105-1050-001
105-1050-001
    CINCH
105-1050-001 数据手册
Tip Jacks Insulated Standard: Rib-Loc® Type SPECIFICATIONS Contact: Brass body per QQ-B-626D with wrap around beryllium copper spring per QQ-C-553 Finish: Silver Body: Nylon 6/6 per ASTM D4066 Panel Thickness: Up to .375 (9.05) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 5 amps Breakdown Voltage: 3500 Vrms minimum Contact Resistance: 0.005 ohms maximum Adjacent Jack C: 1 pF nominal SILVER PLATING 105-1050-001 Blue For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Machined contact with turret terminal • Installs by pressing into mounting hole, no mounting hardware required • Closed entry blocks access or probes greater than .085 (2.16) • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-1050-001 价格&库存
很抱歉,暂时无法提供与“105-1050-001”相匹配的价格&库存,您可以联系我们找货
