IL3685VE
IL3685VE
    NVECORP
    SOIC-16
    DGTLISO6KVRS422/RS48516SOIC
IL3685VE 数据手册
IL3685 Advanced Isolated RS-485 Transceivers Functional Diagrams DE Features • • • • • • • • • • • • • • ISODE D A B ISORO ISORI R RE IL3685-1 (QSOP) DE ISODE Applications XDE • • • • • D A B R 40 Mbps data rate 3 V to 5 V power supplies 20 ns propagation delay Hot-plug capable 50 kV/μs typ.; 30 kV/μs min. common mode transient immunity 44000 year barrier life 15 kV bus ESD protection Low EMC footprint Thermal shutdown protection PROFIBUS compliant 6 kVRMS Reinforced Isolation; 1.2 kVRMS Working Voltage (IL3685VE) IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized ATEX / IECEx certified for IS-to-IS intrinsically safe applications QSOP, 0.15", or 0.3" 16-pin packages RE PROFIBUS, PROFIBUS DP, and FMS networks Factory automation Industrial control networks Building environmental controls Equipment covered under IEC 61010-1 Edition 3 Description IL3685-Series are second-generation isolated, high-speed differential bus transceivers. The devices use NVE’s patented* spintronic Giant Magnetoresistance (GMR) technology and have advanced features such as hot-plug capability and PROFIBUS compliance. IL3685-3 (narrow-body) DE ISODE The wide-body version provides true 8 mm creepage. Narrow-body and QSOP packages offer unprecedented miniaturization. D A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. A B R The device is compatible with 3 V as well as 5 V input supplies, allowing interface to standard microcontrollers without additional level shifting. RE IL3685 (wide-body) VID (A-B) ≥ 200 mV ≤−200mV Open ≥ 1.5 V ≤−1.5 V ≥ 1.5 V ≤−1.5 V DE L L L H H H H RE L L L L L H H R H L H H L Z Z D X X X H L H L X L H Z X Mode Current limiting and thermal shutdown features protect against output short circuits and bus contention that may cause excessive power dissipation. Receiver inputs feature a “fail-safe if open” design, ensuring a logic high R-output if A/B are floating. Notes Receive Drive Disabled A/B failsafe R reads back D information R tri-state (no output) R tri-state; A/B failsafe IsoLoop® is a registered trademark of NVE Corporation. *U.S. Patent number 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 REV. Z (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Absolute Maximum Ratings(7) Parameter Storage Temperature Junction Temperature Voltage Range at A or B Bus Pins Supply Voltage(1) Digital Input Voltage Digital Output Voltage ESD (all bus nodes) Symbol TS TJ VDD1, VDD2 Min. −55 −55 Typ. −7 −0.5 −0.5 −0.5 15 Max. 150 150 Units °C °C 12 7 VDD + 0.5 VDD + 1 V V V V kV Test Conditions HBM Recommended Operating Conditions Parameter Ambient Operating Temperature Junction Temperature Symbol VDD1 VDD2 TA TJ High-Level Digital Input Voltage VIH Low-Level Digital Input Voltage Differential Input Voltage(2) High-Level Output Current (Driver) High-Level Digital Output Current (Receiver) Low-Level Output Current (Driver) Low-Level Digital Output Current (Receiver) Digital Input Signal Rise and Fall Times VIL VID IOH Supply Voltage Min. 3.0 4.5 −40 −40 2.4 3.0 0 Typ. IOH Max. 5.5 5.5 85 100 Units VDD1 V 0.8 +12 / −7 60 V V mA 8 mA V °C °C IOL −60 mA IOL −8 mA tIR, tIF Test Conditions VDD1 = 3.3 V VDD1 = 5.0 V DC Stable 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10: IL3685VE version (Reinforced Isolation; VDE File Number 5016933-4880-0002) • Working Voltage (VIORM): 1200 VRMS (1700 VPK) with 20% Safety Factor; pollution degree 2 • Isolation voltage (VISO): 6000 VRMS • Surge immunity (VIOSM): 12.8 kVPK • Surge rating: 8000 V • Transient overvoltage (VIOTM): 6000 VPK • Each