105-0603-001
105-0603-001
    CINCH
105-0603-001 数据手册
Tip Jack Insulated Deluxe SPECIFICATIONS Contact: Brass per QQ-B-626D with wrap around beryllium copper spring per QQ-C-533 Finish: Silver Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 0.4 lb. in (4.5 kg. cm.) Panel Thickness: Up to .437 (11.10) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 10 amps Breakdown Voltage: 5700 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel C: 2 pF nominal SILVER PLATING PART NO. COLOR 105-0603-001 Black For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Machined contact with turret terminal • Hex socket head .188 (4.77) for ease in mounting • Closed entry blocks access of probes greater than .085 (2.16) • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-0603-001 价格&库存
很抱歉,暂时无法提供与“105-0603-001”相匹配的价格&库存,您可以联系我们找货
  • 1+27.368451+3.55660
  • 10+23.2162910+3.01702
  • 25+21.7613325+2.82794
  • 50+20.7222250+2.69291
  • 100+19.73150100+2.56416
  • 250+18.49570250+2.40357
  • 500+17.61279500+2.28883
  • 1000+16.772441000+2.17962
  • 2500+15.723192500+2.04327
库存:1246
