105-0202-200
105-0202-200
    CINCH
105-0202-200 数据手册
Tip Jack Insulated Metal Clad: Military Type SPECIFICATIONS Contact: Brass per QQ-B-626D with wrap around beryllium copper spring per QQ-C-533 Finish: Gold Body: Nylon 6/6 per ASTM D4066 Threaded Brass Jacket: Per QQ-B-626D, nickel plated Hardware: Nickel plated washer and nut (unassembled) Panel Thickness: Up to .218 (5.45) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 10 amps Breakdown Voltage: 5700 Vrms minimum Contact Resistance: 0.004 ohms maximum Contact-To-Panel C: 2 pF nominal Manufactured to meet MIL-C-39024/10 GOLD PLATING JCI PART NO. TO MIL-SPEC. PART NO. CROSS REFERENCE PART NO. 105-0202-200 COLOR Red MIL-C-39024/10 -02 For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Machined contact with turret terminal • For military or industrial applications • Closed entry blocks access of probes greater than .085 (2.16) • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-0202-200
物料型号:105-0202-200
器件简介:该文档描述的是一种符合MIL-C-39024/10标准的绝缘金属包层(Insulated Metal Clad)的Tip Jack,适用于军事或工业应用。
引脚分配:文档中没有明确提供引脚分配的详细信息。
参数特性: - 电流:10安培 - 击穿电压:至少5700 Vrms - 接触电阻:最大0.004欧姆 - 接触至面板电容:名义上2皮法拉
功能详解:该Tip Jack具有以下特点: - 机械加工的接触带有涡轮终端 - 封闭的入口阻止了大于0.085英寸(2.16毫米)的探针进入 - 尼龙材料符合UL标准,具有自熄性
应用信息:适用于军事或工业应用。
封装信息:文档中提供了一些尺寸信息,例如面板厚度可达0.218英寸(5.45毫米),但未提供完整的封装信息
105-0202-200 价格&库存
很抱歉,暂时无法提供与“105-0202-200”相匹配的价格&库存,您可以联系我们找货