part tested at 2387 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 6000 VPK for 60 sec.; then 2122 VPK for 10 sec. with 5 pC partial discharge limit Standard versions (Basic Isolation; VDE File Number 5016933-4880-0001) • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating: 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit. • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit. • Working Voltage (VIORM; pollution degree 2): Package QSOP16 Narrow-body SOIC16 Wide-body SOIC16/True 8™ Part No. Suffix -1 -3 None Safety-Limiting Values Safety rating ambient temperature Safety rating power (180 °C) Supply current safety rating (total of supplies) Working Voltage 600 VRMS 700 VRMS 600 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) Standard isolation grade 2500 V rating; each part tested at 3000 VRMS (4243 VPK) for 1 second; each lot sample tested at 2500 VRMS (3536 VPK) for 1 minute. V-Series isolation grade 6 kV rating; each part tested at 7.2 kVRMS (10.2 kVPK) for 1 second; each lot sample tested at 6 kVRMS (8485 VPK) for 1 minute. Intrinsically Safe Certification • IL3685VE is ATEX / IEC 60079-0 / 60079-11 certified Intrinsically Safe (IS) for use in IS to IS applications. • 500 VRMS rating. Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 IL3685-1 (QSOP Package) Pin Connections 1 VDD1 2 R Input power supply. 3 GND1 Input power supply ground return. 4 RE Read data enable (if RE is high, R= high impedance). 5 DE Drive enable (HIGH if left unconnected). 6 D 7, 8 NC 9 B 10 VDD2X 11 A Output data from bus. Data input to bus. No internal connection. Inverting bus line. Output transceiver power supply (normally connected to pin 16). Non-inverting bus line. 12 ISORO Isolated R output (should be externally connected to pin 15; no other connection should be made). 13 ISODE Isolated DE output. 14 GND2 Output power supply ground return. 15 ISORI Isolated R input (should be connected to pin 12; no other connection should be made). 16 VDD2I Output isolation power supply (normally connected to pin 10). VDD1 1 16 VDD2 R 2 15 ISORI GND1 3 14 GND2 RE 4 13 ISODE DE 5 12 ISORO D 6 11 A NC 7 10 VDD2X NC 8 9 B IL3685-1 IL3685-3 (0.15" Narrow-Body SOIC) Pin Connections 1 VDD1 Input power supply. 2 GND1 Input power supply ground return. 3 R 4 RE Read data enable (if RE is high, R= high impedance). 5 D Data input to bus. 6 DE Drive enable (HIGH if left unconnected). 7, 8 NC No internal connection. 9 GND2X 10 XDE Output data from bus. Output transceiver ground return. (normally connected to pin 15). Transceiver Device Enable input enables the transceiver from the bus side, or is connected to ISODE to enable the transceiver from the controller-side DE input (this input should not be left unterminated). VDD1 1 16 VDD2I GND1 2 15 GND2I R 3 14 ISODE RE 4 13 VDD2X D 5 12 B DE 6 11 A 11 A Non-inverting bus line. NC 7 10 XDE 12 B Inverting bus line. NC 8 9 GND2X VDD2X Output transceiver power supply (normally connected to pin 16). 14 ISODE Isolated DE output (normally connected to pin 10). 15 GND2I Output isolation power supply ground return. (normally connected to pin 9). 16 VDD2I Output isolation power supply (normally connected to pin 13). 13 IL3685-3 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 IL3685 (0.3" SOIC Wide-Body SOIC) Pin Connections 1 VDD1 Input power supply. 2 GND1 Input power supply ground return (pin 2 is internally connected to pin 8). 3 R 4 RE Read data enable (if RE is high, R= high impedance). 