0 11.5 12.0 12.5 13.0 13.5 14.0 61 03 000 0045 61 03 000 0046 61 03 000 0047 61 03 000 0048 61 03 000 0049 61 03 000 0050 61 03 000 0051 61 03 000 0052 61 03 000 0053 61 03 000 0054 61 03 000 0055 61 03 000 0056 61 03 000 0057 61 03 000 0058 61 03 000 0142 61 03 000 0059 61 03 000 0127 Cable clamp cable diameter approx. 5 ... 7 mm cable diameter approx. 7 ... 10 mm cable diameter approx. 10 ... 12 mm 61 03 000 0141 61 03 000 0044 61 03 000 0143 for cable Ø approx. 5 ... 7 mm for cable Ø approx. 7 ... 10 mm Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 09142083012 09142083111 09142083011 09142083112 09670007570 09670008570 09670007470 09670008470 09670005570
09142083012 价格&库存
很抱歉,暂时无法提供与“09142083012”相匹配的价格&库存,您可以联系我们找货
  • 1+555.550021+69.42137
  • 10+472.1848810+59.00409
  • 25+442.6431625+55.31256
  • 50+421.5315250+52.67446
  • 100+401.43646100+50.16339
库存:27
