LTV-815
LTV-815
    LITE-ON(光宝)
    DIP-4
    特性:高电流传输比(CTR):在IF = 1mA、VCE = 2V时为600%。 高输入输出隔离电压:Viso = 5000Vrms。 响应时间:典型值为60μs(VCE = 2V、IC = 10mA...
LTV-815 数据手册
Photocoupler Product Data Sheet LTV-815 825 845 ( M, S, S-TA1, S-TA, S-TP ) Series Spec No.: DS-70-96-0015 Effective Date: 10/20/2015 Revision: F LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto Photocoupler LTV-8x5 series 1. DESCRIPTION 1.1 Features  Current transfer ratio ( CTR : MIN. 600% at IF = 1mA, VCE = 2V )  High input-output isolation voltage ( Viso = 5,000Vrms )  Response time ( tr : TYP. 60s at VCE = 2V, IC = 10mA, RL = 100 )  Dual-in-line package : LTV-815 : 1-channel type LTV-825 : 2-channel type LTV-845 : 4-channel type  Wide lead spacing package : LTV-815M : 1-channel type LTV-825M : 2-channel type LTV-845M : 4-channel type  Surface mounting package : LTV-815S : 1-channel type LTV-825S : 2-channel type LTV-845S : 4-channel type  Tape and reel packaging : LTV-815S-TA : 1-channel type LTV-815S-TA1 : 1-channel type LTV-815S-TP : 1-channel type LTV-825S-TA1 : 2-channel type  Safety approval UL 1577 VDE DIN EN60747-5-5 (VDE 0884-5) CSA CA5A Nordic Safety ( FIMKO/NEMKO/SEMKO/DEMKO)  BSI RoHS Compliance All materials be used in device are followed EU RoHS directive (No.2002/95/EC).  ESD pass HBM 8000V/MM2000V  MSL class1 1.2 Applications  Hybrid substrates that require high density mounting.  Programmable controllers 1/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 2. PACKAGE DIMENSIONS 2.1 LTV-815 2.3 LTV-815S 2.2 LTV-815M Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (W: China-CZ, Y: Thailand) 4. Rank shall be or shall not be marked. 5. “●” for halogen free option. 6. “4”or”V” for VDE option. Dimensions in millimeters(inches). 2/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 2.4 LTV-825 2.6 LTV-825S 2.5 LTV-825M Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (W: China-CZ, Y: Thailand) 4. Rank shall be or shall not be marked. 5. “●” for halogen free option. 6. VDE option shall be . Dimensions in millimeters(inches). 3/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 2.7 LTV-845 2.8 LTV-845M 2.9 LTV-845S Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (W: China-CZ, Y: Thailand) 4. Rank shall be or shall not be marked. 5. “●” for halogen free option. 6. VDE option shall be . Dimensions in millimeters(inches). 4/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 3. TAPING DIMENSIONS 3.1 LTV-815S-TA 3.2 LTV-815S-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment 3.3 Quantities Per Reel Package Type TA/TA1 Quantities (pcs) 1000 5/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 3.4 LTV-815S-TP Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) Distance of compartment Distance of compartment to compartment F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 8±0.1 (0.472) 3.5 Quantities Per Reel Package Type TP Quantities (pcs) 2000 6/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 3.6 LTV-825S-TA 3.7 LTV-825S-TA1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment 3.8 Quantities Per Reel Package Type TA/TA1 Quantities (pcs) 1000 7/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 4. RATING AND CHARACTERISTICS 4.1 Absolute Maximum Ratings at Ta=25°C Parameter Input Symbol Rating Unit Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation P 70 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 6 V Collector Current IC 80 mA Collector Power Dissipation PC 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 5000 Vrms Operating Temperature Topr -30 ~ +110 o C Storage Temperature Tstg -55 ~ +125 o C 260 o C Output 1. 