LTV-814S-TA1
LTV-814S-TA1
    LITE-ON(光宝)
    SMD-4P
    光电耦合器 VF=1.2V IF=50mA VISO=5KV CTR=20~300%
LTV-814S-TA1 数据手册
Photocoupler Product Data Sheet LTV-814 824 844 (M, S, S-TA, S-TA1, S-TP) Series Spec No.: DS-70-96-0013 Effective Date: 05/17/2016 Revision: J LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto Photocoupler LTV-8x4 series 1. DESCRIPTION 1.1 Features  Current transfer ratio ( CTR : MIN. 20% at IF = ±1mA, VCE = 5V )  High input-output isolation voltage ( Viso = 5,000Vrms )  Response time ( tr : TYP. 4s at VCE = 2V, IC = 2mA, RL = 100 )  Dual-in-line package : LTV-814 : 1-channel type LTV-824 : 2-channel type LTV-844 : 4-channel type  Wide lead spacing package : LTV-814M : 1-channel type LTV-824M : 2-channel type LTV-844M : 4-channel type  Surface mounting package : LTV-814S : 1-channel type LTV-824S : 2-channel type LTV-844S : 4-channel type  Tape and reel packaging : LTV-814S-TA : 1-channel type LTV-814S-TA1 : 1-channel type LTV-814S-TP : 1-channel type LTV-824S-TA1 : 2-channel type  Safety approval UL 1577 VDE DIN EN60747-5-5 (VDE 0884-5) CSA CA5A Nordic Safety ( FIMKO/NEMKO/SEMKO/DEMKO)  BSI RoHS Compliance All materials be used in device are followed EU RoHS directive (No.2002/95/EC).  ESD pass HBM 8000V/MM2000V  MSL class1 1.2 Applications  Hybrid substrates that require high density mounting.  Programmable controllers 1/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 2. PACKAGE DIMENSIONS 2.1 LTV-814 2.3 LTV-814S 2.2 LTV-814M Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (W: China-CZ, Y: Thailand) 4. Rank shall be or shall not be marked. 5. “●” for halogen free option. 6. “4”or”V” for VDE option. Dimensions in millimeters (inches). 2/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 2.4 LTV-824 2.6 LTV-824S 2.5 LTV-824M Notes : 1. 2. 3. 4. 5. Year date code. 2-digit work week. Factory identification mark shall be marked (W: China-CZ, Y: Thailand) Rank shall be or shall not be marked. “●” for halogen free option. 6. “4”or”V” for VDE option. Dimensions in millimeters (inches). 3/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 2.7 LTV-844 2.8 LTV-844M 2.9 LTV-844S Notes : 1. 2. 3. 4. 5. Year date code. 2-digit work week. Factory identification mark shall be marked (W: China-CZ, Y: Thailand) Rank shall be or shall not be marked. “●” for halogen free option. 6. “4”or”V” for VDE option. Dimensions in millimeters (inches). 4/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 3. TAPING DIMENSIONS 3.1 LTV-814S-TA 3.2 LTV-814S-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment 3.3 Quantities Per Reel Package Type TA/TA1 Quantities (pcs) 1000 5/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 3.4 LTV-814S-TP Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) Distance of compartment Distance of compartment to compartment F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 8±0.1 (0.472) 3.5 Quantities Per Reel Package Type TP Quantities (pcs) 2000 6/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 3.6 LTV-824S-TA 3.7 LTV-824S-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment 3.8 Quantities Per Reel Package Type TA/TA1 Quantities (pcs) 1000 7/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 4. RATING AND CHARACTERISTICS 4.1 Absolute Maximum Ratings at Ta=25°C Parameter Symbol Rating Unit Forward Current IF ±50 mA Power Dissipation P 70 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 6 V Collector Current IC 50 mA Collector Power Dissipation PC 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 5000 Vrms Operating Temperature (LTV-824/844) Topr -30 ~ +100 o C Operating Temperature (LTV-814) Topr -50 ~ +110 o C Storage Temperature Tstg -55 ~ +125 o C 260 o C Input Output 1. 