Banana Jack Insulated Rib-Loc® Solder Terminal
SPECIFICATIONS
Contact: Formed brass per QQ-B-626D
Finish: Bright tin
Body: Nylon 6/6 per ASTM D4066
Panel Thickness: Up to .250 (6.35)
RATINGS
Current: 15 amps
Breakdown Voltage: 7000 Vrms minimum
Contact Resistance: 0.010 ohms maximum
Contact-To-Panel C: 2.4 pF nominal
INCHES (MILLIMETERS)
CUSTOMER DRAWINGS AVAILABLE UPON REQUEST
BRIGHT TIN PLATING
108-2310-801 Blue
For Standard Banana Plug:
.175 (4.44) Across Flats
FEATURES:
• Requires no mounting hardware
• Accepts up to 16 gauge wire
• Nylon UL approved for self extinguishing
Johnson ComponentsTM • P.O. Box 1732 • Waseca, MN 56093-0832 • 1-800-247-8256 • Fax: 507-833-6287 • www.cinchconnectivity.com
很抱歉,暂时无法提供与“108-2310-801”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+8.65584500+1.12058
