Tip Jacks
Insulated Standard: Rib-Loc® Type
SPECIFICATIONS
Contact: Brass body per QQ-B-626D with
wrap around beryllium copper
spring per QQ-C-553
Finish: Silver
Body: Nylon 6/6 per ASTM D4066
Panel Thickness: Up to .375 (9.05)
INCHES (MILLIMETERS)
CUSTOMER DRAWINGS AVAILABLE UPON REQUEST
RATINGS
Current: 5 amps
Breakdown Voltage: 3500 Vrms minimum
Contact Resistance: 0.005 ohms maximum
Adjacent Jack C: 1 pF nominal
SILVER PLATING
105-1041-001 White
For Standard Tip Plug: .080 (2.00) Diameter
FEATURES:
• Machined contact with turret terminal
• Installs by pressing into mounting hole, no mounting hardware required
• Closed entry blocks access or probes greater than .085 (2.16)
• Nylon UL approved for self extinguishing
Cinch Connectivity Solutions
299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
很抱歉,暂时无法提供与“105-1041-001”相匹配的价格&库存,您可以联系我们找货