2 1. AC For 1 Minute, Soldering Temperature Tsol R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. 2. For 10 Seconds 8/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 4.2 ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C Parameter Input Symbol Min. Typ. Max. Unit Forward Voltage VF — 1.2 1.4 V IF=±20mA Reverse Current IR — — 10 A VR=4V Terminal Capacitance Ct — 30 250 pF V=0, f=1KHz Collector Dark Current ICEO — — 1 A VCE=10V, IF=0 BVCEO 35 — — V IC=0.1mA, IF=0 BVECO 6 — — V IE=10A, IF=0 IC 6 — 75 mA Collector-Emitter Output Test Condition Breakdown Voltage Emitter-Collector Breakdown Voltage Collector Current IF=1mA, VCE=2V 1. Current Transfer Ratio CTR 600 — 7500 % VCE(sat) — 0.8 1 V Riso 51010 11011 —  Collector-Emitter IF=20mA, IC=5mA Saturation Voltage Isolation Resistance TRANSFER DC500V, 40 ~ 60% R.H. CHARACTERISTICS Floating Capacitance Cf — 0.6 1 pF Cut-off Frequency fc 1 6 — kHz 40 ~ 60% R.H. V=0, f=1MHz VCE=5V, IC=2mA RL=100,-3dB Response Time (Rise) Response Time (Fall) 1. CTR  IC IF tr tf — — 60 53 300 250 s s VCE=2V, IC=10mA RL=100,  100% 9/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 5. CHARACTERISTICS CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Collector power dissipation Pc (mW) Forward current I F (mA) 60 50 40 30 20 10 0 -30 0 25 50 75 100 125 200 150 100 50 0 -30 Ambient temperature Ta ( C) 50mA 2 Ta= 75 C o 50 C 200 20 10 5 2 1 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 0 Forward current IF (mA) 0.5 1.0 1.5 2.0 2.5 3.0 Forward voltage VF (V) Fig.5 Current Transfer Ratio vs. Forward Current Fig.6 Collector Current vs. Collector-emitter Voltage 2000 100 VCE= 2V o Ta= 25 C 1600 o Ta= 25 C Collector current Ic (mA) Current transfer ratio CTR (%) o 50 0 1200 800 400 0 0.1 125 25 oC 0C o -25 C 100 1 0 100 o Forward current IF (mA) 30mA 5mA 7mA 1mA 3mA Ic= 0.5mA Collector-emitter saturation voltage VCE (sat) 3 75 500 o Ta= 25 C 6 4 50 Fig.4 Forward Current vs. Forward Voltage 8 5 25 Ambient temperature Ta ( C) Fig.3 Collector-emitter Saturation Voltage vs. Forward Current 7 0 O O 80 IF = 10mA Pc(MAX.) 60 5mA 40 2mA 1mA 20 0 0.2 0.5 1 2 Forward current IF (mA) 5 10 0 1 2 3 4 5 Collector-emitter voltage VCE(V) 10/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series Fig.7 Relative Current Transfer Ratio vs. Ambient Temperature Fig.8 Collector-emitter Saturation Voltage vs. Ambient Temperature Collector-emitter saturation voltage VCE (sat) (V) Relative current transfer ratio (%) 150 I F= 1mA VCE= 2V 100 50 0 -30 I F= 20mA I C= 5mA 1.0 0.8 0.6 0.4 0.2 0 0 25 50 75 100 -20 40 60 80 100 Fig.10 Response Time vs. Load Resistance -5 500 VCE = 10V -6 10 Response time ( s) Collecotr dark current ICEO(A) 20 Ambient temperature Ta ( C) Fig.9 Collector Dark Current vs. Ambient Temperature 10 0 o o Ambient temperature Ta ( C) -7 10 -8 10 -9 10 200 100 tr o tf 50 20 10 td 5 ts 2 1 -10 10 VCE= 2V I C= 10mA Ta= 25 C 0.5 -11 10 -25 0 25 50 75 0.2 0.05 100 o Fig.11 Frequency Response 0.5 1 2 5 10 Test Circuit for Response Time VCE= 2V IC= 2mA Ta= 25 C o Voltage gain Av (dB) 0.1 