105-0810-001
105-0810-001
    CINCH
105-0810-001 数据手册
Tip Jack Insulated Standard SPECIFICATIONS: Contact: Phosphor bronze per QQ-B-750 Finish: Bright tin Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 4.0 lb. in. (4.5 kg. cm.) Panel Thickness: Up to .437 (11.10) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 10 amps Breakdown Voltage: 5700 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel C: 2 pF nominal BRIGHT TIN PLATING 105-0810-001 Blue For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Formed contact with slotted terminal • Hex socket head .188 (4.77) for ease in mounting • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-0810-001 价格&库存
很抱歉,暂时无法提供与“105-0810-001”相匹配的价格&库存,您可以联系我们找货
    • 100+14.58095100+1.88997
    • 300+10.03510300+1.30074
    • 500+9.56770500+1.24016
    • 1000+8.205161000+1.06355
    • 2500+7.577362500+0.98217
    库存:3900
    105-0810-001
      • 17+11.6441317+1.50930
      库存:236
      105-0810-001
      • 1+15.812941+2.04966
