108-0910-001
108-0910-001
    CINCH
108-0910-001 数据手册
Banana Jack Insulated Solder Terminal SPECIFICATIONS Contact: Formed brass per QQ-B-626D Finish: Bright tin Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 6.0 lb. in. (7kg. cm.) Panel Thickness: Up to .343 (8.80) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 15 amps Breakdown Voltage: 7000 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel: 2.4 pF nominal BRIGHT TIN PLATING 108-0910-001 Blue For Standard Banana Plug: .175 (4.44) Across Flats FEATURES: • Keyed mounting with double flats • Accepts up to 16 gauge wire • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
108-0910-001 价格&库存
很抱歉,暂时无法提供与“108-0910-001”相匹配的价格&库存,您可以联系我们找货
  • 1+95.826161+12.42090
  • 10+81.4666210+10.55963
  • 25+76.3595225+9.89765
  • 50+72.7132050+9.42502
  • 100+69.24253100+8.97515
  • 250+64.90945250+8.41350
  • 500+61.81385500+8.01226
  • 1000+58.867001000+7.63029
库存:8249
