108-0753-001
108-0753-001
    CINCH
108-0753-001 数据手册
Banana Plug Uninsulated Panel Mount Screw Type, Nickel Silver Spring INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST SPECIFICATIONS Plug Body: Brass per QQ-B-626D Plug Spring: Nickel silver per QQ-C-585 Finish: Silver Panel Thickness: Up to .125 (3.20) Hardware: Nickel plated screw, stamped tin plated solder terminal (unassembled) RATINGS Current: 15 amps Contact Resistance: 0.010 ohms maximum NICKEL PLATING 108-0753-001 For Standard Banana Jack: .166 (4.23) Diameter FEATURES: • Rugged screw type • Stamped tin plated solder terminal with hole for up to 14 gauge wire Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
108-0753-001 价格&库存
很抱歉,暂时无法提供与“108-0753-001”相匹配的价格&库存,您可以联系我们找货
  • 20+47.7897120+6.19446
  • 50+41.8580450+5.42560
  • 100+29.27256100+3.79428
  • 250+26.76945250+3.46983
  • 500+24.94032500+3.23274
库存:10520
108-0753-001
  • 5+36.132695+4.68349
库存:1608
