Photocoupler
Product Data Sheet
LTV-815 825 845
( M, S, S-TA1, S-TA, S-TP )
Series
Spec No.: DS-70-96-0015
Effective Date: 10/20/2015
Revision: F
LITE-ON DCC
RELEASE
BNS-OD-FC001/A4
LITE-ON Technology Corp. / Optoelectronics
No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C.
Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660
http://www.liteon.com/opto
Photocoupler
LTV-8x5 series
1. DESCRIPTION
1.1 Features
Current transfer ratio ( CTR : MIN. 600% at IF = 1mA, VCE = 2V )
High input-output isolation voltage ( Viso = 5,000Vrms )
Response time ( tr : TYP. 60s at VCE = 2V, IC = 10mA, RL = 100 )
Dual-in-line package :
LTV-815 : 1-channel type
LTV-825 : 2-channel type
LTV-845 : 4-channel type
Wide lead spacing package :
LTV-815M : 1-channel type
LTV-825M : 2-channel type
LTV-845M : 4-channel type
Surface mounting package :
LTV-815S : 1-channel type
LTV-825S : 2-channel type
LTV-845S : 4-channel type
Tape and reel packaging :
LTV-815S-TA : 1-channel type
LTV-815S-TA1 : 1-channel type
LTV-815S-TP : 1-channel type
LTV-825S-TA1 : 2-channel type
Safety approval
UL 1577
VDE DIN EN60747-5-5 (VDE 0884-5)
CSA CA5A
Nordic Safety ( FIMKO/NEMKO/SEMKO/DEMKO)
BSI RoHS Compliance
All materials be used in device are followed EU RoHS directive (No.2002/95/EC).
ESD pass HBM 8000V/MM2000V
MSL class1
1.2 Applications
Hybrid substrates that require high density mounting.
Programmable controllers
1/15
Part No.: LTV-8x5 series
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
2. PACKAGE DIMENSIONS
2.1
LTV-815
2.3
LTV-815S
2.2
LTV-815M
Notes :
1. Year date code.
2. 2-digit work week.
3. Factory identification mark shall be marked
(W: China-CZ, Y: Thailand)
4. Rank shall be or shall not be marked.
5. “●” for halogen free option.
6. “4”or”V” for VDE option.
Dimensions in millimeters(inches).
2/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
2.4
LTV-825
2.6
LTV-825S
2.5
LTV-825M
Notes :
1. Year date code.
6. VDE option shall be
3/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
2.7
LTV-845
2.8
LTV-845M
2.9
LTV-845S
Notes :
1. Year date code.
4/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
3.
TAPING DIMENSIONS
3.1 LTV-815S-TA
3.2 LTV-815S-TA1
Description
Symbol
Dimension in mm (inch)
Tape wide
W
16±0.3 (0.63)
Pitch of sprocket holes
P0
4±0.1 (0.15)
F
7.5±0.1 (0.295)
P2
2±0.1 (0.079)
P1
12±0.1 (0.472)
Distance of compartment
Distance of compartment to
compartment
3.3 Quantities Per Reel
Package Type
TA/TA1
Quantities (pcs)
1000
5/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
3.4 LTV-815S-TP
Description
Symbol
Tape wide
W
16±0.3 (0.63)
P0
4±0.1 (0.15)
compartment
F
7.5±0.1 (0.295)
P2
2±0.1 (0.079)
P1
8±0.1 (0.472)
3.5 Quantities Per Reel
Package Type
TP
Quantities (pcs)
2000
6/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
3.6 LTV-825S-TA
3.7 LTV-825S-TA1
Description
Symbol
Tape wide
W
16±0.3 (0.63)
P0
4±0.1 (0.15)
F
7.5±0.1 (0.295)
P2
2±0.1 (0.079)
P1
12±0.1 (0.472)
compartment
3.8 Quantities Per Reel
Package Type
TA/TA1
Quantities (pcs)
1000
7/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
4. RATING AND CHARACTERISTICS
4.1 Absolute Maximum Ratings at Ta=25°C
Parameter
Input
Symbol
Rating
Unit
Forward Current
IF
50
mA
Reverse Voltage
VR
6
V
Power Dissipation
P
70
mW
Collector - Emitter Voltage
VCEO
35
V
Emitter - Collector Voltage
VECO
6
V
Collector Current
IC
80
mA
Collector Power Dissipation
PC
150
mW
Total Power Dissipation
Ptot
200
mW
Isolation Voltage
Viso
5000
Vrms
Operating Temperature
Topr
-30 ~ +110
o
C
Storage Temperature
Tstg
-55 ~ +125
o
C
260
o
C
Output
1.
