IL260E
IL260E
    NVECORP
    SOIC-16
    DGTL ISO 2.5KV GEN PURP 16SOIC
IL260E 数据手册
IL260/IL261/IL262 High Speed Five-Channel Digital Isolators Features IN1 OUT1 IN2 OUT2 IN3 OUT3 IN4 OUT4 IN5 OUT5 IL260 IN1 OUT1 IN2 OUT2 IN3 OUT3 IN4 OUT4 • • • • • • • • • • • • • • • High Speed: 110 Mbps 1.2 mA/channel typical quiescent current Very high isolation: 6 kVRMS Reinforced Isolation (VE-Series) 50 kV/μs typ.; 30 kV/μs min. common mode transient immunity No carrier or clock for low EMI emissions and susceptibility −40 to 85 °C operating temperature 44000 year barrier life Excellent magnetic immunity 2 ns typical pulse width distortion 100 ps pulse jitter 4 ns typical propagation delay skew 10 ns typical propagation delay 2 ns channel-to-channel skew IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized 0.15" and True 8™ mm 16-pin SOIC; 16-pin QSOP packages IL 14 26004 1 00 Functional Diagrams Applications • • • • • • ADCs and DACs Multiplexed data transmission Board-to-board communication Peripheral interfaces Equipment covered under IEC 61010-1 Edition 3 5 kVRMS rated IEC 60601-1 medical applications Description OUT5 IN5 IL261 NVE’s IL260-Series five-channel high-speed digital isolators are CMOS devices manufactured with NVE’s patented* spintronic Giant Magnetoresistive (GMR) technology. A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. IN1 OUT1 IN2 OUT2 IN3 OUT3 OUT4 IN4 OUT5 IN5 All transmit and receive channels operate at 110 Mbps over the full temperature and supply voltage range. The symmetric magnetic coupling barrier provides a typical propagation delay of only 10 ns and a pulse width distortion of 2 ns, achieving the best specifications of any isolator. The unique fifth channel can be is used to distribute isolated clocks or handshake signals to multiple delta-sigma A/D converters. High channel density makes these devices ideal for isolating ADCs and DACs, parallel buses and peripheral interfaces. Typical transient immunity of 50 kV/µs is unsurpassed. Performance is specified over the temperature range of −40 °C to +85 °C without derating. The five-channel devices provide the highest channel density available. Parts are available in ultraminiature 16-pin QSOPs, as well as 0.15"and 0.3"-wide SOIC packages. IL262 V-Series versions offer extremely high isolation voltage of 6 kVRMS, and true 8 mm creepage. IsoLoop is a registered trademark of NVE Corporation. *U.S. Patent number 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 REV. X (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 Absolute Maximum Ratings(1) Parameters Storage Temperature Junction Temperature Supply Voltage Input Voltage Output Voltage Output Current Drive Lead Solder Temperature ESD Symbol TS TJ VDD1,VDD2 VI VO IO Min. −55 −55 −0.5 −0.5 −0.5 −10 Typ. Max. 150 150 7 VDD + 0.5 VDD + 0.5 10 260 Units °C °C V V V mA °C kV Test Conditions Max. 85 100 5.5 VDD 0.8 1 Units °C °C V V V μs Test Conditions 2 10 sec. HBM Recommended Operating Conditions Parameters Ambient Operating Temperature Junction Temperature Supply Voltage Logic High Input Voltage Logic Low Input Voltage Input Signal Rise and Fall Times Symbol TA TJ VDD1,VDD2 VIH VIL tIR, tIF Min. −40 −40 2.5 2.4 0 Typ. 