R
TI
F I ED
TEST TIPS & PLUGS
2
T
Y
CE
900
ISO
Q
I
UAL
SPECIFICATIONS: Tips: Brass, Nickel Plate
Handles: Nylon 6/6, Available in Red or Black
Rating: 10 Amps AC for 10º0ºº C temperature rise, continuous duty
FORCE FIT SOLDERLESS TIPS
SENIOR
CAT. NO. 1690
JUNIOR
CAT. NO.
6000
6001
6002
CAT. NO. 1680
THREADED SOLDERSLESS TIP
SENIOR
SOLDERLESS - .080 DIA. TIP PLUGS
Fully insulated molded nylon sleeve. Maximum reliability with minimum contact resistance.
Recessed metal head eliminates possibility of shock or grounding. Designed for solderless
connection of up to 16 gauge stranded wire which fits through handle and tip and is
secured by screwing handle tight. Current rating 10 Amps. Fits all standard tip jacks.
JUNIOR
SELECTION OF COLORS
COLOR
COLOR
CAT. NO.
GREEN
WHITE
6003
YELLOW
RED
6004
6005
BLUE
BLACK
MINIATURE - .080 DIA. TIP PLUGS
Designed for miniaturization where space is critical. Solder lead connection. Maximum
reliability with minimum contact resistance. Base of tip is recessed to eliminate shock or
grounding. Fits horizontal tip jacks. Current rating: 10 Amps.
SELECTION OF COLORS
CAT. NO. 1691
CAT. NO.
6006
6007
6008
CAT. NO. 1681
CAT. NO. 1660- RED
CAT. NO. 1661- BLACK
HEAVY DUTY
CAT. NO.
6009
6010
6011
COLOR
GREEN
YELLOW
BLUE
STREAMLINE TIPS
INSULATED SOLDERLESS TIP
SENIOR
COLOR
WHITE
RED
BLACK
JUNIOR
CAT. NO. 1670- RED
CAT. NO. 1671- BLACK
NEEDLE TIPS
CAT. NO. 1615 - RED
CAT. NO. 1616 - BLACK
CAT. NO.
3022-12
3022-20
A
.120
.093
STANDARD PHONE TIPS
Ideal for replacement tip for headset, speaker, or extension cord. Cat. No. 1601 Tip
accommodates heavier wire.
CAT. NO. 3017 - RED
CAT. NO. 3018 - BLACK
CAT. NO. 3019 - TIP ONLY
CAT. NO. 3015 - RED
CAT. NO. 3016 - BLACK
CAT. NO. 3014 - TIP ONLY
76
31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040
e-mail: kec@keyelco.com • WebSite: keyelco.com
CAT. NO. 1600
CAT. NO. 1601
很抱歉,暂时无法提供与“1681”相匹配的价格&库存,您可以联系我们找货