2
1.
AC For 1 Minute,
Soldering Temperature
Tsol
R.H. = 40 ~ 60%
Isolation voltage shall be measured using the following method.
(1) Short between anode and cathode on the primary side and between collector and emitter on the
secondary side.
(2) The isolation voltage tester with zero-cross circuit shall be used.
(3) The waveform of applied voltage shall be a sine wave.
2.
For 10 Seconds
8/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
4.2
ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C
Parameter
Input
Symbol
Min.
Typ.
Max.
Unit
Forward Voltage
VF
1.2
1.4
V
IF=±20mA
Reverse Current
IR
10
A
VR=4V
Terminal Capacitance
Ct
30
250
pF
V=0, f=1KHz
Collector Dark Current
ICEO
1
A
VCE=10V, IF=0
BVCEO
35
V
IC=0.1mA, IF=0
BVECO
6
V
IE=10A, IF=0
IC
6
75
mA
Collector-Emitter
Output
Test Condition
Breakdown Voltage
Emitter-Collector
Breakdown Voltage
Collector Current
IF=1mA, VCE=2V
1.
Current Transfer Ratio
CTR
600
7500
VCE(sat)
0.8
1
V
Riso
51010
11011
Collector-Emitter
IF=20mA, IC=5mA
Saturation Voltage
Isolation Resistance
TRANSFER
DC500V,
40 ~ 60% R.H.
CHARACTERISTICS
Floating Capacitance
Cf
0.6
1
pF
Cut-off Frequency
fc
1
6
kHz
40 ~ 60% R.H.
V=0, f=1MHz
VCE=5V, IC=2mA
RL=100,-3dB
Response Time (Rise)
Response Time (Fall)
1.
CTR
IC
IF
tr
tf
60
53
300
250
s
s
VCE=2V, IC=10mA
RL=100,
100%
9/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
5. CHARACTERISTICS CURVES
Fig.1 Forward Current vs. Ambient
Temperature
Fig.2 Collector Power Dissipation vs.
Ambient Temperature
Collector power dissipation Pc (mW)
Forward current I F (mA)
60
50
40
30
50
75
100
125
200
150
100
50
Ambient temperature Ta ( C)
50mA
2
Ta= 75 C
o
50 C
200
5
2
1
0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
Forward current IF (mA)
0.5
1.0
1.5
2.0
2.5
3.0
Forward voltage VF (V)
Fig.5 Current Transfer Ratio vs. Forward
Current
Fig.6 Collector Current vs.
Collector-emitter Voltage
2000
100
VCE= 2V
o
Ta= 25 C
1600
o
Ta= 25 C
Collector current Ic (mA)
Current transfer ratio CTR (%)
o
50
800
400
125
25 oC
0C
o
-25 C
100
1
o
30mA
5mA
7mA
1mA
3mA
Ic= 0.5mA
Collector-emitter saturation voltage
VCE (sat)
3
75
500
o
Ta= 25 C
6
4
50
Fig.4 Forward Current vs. Forward
Voltage
8
5
25
Fig.3 Collector-emitter Saturation
Voltage vs. Forward Current
7
O
O
80
IF = 10mA
Pc(MAX.)
60
5mA
40
2mA
1mA
0.5
1
2
5
10
2
3
4
5
Collector-emitter voltage VCE(V)
10/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
Fig.7 Relative Current Transfer Ratio
vs. Ambient Temperature
Fig.8 Collector-emitter Saturation Voltage
VCE (sat) (V)
Relative current transfer ratio (%)
150
I F= 1mA
VCE= 2V
100
50
I F= 20mA
I C= 5mA
1.0
0.8
0.6
0.4
0.2
50
75
100
-20
40
60
80
100
Fig.10 Response Time vs. Load
Resistance
-5
500
VCE = 10V
-6
10
Response time ( s)
Collecotr dark current ICEO(A)
Fig.9 Collector Dark Current vs.
