NSL-33-007
NSL-33-007
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    径向-5引线
    Optoisolator Photocell Optocoupler 2000Vrms 2 Channel
NSL-33-007 数据手册
NSL-33-007 CdS Dual Output Optocoupler Features  Compact moisture resistance package  Best distortion characteristics  Dual passive resistance output  Assembly RoHS compliance except Cd in photocell Dual Photocell 4.1 6.0 2.54 20.3 min. 2.54 8.9 LED ø 8.9 Description This optocoupler consists of an LED coupled to a dual photocell. The photocell resistance is high when the LED current is “off” and low when the LED current is “on”. 14.1 2.54 Photocell + LED - Photocell Dimension in mm Tolerance: +/- 0.20 Circuit Schematic TYPICAL ON RESISTANCE VS FORWARD CURRENT (SINGLE PHOTOCELL) 100000 R-on (ohm) Absolute Maximum Ratings Storage Temperature -40 C to +75C Operating Temperature -40 C to +75C 260C Soldering Temperature (1) 2000V Isolation Voltage (Peak) Note: (1) >2 mm from case for 4.6 mA % (3) Specifications subject to change without notice. Advanced Photonix Canada Inc., 300 St-Sacrement Suite 519 Montréal, QC, Canada H2Y 1X4 Test Conditions REV 04/22-14 Page 1 of 2 Phone:(514) 768-8000 Fax: (514) 768-8889 http://www.advancedphotonix.com NSL-33-007 CdS Dual Output Optocoupler PHO T O CEL L AL L O W ABL E PO W ER DISSIPAT IO N VS T EMPERAT URE O UT PUT RESI ST ANCE VS T EM PERAT URE +100 ALLOWABLEPOWER DISSIPATION (%) 120 ALLOWABLEPOWER DISSIPATION (%) IF = 20 mA 100 80 60 40 20 IF = 20 mA +60 +40 +20 0 -20 -40 -60 -80 -100 -20 0 -20 0 + 20 + 40 + 60 + 80 ALLOWABLE FORWARD CURRENT IF (%) 20 1.6 1.8 2.0 +60 +80 +70 100 80 60 40 20 0 2.4 2.2 +40 LED ALLOWABLE FORWARD CURRENT VS T EMPERAT URE 120 40 0 1.4 +20 0 AM BI ENT T EM PERAT URE (d eg . C) LED FORWARD CURRENT VS FORWARD VOLTAGE FORWARD CURRENT (mA) +80 0 -20 +20 +40 +80 +60 FORWARD VOLTAGE (V) +5V 100% 5mA L Function Generator: 20 Hz, 5V peak 50 ohm 63% Oscilloscope R CH2 NSL-33-007 37% CH1 Advanced Photonix Canada Inc., 300 St-Sacrement Suite 519 Montréal, QC, Canada H2Y 1X4 0% Page 2 of 2 Tr Time Tf Phone:(514) 768-8000 Fax: (514) 768-8889 http://www.advancedphotonix.com
NSL-33-007 价格&库存
很抱歉,暂时无法提供与“NSL-33-007”相匹配的价格&库存,您可以联系我们找货
