6N136S
6N136S
    LITE-ON(光宝)
    OC-8P_9.68X6.5MM_SM
    Optoisolator Transistor with Base Output 2500Vrms 1 Channel 8-SMD
6N136S 数据手册
L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only 6N135, 6N136 Single Channel, High Speed Optocouplers Jan.2009 Description The 6N135/6 consists of a high efficient AlGaAs Light Emitting Diode and a high speed optical detector. This design provides excellent AC and DC isolation between the input and output sides of the Optocoupler. Connection for the bias of the photodiode improves the speed that of a conventional phototransistor coupler by reducing the base-collector capacitances. The internal shield ensures high common mode transient immunity. A guaranteed common mode transient immunity is up to 1KV/μsec. Features • High speed – 1MBd typical • Available in Dual-in-line, Wide lead spacing, Surface mounting package. • Storable output. • UL, CSA approval Functional Diagram NC Vcc ANODE VB Application Cathode NC • High Voltage Isolation • Isolation in line receivers Vo • Feedback element in switching mode power supplier GND • Power transistor isolation in motor drives • Interface between Microprocessor system, computer and their peripheral • Replace pulse transformers. • Replace slower optocoupler isolators. 6N135/6N136 Truth Table (Positive Logic) LED OUT ON L OFF H A 0.1µF bypass Capacitor must be connected between Pin8 and Pin5 Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 1 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Ordering Information Minimum CMR Part Option dV/dt (V/µs) VCM (V) CTR Remarks Single Channel, DIP-8 6N135 7 M S 1000 Single Channel, Wide Lead Spacing Single Channel, SMD-8 10 Single Channel, DIP-8 6N136 M S Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 19 Single Channel, Wide Lead Spacing Single Channel, SMD-8 Page : 2 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Package Dimensions 8-pin DIP Package (6N135 / 6N136) *1. Year date code. *2. 2-digit work week. *3. Factory identification mark (Z : Taiwan, Y : Thailand). Dimensions are in Millimeters and (Inches). Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 3 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Package Dimensions 8-pin DIP Wide Lead Spacing Package (6N135M / 6N136M) *1. Year date code. *2. 2-digit work week. *3. Factory identification mark (Z : Taiwan, Y : Thailand). Dimensions are in Millimeters and (Inches). Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 4 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Package Dimensions 8-pin DIP Surface Mount Package (6N135S / 6N136S) *1. Year date code. *2. 2-digit work week. *3. Factory identification mark (Z : Taiwan, Y : Thailand). Dimensions are in Millimeters and (Inches). Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 5 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Taping Dimensions 6N135S/136S-TA 6N137S-TA1 6N135S/136S-TA1 Description Symbol Dimensions in millimeters ( inches ) Tape wide W 16 ± 0.3 ( .63 ) Pitch of sprocket holes P0 4 ± 0.1 ( .15 ) Distance of compartment F P2 7.5 ± 0.1 ( .295 ) 2 ± 0.1 ( .079 ) Distance of compartment to compartment P1 12 ± 0.1 ( .472 ) Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 6 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Recommended Lead Free Reflow Profile Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 7 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Absolute Maximum Ratings*1 Parameter Symbol Min Max TST -55 125 o 85 o Storage Temperature Operating Temperature TA -40 Isolation Voltage VISO 5000 Supply Voltage VCC Lead Solder Temperature * 2 Units Note C C VRMS 15 V 260 °C 2 Input Average Forward Input Current IF 25 mA Reverse Input Voltage VR 5 V Input Power Dissipation PI 45 mW Output Collector Current IO 8 mA Output Collector Voltage VO 20 V Output Collector Power Dissipation PO 100 mW Output -0.5 1.Ambient temperature = 25oC, unless otherwise specified. Stresses exceeding the absolute maximum ratings can cause permanent damage to the device. Exposure to absolute maximum ratings for long periods of time can adversely affect reliability. 