IL610A-2E
IL610A-2E
    NVECORP
    DIP-8
    DGTL ISO 2.5KV 1CH GEN PURP 8DIP
IL610A-2E 数据手册
IL600A Series Isolators Passive-Input Digital Isolators – Open Drain Outputs Functional Diagrams Features VOE OUT1 IN1 GND IL610A OUT1 IN1 OUT2 IN2 • • • • • • • • • • • • 10 Mbps data rate Flexible inputs with very wide input voltage range 5 mA input current Failsafe output (logic high output for zero coil current) No carrier or clock for low EMI emissions and susceptibility 3 V to 5 V power supplies 44000 year barrier life Low power dissipation −40 °C to 85 °C temperature range 2500 VRMS isolation IEC 60747-17 (VDE 0884-17):2021-10; UL 1577 8-pin MSOP, SOIC, and PDIP packages GND Applications IL611A VDD1 IN1 OUT2 OUT1 VDD2 GND IN2 GND IL612A • • • • • • • General purpose optocoupler replacement Wired-OR alarms SPI interface I 2C RS-485, RS-422, or RS-232 Space-critical multi-channel applications Isolated relays and actuators Description The IL600A-Series are isolated signal couplers with opendrain outputs. They have a similar interface but better performance and higher package density than optocouplers. The devices are manufactured with NVE’s patented* IsoLoop® spintronic Giant Magnetoresistive (GMR) technology for small size, high speed, and low power. A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. A resistor sets the input current; a capacitor in parallel with the current-limit resistor provides improved dynamic performance. These versatile components simplify inventory requirements by replacing a variety of optocouplers, functioning over a wide range of data rates, edge speeds, and power supply levels. The devices are available in MSOP, SOIC, and PDIP packages, as well as bare die. Isoloop® is a registered trademark of NVE Corporation. *U.S. Patent numbers 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 REV. AB (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Absolute Maximum Ratings(1) Parameters Storage Temperature Junction Temperature Ambient Operating Temperature Supply Voltage DC Input Current AC Input Current (Single-Ended Input) AC Input Current (Differential Input) Output Voltage Maximum Output Current ESD (IL610A Output Enable CMOS input) Symbol TS TJ TA VDD IIN IIN IIN VO IO Min. −55(2) −55 −40(3) −0.5 −25 −35 −75 −0.5 −10 Typ. Max. 150 150 85 7 25 35 75 VDD+1.5 10 2 Units °C °C °C V mA mA mA V mA kV Test Conditions HBM Note 1: Operating at absolute maximum ratings will not damage the device. Parametric performance is not guaranteed at absolute maximum ratings. Note 2: -55oC applies to all except IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13. -20oC applies to IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13 Note 3: -40oC applies to all except IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13. -20oC applies to IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13 Recommended Operating Conditions Parameters Ambient Operating Temperature Junction Temperature Supply Voltage Open Drain Reverse Voltage Open Drain Voltage Open Drain Load Current Common Mode Input Voltage Symbol TA TJ VDD VSD VDS IOD VCM Min. −40(3) −40 3.0 −0.5 Typ. Max. 85 100 5.5 6.5 7 400 Units °C °C V V V mA VRMS Test Conditions 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10 (Basic Isolation; VDE File Number 5016933-4880-0001): • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit • Working Voltage (VIORM; pollution degree 2): Package MSOP8 SOIC8 PDIP8 Part No. Suffix -1 -3 -2 Safety-Limiting Values Safety rating ambient temperature Safety rating power (180°C) Supply current safety rating (total of supplies) Working Voltage 800 VRMS 700 VRMS 900 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577(Component Recognition Program File Number E207481) • 2500 V rating for all types other than MSOP. • Each part other than MSOP tested at 3000 VRMS (4240 VPK) for 1 second; each lot sample tested at2500 VRMS (3530 VPK) for 1 minute. • MSOP rating 1000 V; tested at 1200 VRMS (1768 VPK) for 1 second; each lot sample tested at 1500 VRMS (2121 VPK) for 1 minute. Soldering Profile Per JEDEC J-STD-020C; MSL 1 Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators IL610A Pin Connections 1 2 3 4 5 6 NC IN+ IN− NC GND OUT 7 VOE 8 VDD No internal connection Coil connection Coil connection No internal connection Ground return for VDD Data out Output enable. Internally held low with 100 kΩ Supply Voltage NC VDD IN+ VOE IN- OUT NC GND IL610A IL611A Pin Connections 1 2 3 4 5 6 7 8 IN1+ IN1− IN2+ IN2− GND OUT2 OUT1 VDD Channel 1 coil connection