LTV-817-C
LTV-817-C
    LITE-ON(光宝)
    OC-4P_6.5X4.6MM_TM
    光电耦合器 VF=1.2V IF=50mA VISO=5KV CTR=200~400% DIP4_4.6X6.5MM
LTV-817-C 数据手册
Photocoupler Product Data Sheet LTV-817 (M, S, S-TA, S-TA1, S-TP) Series Spec No.: DS70-2012-0050 Effective Date: 12/12/2013 Revision: B LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only FEATURES * Current transfer ratio ( CTR : MIN. 50% at IF = 5mA, VCE = 5V ) * High input-output isolation voltage ( Viso = 5,000Vrms ) * Response time ( tr : TYP. 4s at VCE = 2V, IC = 2mA, RL = 100 ) * Dual-in-line package : LTV-817 : 1-channel type * Wide lead spacing package : LTV-817M : 1-channel type * Surface mounting package : LTV-817S : 1-channel type * Tape and reel packaging : LTV-817S-TA : 1-channel type LTV-817S-TA1 : 1-channel type LTV-817S-TP : 1-channel type * Safety approval UL 1577, Cert. No.E113898 CSA CA5A, Cert. No. 1020087 (CA 91533-1) FIMKO EN/IEC 60950-1, EN/IEC 60065; Cert. No.NCS/FI 24426 M3 NEMKO EN/IEC 60950-1,EN/IEC 60065; Cert. No.P08209622/A1 DEMKO EN/IEC 60950-1,EN/IEC 60065; Cert. No.314703-02 SEMKO EN/IEC 60950-1,EN/IEC 60065; Cert. No. 1119078 VDE DIN EN60747-5-5, Cert. No. 40015248 CQC GB8898-2011/GB4943.1-2011, Cert.No. CQC10001054420/CQC10001054421 * RoHS compliance All materials be used in device are followed EU RoHS directive (No.2002/95/EC). * ESD pass HBM 8000V/MM2000V *MSL class1 Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 1 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817: *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Y : Thailand, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 2 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Y : Thailand, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 3 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Y : Thailand, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 4 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS LTV-817S-TA : LTV-817S-TA1 : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 5 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS LTV-817S-TP : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 6 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ABSOLUTE MAXIMUM RATING ( Ta = 25C ) PARAMETER SYMBOL RATING UNIT Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation P 70 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 6 V Collector Current IC 50 mA Collector Power Dissipation PC 150 mW Ptot 200 mW Viso 5,000 Vrms Operating Temperature Topr -30 ~ +110 C Storage Temperature Tstg -55 ~ +125 C Tsol 260 C INPUT OUTPUT Total Power Dissipation *1 Isolation Voltage ○ *2 Soldering Temperature *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 7 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25C ) PARAMETER INPUT OUTPUT VF — 1.2 1.4 V IF=20mA Reverse Current IR — — 10 A VR=4V Terminal Capacitance Ct — 30 250 pF V=0, f=1KHz Collector Dark Current ICEO — — 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 — — V IC=0.1mA IF=0 Emitter-Collector Breakdown Voltage BVECO 6 — — V IE=10A IF=0 IC 2.5 — 30 mA CTR 50 — 600 % Collector-Emitter Saturation Voltage VCE(sat) — 0.1 0.2 V IF=20mA IC=1mA Isolation Resistance Riso —  DC500V 40 ~ 60% R.H. Floating Capacitance Cf — 0.6 1 pF V=0, f=1MHz Cut-Off Frequency fc — 80 — kHz Response Time (Rise) tr — 4 18 s Response Time (Fall) tf — 3 18 s *1 Current Transfer Ratio ◇ *1 CTR  IC CONDITIONS Forward Voltage Collector Current TRANSFER CHARACTERISTICS SYMBOL MIN. TYP. MAX. UNIT 51010 11011 IF=5mA VCE=5V VCE=5V, IC=2mA RL=100, -3dB VCE=2V, IC=2mA RL=100  100% IF Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 8 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only RANK TABLE OF CURRENT TRANSFER RATIO CTR MODEL NO. RANK MARK CTR ( % ) L 50 ~ 100 A 80 ~ 160 B 130 ~ 260 C 200 ~ 400 D 300 ~ 600 L or A or B or C or D 50 ~ 600 LTV-817 IF = 5 mA CONDITIONS VCE = 5 V Ta = 25 C Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 9 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .1 F o rw o rd C u rre n t F ig .2 C o lle cto r P o w e r D is sip tio n v s . A m b ie n t T e m p e ra tu te v s . A m b ie n t T e m p e ra tu re C o llec to r Po w er d issip atio n Pc (m W) 60 Fo rw ard c urrent I F (m A) 50 40 30 20 10 0 -30 0 25 50 75 100 200 150 100 50 0 -30 125 0 25 50 75 100 o Am b ient tem p erature Ta ( C ) F ig .3 C o lle c to r-e m itte r S a tu ra tio n F ig .4 F o rw a rd C u rre n t v s. F o rw a rd V o lta g e 500 O Ta= 25 C o Fo rw ard c urrent I F (m A) 5m A 7m A 3m A Ic = 0.5m A C o llec o tr-em itter saturatio n vo ltag e VC E (sat) (V) 5 1m A V o lta g e v s . F o rw a rd C u rre n t 6 4 3 2 Ta= 75 C 50 C o 200 o 25 C 0 C -25 C o 100 o 50 20 10 5 1 2 0 1 0 5 10 15 0 1.0 0.5 1.5 2.0 2.5 3.0 Fo rw ard vo ltag e VF (V) Fo rw ard c urrent IF (m A) F ig .5 C u rre n t T ra n s fe r R a tio vs. F ig .6 C o lle cto r C u rre n t vs. F o rw a rd C u rre n t C o lle cto r-e m itte r V o lta g e 200 30 V C E = 5V 180 I F = 30m A o Ta= 25 C o Ta= 25 C C o llec to r c urrent Ic (m A) C urrent transfer ratio C TR (%) 125 o Am b ient tem p erature Ta ( C ) 160 140 120 100 80 60 40 20m A 25 Pc (M AX.) 20 15 10m A 10 5m A 5 20 0 0 1 2 5 10 20 Fo rw ard c urrent I F (m A) 50 0 1 2 3 4 5 6 7 8 9 C o llec to r-em itter vo ltag e VC E (V) Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 10 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .7 R e la tive C u rre n t T ra n sfe r R a tio F ig .8 C o lle cto r-e m itte r S a tu ra tio n V o lta g e vs. A m b ie n t T e m p e ra tu re vs. A m b ie n t T e m p e ra tu re 0.16 I F = 5m A C o llec to r-em itter saturatio n vo ltag e VC E (sat) (V) Relative c urrent transfer ratio (%) 150 V C E = 5V 100 50 0 -30 0 25 50 75 100 I F = 20m A 0.14 Ic = 1m A 0.12 0.10 0.08 0.06 0.04 0.02 0 -25 125 0 Am b ient tem p erature Ta ( C ) 75 100 125 F ig .1 0 R e sp o n se T im e vs. L o a d A m b ie n t T e m p e ra tu re R e sista n ce -5 500 V C E = 20V 200 -6 10 100 Resp o nse tim e ( s) C o llec to r d ark c urrent I C EO (A) 50 Am b ient tem p erature Ta ( C ) F ig .9 C o lle cto r D a rk C u rre n t vs. 10 25 o o -7 10 -8 10 -9 10 VC E = 2V Ic = 2m A o Ta= 25 C 50 tr 20 tf 10 td 5 ts 2 1 -10 10 0.5 -11 10 -25 0 25 50 75 100 o 0.2 0.05 0.1 0.2 0.5 1 2 Lo ad resistanc e R L (k Am b ient tem p erature Ta ( C ) 5 10 ) T e st C ircu it fo r R e sp o n se T im e F ig .1 1 F re q u e n cy R e sp o n se Vo ltag e g ain Av (d B ) 125 VC E = 2V Ic = 2m A o Ta= 25 C 0 10 R L= 10k 1k 100 T e st C ircu it fo r F re q u e n cy R e sp o n se 20 0.5 1 2 5 10 20 50 100 500 Freq uenc y f (kH z) Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 11 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm 