108-2301-801
108-2301-801
    CINCH
108-2301-801 数据手册
Banana Jack Insulated Rib-Loc® Solder Terminal SPECIFICATIONS Contact: Formed brass per QQ-B-626D Finish: Bright tin Body: Nylon 6/6 per ASTM D4066 Panel Thickness: Up to .250 (6.35) RATINGS Current: 15 amps Breakdown Voltage: 7000 Vrms minimum Contact Resistance: 0.010 ohms maximum Contact-To-Panel C: 2.4 pF nominal INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST BRIGHT TIN PLATING 108-2301-801 White For Standard Banana Plug: .175 (4.44) Across Flats FEATURES: • Requires no mounting hardware • Accepts up to 16 gauge wire • Nylon UL approved for self extinguishing Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
108-2301-801 价格&库存
很抱歉,暂时无法提供与“108-2301-801”相匹配的价格&库存,您可以联系我们找货
  • 500+8.65584500+1.12058