5 DE Drive enable (HIGH if left unconnected). VDD1 1 16 VDD2 Data input to bus. GND1 2 15 GND2 Output data from bus. 6 D 7 NC 3 14 NC GND1 Input power supply ground return (pin 8 is internally connected to pin 2). R 8 RE 4 13 B 9 GND2 Output power supply ground return (pin 9 is internally connected to pin 15). DE 5 12 A 10 ISODE Isolated DE output for use in PROFIBUS applications where the state of the isolated drive enable node needs to be monitored. D 6 11 NC NC 7 10 ISODE GND1 8 9 GND2 No internal connection. 11 NC No internal connection. 12 A Non-inverting bus line. 13 B Inverting bus line. 14 NC 15 GND2 Output power supply ground return (pin 15 is internally connected to pin 9). 16 VDD2 Output power supply. IL3685 No internal connection. 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Driver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Parameter Symbol Min. Typ. Max. Units Output voltage VO VDD V Differential Output Voltage(2) |VOD1| VDD V Differential Output Voltage(2) |VOD2| 2.1 3 3.5 V Differential Output Voltage(2) Change in Magnitude of Differential Output Voltage(4) Common Mode Output Voltage Change in Magnitude of Common Mode Output Voltage(4) High Level Input Current Low Level Input Current Absolute |Short-circuit Output Current| VOD3 1.9 Test Conditions IO = 0 IO = 0 RL = 54 Ω −7 V < VCM < 12 V; RL = 60 Ω 3.5 V Δ|VOD| ±0.2 V RL = 54 Ω or 100 Ω VOC 3 V RL = 54 Ω or 100 Ω Δ|VOC| ±0.2 V RL = 54 Ω or 100 Ω IIH IIL IOS 10 −10 250 μA μA mA VI = 3.5 V VI = 0.4 V −7 V < VO < 12 V Receiver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Parameter Symbol Min. Typ. Max. Units Positive-going Input Threshold VIT+ 0.2 V Voltage Negative-going Input Threshold VIT− −0.2 V Voltage Hysteresis Voltage (VIT+ − VIT−) VHYS 28 mV Differential Bus Input Capacitance CD 9 12 pF High Level Digital Output Voltage VOH Low Level Digital Output Voltage VOL 0.2 V High-impedance-state output current Line Input Current IOZ II ±1 220 −160 Input Resistance Bus-Side Supply Current RI IDD2 μA μA μA kΩ mA Bus-Side Dynamic Supply Current VDD – 0.2 VDD V 54 5 1 0.8 ΔIDD2/ΔfIN 16 Test Conditions −7 V < VCM < 12 V −7 V < VCM < 12 V VCM = 0 V, T = 25°C VID = 200 mV IOH = −20 μA VID= −200 mV IOH = 20 μA VO = 0.4 to (VDD2−0.5) V VI = 12 V VI = −7 V RT = ∞ RT = 60 Ω Power Consumption Parameter Controller-Side Quiescent Current VDD1 = 3.3 V VDD1 = 5 V Tmin to Tmax and VDD2 = 5 V unless otherwise stated Symbol Min. Typ. Max. 3 4 IDD1 4 6 Bus-Side Quiescent Supply Current IDD2 5 Controller-Side Dynamic Supply Current IDD1 0.22 1 0.8 Bus-Side Dynamic Supply Current ΔIDD2/ΔfIN 16 Units mA mA mA/Mbps Test Conditions fIN = 0 Hz Outputs Enabled; RT = ∞; fIN = 0 Hz ; VDD2X connected to VDD2I if applicable VDD1 = 3.3 V RT = ∞ RT = 60 Ω 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Switching Characteristics Parameter Data Rate Propagation Delay(5) Pulse Skew(6) Limit(3) Skew Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Parameter Data Rate Propagation Delay(5) Pulse Skew(6) Limit(3) Skew Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Symbol VDD1 = 5 V, VDD2 = 5 V Min. Typ. 40 Max. Units Mbps tPD 20 30 ns tSK(P) 1 5 ns tSK(LIM) tPZH tPZL tPHZ tPLZ 2 15 15 15 15 10 30 30 30 30 ns ns ns ns ns |CMH|,|CML| Symbol 30 50 VDD1 = 3.3 V, VDD2 = 5 V Min. Typ. 40 kV/μs Max. Units Mbps tPD 25 35 ns tSK(P) 2 5 ns tSK(LIM) tPZH tPZL tPHZ tPLZ 4 17 17 17 17 10 30 30 30 30 ns ns ns ns ns |CMH|,|CML| 30 50 kV/μs Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF RL = 54 Ω, CL = 50 pF CL = 15 pF CL= 15 pF CL = 15 pF CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF RL = 54 Ω, CL = 50 pF CL = 15 pF CL= 15 pF CL = 15 pF CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Magnetic Field Immunity(8) Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) HPF