2 1. AC For 1 Minute, Soldering Temperature Tsol R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. 2. For 10 Seconds 8/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 4.2 ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C Parameter Symbol Min. Typ. Max. Unit Test Condition Forward Voltage VF — 1.2 1.4 V IF=±20mA Terminal Capacitance Ct — 30 250 pF V=0, f=1KHz Collector Dark Current ICEO — — 100 nA VCE=20V, IF=0 BVCEO 35 — — V IC=0.1mA, IF=0 BVECO 6 — — V IE=10A, IF=0 IC 0.2 — 3 mA CTR 20 — 300 % VCE(sat) — 0.1 0.2 V Riso 51010 11011 —  Input Collector-Emitter Output Breakdown Voltage Emitter-Collector Breakdown Voltage Collector Current IF=±1mA, VCE=5V 1. Current Transfer Ratio Collector-Emitter IF=±20mA, IC=1mA Saturation Voltage Isolation Resistance TRANSFER DC500V, 40 ~ 60% R.H. CHARACTERISTICS Floating Capacitance Cf — 0.6 1 pF Cut-off Frequency fc — 80 — kHz 40 ~ 60% R.H. V=0, f=1MHz VCE=5V, IC=2mA RL=100,-3dB Response Time (Rise) Response Time (Fall) 1. CTR  IC tr tf — — 4 3 18 18 s s VCE=2V, IC=2mA RL=100,  100% IF 9/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 5. RANK TABLE OF CURRENT TRANSFER RATIO CTR LTV-814 LTV-824/844 CTR Rank Min Max A 50 150 B 100 300 A or B or No mark 20 300 No mark 20 300 Condition IF=±1mA VCE=5V Ta=25oC 10/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 6. CHARACTERISTICS CURVES F ig .1 F o rw o rd C u rre n t F ig .2 C o lle cto r P o w e r D is sip tio n v s . A m b ie n t T e m p e ra tu te v s . A m b ie n t T e m p e ra tu re C o llec to r Po w er d issip atio n Pc (m W) 60 Fo rw ard c urrent I F (m A) 50 40 30 20 10 0 -30 0 25 50 75 100 200 150 100 50 0 -30 125 0 25 50 75 100 o Am b ient tem p erature Ta ( C ) F ig .3 C o lle c to r-e m itte r S a tu ra tio n F ig .4 F o rw a rd C u rre n t v s. F o rw a rd V o lta g e 500 O Ta= 25 C o Fo rw ard c urrent I F (m A) 5m A 7m A 3m A Ic = 0.5m A C o llec o tr-em itter saturatio n vo ltag e VC E (sat) (V) 5 1m A V o lta g e v s . F o rw a rd C u rre n t 6 4 3 2 Ta= 75 C 50 C o 200 o 25 C 0 C -25 C o 100 o 50 20 10 5 1 2 0 1 0 5 10 15 0 1.0 0.5 1.5 2.0 2.5 3.0 Fo rw ard vo ltag e VF (V) Fo rw ard c urrent IF (m A) F ig .5 C u rre n t T ra n s fe r R a tio vs. F ig .6 C o lle cto r C u rre n t vs. F o rw a rd C u rre n t C o lle cto r-e m itte r V o lta g e 200 30 V C E = 5V 180 I F = 30m A o Ta= 25 C o Ta= 25 C C o llec to r c urrent Ic (m A) C urrent transfer ratio C TR (%) 125 o Am b ient tem p erature Ta ( C ) 160 140 120 100 80 60 40 20m A 25 Pc (M AX.) 20 15 10m A 10 5m A 5 20 0 0 1 2 5 10 20 Fo rw ard c urrent I F (m A) 50 0 1 2 3 4 5 6 7 8 9 C o llec to r-em itter vo ltag e VC E (V) 11/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series F ig .7 R e la tive C u rre n t T ra n sfe r R a tio F ig .8 C o lle cto r-e m itte r S a tu ra tio n V o lta g e vs. A m b ie n t T e m p e ra tu re vs. A m b ie n t T e m p e ra tu re 0.16 I F = 5m A C o llec to r-em itter saturatio n vo ltag e VC