108-2302-621
108-2302-621
    CINCH
108-2302-621 数据手册
Banana Jack Insulated Turret Terminal SPECIFICATIONS Contact: Machined brass per QQ-B-626D Finish: Silver Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 6.0 lb. in. (7kg. cm.) Panel Thickness: Up to .343 (8.80) RATINGS Current: 15 amps Breakdown Voltage: 7000 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel: 2.4 pF nominal INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST SILVER PLATING 108-2302-621 Red For Standard Banana Plug: .175 (4.44) Across Flats FEATURES: • Keyed mounting with double flats • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
108-2302-621 价格&库存
很抱歉,暂时无法提供与“108-2302-621”相匹配的价格&库存,您可以联系我们找货
  • 98+18.4709298+2.39419
库存:98
108-2302-621
  • 1+19.348221+2.50790
