LTV-845
LTV-845
    LITE-ON(光宝)
    DIP-16_19.84X6.5MM
LTV-845 数据手册
Photocoupler Product Data Sheet LTV-815 825 845 ( M, S, S-TA1, S-TA, S-TP ) Series Spec No.: DS-70-96-0015 Effective Date: 07/04/2013 Revision: E LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only FEATURES * High current transfer ratio ( CTR : MIN. 600% at IF = 1mA, VCE = 2V ) * High input-output isolation voltage ( Viso = 5,000Vrms ) * Response time ( tr : TYP. 60s at VCE = 2V, IC = 10mA, RL = 100 ) * Dual-in-line package : LTV-815 : 1-channel type LTV-825 : 2-channel type LTV-845 : 4-channel type * Wide lead spacing package : LTV-815M : 1-channel type LTV-825M : 2-channel type LTV-845M : 4-channel type * Surface mounting package : LTV-815S : 1-channel type LTV-825S : 2-channel type LTV-845S : 4-channel type * Tape and reel packaging : LTV-815S-TA1, LTV-825S-TA1 LTV-815S-TA, LTV-815S-TP * Safety approval UL / TUV / CSA / FIMKO / NEMKO / DEMKO / SEMKO / VDE* approved *Required “V” ordering option * RoHS compliant Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 1 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-815 : LTV-825 : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (W: China-CZ, X : China-TJ, Y : Thailand) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 2 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-845 : LTV-815M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (W: China-CZ, X : China-TJ, Y : Thailand) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 3 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-825M : LTV-845M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (W: China-CZ, X : China-TJ, Y : Thailand) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 4 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-815S : LTV-825S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (W: China-CZ, X : China-TJ, Y : Thailand,). Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 5 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-845S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (W: China-CZ, X : China-TJ, Y : Thailand,). Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 6 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS LTV-815S-TA1 : LTV-825S-TA1 : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 7 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS LTV-815S-TA : LTV-815S-TP : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment (Option: TA) Distance of compartment to compartment (Option: TP) Symbol W P0 F P2 P1 P1 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) 8  0.1 ( .315 ) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 8 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ABSOLUTE MAXIMUM RATING ( Ta = 25C ) PARAMETER SYMBOL RATING UNIT Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation P 70 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 6 V Collector Current IC 80 mA Collector Power Dissipation PC 150 mW Ptot 200 mW Viso 5,000 Vrms Operating Temperature Topr -30 ~ +100 C Storage Temperature Tstg -55 ~ +125 C Tsol 260 C INPUT OUTPUT Total Power Dissipation *1 Isolation Voltage *2 Soldering Temperature *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 9 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25C ) PARAMETER INPUT OUTPUT VF — 1.2 1.4 V IF=20mA Reverse Current IR — — 10 A VR=4V Terminal Capacitance Ct — 30 250 pF V=0, f=1KHz Collector Dark Current ICEO — — 1 A VCE=10V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 — — V IC=0.1mA IF=0 Emitter-Collector Breakdown Voltage BVECO 6 — — V IE=10A IF=0 IC 6 — 75 mA CTR 600 — 7,500 % Collector-Emitter Saturation Voltage VCE(sat) — 0.8 1 V IF=20mA IC=5mA Isolation Resistance Riso —  DC500V 