105-0604-001
105-0604-001
    CINCH
    绝缘豪华型产品电气性能
105-0604-001 数据手册
Tip Jack Insulated Deluxe SPECIFICATIONS Contact: Brass per QQ-B-626D with wrap around beryllium copper spring per QQ-C-533 Finish: Silver Body: Nylon 6/6 per ASTM D4066 Hardware: Nickel plated nut (unassembled) Body Thread Stripping Torque: 0.4 lb. in (4.5 kg. cm.) Panel Thickness: Up to .437 (11.10) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 10 amps Breakdown Voltage: 5700 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel C: 2 pF nominal SILVER PLATING PART NO. COLOR 105-0604-001 Green For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Machined contact with turret terminal • Hex socket head .188 (4.77) for ease in mounting • Closed entry blocks access of probes greater than .085 (2.16) • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-0604-001 价格&库存
很抱歉,暂时无法提供与“105-0604-001”相匹配的价格&库存,您可以联系我们找货
  • 1+26.623401+3.39080
  • 10+23.0317010+2.93340
  • 25+21.1541025+2.69430
  • 50+20.5244050+2.61400
  • 100+19.35830100+2.46550
  • 250+18.19210250+2.31700
  • 500+17.38740500+2.21450
  • 1000+15.591601000+1.98580
  • 2500+14.518702500+1.84910
库存:297