2.260oC for 10 seconds. Refer to Lead Free Reflow Profile. Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 8 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Electrical Specifications Parameters Test Condition Symbol Device Min Typ Max Units 1.4 1.7 V Input Input Forward Voltage IF =16mA, TA=25℃ Input Reverse Voltage IR = 10µA VF BVR 6N135 6N136 5 V Detector Current transfer ratio IF=16mA;Vcc=4.5V; TA=25℃;Vo=0.4V 6N135 IF IF=16mA;Vcc=4.5V; Io=1.1mA; TA=25℃ IF=16mA;Vcc=4.5V; Io=3mA; TA=25℃ 50 % 6N135 19 24 50 0.18 0.4 VOL V 6N136 IF=0mA, Vo=Vcc=5.5V TA=25℃ Logic high output current 18 CTR 6N136 Logic low output voltage output voltage 7 0.25 0.4 0.5 IOH IF=0mA, Vo=Vcc=15V TA=25℃ 6N135 6N136 μA 1 Logic low supply current IF=16mA, Vo=open (Vcc=15V) IccL 6N135 6N136 Logic high supply current IF=0mA, Vo=open ; TA=25℃ (Vcc=15V) IccH 6N135 6N136 μA 400 1 μA *All Typical at TA =25ْ C Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 9 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Switching Specifications TA=0~70℃, Vcc=5V, unless otherwise specified. Parameter Propagation Delay Time to Low Output Level Propagation Delay Time to High Output Level Logic High Common Mode Transient Immunity Logic Low Common Mode Transient Immunity Test Condition TA=25℃ (RL=4.1KΩ, IF=16mA) TA=25℃ (RL=1.9KΩ, IF=16mA) TA=25℃ (RL=4.1KΩ, IF=16mA) TA=25℃ (RL=1.9KΩ, IF=16mA) Symbol Min Typ Max Units 6N135 0.09 1.5 μs 6N136 0.1 0.8 μs 6N135 0.8 1.5 μs 6N136 0.4 0.8 μs tPHL tPLH IF=0mA;VCM=10Vp-p; RL=4.1KΩ; TA=25C IF=0mA;VCM=10Vp-p; RL=1.9KΩ; TA=25C Device 6N135 1 KV/µs 6N136 1 KV/µs 6N135 1 KV/µs 6N136 1 KV/µs |CMH| IF=0mA;VCM=10Vp-p; RL=4.1KΩ; TA=25C |CML| IF=0mA;VCM=10Vp-p; RL=1.9KΩ; TA=25C *All Typical at TA =25ْ C Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 10 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Isolation Characteristics Parameter Test Condition Symbol Input-Output Insulation Leakage Current 45% RH, t = 5s, o VI-O = 3kV DC, TA = 25 C II-O Withstand Insulation Test Voltage RH ≤ 50%, t = 1min, o TA = 25 C VISO Input-Output Resistance VI-O = 500V DC RI-O Min Typ Max Units 1.0 µA 5000 VRMS 12 Ω 10 *All Typical at TA =25℃ Notes 1. A 0.1µF or bigger bypass capacitor for VCC is needed as shown in Fig.1 2. Current Transfer Ratio is defined as the ratio of output collector current Io , to the forward LED input current IF, times 100. 3. The 1.9KΩ load represents 1TTL unit load of 1.6mA and the 5.6KΩ pull-up resistor. 4. The 4.1KΩ load represents 1LSTTL unit load of 0.36mA and the 6.1KΩ pull-up resistor. Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 11 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Switching Time Test Circuit Figure 1: Single Channel Test Circuit for tPHL and tPLH Figure 2: Single Channel Test Circuit for Common Mode Transient Immunity Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 12 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Characteristics Curves Figure 3: DC and pulsed transfer characteristics Figure 6: Current transfer ratio vs. input Figure 4: Input current vs. forward voltage Figure 7: Current transfer ratio vs. temperature Figure 5: Logic high output current vs. temperature Figure 8: Small-signal current transfer ratio vs. quiescent current Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 13 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Characteristics Curves Figure 9: Propagation delay time vs. temperature Figure 10: Propagation delay time vs. load resistance TPLH6N135 TPLH6N136 TPHL6N136 TPHL6N135 Part No. : 6N135 / 6N136 series BNS-OD-C131/A4 Page : 14 of 15 L IT E - O N T E CH NO L O G Y CO RP O RAT IO N Property of Lite-on Only Notice Specifications of the products displayed herein are subject to change without notice. The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical instrumentation and application. For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives. Part No. : 6N135 / 6N136 series Page : 15 of 15
6N136S 价格&库存
很抱歉,暂时无法提供与“6N136S”相匹配的价格&库存,您可以联系我们找货
