108-0913-001
108-0913-001
    CINCH
108-0913-001 数据手册
Banana Jack Insulated Solder Terminal SPECIFICATIONS Contact: Formed brass per QQ-B-626D Finish: Bright tin Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 6.0 lb. in. (7kg. cm.) Panel Thickness: Up to .343 (8.80) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 15 amps Breakdown Voltage: 7000 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel: 2.4 pF nominal BRIGHT TIN PLATING 108-0913-001 Gray For Standard Banana Plug: .175 (4.44) Across Flats FEATURES: • Keyed mounting with double flats • Accepts up to 16 gauge wire • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
108-0913-001 价格&库存
很抱歉,暂时无法提供与“108-0913-001”相匹配的价格&库存,您可以联系我们找货
  • 1+15.582151+2.01725
  • 10+13.2176010+1.71114
  • 25+12.3862725+1.60351
  • 50+11.7954550+1.52703
  • 100+11.23069100+1.45391
  • 250+10.52704250+1.36282
  • 500+10.02434500+1.29774
  • 1000+9.545811000+1.23579
  • 2500+8.948392500+1.15845
库存:1780