Ambient Temperature
10
o
o
-7
10
-8
10
-9
10
200
100
tr
o
tf
50
td
5
ts
2
1
-10
10
VCE= 2V
I C= 10mA
Ta= 25 C
0.5
-11
10
-25
50
75
0.2
0.05
100
o
Fig.11 Frequency Response
0.5
1
2
5
10
Test Circuit for Response Time
VCE= 2V
IC= 2mA
Ta= 25 C
o
Voltage gain Av (dB)
0.1 0.2
Load resistance RL(k )
Vcc
Input
RD
RL
Input
Output
Output
10%
90%
td
ts
tr
tf
Test Circuit for Frequency Response
-10
100
1k
Vcc
RD
-20
0.02
0.1
1
10
RL
Output
100
Frequency f (kHz)
11/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
6. TEMPERATURE PROFILE OF SOLDERING
6.1 IR Reflow soldering (JEDEC-STD-020C compliant)
One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three
times.
Profile item
Conditions
Preheat
- Temperature Min (TSmin)
150˚C
- Temperature Max (TSmax)
200˚C
- Time (min to max) (ts)
90±30 sec
Soldering zone
- Temperature (TL)
217˚C
- Time (tL)
60 sec
Peak Temperature (TP)
260˚C
3˚C / sec max.
Ramp-up rate
3~6˚C / sec
Ramp-down rate
20 sec
Temperature ( C)
Ramp-up
TP 260 C
TL 217 C
Tsmax 200 C
Ramp-down
60 sec
Tsmin
150 C
tL (Soldering)
25 C
60 ~ 120 sec
ts (Preheat)
35~70 sec
12/15
Time (sec)
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
6.2 Wave soldering (JEDEC22A111 compliant)
One time soldering is recommended within the condition of temperature.
Temperature: 260+0/-5˚C
Time: 10 sec.
Preheat temperature:25 to 140˚C
Preheat time: 30 to 80 sec.
6.3 Hand soldering by soldering iron
Allow single lead soldering in every single process. One time soldering is recommended.
Temperature: 380+0/-5˚C
Time: 3 sec max.
13/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
7. RRECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD)
7.1 4 PIN
7.2 8 PIN
7.3 16PIN
Note :
Dimensions in millimeters.
14/15
BNC-OD-FC002/A4
Rev.: -
Photocoupler
LTV-8x5 series
8. Naming rule
LTV- 8X5(1)-(2)-G
DEVICE PART NUMBER
(1) No suffix = Dual-in-Line package
M = Wide lead spacing package
S = Surface mounting package
(2) TAPING TYPE(TA,TA1,TP or none)
LTV-815 and LTV-825 have tape and reel solution.
Please refer to orientation of taping on Page P5-P7
(3) Halogen free option
Example : LTV-817S-TA1-G
LTV 8X5(1)(2) -V-G
DEVICE PART NUMBER
(3) VDE order option
(4) Halogen free option
Example : LTV815STA1-V-G
9. Notes:
LiteOn is continually improving the quality, reliability, function or design and LiteOn reserves the right to make changes
without further notices.
The products shown in this publication are designed for the general use in electronic applications such as office automation
equipment, communications devices, audio/visual equipment, electrical application and instrumentation.
For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control
equipment, medical equipment, etc, please contact our sales representatives.
When requiring a device for any ”specific” application, please contact our sales in advice.
If there are any questions about the contents of this publication, please contact us at your convenience.
The contents described herein are subject to change without prior notice.
Immerge unit’s body in solder paste is not recommended.
15/15
BNC-OD-FC002/A4
Rev.: -
很抱歉,暂时无法提供与“LTV-815M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.65816
- 200+0.26266
- 500+0.25391
- 1000+0.24959