Channel 1 coil connection Channel 2 coil connection Channel 2 coil connection Ground return for VDD Data out, channel 2 Data out, channel 1 Supply Voltage IN1+ VDD IN1- OUT1 IN2+ OUT2 IN2- GND IL611A IL612A Pin Connections 1 2 3 4 5 6 7 8 IN1 VDD1 OUT2 GND1 GND2 IN2 VDD2 OUT1 Data in, channel 1 Supply Voltage 1 Data out, channel 2 Ground return for VDD1 Ground return for VDD2 Data in, channel 2 Supply Voltage 2 Data out, channel 1 IN1 OUT1 VDD1 VDD2 OUT2 IN2 GND1 GND2 IL612A 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Operating Specifications Input Specifications (VDD = 3 V − 5.5 V; T = −40°C(2) − 85°C unless otherwise stated) Parameters Symbol Min. Typ. Max. Units 47 85 112 Ω Coil Input Resistance RCOIL 31 85 128 Ω Coil Resistance Temperature Coefficient TC RCOIL 0.2 0.25 Ω/°C Coil Inductance LCOIL 9 nH IINH-DC 0.5 1 mA DC Input Threshold (5 V) IINL-DC 3.5 5 mA DC Input Threshold (3 V) IINH-DC 0.5 0.3 mA IINL-DC 5 8 mA IINH-BOOST 0.5 1 mA Dynamic Input Threshold (3 V) IINL-BOOST IINH-DIFF 3.5 0.5 5 mA 1 mA Differential Input Threshold IINL-DIFF IFS-HIGH IFS-LOW IFS-HIGH IFS-LOW VIH VIL tIR, tIF |CMH|,|CML| Failsafe Input Current(1) (5 V) Failsafe Input Current(1) (3 V) VOE Logic High Input Voltage VOE Logic Low Input Voltage Input Signal Rise and Fall Times Common Mode Transient Immunity Notes: 1. 2. −25 5 −25 8 2.4 0 15 5 mA 0.5 25 0.3 25 VDD1 0.8 1 mA mA mA mA V V μs kV/μs 20 Test Circuit 1; VDD = 4.5 V − 5.5 V Test Circuit 1; VDD = 3V − 3.6 V; no boost cap VDD = 3V − 3.6 V; tIR = tIF = 3 ns; CBOOST = 16 pF Test Circuit 2; VDD = 3V − 5.5 V; input current reverses; boost cap not required Test Circuit 1; VDD = 4.5 V − 5.5 V Test Circuit 1; VDD = 3 V − 3.6 V VT = 300 Vpeak Failsafe Operation is defined as the guaranteed output state which will be achieved if the DC input current falls between the input levels specified (see Test Circuit 1 for details). Note if Failsafe to Logic Low is required, the DC current supplied to the coil must be at least 8 mA using 3.3 V supplies versus 5 mA for 5 V supplies. -20oC for IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13 +V Rlimit 3.5 Test Conditions T = 25°C T = −40°C − 85°C Cboost 2K IL610A 3 2 + 8 +V VDD 2K 10nF VDD 10 nF 7 6 8 IL610A Rlimit 7 6 3 2 + 5 5 15pF 15 pF 1K GND1 GND2 GND1 Test Circuit 1 (Single-Ended) GND2 Test Circuit 2 (Differential) 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Electrical Specifications (VDD = 3 V − 5.5 V; T = −40°C(3) − 85°C unless otherwise stated) Parameters Symbol Min. Typ. Max. Units Quiescent Supply Current (5 V) IL610A IDD 2 3 mA IL611A IDD 4 6 mA IL612A IDD1 2 3 mA IL612A IDD2 2 3 mA Quiescent Supply Current (3.3 V) IL610A IDD 1.3 2 mA IL611A IDD 2.6 4 mA IL612A IDD1 1.3 2 mA IL612A IDD2 1.3 2 mA Logic High Output Voltage(1) VOH VDD V 0 0.1 V Logic Low Output Voltage VOL 0.4 0.8 V Logic Output Current |IO| 7 10 mA Switching Specifications (VDD = 3 V − 5.5 V; T = −40°C(3) − 85°C unless otherwise stated) Parameters Symbol Min. Typ. Max. Units Input Signal Rise and Fall Times tIR, tIF 10 µs Data Rate 10 Mbps Minimum Pulse Width PW 100 ns Propagation Delay Input to Output tPHL 20 25 ns (High to Low) Propagation Delay Input to Output tPLH 50 75 ns (Low to High) Notes: 1. 2. 3. Test Conditions VDD = 5 V, IIN=0 Rpullup = open circuit VDD= 3.3 V, IIN=0 Rpullup = open circuit Off State IO = −20 µA IO = −4 mA Test Conditions Test Circuit 1; tIR = tIF = 3 ns; CBOOST = 16 pF VDD refers to the supply voltage on the output side of the isolated channel. Failsafe Operation is defined as the guaranteed output state which will be achieved if the DC input current falls between the input levels specified (see Test Circuit 1 for details). Note if Failsafe to Logic Low is required, the DC current supplied to the coil must be at least 8 mA using 3.3 V supplies versus 5 mA for 5 V supplies. -20oC for IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Insulation Specifications Parameters Creepage Distance (external) MSOP SOIC PDIP Total Barrier Thickness Leakage Current Barrier Resistance Barrier Capacitance Comparative Tracking Index High Voltage Endurance (Maximum Barrier Voltage for Indefinite Life) Symbol Min. Typ. 3.01 4.03 7.08 0.012 RIO CIO CTI AC Max. Units ≥175 1000 mm mm mm mm µA Ω pF V VRMS 1500 VDC 0.013 0.2 >1014 7 VIO DC Barrier Life 44000 Test Conditions 240 VRMS, 60 Hz 500 V f = 1 MHz Per IEC 60112 At maximum operating temperature Years 100°C, 1000 VRMS, 60% CL activation energy Units Test Conditions °C/W Double-sided PCB in free air Thermal Characteristics