IL3522ETR13
IL3522ETR13
    NVECORP
    SOIC-16
    RS422, RS485 Digital Isolator 2500Vrms 3 Channel 40Mbps 30kV/µs CMTI 16-SOIC (0.295", 7.50mm Width)
IL3522ETR13 数据手册
IL3522 High Speed Isolated RS485/RS422 Transceiver Functional Diagram DE Features • • • • • • • • • • • • • ISODE Y Z D A B R RE IL3522 40 Mbps data rate 20 ns propagation delay 1 ns pulse skew 6 kVRMS Reinforced Isolation / 12.8 kV surge / 1.2 kVRMS WV (IL3522VE) 50 kV/μs typ.; 30 kV/μs min. common mode transient immunity 3 V to 5 V power supplies 44000 year barrier life 15 kV bus ESD protection Low EMC footprint Thermal shutdown protection −40 °C to +85 °C temperature range IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized 16-pin JEDEC-standard True 8™ mm SOIC packages Applications IL3522 Receiver RE H L L L R Z H L H V(A−B) X ≥ 200 mV ≤−200 mV Open IL3522 Driver DE L H H D X H L V(Y−Z) Z ≥2V ≤−2 V H = High Level, L = Low Level X = Irrelevant, Z = High Impedance • • • • • Factory automation Industrial control networks Building environmental controls Equipment covered under IEC 61010-1 Edition 3 5 kVRMS rated IEC 60601-1 medical applications Description The IL3522 is a galvanically isolated, high-speed differential bus transceiver, designed for bidirectional data communication on balanced transmission lines. The device uses NVE’s patented* spintronic Giant Magnetoresistance (GMR) technology. A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. The IL3522 delivers an exceptional 2.3 V differential output into a 54 Ω load over the supply range of 4.5 V to 5.5 V. This provides better data integrity over longer cable lengths, even at data rates as high as 40 Mbps. The device is also compatible with 3 V supplies, allowing interface to standard microcontrollers without additional level shifting. Current limiting and thermal shutdown features protect against output short circuits and bus contention that may cause excessive power dissipation. Receiver inputs feature a “fail-safe if open” design, ensuring a logic high R-output if A/B are floating. IsoLoop® is a registered trademark of NVE Corporation. *U.S. Patent number 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 REV. T (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Absolute Maximum Ratings(7) Parameters Storage Temperature Junction Temperature Voltage Range at any Bus Pin Supply Voltage (1) Digital Input Voltage Digital Output Voltage ESD (all bus nodes) Symbol TS TJ VDD1, VDD2 Min. −55 −55 −7 −0.5 −0.5 −0.5 15 Typ. Min. 3.0 4.5 −40 −40 2.4 3.0 0 Typ. Max. 150 150 12 7 VDD + 0.5 VDD + 1 Units °C °C V V V V kV Test Conditions Max. 5.5 5.5 85 100 Units Test Conditions VDD1 V 0.8 +12/−7 60 V V mA 8 mA HBM Recommended Operating Conditions Parameters Ambient Operating Temperature Junction Temperature Symbol VDD1 VDD2 TA TJ High-Level Digital Input Voltage VIH Low-Level Digital Input Voltage Differential Input Voltage (2) High-Level Output Current (Driver) High-Level Digital Output Current (Receiver) Low-Level Output Current (Driver) Low-Level Digital Output Current (Receiver) Digital Input Signal Rise and Fall Times VIL VID IOH Supply Voltage IOH V °C °C IOL −60 mA IOL −8 mA tIR, tIF VDD1 = 3.3 V VDD1 = 5.0 V DC Stable 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10: IL3522VE version (Reinforced Isolation; VDE File Number 5016933-4880-0002) • Working Voltage (VIORM): 1200 VRMS (1700 VPK) with 20% Safety Factor; pollution degree 2 • Isolation voltage (VISO): 6000 VRMS • Surge immunity (VIOSM): 12.8 kVPK • Surge rating: 8000 V • Transient overvoltage (VIOTM): 6000 VPK • Each part tested at 2387 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 6000 VPK for 60 sec.; then 2122 VPK for 10 sec. with 5 pC partial discharge limit Standard IL3522E version (Basic Isolation; VDE File Number 5016933-4880-0001) • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating: 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit. • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit. • Working Voltage (VIORM; pollution degree 2): Package QSOP16 Narrow-body SOIC16 Wide-body SOIC16/True 8™ Part No. Suffix -1 -3 None Safety-Limiting Values Safety rating ambient temperature Safety rating power (180 °C) Supply current safety rating (total of supplies) Working Voltage 600 VRMS 700 VRMS 600 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) Standard isolation grade 2500 V rating; each part tested at 3000 VRMS (4243 VPK) for 1 second; each lot sample tested at 2500 VRMS (3536 VPK) for 1 minute. V-Series isolation grade 6 kV rating; each part tested at 7.2 kVRMS (10.2 kVPK) for 1 second; each lot sample tested at 6 kVRMS (8485 VPK) for 1 minute. Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 IL3522 Pin Connections 1 VDD1 Input Power Supply 2 GND1 Input Power Supply Ground Return (pin 2 is internally connected to pin 8) 3 R 4 RE Read Data Enable (if RE is high, R = high impedance) 5 DE Drive Enable 6 D 7 NC 8 GND1 Input Power Supply Ground Return (pin 8 is internally connected to pin 2) 9 GND2 Output Power Supply Ground Return (pin 9 is internally connected to pin 15) 10 ISODE Isolated DE Output for use in Profibus applications where the state of the isolated drive enable node needs to be monitored 11 Y Y Bus (Drive – True) 12 Z Z Bus (Drive – Inverse) 13 B B Bus (Receive – Inverse) 14 A A Bus (Receive – True) 15 GND2 Output Power Supply Ground Return (pin 15 is internally connected to pin 9) 16 VDD2 Output Power Supply Output Data from Bus Data Input to Bus VDD1 VDD2 GND1 GND2 R A RE B DE Z D Y No Internal Connection NC ISODE GND2 GND1 IL3522 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Driver Section Electrical Specifications are Tmin to Tmax and VDD = 4.5 V to 5.5 V, unless otherwise stated. Parameters Symbol Min. Typ. Input Clamp Voltage VIK Output voltage VO Differential Output Voltage(8) |VOD1| Differential Output Voltage(8) |VOD2| 2.5 3 Differential Output Voltage(8) Change in Magnitude of Differential Output Voltage(4) Common Mode Output Voltage Change in Magnitude of Common Mode Output Voltage(4) Max. −1.5 VDD VDD 5 Units V V V V 5 V Δ|VOD| ±0.2 V RL = 54 Ω or 100 Ω VOC 3 V RL = 54 Ω or 100 Ω Δ|VOC| ±0.2 V RL = 54 Ω or 100 Ω VOD3 2.3 Output Current IO High Level Input Current Low Level Input Current Absolute |Short-circuit Output Current| IIH IIL 1 −0.8 10 −10 IOS 250 mA Test Conditions IL = −18 mA IO = 0 IO = 0 RL = 54 Ω, VDD = 5 V −7 V > VCM < 12 V; RL = 54 Ω, VDD = 4.5 V Output Disabled, VO = 12 VO = −7 μA μA VI = 3.5 V VI = 0.4 V mA −7 V > VO < 12 V Receiver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Parameters Symbol Min. Typ. Max. Units Positive-going Input Threshold VIT+ 0.2 V Voltage(2) Negative-going Input Threshold VIT−0.2 V Voltage(2) Hysteresis Voltage (VIT+ − VIT-) VHYS 40 mV High Level Digital Output Voltage VOH VDD – 0.2 VDD V Low Level Digital Output Voltage VOL 0.2 V High-impedance-state output current Line Input Current IOZ II ±1 1 −0.8 Input Resistance RI μA mA mA kΩ 20 Test Conditions −7 V > VCM < 12 V −7 V > VCM < 12 V VCM = 0 V, T = 25°C VID = 200 mV IOH = −20 μA VID = −200 mV IOH = 20 μA VO=0.4 to (VDD2−0.5) V VI = 12 V VI = −7 V Power Consumption Parameter Controller-Side Quiescent Current VDD1 = 3.3 V VDD1 = 5 V Tmin to Tmax and VDD2 = 5 V unless otherwise stated Symbol Min. Typ. Max. 3 4 IDD1 4 6 Bus-Side Quiescent Supply Current IDD2 5 Controller-Side Dynamic Supply Current IDD1 0.22 1 0.8 Bus-Side Dynamic Supply Current ΔIDD2/ΔfIN 16 Units mA mA mA/Mbps Test Conditions fIN = 0 Hz Outputs Enabled; RT = ∞; fIN = 0 Hz VDD1 = 3.3 V RT = ∞ RT = 60 Ω 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Switching Characteristics Parameters Data Rate Propagation Delay(5) Pulse Skew(6) Limit(3) Skew Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Parameters Data Rate Propagation Delay(5) Pulse Skew(6) Skew Limit(3) Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Symbol VDD1 = 5 V, VDD2 = 5 V Min. Typ. 40 tPD 27 35 ns tSK(P) 1 6 ns tSK(LIM) tPZH tPZL 2 15 15 12 25 25 ns ns ns Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF RL = 54 Ω, CL = 50 pF CL = 15 pF CL = 15 pF tPHZ 15 25 ns CL = 15 pF tPLZ 15 25 ns CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns |CMH|,|CML| Symbol 30 Max. Units Mbps 50 VDD1 = 3.3 V, VDD2 = 5 V Min. Typ. 40 kV/μs tPD 30 38 ns tSK(P) 1 6 ns tSK(LIM) tPZH tPZL 4 17 17 12 27 27 ns ns ns Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF RL = 54 Ω, CL = 50 pF CL = 15 pF CL = 15 pF tPHZ 17 27 ns CL = 15 pF tPLZ 17 27 ns CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns |CMH|,|CML| 30 Max. Units Mbps 50 kV/μs Magnetic Field Immunity(13) Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(14) HPF HPM HOSC KX Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(14) HPF HPM HOSC KX VDD1 = 5 V, VDD2 = 5 V 3500 4500 4500 2.5 VDD1 = 3.3 V, VDD2 = 5 V 1500 2000 2000 2.5 A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz Test Conditions Per IEC 60601 ≥600 1000 Units mm mm Ω pF μARMS VRMS VRMS 1500 12.8 VDC kVPK Insulation Specifications Parameters Creepage Distance (external) Total Barrier Thickness (internal) Barrier Resistance Barrier Capacitance Leakage Current Comparative Tracking Index High Voltage Endurance AC (Maximum Barrier Voltage for Indefinite Life) DC Surge Immunity (“V” Versions) Symbol Min. 8.03 0.013 Typ. 8.3 0.016 >1014 7 0.2 RIO CIO CTI Max. VIO VIOSM Barrier Life 44000 Years 500 V f = 1 MHz 240 VRMS, 60 Hz Per IEC 60112 At maximum operating temperature Per IEC 61000-4-5 100°C, 1000 VRMS, 60% CL activation energy 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Thermal Characteristics Parameter Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance Power Dissipation Symbol Min. Typ. θJA 67 θJC 12 θJA 46 θJC 9 Max. Units Test Conditions Double-sided PCB in free air °C/W PD 2s2p PCB in free air per JESD51 1500 mW Notes: 1. All voltages are with respect to network ground except differential I/O bus voltages. 2. Differential input voltage is measured at the noninverting terminal A with respect to the inverting terminal B. 3. Skew limit is the maximum propagation delay difference between any two devices at 25°C. 4. Δ|VOD| and Δ|VOC| are the changes in magnitude of VOD and VOC, respectively, that occur when the input is changed from one logic state to the other. 5. Includes 10 ns read enable time. Maximum propagation delay is 25 ns after read assertion. 6. Pulse skew is defined as |tPLH – tPHL| of each channel. 7. Absolute Maximum specifications mean the device will not be damaged if operated under these conditions. It does not guarantee performance. 8. Differential output voltage is measured at terminal Y with respect to Z. 9. The relevant test and measurement methods are given in the Electromagnetic Compatibility section. 10. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin.” 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Power Supply Decoupling VDD1 and VDD2 should be bypassed with 0.1 µF typical (0.047 µF minimum) capacitors as close as possible to VDD pins. Maintaining Creepage Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. DC Correctness The IL3522 incorporates a patented refresh circuit to maintain the correct output state with respect to data input. At power up, the bus outputs will follow the Function Table shown on Page 1. The DE input should be held low during power-up to eliminate false drive data pulses from the bus. An external power supply monitor to minimize glitches caused by slow power-up and power-down transients is not required. Electromagnetic Compatibility The IL3522 is fully compliant with IEC 61000-6-1 and IEC 61000-6-2 standards for immunity, and IEC 61000-6-3, IEC 61000-6-4, CISPR, and FCC Class A standards for emissions. Immunity to external magnetic fields is even higher if the field direction is “end-to-end” (rather than to “pin-to-pin”) as shown in the diagram below: 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Application Information The following figure shows typical connections to a microcontroller. The schematic includes typical termination and fail-safe resistors, and power supply decoupling capacitors: VDD2 = 5 V VDD1 = 3.3 V C DD2 C DD1 47nF 1 5 47nF 16 D 6 11 12 R 3 14 13 RE 4 2 or 8 GND1 10µF 10 ISODE R FS-EXT 560R Y Z A RT 120R B Isolation Boundary Microcontroller DE IL3522 + C DD2B 9 or 15 R FS-EXT 560R GND2 Typical IL3522 connections. Receiver Features The receiver includes a “fail-safe if open” function that guarantees a high level output if the receiver inputs are unconnected (floating). The receiver output “R” has tri-state capability via the active low RE input. Driver Features The RS-422 driver is differential output and delivers at least 1.5 V across a 54 Ω load. Drivers feature low propagation delay skew to maximize bit width and minimize EMI. Drivers have tri-state capability via the active-high DE input. Receiver Data Rate, Cables and Terminations The IL3522 is intended for networks up to 4,000 feet (1,200 m), but the maximum data rate decreases as cable length increases. Twisted pair cable should be used in all networks since they tend to pick up noise and other electromagnetically induced voltages as common mode signals, which are effectively rejected by the differential receivers. 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Fail-Safe Operation “Fail-safe operation” is defined here as the forcing of a logic high state on the “R” output in response to an open-circuit condition between the “A” and “B” lines of the bus, or when no drivers are active on the bus. Proper biasing can ensure fail-safe operation, that is a known state when there are no active drivers on the bus. IL3000-Series Isolated Transceivers include internal pull-up and pull-down resistors of approximately 30 kΩ in the receiver section (RFS-INT; see figure below). These internal resistors are designed to ensure failsafe operation but only if there are no termination resistors. The entire VDD will appear between inputs “A” and “B” if there is no loading and no termination resistors, and there will be more than the required 200 mV with up to four RS-422 worstcase Unit Loads of 12 kΩ. Many designs operating below 1 Mbps or less than 1,000 feet are unterminated. Termination resistors may not be necessary for very low data rates and very short cable runs because reflections have time to settle before data sampling, which occurs at the middle of the bit interval. In busses with low-impedance termination resistors, however, the differential voltage across the conductor pair will be close to zero with no active drivers. In this case the state of the bus is indeterminate, and the idle bus will be susceptible to noise. For example, with 120 Ω termination resistors (RT) on each end of the cable, and four Unit Loads (12 kΩ each), without external fail-safe biasing resistors the internal pull-up and pulldown resistors will produce a voltage between inputs “A” and “B” of only about 5 mV. This is not nearly enough to ensure a known state. External fail-safe biasing resistors (RFS-EXT) at one end of the bus can ensure fail-safe operation with a terminated bus. Resistors should be selected so that under worst-case power supply and resistor tolerances there is at least 200 mV across the conductor pair with no active drivers to meet the input sensitivity specification of the RS-422 standard. Using the same value for pull-up and pull-down biasing resistors maintains balance for positive- and negative going transitions. Lower-value resistors increase inactive noise immunity at the expense of quiescent power consumption. Note that each Unit Load on the bus adds a worst-case loading of 12 kΩ across the conductor pair, and 32 Unit Loads add 375 Ω worst-case loading. The more loads on the bus, the lower the required values of the biasing resistors. In the example with two 120 Ω termination resistors and four Unit Loads, 560 Ω external biasing resistors provide more than 200 mV between “A” and “B” with adequate margin for power supply variations and resistor tolerances. This ensures a known state when there are no active drivers. Other illustrative examples are shown in the table below: Fail-Safe Biasing 5V RFS-EXT VDD 30K RFS-INT A RT None 120 Ω 120 Ω 120 Ω RFS-EXT 30K RFS-INT B GND RFS-EXT Internal Only Internal Only 560 Ω 510 Ω RT RT R Nominal VA-B (inactive) 238 mV 5 mV 254 mV 247 mV Loading Four unit loads (12 kΩ ea.) Four unit loads (12 kΩ ea.) Four unit loads (12 kΩ ea.) 32 unit loads (12 kΩ ea.) Fail-Safe Operation? Yes No Yes Yes 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Package Drawing 0.3" 16-pin SOIC Package Dimensions in inches (mm); scale = approx. 