4 PIN Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 12 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TEMPERATURE PROFILE OF SOLDERING REFLOW (1) IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Profile item Conditions Preheat - Temperature Min (TSmin) - Temperature Max (TSmax) - Time (min to max) (ts) Soldering zone - Temperature (TL) - Time (tL) Peak Temperature (TP) Ramp-up rate Ramp-down rate 150˚C 200˚C 90±30 sec 217˚C 60 sec 260˚C 3˚C /sec max. 3~6˚C / sec 2 0 se c T e m p e ra tu re ( C ) R a m p -u p TP 260 C TL 217 C R a m p -d o w n T sm a x 2 0 0 C 6 0 se c T sm in 150 C tL (S o ld e rin g ) 25 C 6 0 ~ 1 2 0 se c 3 5 ~ 7 0 se c T im e (s e c) ts (P re h e a t) - Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 13 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TEMPERATURE PROFILE OF SOLDERING REFLOW (2) Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature: 260+0/-5˚C Time: 10 sec. Preheat temperature:25 to 140˚C Preheat time: 30 to 80 sec. (3) Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Temperature: 380+0/-5˚C Time: 3 sec max. Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 14 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only NAMING RULE LTV- 817-( 1)-(2) DEVICE PART NUMBER (1)= TAPING TYPE(TA,TA1,TP or none) (2)= CTR RANK(A,B,C,D,L or none) Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 15 BNS-OD-C131/A4 of 16 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only Notes: - Lite-On is continually improving the quality, reliability, function or design and Lite-On reserves the right to make changes without further notices. - The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation. - For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives. - When requiring a device for any ”specific” application, please contact our sales in advice. - If there are any questions about the contents of this publication, please contact us at your convenience. - The contents described herein are subject to change without prior notice. Part No. : LTV-817 (M, S, S-TA, S-TA1, S-TP) Series (Rev.-, September 25, 2013) Page : 16 BNS-OD-C131/A4 of 16
LTV-817-C 价格&库存
很抱歉,暂时无法提供与“LTV-817-C”相匹配的价格&库存,您可以联系我们找货
LTV-817-C
  • 1+0.28970
  • 100+0.26380
库存:1619
LTV-817C
    • 400+0.24988400+0.02986
    • 2000+0.241522000+0.02886
    • 7500+0.235027500+0.02809
    • 20000+0.2294520000+0.02742
    • 75000+0.2183075000+0.02609
    库存:90500
    LTV-817-C
      • 2000+0.17940
      库存:10000
      LTV-817-C
      • 5+1.16666
      • 25+0.83367
      • 100+0.75102
      • 175+0.60489
      • 485+0.57135
      库存:13310
      LTV-817-C
      • 10+0.33210
      • 100+0.27195
      • 300+0.22205
      • 1000+0.19948
      • 5000+0.18144
      • 10000+0.17237
      库存:70053
      LTV-817-C
      • 10+0.46500
      • 200+0.34770
      • 500+0.26960
      • 2000+0.19540
      • 10000+0.17580
      库存:22155
      LTV-817-C
      • 200+0.48397200+0.05784
      • 1000+0.465391000+0.05562
      • 3000+0.453323000+0.05417
      • 7500+0.444037500+0.05306
      • 20000+0.4235920000+0.05062
      库存:6100
      LTV-817-C
      • 1+0.35200
      • 100+0.22000
      • 1000+0.19140
      • 2000+0.16610
      库存:22155
      LTV-817-C
        • 100+0.23000
        库存:131300
        LTV-817C
          • 1000+0.22023
          库存:90500