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation isoapps@nve.com IL260/IL261/IL262 Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10: “VE” version (Reinforced Isolation; VDE File Number 5016933-4880-0002) • Working Voltage (VIORM): 1200 VRMS (1700 VPK) with 20% Safety Factor; pollution degree 2 • Isolation voltage (VISO): 6000 VRMS • Surge immunity (VIOSM): 12.8 kVPK • Surge rating: 8000 V • Transient overvoltage (VIOTM): 6000 VPK • Each part tested at 2387 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 6000 VPK for 60 sec.; then 2122 VPK for 10 sec. with 5 pC partial discharge limit Standard versions (Basic Isolation; VDE File Number 5016933-4880-0001) • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating: 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit. • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit. • Working Voltage (VIORM; pollution degree 2): Package QSOP16 Narrow-body SOIC16 Wide-body SOIC16/True 8™ Part No. Suffix -1 -3 None Safety-Limiting Values Safety rating ambient temperature Safety rating power (180 °C) Supply current safety rating (total of supplies) Working Voltage 600 VRMS 700 VRMS 600 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) V-Series isolation grade 6 kV rating; tested at 7.2 kVRMS (10.2 kVPK) for 1 second; each lot sample tested at 6 kVRMS (8485 VPK) for 1 minute Standard isolation grade Each part tested at 3000 VRMS (4243 VPK) for 1 second; each lot sample tested at 2500 VRMS (3536 VPK) for 1 minute Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation isoapps@nve.com IL260/IL261/IL262 IL260 Pin Connections 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 IN1 GND1 IN2 IN3 IN4 VDD1 IN5 GND1 GND2 OUT5 OUT4 OUT3 OUT2 OUT1 GND2 VDD2 Input 1 Ground* Input 2 Input 3 Input 4 Supply Voltage 1 Input 5 Ground* Ground* Output 5 Output 4 Output 3 Output 2 Output 1 Ground* Supply Voltage 2 IN1 VDD2 GND1 GND2 IN2 OUT1 IN3 OUT2 IN4 OUT3 VDD1 OUT4 IN5 OUT5 GND1 GND2 IL260 IL261 Pin Connections 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 VDD1 GND1 IN1 IN2 IN3 IN4 OUT5 GND1 GND2 IN5 OUT4 OUT3 OUT2 OUT1 GND2 VDD2 Supply Voltage 1 Ground* Input 1 Input 2 Input 3 Input 4 Output 5 Ground* Ground* Input 5 Output 4 Output 3 Output 2 Output 1 Ground* Supply Voltage 2 VDD1 VDD2 GND1 GND2 IN1 OUT1 IN2 OUT2 IN3 OUT3 IN4 OUT4 OUT5 IN5 GND1 GND2 IL261 IL262 Pin Connections 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 VDD1 GND1 IN1 IN2 IN3 OUT4 OUT5 GND1 GND2 IN5 IN4 OUT3 OUT2 OUT1 GND2 VDD2 Supply Voltage 1 Ground* Input 1 Input 2 Input 3 Output 4 Output 5 Ground* Ground* Input 5 Input 4 Output 3 Output 2 Output 1 Ground* Supply Voltage 2 VDD1 VDD2 GND1 GND2 IN1 OUT1 IN2 OUT2 IN3 OUT3 OUT4 IN4 OUT5 IN5 GND1 GND2 IL262 *NOTE: Pins 2 and 8 are internally connected, as are pins 9 and 15. 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation isoapps@nve.com IL260/IL261/IL262 Parameters Input Quiescent Current Output Quiescent Current IL260 IL261 IL262 IL260 IL261 IL262 Logic Input Current Logic High Output Voltage Logic Low Output Voltage Maximum Data Rate Minimum Pulse Width(7) Propagation Delay Input to Output (High to Low) Propagation Delay Input to Output (Low to High) Pulse Width Distortion |tPHL−tPLH|(2) Propagation Delay Skew(3) Output Rise Time (10%–90%) Output Fall Time (10%–90%) Common Mode Transient Immunity (Output Logic High to Logic Low)(4) Channel-to-Channel Skew Dynamic Power Consumption(6) Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) 3.3 Volt Electrical Specifications (Tmin to Tmax) Symbol Min. Typ. Max. 300 400 IDD1 1.2 1.75 2.4 3.5 6 8.75 IDD2 4.8 7 3.6 5.25 Ii −10 10 VDD−0.1 VDD VOH 0.8 x VDD 0.9 x VDD 0 0.1 VOL 0.5 0.8 Switching Specifications (2.5 V 1014 5 VIO VIOSM 44000 Symbol Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance QSOP 0.15" SOIC16 0.3" SOIC16 QSOP 0.15" SOIC16 0.3" SOIC16 Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance 0.3" SOIC Power Dissipation QSOP 0.15" SOIC16 0.3" SOIC16 θJA θJC Test Conditions mm Barrier Life Parameter Units Thermal Characteristics Min. Typ. 100 82 67 9 8 12 θJA 46 θJC 9 Years Max. Per IEC 61000-4-5 100°C, 1000 VRMS, 60% CL activation energy Test Conditions Double-sided PCB in free air °C/W 2s2p PCB in free air per JESD51 675 675 1500 PD Units At maximum operating temperature mW Notes: 1. Absolute maximum means the device will not be damaged if operated under these conditions. It does not guarantee performance. 