4N37S-TA1
4N37S-TA1
    LITE-ON(光宝)
    OC-6P_7.3X6.5MM_SM
    4N37S-TA1
4N37S-TA1 数据手册
Photocoupler Product Data Sheet 4N35/ 4N37 (M, S, S-TA1) Spec No. :DS-70-99-0012 Effective Date: 08/22/2017 Revision: E LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto Photocoupler 4N3X series 1. DESCRIPTION 1.1 Features  Current transfer ratio (CTR : MIN. 100% at IF = 10mA, VCE = 10V, Ta=25oC)  High input-output isolation voltage 4N35 series : Viso = 3,550Vrms 4N37 series : Viso = 1,500Vrms  Response time (tr : TYP. 3µs at Vcc = 10V, IC = 2mA, RL = 100Ω)  Dual-in-line package : 4N35, 4N37  Wide lead spacing package : 4N35M, 4N37M  Surface mounting package : 4N35S, 4N37S  Tape and reel packaging : 4N35S-TA, 4N37S-TA, 4N35S-TA1, 4N37S-TA1  Safety approval * UL approved (No. E113898) * CSA approved (No. CA91533-1) * FIMKO approved ( No. 193422-01) * VDE approved ( No. 40015248) * BSI approved (No. 9018-9) * CQC approved (No.CQC11001061921-2)  Creepage distance > 8.0 mm ; Clearance > 8.0 mm  The relevant models are the models Approved by VDE according to DIN EN 60747-5-5 Approved Model No.: 4N35-V / 4N37-V / 4N35M-V / 4N37M-V / 4N35S-V / 4N37S-V / 4N35STA-V / 4N37STA-V / 4N35STA1-V / 4N37STA1-V VDE approved No.: 40015248 (According to the specification DIN EN 60747-5-5)  Operating isolation voltage VIORM : 420V (Peak)  Transient voltage VTR : 6000V (Peak)  Pollution : 2 (According to VDE 0110-1 : 1997-04)  Clearances distance (Between input and output) : 7.0mm (MIN.)  Creepage distance (Between input and output) : 7.0mm (MIN.)  Isolation thickness between input and output : 0.4mm (MIN.)  Safety limit values Current (Isi) : 400mA (Diode side) Power (Psi) : 700mW (Phototransistor side) Temperature(Tsi) : 175oC In order to keep safety electric isolation of photocoupler, please set the protective circuit to keep within safety limit values when the actual application equipment troubled.  Indication of VDE approval prints " " on sleeve package. 1/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series  RoHS Compliance All materials be used in device are followed EU RoHS directive (No.2002/95/EC).  ESD pass HBM 8000V/MM2000V  MSL class1 1.2 Applications  Power Supply regulators  Digital logic inputs  Microprocessor inputs 2/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series 2. PACKAGE DIMENSIONS 2.1 4N35 2.3 4N35S 2.2 4N35M Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (W: China-CZ, Y: Thailand X: China-TJ). 4. VDE option. Dimensions in millimeters(inches). 3/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series 2.4 4N37 2.6 4N37S 2.5 4N37M Notes : 1. Year date code. 2. 2-digit work week. 3. Factory identification mark shall be marked (W: China-CZ, Y: Thailand X: China-TJ). 4. VDE option. Dimensions in millimeters(inches). 4/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series 3. TAPING DIMENSIONS 3.1 4N35S-TA , 4N37S-TA : 3.2 4N35S-TA1 , 4N37S-TA1 : Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (0.63) Pitch of sprocket holes P0 4±0.1 (0.15) F 7.5±0.1 (0.295) P2 2±0.1 (0.079) P1 12±0.1 (0.472) Distance of compartment Distance of compartment to compartment 3.3 Quantities Per Reel Package Type TA/TA1 Quantities (pcs) 1000 5/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series 4. RATING AND CHARACTERISTICS 4.1 Absolute Maximum Ratings at Ta=25°C Parameter Input Output Symbol Rating Unit Forward Current IF 60 mA Reverse Voltage VR 6 V Power Dissipation P 100 mW Collector - Emitter Voltage VCEO 30 V Emitter - Collector Voltage VECO 7 V Collector - Base Voltage VCBO 70 V Collector Current IC 100 mA Collector Power Dissipation PC 300 mW Ptot 350 mW 3,550 Vrms 1,500 Vrms Total Power Dissipation 4N35 series *1 Isolation Voltage Viso 4N37 series *1. Operating Temperature Topr -55 ~ +100 °C Storage Temperature Tstg -55 ~ +150 °C *2 Soldering Temperature Tsol 260 °C AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds 6/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series 4.2 ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER INPUT SYMBOL MIN. TYP. MAX. UNIT Forward Voltage VF — 1.2 1.5 V IF=10mA Reverse Current IR — — 10 µA VR=4V Terminal Capacitance Ct — 50 — pF V=0, — — 50 nA VCE=10V, IF=0 — — 500 µA VCE=30V, IF=0 30 — — V Collector Dark Ta=25°C CONDITIONS f=1KHz ICEO Current Ta=100°C Collector-Emitter IC=0.1mA BVCEO Breakdown Voltage OUTPUT Emitter-Collector Breakdown IF=0 BVECO 7 — — V Voltage IF=0 Collector-Base IC=0.1mA BVCBO 70 — — V Breakdown Voltage Collector Current *Current Transfer Ratio IF=0 IC 10 — — mA IF=10mA CTR 100 — — % VCE=10V VCE(sat) — — 0.3 V Collector-Emitter IF=50mA Saturation Voltage TRANSFER Isolation Resistance IE=10µA IC=2mA Riso 5×1010 1×1011 — Ω DC500V 40 ~ 60% R.H. CHARACTERISTICS Floating Capacitance Cf — 1 2.5 pF V=0, Response Time (Rise) tr — 3 10 µs VCE=10V, Response Time (Fall) tf — 3 10 µs RL=100Ω * CTR = f=1MHz IC=2mA IC × 100% IF 7/15 Part No. : 4N3X series BNS-OD-FC002/A4 Rev.: D Photocoupler 4N3X series 4.3 ISOLATION SPECIFICATION ACCORDING TO VDE Parameter Symbol Conditions Rating Unit 55/100/21 - 2 - - 420 VPEAK tp=60s, qc
4N37S-TA1 价格&库存
很抱歉,暂时无法提供与“4N37S-TA1”相匹配的价格&库存,您可以联系我们找货
4N37S-TA1
  • 271+1.72323271+0.22230
库存:392
4N37S-TA1
  • 1000+1.705951000+0.22008
  • 2000+1.155802000+0.14910
  • 3000+1.144403000+0.14763
  • 5000+1.074405000+0.13860
  • 7000+1.071157000+0.13818
  • 10000+0.9848710000+0.12705
库存:4000
4N37S-TA1
  • 1+1.709601+0.22055
  • 10+1.7053610+0.22000
  • 25+1.7011125+0.21945
  • 100+1.69687100+0.21890
  • 250+1.69369250+0.21849
库存:392