Parameter Symbol Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance Power Dissipation MSOP SOIC PDIP MSOP SOIC PDIP MSOP SOIC PDIP Min. Typ. Max. 184 134 114 15 10 36 θJA θJC 500 675 800 PD mW 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Applications Information IL600-Series Isolators are current mode devices. Changes in current flow into the input coil result in logic state changes at the output. As shown in Figure 1, output logic high is the zero input current state. Coil Polarity 3.5 The device switches to logic low if current flows from (In−) to (In+). Note that the designations “In−“ and “In+” refer to logic levels, not current flow. Positive values of current mean current flow into the In− input. 1.5 Input Resistor Selection Coil Current mA 5 Logic State t High Low t Figure 1. Typical IL600-Series Transfer Function ICOIL Resistors set the coil input current (see Figure 2). There is no limit to input voltages because there are no semiconductor input structures. Worst-case logic low threshold current is 8 mA, which is for singleended operation with a 3 V supply. In differential mode, where the input current reverses, the logic low threshold current is 5 mA for the range of supplies. A “boost capacitor” creates current reversals at edge transitions, reducing the input logic low threshold current to the differential level of 5 mA. Typical Resistor Values VCOIL 3.3 V 5V VINH R1 85 Input Coil VINL Coil Resistor 510 Ω 820 Ω The table shows typical values for the external resistor for 5 mA coil current. The values are approximate and should be adjusted for temperature or other application specifics. Single-Ended or Differential Input The IL610, IL611, IL613, and channel 1 of the IL614 can be run with single-ended or differential inputs (see Test Circuits on page 5). In the differential mode, current will naturally flow through the coil in both directions without a boost capacitor, although the capacitor can still be used for increased external field immunity or improved PWD. Absolute Maximum recommended coil current in single-ended mode is 25 mA while differential mode allows up to ±75 mA to flow. The Figure 2. Limiting Resistor Calculation difference in specifications is due to the risk of electromigration of Equivalent Circuit coil metals under constant current flow. In single ended mode, longterm DC current flow above 25 mA can cause erosion of the coil metal. In differential mode, erosion takes place in both directions as each current cycle reverses and has a net effect of zero up to the absolute maximum current. An advantage over optocouplers and other high-speed couplers in differential mode is that no reverse bias protection for the input structure is required for a differential signal. One of the more common applications is for an isolated Differential Line Receiver. For example, RS-485 can drive an IL610 directly for a fraction of the cost of an isolated RS-485 node (see Illustrative Applications). 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Non-inverting and Inverting Configurations IL600-Series Isolators can be configured in noninverting and inverting configurations (see Figure 3). In a typical non-inverting circuit, the In− terminal is connected via a 1 kΩ input resistor to the supply rail, and the input is connected to the In+ terminal. The supply voltage is +5 V and the input signal is a 5 V CMOS signal. When a logic high (+5 V) is applied to the input, the current through the coil is zero. When the input is a logic low (0 V), at least 5 mA flows through the coil from the In− side to the In+ side. The inverting configuration is similar to standard logic. In the inverting configuration, the signal into the coil is differential with respect to ground. The designer must ensure that the difference between the logic low voltage and the coil ground is such that the residual coil current is less than 0.5 mA. +5 V C boost 820R IL610A 8 7 - 6 3 2 + Data Out C1 5 Data In GND GND 1 2 mic. Note: 1 Cis 47F ncera Non-Inverting Circuit +5 V V DD 2K The IL612 and IL614 devices have some inputs that do not offer inverting operation. The IL612 coil In− input is hardwired internally to the device power supply; therefore it is important to ensure the isolator power supply is at the same voltage as the power supply to the source of the input logic signal. The IL614 has a common coil In− for two inputs. This pin should be connected to the power supply for the logic driving channels 2 and 3, and the channels run should be run in non-inverting mode. Both single ended and differential inputs can be handled without reverse bias protection. V DD 2K C boost IL610A 8 7 - 6 3 Data In 820R GND 2 + 1 Inverting Circuit Data Out C1 5 GND 2 Note: 1 Cis 47 nF mic. cera Figure 3. Non-inverting and inverting circuits Boost Capacitor The boost capacitor in parallel with the current-limiting resistor boosts the instantaneous coil current at the signal transition. This ensures switching and reduces propagation delay and reduces pulse-width distortion. 