2. PWD is defined as |tPHL − tPLH|. %PWD is equal to PWD divided by pulse width. 3. tPSK is the magnitude of the worst-case difference in tPHL and/or tPLH between devices at 25°C. 4. CMH is the maximum common mode voltage slew rate that can be sustained while maintaining VO > 0.8 VDD2. CML is the maximum common mode input voltage that can be sustained while maintaining VO < 0.8 V. The common mode voltage slew rates apply to both rising and falling common mode voltage edges. 5. Device is considered a two terminal device: pins 1–8 shorted and pins 9–16 shorted. 6. Dynamic power consumption numbers are calculated per channel and are supplied by the channel’s input side power supply. 7. Minimum pulse width is the minimum value at which specified PWD is guaranteed. 8. The relevant test and measurement methods are given in the Electromagnetic Compatibility section on p. 8. 9. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin” (see diagram on p. 8). 10. 66,535-bit pseudo-random binary signal (PRBS) NRZ bit pattern with no more than five consecutive 1s or 0s; 800 ps transition time. 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation isoapps@nve.com IL260/IL261/IL262 Application Information Electrostatic Discharge Sensitivity IL260/IL261/IL262 parts have a maximum junction temperature of 110°C. Based on the specifications contained in this datasheet, the derating curve at typical operating conditions is as follows: This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Electromagnetic Compatibility IsoLoop Isolators have the lowest EMC footprint of any isolation technology. There are no internal clocks or carriers. IsoLoop Isolators’ Wheatstone bridge configuration and differential magnetic field signaling ensure excellent EMC performance against all relevant standards. These isolators are fully compliant with IEC 61000-6-1 and IEC 61000-6-2 standards for immunity, and IEC 61000-6-3, IEC 61000-6-4, CISPR, and FCC Class A standards for emissions. Immunity to external magnetic fields is even higher if the field direction is “end-to-end” rather than to “pin-to-pin” as shown in the diagram below: Power Supply Decoupling Both power supplies should be bypassed with 0.1 µF typical (0.047 µF minimum) capacitors as close as possible to the VDD pins. Ground planes for both GND1 and GND2 are highly recommended for data rates above 10 Mbps. Maintaining Creepage Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. Cross-axis Field Direction Dynamic Power Consumption IsoLoop Isolators achieve their low power consumption from the way they transmit data across the isolation barrier. By detecting the edge transitions of the input logic signal and converting these to narrow current pulses, a magnetic field is created around the GMR Wheatstone bridge. Depending on the direction of the magnetic field, the bridge causes the output comparator to switch following the input logic signal. Since the current pulses are narrow, about 2.5 ns, the power consumption is independent of mark-to-space ratio and solely dependent on frequency. This has obvious advantages over optocouplers, which have power consumption heavily dependent on mark-to-space ratio. Signal Status on Start-up and Shut Down To minimize power dissipation, input signals are differentiated and then latched on the output side of the isolation barrier to reconstruct the signal. This could result in an ambiguous output state depending on power up, shutdown and power loss sequencing. Therefore, the designer should consider including an