111-0107-001
111-0107-001
    CINCH
111-0107-001 数据手册
Binding Post Insulated Standard SPECIFICATIONS Stud: Brass per QQ-B-626D Finish: Silver Insulating Material: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 6.0 lb. in. (7.0 kg cm) Panel Thickness: Up to .281 (7.15) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 15 amps Contact Resistance: 0.010 ohms maximum Breakdown Voltage: 5700 Vrms minimum Stud-to-Panel: 3.3 pF nominal SILVER PLATING 111-0107-001 Yellow For Standard Banana Plug: .175 (4.44) Dia. FEATURES: • Turret terminal • Captive thumb nut • Insulated body is flatted to prevent turning • Nylon UL approved for self-extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
111-0107-001 价格&库存
很抱歉,暂时无法提供与“111-0107-001”相匹配的价格&库存,您可以联系我们找货
  • 1+102.338201+13.26498
  • 10+86.9821410+11.27455
  • 25+81.5303625+10.56789
  • 50+77.6389150+10.06348
  • 100+73.93269100+9.58309
  • 300+68.42125300+8.86870
  • 500+66.00128500+8.55503
  • 1000+62.854871000+8.14719
库存:1112
