108-0908-001
108-0908-001
    CINCH
108-0908-001 数据手册
Banana Jack Insulated Solder Terminal SPECIFICATIONS Contact: Formed brass per QQ-B-626D Finish: Bright tin Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 6.0 lb. in. (7kg. cm.) Panel Thickness: Up to .343 (8.80) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 15 amps Breakdown Voltage: 7000 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel: 2.4 pF nominal BRIGHT TIN PLATING 108-0908-001 Brown For Standard Banana Plug: .175 (4.44) Across Flats FEATURES: • Keyed mounting with double flats • Accepts up to 16 gauge wire • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
108-0908-001 价格&库存
很抱歉,暂时无法提供与“108-0908-001”相匹配的价格&库存,您可以联系我们找货
    • 7+12.822817+1.66208
    • 14+8.0142614+1.03880
    • 62+4.8085662+0.62328
    库存:108
    108-0908-001
    • 1+15.274781+1.97991
    • 10+13.0161210+1.68714
    • 25+12.1963425+1.58088
    • 50+11.6139650+1.50539
    • 100+11.05815100+1.43335
    • 300+10.23315300+1.32641
    • 500+9.87063500+1.27942
    • 1000+9.399571000+1.21837
    • 2500+8.811272500+1.14211
    库存:1189
