Tip Jack
Insulated Deluxe
SPECIFICATIONS
Contact: Brass per QQ-B-626D with wrap around
beryllium copper spring per QQ-C-533
Finish: Silver
Body: Nylon 6/6 per ASTM D4066
Hardware: Nickel plated nut (unassembled)
Body Thread Stripping Torque: 0.4 lb. in (4.5 kg. cm.)
Panel Thickness: Up to .437 (11.10)
INCHES (MILLIMETERS)
CUSTOMER DRAWINGS AVAILABLE UPON REQUEST
RATINGS
Current: 10 amps
Breakdown Voltage: 5700 Vrms minimum
Contact Resistance: 0.010 ohms maximum
Contact-To-Panel C: 2 pF nominal
SILVER PLATING
PART NO.
105-0607-001
COLOR
Yellow
For Standard Tip Plug: .080 (2.00) Diameter
FEATURES:
• Machined contact with turret terminal
• Hex socket head .188 (4.77) for ease in mounting
• Closed entry blocks access of probes greater than .085 (2.16)
• Nylon UL approved for self extinguishing
Cinch Connectivity Solutions
299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
很抱歉,暂时无法提供与“105-0607-001”相匹配的价格&库存,您可以联系我们找货
