525-03-0-I
525-03-0-I
    STANDEX-MEDER(斯丹麦德)
    4-DIP(0.300",7.62mm)
    OPTOISOLATOR4KVTRANSISTOR
525-03-0-I 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – 521 Optocouplers 525 Series Optocouplers  Features: ATEX Optocoupler for Intrinsically Safe Circuits  Applications: Electronics for Mining, Test & Measurement, Automation Technology  Markets: Oil & Gas Production, Refinery, Mining, Medical, Test and Measurement, and others 525-03-0-i Part Description: Customer Options Coupler Characteristics Unit Isolation Voltage Input / Output (min.) Current Transfer Ratio (min.) Ic/If CTR (If = 10mA) Turn On Time (typ.) 4,000 VDC 0.5 5.5 μsec 4.2 μsec Collector-Ermitter Voltage (max.) 32 VDC Collector Current Ic (max.) 50 mA Creeping Distance (min.) 14.5 mm Air Path Input / Output (min.) 14.5 mm Ton Turn-Off Time (typ.) Toff Insulation Distance Ermitter-Detecto (min.) 5 mm Insulation Resistance Input / Output (min.) 1012 Ohm 50 kHz Transmission Frequencies (typ.) USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015 A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – 525 Optocouplers 525 Optocoupler Housing and Material Specifications Housing Material Plastic Case Color Blue Sealing Compound Polyurethan Connection Pins Cu-Ally Tinned Washability Fully Sealed Environmental Data Unit Shock Resistance (max.) 50 g 20 g Operating Temperature -40 to 85 °C Storage Temperature Soldering Temperature (max.) -40 to 100 °C 260 °C 1/2 sine wave duration 11ms Vibration Resistance (max.) 5 sec. max. Test Circuit and Layout Test Circuit Handling Instructions  It is advised that normal static precautions be taken in handling and assembly of this component to prevent damage and/or degradation which may be induced by ESC. Layout USA: Europe: Asia: +1.866.782.6339 +49.7731.8399.0 +86.21.37820625 │ salesusa@standexmeder.com │ info@standexmeder.com │ salesasia@standexmeder.com Modifications in the sense of technical progress are reserved. Version 01 27.01.2015
525-03-0-I 价格&库存
很抱歉,暂时无法提供与“525-03-0-I”相匹配的价格&库存,您可以联系我们找货
