BU-00233-0
BU-00233-0
    MUELLERELECTRIC
    Banana Jack Connector Standard Banana Press-Fit Black
BU-00233-0 数据手册
BU-00233-@ (Insulated 4mm Banana Jack) • The BU-00223 is an insulated, panel mount 4mm banana jack with solder tab connection. The jack accepts unshrouded and retractable 4mm banana plugs only. • Overall length 0.67” (17mm), insulator extends 0.25” (6.4mm) above panel surface • Can be connected to wire up to 18 AWG via solder tab connection. • Mounting: Can be mounted on panels up to 0.25” (6.4mm) thick. Recommended mounting hole = Ø 0.25” (6.4mm) • Material: Banana jack Nickel-plated brass Insulator Nylon • Rating: Current 15 Amps • Color: The “@” in the model number indicates color. Available colors are: -0 Black, -2 Red • RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-00233-0 价格&库存
很抱歉,暂时无法提供与“BU-00233-0”相匹配的价格&库存,您可以联系我们找货
