LTV-8141
LTV-8141
    LITE-ON(光宝)
    DIP-4
LTV-8141 数据手册
L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only FEATURES * AC input response * High current transfer ratio ( CTR : MIN. 600% at IF = ±1mA, VCE = 2V ) * High input-output isolation voltage ( Viso = 5,000Vrms ) * Response time ( tr : TYP. 60µs at VCE = 2V, IC = 10mA, RL = 100Ω ) * Dual-in-line package : LTV-8141 : 1-channel type LTV-8241 : 2-channel type LTV-8441 : 4-channel type * Wide lead spacing package : LTV-8141M : 1-channel type LTV-8241M : 2-channel type LTV-8441M : 4-channel type * Surface mounting package : LTV-8141S : 1-channel type LTV-8241S : 2-channel type LTV-8441S : 4-channel type * Tape and reel packaging : LTV-8141S-TA1, LTV-8241S-TA1 * UL approved ( No. E113898 ) * TUV approved ( No. R9653630 ) * FIMKO approved ( No. 193422-01 ) * NEMKO approved ( No. P96103013 ) * DEMKO approved ( No. 303986 ) * SEMKO approved ( No. 9646047 / 01-30 ) * VDE approved ( No. 094722 ) Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 1 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-8141 : LTV-8241 : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 2 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-8441 : LTV-8141M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 3 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-8241M : LTV-8441M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 4 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-8141S : LTV-8241S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 5 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-8441S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand, X : China). Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 6 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only TAPING DIMENSIONS LTV-8141S-TA1 : LTV-8241S-TA1 : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Symbol W P0 F P2 P1 Dimensions in mm ( inches ) 16 ± 0.3 ( .63 ) 4 ± 0.1 ( .15 ) 7.5 ± 0.1 ( .295 ) 2 ± 0.1 ( .079 ) 12 ± 0.1 ( .472 ) Page : 7 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only ABSOLUTE MAXIMUM RATING ( Ta = 25°C ) PARAMETER SYMBOL RATING UNIT Forward Current IF ±50 mA Power Dissipation P 70 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 6 V Collector Current IC 80 mA Collector Power Dissipation PC 150 mW Ptot 200 mW Viso 5,000 Vrms Operating Temperature Topr -30 ~ +100 °C Storage Temperature Tstg -55 ~ +125 °C Tsol 260 °C INPUT OUTPUT Total Power Dissipation *1 Isolation Voltage *2 Soldering Temperature *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 8 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25°C ) PARAMETER SYMBOL MIN. TYP. MAX. UNIT CONDITIONS Forward Voltage VF — 1.2 1.4 V IF=±20mA Terminal Capacitance Ct — 50 250 pF V=0, f=1KHz Collector Dark Current ICEO — — 1 µA VCE=10V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 — — V IC=0.1mA IF=0 Emitter-Collector Breakdown Voltage BVECO 6 — — V IE=10µA IF=0 IC 6 — 75 mA * Current Transfer Ratio CTR 600 — 7,500 % Collector-Emitter Saturation Voltage VCE(sat) — 0.8 1 V IF=±20mA IC=5mA Isolation Resistance Riso — Ω DC500V 40 ~ 60% R.H. Floating Capacitance Cf — 0.6 1 pF V=0, f=1MHz Cut-Off Frequency fc 1 6 — KHz Response Time (Rise) tr — 60 300 µs Response Time (Fall) tf — 53 250 µs INPUT OUTPUT Collector Current TRANSFER CHARACTERISTICS * CTR = 5×1010 1×1011 IF=±1mA VCE=2V VCE=5V, IC=2mA RL=100Ω, -3dB VCE=2V, IC=10mA RL=100Ω IC × 100% IF Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 9 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only CHARACTERISTICS CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Collector power dissipation Pc (mW) Forward current I F (mA) 60 50 40 30 20 10 0 -30 0 25 50 75 100 125 200 150 100 50 0 -30 Ambient temperature Ta ( C) 50mA 2 Ta= 75 C 50 C 200 20 10 5 2 1 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 0 0.5 1.0 1.5 2.0 2.5 3.0 Forward voltage VF (V) Fig.5 Current Transfer Ratio vs. Forward Current Fig.6 Collector Current vs. Collector-emitter Voltage 2000 100 VCE= 2V Ta= 25 C o Ta= 25 C o 1600 Collector current Ic (mA) Current transfer ratio CTR (%) o o Forward current IF(mA) 1200 800 400 80 IF = 10mA Pc(MAX.) 60 5mA 40 2mA 1mA 20 0 0.2 0.5 1 2 5 10 Forward current IF(mA) Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 o 50 0 0 0.1 125 25 C 0C -25 C o 100 1 0 100 o Forward current IF (mA) 30mA 5mA 7mA 1mA 3mA Ic= 0.5mA Collector-emitter saturation voltage VCE (sat) 3 75 500 o Ta= 25 C 6 4 50 Fig.4 Forward Current vs. Forward Voltage 8 5 25 Ambient temperature Ta ( C) Fig.3 Collector-emitter Saturation Voltage vs. Forward Current 7 0 O O 0 1 2 3 4 5 Collector-emitter voltage VCE(V) Page : 10 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only CHARACTERISTICS CURVES Fig.7 Relative Current Transfer Ratio vs. Ambient Temperature IF = 1mA VCE= 2V Collector-emitter saturation voltage VCE (sat) (V) Relative current transfer ratio (%) 150 Fig.8 Collector-emitter Saturation Voltage vs. Ambient Temperature 100 50 0 -30 I F= 20mA Ic= 5mA 1.0 0.8 0.6 0.4 0.2 0 0 25 50 75 100 -20 o 40 60 80 100 Fig.10 Response Time vs. Load Resistance -5 500 VCE = 10V -6 10 Response time ( s) Collector dark current I CEO (A) 20 Ambient temperature Ta ( C) Fig.9 Collector Dark Current vs. Ambient Temperature 10 0 o Ambient temperature Ta ( C) -7 10 -8 10 -9 10 -10 10 200 100 VCE = 2V Ic= 10mA Ta= 25 C tr o tf 50 20 10 td 5 ts 2 1 0.5 -11 10 -25 0 25 50 75 100 0.2 0.05 o Ambient temperature Ta ( C) 0.1 0.2 0.5 1 2 5 10 Load resistance RL(k ) Fig.11 Frequency Response Test Circuit for Response Time Vcc VCE = 2V Ic= 2mA Ta= 25 C Input RD RL Input Output Output 10% Voltage gain Av (dB) o 0 90% td ts tr -10 1k Test Circuit for Frequency Response 100 Vcc RD -20 0.02 0.1 1 10 tf RL Output 100 Frequency f (kHz) Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 11 of 12 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of LITE-ON Only RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm 4 PIN 8 PIN 16 PIN Part No. : LTV-8141 / 8241 / 8441 ( M, S, S-TA1 ) BNS-OD-C131/A4 Page : 12 of 12
LTV-8141 价格&库存
很抱歉,暂时无法提供与“LTV-8141”相匹配的价格&库存,您可以联系我们找货
LTV-8141
  • 1+7.424351+0.95776
  • 10+5.1329510+0.66217
  • 100+3.75533100+0.48445
  • 500+3.13942500+0.40500
  • 1000+2.937661000+0.37897
  • 2000+2.766242000+0.35686
  • 5000+2.578935000+0.33269
  • 10000+2.4621710000+0.31763
  • 25000+2.3348925000+0.30121
库存:6770
