105-0754-001
105-0754-001
    CINCH
105-0754-001 数据手册
Horizontal Test Jack Insulated Standard SPECIFICATIONS Contact: Copper aluminum alloy* Finish: Gold or Silver Body: Nylon 6/6 per ASTM D4066 RATINGS Current: 5 amps Breakdown Voltage: 2100 Vrms minimum Contact Resistance: Gold: 0.005 ohms maximum Silver: 0.010 ohms maximum Adjacent Jack C: 1 pF maximum at 1 MHz INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST SILVER PLATING 105-0754-001 Green For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Contact protected from flux and solder • Probe access from both ends or top • Nylon UL approved for self extinguishing * A new material development that, for this application, meets or exceeds beryllium copper. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-0754-001
物料型号:105-0754-001 器件简介:水平测试插孔,绝缘标准 引脚分配:未提供详细信息 参数特性: - 电流:5安培 - 断路电压:最小2100 Vrms - 接触电阻:金:最大0.005欧姆,银:最大0.010欧姆 - 相邻插孔电容:最大1pF(1 MHz) 功能详解:接触点可防止焊剂和焊料的侵蚀,探针可以从两端或顶部访问,尼龙材料符合UL自熄标准。
应用信息:适用于标准尖端插头,直径为0.080英寸(2.00毫米)。
封装信息:绿色,镀银
请注意,这是根据提供的PDF文档内容进行的分析,可能不包含所有详细信息。
如果需要更详细的数据或规格,建议直接联系Cinch Connectivity Solutions。
105-0754-001 价格&库存
很抱歉,暂时无法提供与“105-0754-001”相匹配的价格&库存,您可以联系我们找货
  • 1+13.021521+1.68784
  • 10+11.0939710+1.43799
  • 25+10.5501825+1.36751
库存:728
105-0754-001
  • 1+13.270901+1.69020
  • 10+12.4546010+1.58630
  • 25+11.6499025+1.48380
  • 50+11.1135050+1.41540
  • 100+10.57710100+1.34710
  • 250+9.94730250+1.26690
  • 500+9.31760500+1.18670
  • 1000+8.816201000+1.12290
  • 2500+8.256402500+1.05160
库存:276
105-0754-001
  • 1+15.562991+2.01726
  • 10+13.2071910+1.71191
  • 25+12.3761025+1.60418
  • 50+11.7858250+1.52767
  • 100+11.22147100+1.45452
  • 250+10.51849250+1.36340
  • 500+10.01618500+1.29829
  • 1000+9.538031000+1.23631
  • 2500+8.941102500+1.15894
库存:728
105-0754-001
  • 8+13.303288+1.72436
  • 10+11.3335810+1.46905
  • 25+10.7790925+1.39718
库存:728
105-0754-001
  • 50+14.1360850+1.83231
  • 250+8.23028250+1.06680
  • 500+7.62921500+0.98889
  • 1000+7.096181000+0.91980
库存:1875