HPM HOSC KX Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) HPF HPM HOSC KX VDD1 = 5 V, VDD2 = 5 V 3500 4500 4500 2.5 VDD1 = 3.3 V, VDD2 = 5 V 1500 2000 2000 2.5 A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz Insulation Specifications Parameter Symbol IL3685-1E Creepage Distance IL3685-3E (external) IL3685E Total Barrier Thickness (internal) Barrier Resistance Barrier Capacitance Leakage Current Comparative Tracking Index High Voltage Endurance AC (Maximum Barrier Voltage for Indefinite Life) DC Surge Immunity (“V” Version) Min. 3.2 4.0 8.03 0.013 Max. Units Per IEC 60601 ≥600 1000 1500 12.8 VDC kVPK VIO VIOSM Barrier Life Test Conditions mm 8.3 0.016 >1014 7 0.2 mm Ω pF μARMS VRMS VRMS RIO CIO CTI Typ. 44000 Years 500 V f = 1 MHz 240 VRMS, 60 Hz Per IEC 60112 At maximum operating temperature Per IEC 61000-4-5 100°C, 1000 VRMS, 60% CL activation energy Thermal Characteristics Parameter Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance Symbol QSOP 0.15" SOIC 0.3" SOIC QSOP 0.15" SOIC 0.3" SOIC Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance 0.3" SOIC Power Dissipation QSOP 0.15" SOIC 0.3" SOIC Min. θJA θJC Typ. 100 82 67 9 8 12 θJA 46 θJC 9 Max. Test Conditions Double-sided PCB in free air °C/W 2s2p PCB in free air per JESD51 675 700 1500 PD Units mW 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617(952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Notes: 1. All voltages are with respect to network ground except differential I/O bus voltages. 2. Differential input/output voltage is measured at the noninverting terminal A with respect to the inverting terminal B. 3. Skew limit is the maximum propagation delay difference between any two devices at 25°C. 4. Δ|VOD| and Δ|VOC| are the changes in magnitude of VOD and VOC, respectively, that occur when the input is changed from one logic state to the other. 5. Includes 10 ns read enable time. Maximum propagation delay is 25 ns after read assertion. 6. Pulse skew is defined as |tPLH – tPHL| of each channel. 7. Absolute Maximum specifications mean the device will not be damaged if operated under these conditions. It does not guarantee performance. 8. The relevant test and measurement methods are given in the Electromagnetic Compatibility section. 9. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin.” 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Pinout Differences Between Packages The QSOP (IL3685-1E) and narrow-body (IL3685-3E) versions are designed for minimum board area in densely-populated PCAs. Both have pin sets that should be connected externally for normal operation, but that can be used for testing, trouble-shooting, or special purposes. The widebody version (IL3685E) has redundant ground pins for layout flexibility. The narrow-body version provides a separate isolated DE output (ISODE) and Transceiver Device Enable (XDE) input. ISODE follows the Device Enable input (DE). XDE can be used to enable and disable the transceiver from the bus side, or connected to ISODE to enable and disable the transceiver from the DE controller-side input. The QSOP and narrow-body versions also provide separate bus-side power supply pins— VDD2X for the transceiver module and VDD2I for the isolation module. These should be externally connected for normal operation, but can be used separately for testing or troubleshooting. The QSOP version also has an “ISORI” input that can be used to test the controller-side “R” from the bus side. ISORI should be connected externally to “ISORO” for normal operation. ISORI and ISORO can be used for testing. The wide-body