5X 0.033 (0.85)* 0.043 (1.10) 0.260 (6.60)* 0.280 (7.11) 0.013 (0.3) 0.020 (0.5) 0.007 (0.2) 0.013 (0.3) 0.397 (10.08) 0.413 (10.49) 0.017 (0.43)* 0.022 (0.56) 0.016 (0.4) 0.050 (1.3) 0.007 (0.18)* 0.010 (0.25) 0.092 (2.34) 0.105 (2.67) Pin 1 identified by either an indent or a marked dot 0.08 (2.0) 0.10 (2.5) 0.292 (7.42)* 0.299 (7.59) 0.049 (1.24) 0.051 (1.30) 0.394 (10.00) 0.419 (10.64) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate *Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601. 0.004 (0.1) 0.012 (0.3) Recommended Pad Layout 0.15" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.317 (8.05) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.449 (11.40) 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Ordering Information and Valid part Numbers IL 35 22 V E TR13 Valid Part Numbers IL3522 IL3522E IL3522TR13 IL3522E TR13 Bulk Packaging Blank = Tube TR13 = 13'' Tape and Reel Package Blank = 80/20 Sn/Pb Plating E = RoHS Compliant IL3522VE IL3522VE TR13 Isolation Grade Blank = 2.5 kV Isolation / 600 WV V = 6 kV Isolation / 1 kV WV Channel Configuration 22 = RS-422 Base Part Number 35 = Digital-In, 40 Mbps Transceiver Product Family IL = Isolators RoHS COMPLIANT 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Revision History ISB-DS-001-IL3522-T August 2022 • Upgraded to IEC 60747-17 (VDE 0884-17):2021-10 certification (p. 3). • Increased Working Voltage ratings based on latest VDE testing (p. 3). • Separate power consumption specifications section; added dynamic power consumption (p. 5). • Updated EMC standards. • Deleted minimum magnetic field immunity specifications (p. 6) since it is not 100% tested. • Added thermal characteristics (p. 7). ISB-DS-001-IL3522-S • Updated VDE Reinforced Isolation file number and description. ISB-DS-001-IL3522-R • Updated VDE certification standard to VDE V 0884-10. • Upgraded “V” Version Surge Immunity specification to 12.8 kV. • Upgraded “V” Version VDE 0884-10 rating to reinforced insulation. • Increased V-Series isolation voltage to 6 kVRMS. • Increased typ. Total Barrier Thickness specification to 0.016 mm. • Increased CTI min. specification to ≥600 VRMS. • Increase V-Series surge voltage specification to 10 kV. • Upgraded V-Series safety and approval from IEC 60747-5-5 (VDE 0884) to VDE 0884-10. ISB-DS-001-IL3522-O • Added V-Series versions (5 kVrms isolation / 1000 Vrms working voltage). ISB-DS-001-IL3522-N • IEC 60747-5-5 (VDE 0884) certification. • Upgraded from MSL 2 to MSL 1. • Increased transient immunity specifications based on additional data. • Added VDE 0884 pending. • Added transient immunity specifications. • Added high voltage endurance specification. • Increased magnetic immunity specifications. • Updated package drawings. • Added recommended solder pad layouts. • Changed title to “Very High Speed Isolated RS485/RS422 Transceiver.” • Detailed isolation and barrier specifications. • Cosmetic changes. • Added clarification of internal ground connections (p. 3). ISB-DS-001-IL3522-Q ISB-DS-001-IL3522-P ISB-DS-001-IL3522-M ISB-DS-001-IL3522-L ISB-DS-001-IL3522-J 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3522 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL3522-T August 2022 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL3522ETR13
物料型号:IL3522
器件简介: - IL3522是一款高速隔离RS485/RS422收发器,使用NVE公司的IsoLoop®专利技术和自旋电子Giant Magnetoresistance (GMR)技术。 - 该器件提供高达40 Mbps的数据传输速率,20 ns的传播延迟和1 ns的脉冲倾斜。 - 具有高达6 kVRMS的加强隔离和15 kV的总线ESD保护。
引脚分配: - 16脚SOIC封装,包括输入电源(VDDI)、地(GND)、数据输入输出(D, R)、驱动使能(DE, RE)等。
参数特性: - 工作电压范围3 V至5 V。 - 隔离电压6 kVRMS(对于IL3522VE版本)。 - 工作温度范围-40 °C至+85 °C。 - 符合IEC 60747-17和UL 1577标准。
功能详解: - 接收器具有“开路安全”设计,如果A/B悬空则输出高电平。 - 发射器提供至少2.3 V的差分输出电压至54 Ω负载。 - 具有热关闭保护和电流限制功能。
应用信息: - 适用于工厂自动化、工业控制网络、建筑环境控制等。
封装信息: - 提供16-pin JEDEC标准True 8™ mm SOIC封装。
IL3522ETR13 价格&库存
很抱歉,暂时无法提供与“IL3522ETR13”相匹配的价格&库存,您可以联系我们找货