initialization signal in the start-up circuit. Initialization consists of toggling the input either high then low, or low then high. Thermal Management IsoLoop Isolators are designed for low power dissipation and thermal performance, providing unmatched channel density for high-performance isolators. Nevertheless, package temperature rise should be considered when running multiple channels at high speed. Power consumption is higher at 5 volt operation than at 3.3 volts, and dynamic supply current is higher on the input side of the isolators than the output side, so thermal management is more important with five-volt input-side power supplies. 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation isoapps@nve.com IL260/IL261/IL262 Application Diagram—Multi-Channel Delta-Sigma A/D Converter In a typical single-channel delta-sigma ADC, the system clock is located on the isolated side of the system and only four channels of isolation are required. With multiple ADCs configured in a channel-to-channel isolation configuration, however, clock jitter and edge placement accuracy of the system clock must be matched between ADCs. The best solution is to use a single clock on the system side and distribute the clock to each ADC. The five-channel IL261 is ideal, with the fifth channel used to distribute a single, isolated clock to multiple ADCs as shown below: Bridge Bias Delta Sigma A/D CS5532 Bridge + Bridge Isolation Boundary Serial Data Out Iso SD Out Serial Data In Iso SD In Data Clock Iso Data Clock Chip Select Iso CS Clock Generator Channel 1 IL261 OSC 2 Bridge Bias Delta Sigma A/D CS5532 Bridge + Bridge - Channel n Serial Data Out Iso SD Out Serial Data In Iso SD In Data Clock Iso Data Clock Chip Select Iso CS IL261 OSC 2 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation isoapps@nve.com IL260/IL261/IL262 Package Drawings Ultraminiature 16-pin QSOP Package (-1 suffix) Dimensions in inches (mm); scale = approx. 5X 0.188 (4.77) 0.197 (5.00) 0.020 (0.50) 0.029 (0.75) 0.050 (1.27) 0.056 (1.42) 0.060 (1.52) 0.069 (1.75) 0.150 (3.8) 0.157 (4.0) 0.228 (5.8) 0.244 (6.2) 0.004 (0.10) 0.010 (0.25) 0.025 (0.635) NOM NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.007 (0.20) 0.010 (0.25) 0.009 (0.2) 0.012 (0.3) 0.15" 16-pin SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.013 (0.3) 0.020 (0.5) NOM 0.007 (0.2) 0.013 (0.3) 0.386 (9.8) 0.394 (10.0) Pin 1 identified by either an indent or a marked dot 0.016 (0.4) 0.050 (1.3) 0.055 (1.40) 0.062 (1.58) 0.054 (1.4) 0.072 (1.8) 0.150 (3.81) 0.157 (3.99) 0.049 (1.24) 0.051 (1.30) 0.228 (5.8) 0.244 (6.2) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.004 (0.1) 0.012 (0.3) 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 0.3" 16-pin SOIC Package (no suffix) Dimensions in inches (mm); scale = approx. 5X 0.033 (0.85)* 0.043 (1.10) 0.260 (6.60)* 0.280 (7.11) 0.013 (0.3) 0.020 (0.5) 0.007 (0.2) 0.013 (0.3) 0.397 (10.08) 0.413 (10.49) 0.017 (0.43)* 0.022 (0.56) 0.016 (0.4) 0.050 (1.3) 0.007 (0.18)* 0.010 (0.25) 0.092 (2.34) 0.105 (2.67) Pin 1 identified by either an indent or a marked dot 0.08 (2.0) 0.10 (2.5) 0.292 (7.42)* 0.299 (7.59) 0.049 (1.24) 0.051 (1.30) 0.394 (10.00) 0.419 (10.64) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate *Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601. 