version has internal connections between the isolated DE output and the Transceiver Device Enable input, and well as between the two bus-side power supplies. Power Supply Decoupling VDD1 and VDD2 should be bypassed with 0.1 µF typical (47 nF minimum) capacitors as close as possible to the VDD pins. Maintaining Creepage Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. Electromagnetic Compatibility IL3685-Series Transceivers are fully compliant with IEC 61000-6-1 and IEC 61000-6-2 standards for immunity, and IEC 61000-6-3, IEC 61000-6-4, CISPR, and FCC Class A standards for emissions. The IsoLoop Isolator’s Wheatstone bridge configuration and differential magnetic field signaling ensure excellent EM immunity. Immunity to external magnetic fields is even higher if the field direction is “end-to-end” (rather than to “pin-to-pin”) as shown at right. 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Application Information Figures 1a, 1b, and 1c show typical connections to a bus and microcontroller for the three package versions, including external connections required for normal operation. Typical termination resistors, fail-safe resistors, and power supply decoupling capacitors are also included: VDD2 = 5 V VDD1 = 3.3 V C DD2 C DD1 0.1 µF 1 DE IL3685-1 0.1 µF 10 16 13 ISODE 5 Microcontroller CNTR-P D 6 R 2 RE 4 R FS-EXT 560 A 11 9 12 15 GND1 B R FS-EXT 560 14 Isolation Boundary 3 RT 120 GND2 Figure 1a. Typical QSOP transceiver connections. VDD2 = 5 V VDD1 = 3.3 V 0.1 µF 0.1 µF DE 6 D 5 R 3 IL3685-3 13 16 14 ISODE 15 GND2I 10 CNTR-P XDE R FS-EXT 390 11 RT 220 12 RE 4 2 GND1 Isolation Boundary Microcontroller 1 A B R FS-EXT 390 9 GND2X GND2 Figure 1b. Typical narrow-body transceiver connections. VDD2 = 5 V VDD1 = 3.3 V 47 nF 47 nF 1 DE IL3685 + 10 µF 16 ISODE 5 CNTR-P D R R FS-EXT 390 6 12 3 RT 220 13 RE 4 2 or 8 GND1 Isolation Boundary Microcontroller 10 9 or 15 A B R FS-EXT 390 GND2 Figure 1c. Typical wide-body transceiver connections. 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Transceiver Operation The transceiver block diagram is shown below: Brownout Detector VDD1 100 k VDD2 nominal DE Refresh Clock D RFS1 30 k A R B RFS2 30 k 100 k nominal RE GND Figure 2. Detailed transceiver block diagram. Receiver Features The receiver output “R” has tri-state capability via the active low RE input. Driver Features The driver features low propagation delay skew to maximize bit width and minimize EMI. Drivers have tri-state capability via the active-high DE input. Deterministic Power Up and Brownout Detection IL3685 parts have circuitry to disable the bus driver until the driver-side voltage (VDD2) reaches approximately 3.3 volts on power-up. The transceiver is disabled when the voltage drops below approximately 3.1 volts on power-down. This brownout circuitry ensures the transceiver does not “crash” the bus on power up, power down, or brownout, and eliminates the need for external power supply monitors. In addition, a patented refresh circuit maintains the correct transceiver output state with respect to data input (DC correctness). The refresh circuit ensures the bus outputs will follow the Function Table shown on Page 1 after power up. Hot Plug Operation Deterministic power-up allows IL3685 nodes to “hot plug” into the bus, since the bus driver will be in a high-impedance state until the bus supply is enough for the bus driver to operate. Unpowered Nodes Unpowered nodes (i.e., either no VDD1 or VDD2 power) result in high impedances on the “A” and “B” bus lines , so the unpowered node will not disturb bus operation. Internal Fail-Safe Biasing Resistors Internal “fail-safe biasing” forces a logic high state on “R” with an open-circuit between the bus “A” and “B” lines, or when no drivers are active on the bus. Rigorous PROFIBUS Compatibility Unlike most other transceivers, IL3685E transceivers meet stringent PROFIBUS standards for maximum differential output voltage as well as other PROFIBUS requirements. Thermal Shutdown The bus driver is disabled when the driver die temperature exceeds approximately 150 °C, and re-enabled when the die temperature drops below approximately 135 °C. The receiver section continues to operate during thermal shutdown. 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Termination and Fail-Safe Biasing Internal Biasing Resistors “Fail-safe biasing” forces a logic high state on “R” in response to an open-circuit condition between the bus “A” and “B” lines, or when no drivers are active on the bus. IL3000-Series Isolated Transceivers include internal pull-up and pull-down resistors of approximately 30 kΩ in the receiver section (RFS-INT in Figure 3 below): 5 V RFS-EXT VDD 30K RFS-INT A RT RT R RFS-EXT RFS-INT 30K B GND Figure 3. Termination and internal and external fail-safe biasing resistors. These internal resistors ensure fail-safe operation if there are no termination resistors and up to four RS-485 worst-case Unit Loads of 12 kΩ. Termination Resistors Termination resistors should be on both ends of the network to minimize reflections. Values should be selected to match cable impedance; 220 Ω resistors are typical for PROFIBUS. External Fail-Safe Biasing Resistors Termination resistors bring the differential voltage across the conductor pair close to zero with no active drivers. In this case, the idle bus is indeterminate and susceptible to noise. External fail-safe biasing resistors (labeled RFS-EXT in Figure 3) at one end of the bus ensure fail-safe operation with a terminated bus. Biasing should provide at least 200 mV across the conductor pair to meet the RS-485 input sensitivity specification. Fail-safe resistors of 390 Ω are common for PROFIBUS. They should be on only one node of the network. Using the same value for pull-up and pull-down biasing resistors maintains balance for positive- and negative going transitions. 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Package Drawings Ultraminiature 16-pin QSOP Package (-1 suffix) Dimensions in inches (mm); scale = approx. 5X 0.188 (4.77) 0.197 (5.00) 0.020 (0.50) 0.029 (0.75) 0.050 (1.27) 0.056 (1.42) 0.060 (1.52) 0.069 (1.75) 0.150 (3.8) 0.157 (4.0) 0.228 (5.8) 0.244 (6.2) 0.025 (0.635) NOM NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.007 (0.20) 0.010 (0.25) 0.013 (0.3) 0.020 (0.5) 0.004 (0.10) 0.010 (0.25) 0.15" 16-pin Narrow-Body SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.013 (0.3) 0.020 (0.5) NOM 0.007 (0.2) 0.013 (0.3) 0.386 (9.8) 0.394 (10.0) Pin 1 identified by either an indent or a marked dot 0.016 (0.4) 0.050 (1.3) 0.054 (1.37) 0.062 (1.58) 0.054 (1.4) 0.072 (1.8) 0.150 (3.81) 0.157 (3.99) 0.049 (1.24) 0.051 (1.30) 0.228 (5.8) 0.244 (6.2) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.004 (0.1) 0.012 (0.3) 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 0.3" 16-pin Wide-Body SOIC Package (no suffix) Dimensions in inches (mm); scale = approx. 5X 0.033 (0.85)* 0.043 (1.10) 0.260 (6.60)* 0.280 (7.11) 0.013 (0.3) 0.020 (0.5) 0.007 (0.2) 0.013 (0.3) 0.397 (10.08) 0.413 (10.49) 0.017 (0.43)* 0.022 (0.56) 0.016 (0.4) 0.050 (1.3) 0.007 (0.18)* 0.010 (0.25) 0.092 (2.34) 0.105 (2.67) Pin 1 identified by either an indent or a marked dot 0.08 (2.0) 0.10 (2.5) 0.292 (7.42)* 0.299 (7.59) 0.049 (1.24) 0.051 (1.30) 0.394 (10.00) 0.419 (10.64) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate *Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601. 