E (sat) (V) Relative c urrent transfer ratio (%) 150 V C E = 5V 100 50 0 -30 0 25 50 75 100 I F = 20m A 0.14 Ic = 1m A 0.12 0.10 0.08 0.06 0.04 0.02 0 -25 125 0 Am b ient tem p erature Ta ( C ) 75 100 125 F ig .1 0 R e sp o n se T im e vs. L o a d A m b ie n t T e m p e ra tu re R e sista n ce -5 500 V C E = 20V 200 -6 10 100 Resp o nse tim e ( s) C o llec to r d ark c urrent I C EO (A) 50 Am b ient tem p erature Ta ( C ) F ig .9 C o lle cto r D a rk C u rre n t vs. 10 25 o o -7 10 -8 10 -9 10 VC E = 2V Ic = 2m A o Ta= 25 C 50 tr 20 tf 10 td 5 ts 2 1 -10 10 0.5 -11 10 -25 0 25 50 75 100 o 0.2 0.05 0.1 0.2 0.5 1 2 Lo ad resistanc e R L (k Am b ient tem p erature Ta ( C ) 5 10 ) T e st C ircu it fo r R e sp o n se T im e F ig .1 1 F re q u e n cy R e sp o n se Vo ltag e g ain Av (d B ) 125 VC E = 2V Ic = 2m A o Ta= 25 C 0 10 R L= 10k 1k 100 T e st C ircu it fo r F re q u e n cy R e sp o n se 20 0.5 1 2 5 10 20 50 100 500 Freq uenc y f (kH z) 12/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 7. TEMPERATURE PROFILE OF SOLDERING 7.1 IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin) 150˚C - Temperature Max (TSmax) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL) 217˚C - Time (tL) 60 sec Peak Temperature (TP) 260˚C 3˚C / sec max. Ramp-up rate 3~6˚C / sec Ramp-down rate 2 0 se c T e m p e ra tu re ( C ) R a m p -u p TP 260 C TL 217 C R a m p -d o w n T sm a x 2 0 0 C 6 0 se c T sm in 150 C tL (S o ld e rin g ) 25 C 6 0 ~ 1 2 0 se c 3 5 ~ 7 0 se c T im e (s e c) ts (P re h e a t) 13/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 7.2 Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature: 260+0/-5˚C Time: 10 sec. Preheat temperature:25 to 140˚C Preheat time: 30 to 80 sec. 7.3 Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Temperature: 380+0/-5˚C Time: 3 sec max. 14/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 8. RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) 8.1 4 PIN 8.2 8 PIN 8.3 16PIN Note : Dimensions in millimeters. 15/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4 Photocoupler LTV-8x4 series 9. NAMING RULE LTV- 8X4(1)-(2)-( 3 )-G DEVICE PART NUMBER (1) No suffix = Dual-in-Line package M = Wide lead spacing package S = Surface mounting package - (2) TAPING TYPE(TA,TA1,TP or none) (3) CTR RANK (A,B,C,D,L or none) Example : LTV-814S-TA1-A-G LTV 8X4(1)(2 )(3)-V-G DEVICE PART NUMBER (1) No suffix = Dual-in-Line package M = Wide lead spacing package S = Surface mounting package (2) TAPING TYPE (TA,TA1,TP or none) (3) CTR RANK (A,B,C,D,L or none) (4) VDE order option (5) Halogen free option Example : LTV814STA1A-V-G 10. NOTES  LiteOn is continually improving the quality, reliability, function or design and LiteOn reserves the right to make changes without further notices.  The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation.  For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives.  When requiring a device for any ”specific” application, please contact our sales in advice.  If there are any questions about the contents of this publication, please contact us at your convenience.  The contents described herein are subject to change without prior notice.  Immerge unit’s body in solder paste is not recommended. 16/16 Part No.: LTV-8x4 series BNC-OD-FC002/A4
LTV-814S-TA1 价格&库存
很抱歉,暂时无法提供与“LTV-814S-TA1”相匹配的价格&库存,您可以联系我们找货