40 ~ 60% R.H. Floating Capacitance Cf — 0.6 1 pF V=0, f=1MHz Cut-Off Frequency fc 1 6 — kHz Response Time (Rise) tr — 60 300 s Response Time (Fall) tf — 53 250 s * Current Transfer Ratio * CTR  IC CONDITIONS Forward Voltage Collector Current TRANSFER CHARACTERISTICS SYMBOL MIN. TYP. MAX. UNIT 51010 11011 IF=1mA VCE=2V VCE=5V, IC=2mA RL=100, -3dB VCE=2V, IC=10mA RL=100  100% IF Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 10 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .1 F o rw a rd C u rre n t vs. A m b ie n t F ig .2 C o lle cto r P o w e r D issip a tio n vs. T e m p e ra tu re A m b ie n t T e m p e ra tu re C o llec to r p o w er d issip atio n Pc (m W) Fo rw ard c u rrent I F (m A) 60 50 40 30 20 10 0 -30 0 25 50 75 100 125 200 150 100 50 0 -30 Am b ient tem p erature Ta ( C ) 50m A Fo rw ard c u rrent I F (m A) 30m A 5m A 7m A 1m A 3m A 4 Ic = 0.5m A C o llec to r-em itter saturatio n vo ltag e VC E (sat) 125 o 1 Ta= 75 C o 50 C 200 o 25 C o 0C 100 o -25 C 50 20 10 5 2 0 1 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 0 Fo rw ard c u rrent I F (m A) 0.5 1.0 1.5 2.0 C u rre n t 3.0 F ig .6 C o lle cto r C u rre n t vs. C o lle cto r-e m itte r V o lta g e 2000 100 V C E = 2V o Ta= 25 C o Ta= 25 C C o llec to r c u rrent Ic (m A) 1600 1200 800 400 0 0.1 2.5 Fo rw ard vo ltag e V F (V) F ig .5 C u rre n t T ra n sfe r R a tio vs. F o rw a rd C u rrent transfer ratio C TR (%) 100 500 o Ta= 25 C 6 2 75 V o lta g e 8 3 50 F ig .4 F o rw a rd C u rre n t vs. F o rw a rd V o lta g e vs. F o rw a rd C u rre n t 5 25 Am b ient tem p erature Ta ( C ) F ig .3 C o lle cto r-e m itte r S a tu ra tio n 7 0 O O 80 I F = 10m A Pc (M AX.) 60 5m A 40 2m A 1m A 20 0 0.2 0.5 1 2 Fo rw ard c u rrent I F (m A) 5 10 0 1 2 3 4 5 C o llec to r-em itter vo ltag e V C E (V) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 11 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .7 R e la tive C u rre n t T ra n sfe r R a tio F ig .8 C o lle cto r-e m itte r S a tu ra tio n V o lta g e vs. A m b ie n t T e m p e ra tu re vs. A m b ie n t T e m p e ra tu re C o llec to r-em itter saturatio n vo ltag e VC E (sat) (V) Relative c urrent transfer ratio ( %) 150 I F = 1m A VC E = 2V 100 50 0 -30 I F = 20m A I C = 5m A 1.0 0.8 0.6 0.4 0.2 0 0 25 50 75 100 -20 Am b ient tem p erature Ta ( C ) 40 60 80 100 F ig .1 0 R e sp o n se T im e vs. L o a d A m b ie n t T e m p e ra tu re R e sista n ce -5 500 VC E = 10V 200 -6 s) 10 -7 100 VC E = 2V I C = 10m A Ta= 25 C tr o tf 50 10 Resp o nse tim e ( C o llec o tr d ark c urrent I C EO (A) 20 Am b ient tem p erature Ta ( C ) F ig .9 C o lle cto r D a rk C u rre n t vs. 10 0 o o -8 10 -9 10 20 td 10 5 ts 2 1 -10 10 0.5 -11 10 -25 0 25 50 75 0.2 0.05 100 o F ig .1 1 F re q u e n cy R e sp o n se 0.5 1 2 5 10 ) T e st C ircu it fo r R e sp o n se T im e VC E = 2V IC = 2m A Ta= 25 C o Vo ltag e g ain Av (d B) 0.1 0.2 Lo ad resistanc e R L (k Am b ient tem p erature Ta ( C ) 0 Inp ut Vc c O utp ut Inp ut RD RL 10% O utp ut 90% td ts tr tf T e st C ircu it fo r F re q u e n cy R e sp o n se -10 100 1k Vc c RD -20 0.02 0.1 1 10 RL O utp ut 100 Freq uenc y f (kH z) Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 12 of 13 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm 4 PIN 8 PIN 16 PIN Part No. : LTV-815/ 825/ 845 ( M, S, S-TA1, S-TA, S-TP ) Series (Rev.E, May 03’2013) Page : BNS-OD-C131/A4 13 of 13
LTV-845 价格&库存
很抱歉,暂时无法提供与“LTV-845”相匹配的价格&库存,您可以联系我们找货
LTV-845
  • 1+16.280031+2.09743
  • 25+10.2925725+1.32604
  • 100+8.78448100+1.13175
  • 500+7.54702500+0.97232
  • 1000+7.143141000+0.92028
  • 2000+6.800862000+0.87619
  • 5000+6.427545000+0.82809
  • 10000+6.1952410000+0.79816
库存:19646