0.004 (0.1) 0.012 (0.3) 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Recommended Pad Layouts 4 mm x 5 mm 16-pin QSOP Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.05) 0.025 (0.635) 0.012 (0.30) 16 PLCS 0.275 (6.99) 0.15" Narrow-Body 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.06) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.275 (6.99) 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 0.3" 16-pin Wide-Body SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.317 (8.05) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.449 (11.40) 17 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Ordering Information and Valid Part Numbers IL 36 85 -3 V E TR13 Valid Part Numbers IL3685E IL3685E TR13 IL3685-3E IL3685-3E TR13 IL3685-1E TR7 IL3685-1E TR13 Bulk Packaging Blank = Tube TR13 = 13'' Tape and Reel Package E = RoHS Compliant Isolation Grade Blank = 2.5 kV Basic Isolation V = 6 kV Reinforced Isolation IL3685VE IL3685VE TR13 Package Type Blank = 0.3'' SOIC -3 = 0.15'' SOIC -1 = 0.15'' QSOP Channel Configuration 85 = RS-485 Base Part Number 36 = 40 Mbps, PROFIBUS compliant Product Family IL = Isolators RoHS COMPLIANT 18 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Revision History ISB-DS-001-IL3685-Z August 2022 ISB-DS-001-IL3685-Y ISB-DS-001-IL3685-X Changes • Clarified truth table (p. 1). Upgraded VDE approval to IEC 60747-17 (VDE 0884-17):2021-10 (p. 3). • Increased Working Voltage ratings based on latest VDE testing (p. 3). • Added IL3685VE ATEX / IEC 60079 certification for intrinsically safe applications (p. 3). • Changes • Upgrade from VDE V 0884-10 to VDE V 0884-11 / IEC 60747-17 (p. 3). • Separate power consumption specifications section; added dynamic power consumption (p. 6). • Revised thermal specifications (p. 8). • More details on power up, hot plug, brownout detection, and unpowered nodes (p. 12). • Updated EMC standards. Change • ISB-DS-001-IL3685-W Change • ISB-DS-001-IL3685-V ISB-DS-001-IL3685-T ISB-DS-001-IL3685-S ISB-DS-001-IL3685-R ISB-DS-001-IL3685-Q Dropped 10 µF tantalum capacitor recommendation (p. 8). Change • ISB-DS-001-IL3685-U Improved thermal specifications based on new test data (p. 2). Added IL3685VE to the list of available parts (p. 16). Changes • Refined thermal resistance specifications based on additional test data (p. 2). • Added worst-case operating conditions to max. ambient operating temperature spec. • Deleted minimum magnetic field immunity specifications (p. 8) since it is not 100% tested. Changes • Added QSOP version (IL3685-1E). • VDE certification and UL approval for V-Series version (6 kV reinforced isolation). Changes • Eliminated inconsistent Driver Section output current specification. • Improved Receiver Section Line Input Current and Input Resistance specifications. Changes • Updated VDE certification standard to VDE V 0884-10. • Upgraded “V” Version Surge Immunity specification to 12.8 kV. • Upgraded “V” Version VDE 0884-10 rating to reinforced insulation. Changes • Increased V-Series isolation voltage to 6 kVrms. • Increased typ. Total Barrier Thickness specification to 0.016 mm. • Increased CTI min. specification to ≥600 VRMS. 19 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 20 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3685 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL3685-Z August 2022 21 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL3685VE 价格&库存
很抱歉,暂时无法提供与“IL3685VE”相匹配的价格&库存,您可以联系我们找货
