73550400914
73550400914
    HARTING(浩亭)
73550400914 数据手册
HAN Port HAN Port is an interface that provides a convenient and environmentally protected method of accessing the network ports. Features & Benefits: • • • • • • HAN Port typically mounts on the outside of an enclosure. HAN Port maintains the NEMA 12/4 integrity of control systems. HAN Port provides safety and convenience to programmers and trouble-shooters. HAN Port protects control devices from unwanted substances, such as dust, dirt, oil, chemicals, etc. HAN Port is UL recognized (UR), CSA, and CE certified. HAN Port is available in 3 different termination styles, i.e. PC boards with terminal blocks, complete cable extension solutions, and bulk-head (pass-thru) connectors. HAN  Port HAN Port is the solution to meet new electrical safety requirements specified by the National Fire Protection Agency (70E Standard). The new standard, which is currently in draft form, requires employees who are within four feet of live (exposed) 50 to 600 volts to wear the following protective clothing: • Safety Glasses • Face Shield • Flame Resistant Clothing • Hand and Arm Protection (Gloves) Given the stringent requirements, HAN Port allows users to maintain convenience, safety, and efficiency. -1- HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0901 2.76 2.16 HAN Prog Port RJ45 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0914 4.05 3.49 HAN Prog Port RJ45 120VAC 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0915 5.12 4.53 HAN Prog Port RJ45 120VAC 3A 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0903 2.76 2.16 HAN Prog Port DB9F/M RJ45 1.52 1.26 .17 (Dimensions are in inches) -2- HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0905 2.76 2.16 .17 HAN Prog Port DB9M 1.52 1.26 10 FOOT CABLE ASSEMBLY (Dimensions are in inches) 73 55 040 0902 2.76 2.16 HAN Prog Port DB9F Terminal Blk 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0904 2.76 2.16 HAN Prog Port DB9F/M 1.52 1.26 .17 Rear View (Dimensions are in inches) 73 55 040 0907 4.05 3.49 HAN Prog Port DB9M RJ45 1.52 1.26 .17 (Dimensions are in inches) -3- DB9 FEMALE HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0908 4.05 3.49 HAN Prog Port DB9M 120VAC 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0913 4.05 3.49 1.52 1.26 .17  HAN Prog Port DB9F Terminal Blk 120VAC (Dimensions are in inches) 73 55 040 0923 5.12 4.53 HAN Prog Port DB9M 120VAC 3A 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0912 4.05 3.49 HAN Prog Port DB9F/M RJ45 120VAC 1.52 1.26 .17 (Dimensions are in inches) -4- HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0921 5.12 4.53 HAN Prog Port DB9M RJ45 120VAC 1.52 1.26 .17 DB9 FEMALE (Dimensions are in inches) 73 55 040 0916 4.05 3.49 HAN Prog Port DB9F Terminal Blk 120VAC 3A 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0920 5.12 4.53 HAN Prog Port DB9M RJ45 120VAC 3A 1.52 1.26 .17 DB9 FEMALE (Dimensions are in inches) 73 55 040 0906 6 FOOT CABLE ASSEMBLEY 2.76 2.16 HAN Prog Port 2x6 Pin Mini Din 1.52 1.26 .17 (Dimensions are in inches) -5- HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0910 4.05 3.49 HAN Prog Port 2x6 Pin Mini Din RJ45 1.52 1.26 .17 6 PIN MINIDIN MALE (Dimensions are in inches) 73 55 040 0911 4.05 3.49 HAN Prog Port 2x6 Pin Mini Din 120VAC 1.52 1.26 .17 6 PIN MINIDIN MALE (Dimensions are in inches) 73 55 040 0918 5.12 4.53 HAN Prog Port 2x6 Pin Mini Din 120VAC 3A 1.52 1.26 .17 6 PIN MINIDIN MALE (Dimensions are in inches) 73 55 040 0922 5.12 4.53 HAN Prog Port 2x6 Pin Mini Din DB9M 120VAC 1.52 1.26 .17 (Dimensions are in inches) -6- 6 PIN MINIDIN MALE HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0917 5.12 4.53 HAN Prog Port 2x6 Pin Mini Din RJ45 120VAC 1.52 1.26 .17 (Dimensions are in inches) 6 PIN MINIDIN MALE 73 55 040 0909 4.05 3.49 HAN Prog Port DB25F 1.52 1.26 .17 (Dimensions are in inches) 73 55 040 0919 5.12 4.53 HAN Prog Port DB25F 120VAC D825 MALE (Dimensions are in inches) 73 55 040 0924 5.82 4.67 3.28 .25 2.74 HAN Prog Port (48B) 10 FOOT CABLE 1.52 1.26 .17 (Dimensions are in inches) Without 3A Breaker -7- HAN Port Description Part Number Panel Cutout Drawing 73 55 040 0925 5.82 4.67 3.28 2.74 .25 HAN Prog Port (48B) With 3A Breaker (Dimensions are in inches) -8- HAN Port Part Number Description Page 73 55 040 0901 73 55 040 0902 73 55 040 0903 73 55 040 0904 73 55 040 0905 73 55 040 0906 73 55 040 0907 73 55 040 0908 73 55 040 0909 73 55 040 0910 73 55 040 0911 73 55 040 0912 73 55 040 0913 73 55 040 0914 73 55 040 0915 73 55 040 0916 73 55 040 0917 73 55 040 0918 73 55 040 0919 73 55 040 0920 73 55 040 0921 73 55 040 0922 73 55 040 0923 73 55 040 0924 73 55 040 0925 HAN Prog Port RJ45 HAN Prog Port DB9F Terminal Blk HAN Prog Port DB9F/M RJ45 HAN Prog Port DB9F/M HAN Prog Port DB9M HAN Prog Port 2x6pin mini Din HAN Prog Port DB9M RJ45 HAN Prog Port DB9M 120VAC HAN Prog Port DB25F HAN Prog Port 2x6pin mini Din RJ45 HAN Prog Port 2x6 pin mini Din 120VAC HAN Prog Port DB9F/M RJ45 120VAC HAN Prog Port DB9F Terminal Blk 120 VAC HAN Prog Port RJ45 120VAC HAN Prog Port RJ45 120VAC 3A HAN Prog Port DB9F Term Blk 120VAC 3A HAN Prog Port 2x6pin mini Din RJ45 120VAC HAN Prog Port 2x6pin mini Din 120VAC 3A HAN Prog Port DB25F 120VAC HAN Prog Port DB9M RJ45 120VAC 3A HAN Prog Port DB9M RJ45 120VAC HAN Prog Port 2x6pin mini Din DB9M 120VAC HAN Prog Port DB9M 120VAC 3A HAN Prog Port (48B) HAN Prog Port (48B) -9- 2 3 2 3 3 5 3 4 7 6 6 4 4 2 2 5 7 6 7 5 5 6 4 7 8 - 10 -
73550400914 价格&库存
很抱歉,暂时无法提供与“73550400914”相匹配的价格&库存,您可以联系我们找货
  • 1+1124.060711+145.69967
  • 10+955.5038710+123.85150
  • 30+884.2934530+114.62127
  • 50+853.0269250+110.56853
  • 100+812.37447100+105.29920
库存:12
