BU-31602-2
BU-31602-2
    MUELLERELECTRIC
    BU-31602-2
BU-31602-2 数据手册
BU-31602-@ (Press-fit, UL® Listed Banana Jack with Solder Pin Connection) • The BU-31602 is a press-fit, front install UL® listed 4mm banana jack. Accepts shrouded, unshrouded, and retractable 4mm banana plugs. • Mounting: Can be mounted on panels up to 1.0” (25.4mm) thick with a recommended mounting hole of Ø7/16” (11.2mm). • Overall length 1.25” (31.8mm), pin length = 0.23” (5.8mm), pin Ø = 0.078” • Connect wire via solder pin connection. • Material: Housing Nylon Contacts Nickel-plated brass • Ratings: Current 15 Amps Voltage 1000V, CAT III • Colors: The “@” in the part number indicates color. Standard colors are: -0 Black, -2 Red • RoHS 3 compliant (exemption 6c), Certified Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
BU-31602-2 价格&库存
很抱歉,暂时无法提供与“BU-31602-2”相匹配的价格&库存,您可以联系我们找货
