3022-20
3022-20
    KEYSTONE
3022-20 数据手册
R TI F I ED TEST TIPS & PLUGS 2 T Y CE 900 ISO Q I UAL SPECIFICATIONS: Tips: Brass, Nickel Plate Handles: Nylon 6/6, Available in Red or Black Rating: 10 Amps AC for 10º0ºº C temperature rise, continuous duty FORCE FIT SOLDERLESS TIPS SENIOR CAT. NO. 1690 JUNIOR CAT. NO. 6000 6001 6002 CAT. NO. 1680 THREADED SOLDERSLESS TIP SENIOR SOLDERLESS - .080 DIA. TIP PLUGS Fully insulated molded nylon sleeve. Maximum reliability with minimum contact resistance. Recessed metal head eliminates possibility of shock or grounding. Designed for solderless connection of up to 16 gauge stranded wire which fits through handle and tip and is secured by screwing handle tight. Current rating 10 Amps. Fits all standard tip jacks. JUNIOR SELECTION OF COLORS COLOR COLOR CAT. NO. GREEN WHITE 6003 YELLOW RED 6004 6005 BLUE BLACK MINIATURE - .080 DIA. TIP PLUGS Designed for miniaturization where space is critical. Solder lead connection. Maximum reliability with minimum contact resistance. Base of tip is recessed to eliminate shock or grounding. Fits horizontal tip jacks. Current rating: 10 Amps. SELECTION OF COLORS CAT. NO. 1691 CAT. NO. 6006 6007 6008 CAT. NO. 1681 CAT. NO. 1660- RED CAT. NO. 1661- BLACK HEAVY DUTY CAT. NO. 6009 6010 6011 COLOR GREEN YELLOW BLUE STREAMLINE TIPS INSULATED SOLDERLESS TIP SENIOR COLOR WHITE RED BLACK JUNIOR CAT. NO. 1670- RED CAT. NO. 1671- BLACK NEEDLE TIPS CAT. NO. 1615 - RED CAT. NO. 1616 - BLACK CAT. NO. 3022-12 3022-20 A .120 .093 STANDARD PHONE TIPS Ideal for replacement tip for headset, speaker, or extension cord. Cat. No. 1601 Tip accommodates heavier wire. CAT. NO. 3017 - RED CAT. NO. 3018 - BLACK CAT. NO. 3019 - TIP ONLY CAT. NO. 3015 - RED CAT. NO. 3016 - BLACK CAT. NO. 3014 - TIP ONLY 76 31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040 e-mail: kec@keyelco.com • WebSite: keyelco.com CAT. NO. 1600 CAT. NO. 1601
3022-20 价格&库存
很抱歉,暂时无法提供与“3022-20”相匹配的价格&库存,您可以联系我们找货
    • 1+37.69200
    • 200+14.59080
    • 500+14.07240
    • 1000+13.82400
