BU-31104-@
(Insulated, Stackable Banana Plug)
• The BU-31104-@ is a fully insulated, stackable 4mm Banana plug. It can be
plugged into any standard 4mm banana jack that accepts shrouded banana
plugs. The Jack end will accept shrouded, un-shrouded, or retractable 4mm
banana. This part is designed to be soldered to wire from 16-22 AWG and
then simply snaps together. The banana plug has a plastic safety tip.
• Overall length of 2.1” (53mm), Width of 0.73” (19mm), and Height of 0.45”
(11mm)
• Material:
o Banana – Nickel plated beryllium copper
o Insulator – Polypropylene
• Rating:
o Current – 40 Amps
o 1,000 V CAT III
• Color: The “@” in the model number indicates color.
Available colors are: -0 Black, -2 Red
• RoHS 3 Compliant.
Mueller Electric Company
2850 Gilchrist Rd. Bld 5A
Akron, OH 44305
www.muellerelectric.com
Toll Free: 800.955.2629
Phone: 330.780.2525
Fax: 330.780.2524
Assembly Instructions
1) Thread wire thru offset hole of housing and solder into cross hole in Banana Plug.
2) Align the Banana plug into the housing as shown
3) Snap together
Akron, OH 44305
Phone: 330.780.2525
Fax: 330.780.2524
很抱歉,暂时无法提供与“BU-31104-2”相匹配的价格&库存,您可以联系我们找货
