105-0204-200
105-0204-200
    CINCH
105-0204-200 数据手册
Tip Jack Insulated Metal Clad: Military Type SPECIFICATIONS Contact: Brass per QQ-B-626D with wrap around beryllium copper spring per QQ-C-533 Finish: Gold Body: Nylon 6/6 per ASTM D4066 Threaded Brass Jacket: Per QQ-B-626D, nickel plated Hardware: Nickel plated washer and nut (unassembled) Panel Thickness: Up to .218 (5.45) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST RATINGS Current: 10 amps Breakdown Voltage: 5700 Vrms minimum Contact Resistance: 0.004 ohms maximum Contact-To-Panel C: 2 pF nominal Manufactured to meet MIL-C-39024/10 GOLD PLATING JCI PART NO. TO MIL-SPEC. PART NO. CROSS REFERENCE PART NO. 105-0204-200 COLOR Green MIL-C-39024/10 -05 For Standard Tip Plug: .080 (2.00) Diameter FEATURES: • Machined contact with turret terminal • For military or industrial applications • Closed entry blocks access of probes greater than .085 (2.16) • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
105-0204-200 价格&库存
很抱歉,暂时无法提供与“105-0204-200”相匹配的价格&库存,您可以联系我们找货
  • 30+42.83117
库存:58
105-0204-200
  • 1+76.128281+9.86768
  • 10+73.2763710+9.49802
  • 20+55.8607420+7.24062
库存:33
105-0204-200
  • 2+77.455582+10.03972
  • 10+74.5542210+9.66365
  • 20+56.8344320+7.36683
库存:33
105-0204-200
  • 1+89.817601+11.43940
  • 10+81.7478010+10.41160
  • 20+74.8441020+9.53240
  • 50+72.1620050+9.19080
  • 100+69.46820100+8.84770
  • 200+64.25540200+8.18380
  • 500+62.01640500+7.89860
  • 1000+56.745301000+7.22730
库存:143
105-0204-200
  • 10+133.8462010+17.34902
  • 25+85.2108725+11.04495
  • 50+79.8984550+10.35636
  • 100+72.09427100+9.34479
  • 300+67.02650300+8.68791
库存:1250