0.004 (0.1) 0.012 (0.3) 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 Recommended Pad Layouts 4 mm x 5 mm 16-pin QSOP Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.05) 0.025 (0.635) 0.012 (0.30) 16 PLCS 0.275 (6.99) 0.15" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.06) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.275 (6.99) 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 0.3" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.317 (8.05) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.449 (11.40) 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 Available Parts Available Parts IL260-1E IL260-3E IL260E IL260VE IL261-1E IL261-3E IL261E IL261VE IL262-3E IL262E IL262VE Transmit Channels 5 5 5 5 4 4 4 4 3 3 3 Receive Channels 0 0 0 0 1 1 1 1 2 2 2 Isolation Voltage (RMS) 2.5 kV 2.5 kV 2.5 kV 6 kV 2.5 kV 2.5 kV 2.5 kV 6 kV 2.5 kV 2.5 kV 6 kV Package QSOP Narrow SOIC Wide SOIC Wide SOIC QSOP Narrow SOIC Wide SOIC Wide SOIC Narrow SOIC Wide SOIC Wide SOIC All part types are available on tape and reel. Ordering Information IL 260 V - 3 E TR13 Valid Part Numbers Bulk Package Blank = Tube TR7 = 7'' Tape and Reel TR13 = 13'' Tape and Reel Package Blank = 80/20 Tin/Lead Plating E = RoHS Compliant Package Type Blank = 0.3" 16-pin SOIC -1 = 0.15'' 16-pin QSOP -3 = 0.15'' 16-pin SOIC Grade Blank = Standard Isolation Voltage (2.5 kV) V = High Isolation Voltage (6 kV) IL260 IL260E IL260VE IL260-1E IL260-3 IL260-3E IL261 IL261E IL261VE IL261-1E IL261-3 IL261-3E IL262 IL262E IL262VE IL262-3 IL262-3E All IL260-Series part types are available on tape and reel. Base Part Number 260 = 5 Transmit Channels 261 = 4 Transmit Channels; 1 Receive Channel 262 = 3 Transmit Channels; 2 Receive Channel Product Family IL = Isolators RoHS COMPLIANT 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 Revision History ISB-DS-001-IL260/1/2-X August 2022 Change • Upgraded to IEC 60747-17 (VDE 0884-17):2021-10 (p. 3). • ISB-DS-001-IL260/1/2-W Increased Working Voltage ratings based on latest VDE testing (p. 3). Changes Reduced minimum supply voltage to 2.5 V (p. 2). • ISB-DS-001-IL260/1/2-V • Updated EMC standards. • Deleted minimum magnetic field immunity specifications (not 100% tested). • Updated thermal specifications (p. 7). Change VDE certification and UL approval for V-Series versions (6 kV reinforced isolation). • ISB-DS-001-IL260/1/2-U ISB-DS-001-IL260/1/2-T ISB-DS-001-IL260/1/2-S ISB-DS-001-IL260/1/2-R ISB-DS-001-IL260/1/2-Q Changes • Updated VDE certification standard to VDE V 0884-10. • Upgraded “VE” Version Surge Immunity specification to 12.8 kV. • Upgraded “VE” Version VDE 0884-10 rating to reinforced insulation. • Corrected QSOP pin width dimension (p. 10). Changes • Increased V-Series isolation voltage to 6 kVrms. • Increased typ. Total Barrier Thickness specification to 0.016 mm. • Increased CTI min. specification to ≥600 VRMS. Changes • Added V-Series 5 kV isolation voltage versions. • More detailed “Available Parts” table. Changes • Added QSOP packages (-1 suffix). • Revised and added details to thermal characteristic specifications (p. 2). • Added VDE 0884 Safety-Limiting Values (p. 3). • Added “Thermal Management” paragraph in Applications section. Change • ISB-DS-001-IL260/1/2-P IEC 60747-5-5 (VDE 0884) certification. Changes • Tighter quiescent current specifications. • Upgraded from MSL 2 to MSL 1. 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL260/IL261/IL262 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL260/1/2-X August 2022 17 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL260E
物料型号:NVE CORPORATION IL260/IL261/IL262 高速五通道数字隔离器。
器件简介: - 这些隔离器采用NVE专利的自旋电子巨磁电阻(GMR)技术制造。 - 具有独特的陶瓷/聚合物复合隔离层,提供出色的隔离效果和几乎无限的隔离寿命。
引脚分配: - IL260、IL261和IL262具有不同的引脚分配,文档中提供了详细的引脚连接图表。
参数特性: - 高速:110 Mbps。 - 典型静态电流:每通道1.2 mA。 - 非常高的隔离电压:6 kVRMS加强隔离(VE系列)。 - 典型共模瞬态抗扰度:50 kV/μs;最小30 kV/μs。 - 工作温度范围:-40至85°C。 - 隔离寿命:44000年。
功能详解: - 所有传输和接收通道在整个温度和供电电压范围内以110 Mbps运行。 - 对称的磁耦合隔离层提供了仅有10 ns的典型传播延迟和2 ns的脉冲宽度失真。
应用信息: - 适用于模数转换器(ADCs)和数模转换器(DACs)的隔离。 - 多路复用数据传输、板对板通信、外围接口等。
封装信息: - 提供0.15"和真正的8 mm 16引脚SOIC;16引脚QSOP封装。
IL260E 价格&库存
很抱歉,暂时无法提供与“IL260E”相匹配的价格&库存,您可以联系我们找货