0.2 Load resistance RL(k ) Ambient temperature Ta ( C) 0 Vcc Input RD RL Input Output Output 10% 90% td ts tr tf Test Circuit for Frequency Response -10 100 1k Vcc RD -20 0.02 0.1 1 10 RL Output 100 Frequency f (kHz) 11/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 6. TEMPERATURE PROFILE OF SOLDERING 6.1 IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (TSmin) 150˚C - Temperature Max (TSmax) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL) 217˚C - Time (tL) 60 sec Peak Temperature (TP) 260˚C 3˚C / sec max. Ramp-up rate 3~6˚C / sec Ramp-down rate 20 sec Temperature ( C) Ramp-up TP 260 C TL 217 C Tsmax 200 C Ramp-down 60 sec Tsmin 150 C tL (Soldering) 25 C 60 ~ 120 sec ts (Preheat) 35~70 sec 12/15 Time (sec) Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 6.2 Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature: 260+0/-5˚C Time: 10 sec. Preheat temperature:25 to 140˚C Preheat time: 30 to 80 sec. 6.3 Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Temperature: 380+0/-5˚C Time: 3 sec max. 13/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 7. RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) 7.1 4 PIN 7.2 8 PIN 7.3 16PIN Note : Dimensions in millimeters. 14/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: - Photocoupler LTV-8x5 series 8. Naming rule LTV- 8X5(1)-(2)-G DEVICE PART NUMBER (1) No suffix = Dual-in-Line package M = Wide lead spacing package S = Surface mounting package - (2) TAPING TYPE(TA,TA1,TP or none) LTV-815 and LTV-825 have tape and reel solution. Please refer to orientation of taping on Page P5-P7 (3) Halogen free option Example : LTV-817S-TA1-G LTV 8X5(1)(2) -V-G DEVICE PART NUMBER (1) No suffix = Dual-in-Line package M = Wide lead spacing package S = Surface mounting package (2) TAPING TYPE(TA,TA1,TP or none) LTV-815 and LTV-825 have tape and reel solution Please refer to orientation of taping on Page P5-P7 (3) VDE order option (4) Halogen free option Example : LTV815STA1-V-G 9. Notes:  LiteOn is continually improving the quality, reliability, function or design and LiteOn reserves the right to make changes without further notices.  The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation.  For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives.  When requiring a device for any ”specific” application, please contact our sales in advice.  If there are any questions about the contents of this publication, please contact us at your convenience.  The contents described herein are subject to change without prior notice.  Immerge unit’s body in solder paste is not recommended. 15/15 Part No.: LTV-8x5 series BNC-OD-FC002/A4 Rev.: -
LTV-815 价格&库存
很抱歉,暂时无法提供与“LTV-815”相匹配的价格&库存,您可以联系我们找货
LTV-815
  • 56+3.2304056+0.41619
  • 100+2.12874100+0.27426
  • 500+1.76440500+0.22732
  • 1000+1.522231000+0.19612
  • 2000+1.130412000+0.14564
  • 5000+1.078255000+0.13892
  • 10000+0.9894110000+0.12747
  • 25000+0.9372525000+0.12075
库存:9632
LTV-815
  • 365+2.24442365+0.28916
  • 500+2.06387500+0.26590
  • 1000+1.811971000+0.23345
  • 2000+1.187462000+0.15299
  • 5000+1.143455000+0.14732
库存:15714
LTV-815
  • 53+3.1677053+0.40811
  • 100+2.08657100+0.26883
  • 500+1.72980500+0.22286
  • 1000+1.491951000+0.19222
  • 2000+1.108402000+0.14280
  • 5000+1.057875000+0.13629
  • 10000+0.9698510000+0.12495
  • 25000+0.9193225000+0.11844
库存:4800