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Select the value of the boost capacitor based on the rise and fall times of the signal driving the inputs. The instantaneous boost capacitor current is proportional to input edge speeds ( C dV dt ). Select a capacitor value based on the rise and fall times of the input signal to be isolated that provides approximately 20 mA of additional “boost” current. Figure 4 is a guide to boost capacitor selection. For high-speed logic signals (tr,tf < 10 ns), a 16 pF capacitor is recommended. The capacitor value is generally not critical; if in doubt, choose a higher value. 1000 Signal Rise/Fall Time (ns) 500 3 16 2500 5000 CBoost (pF) Figure 4. Cboost Selector 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Dynamic Power Consumption Power consumption is proportional to duty cycle, not data rate. The use of NRZ coding minimizes power dissipation since no additional power is consumed when the output is in the high state. In differential mode, where the logic high condition may still require a current to be forced through the coil, power consumption will be higher than a typical NRZ single ended configuration. Power Supply Decoupling 0.1 µF typical (0.047 µF minimum) ceramic capacitors are recommended to decouple the power supplies. The capacitors should be placed as close as possible to the appropriate VDD pin. Maintaining Creepage Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. Electromagnetic Compatibility and Magnetic Field Immunity Because IL600-Series Isolators are completely static, they have the lowest emitted noise of any non-optical isolators. IsoLoop Isolators operate by imposing a magnetic field on a GMR sensor, which translates the change in field into a change in logic state. A magnetic shield and a Wheatstone Bridge configuration provide good immunity to external magnetic fields. Immunity to external magnetic fields can be enhanced by proper orientation of the device with respect to the field direction, the use of differential signaling, and boost capacitors. 1. Orientation of the device with respect to the field direction An applied field in the “H1” direction is the worst case for magnetic immunity. In this case the external field is in the same direction as the applied internal field. In one direction it will tend to help switching; in the other it will hinder switching. This can cause unpredictable operation. NC VDD IN+ VOE H2 IN- An applied field in direction “H2” has considerably less effect and results in higher magnetic immunity. H1 OUT GND NC 2. Differential Signaling and Boost Capacitors Regardless of orientation, driving the coil differentially improves magnetic immunity. This is because the logic high state is driven by an applied field instead of zero field, as is the case with single-ended operation. The higher the coil current, the higher the internal field, and the higher the immunity to external fields. Optimal magnetic immunity is achieved by adding the boost capacitor. Method Approximate Immunity Immunity Description Field applied in H1 direction ±20 Gauss A DC current of 16 A flowing in a conductor 1 cm from the device could cause disturbance. Field applied in H2 direction ±70 Gauss A DC current of 56 A flowing in a conductor 1 cm from the device could cause disturbance. Field applied in any direction but with boost capacitor (16 pF) in circuit ±250 Gauss A DC current of 200 A flowing in a conductor 1 cm from the device could cause disturbance. Data Rate and Magnetic Field Immunity It is easier to disrupt an isolated DC signal with an external magnetic field than it is to disrupt an isolated AC signal. Similarly, a DC magnetic field will have a greater effect on the device than an AC magnetic field of the same effective magnitude. For example, signals with pulses longer than 100 μs are more susceptible to magnetic fields than shorter pulse widths. 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Illustrative Applications V DD1 V DD2 8 R ISL8485 1 C1 8 IL610A 7 D B/Z 3 4 6 2 A/Y 7 6 C2 R + 5 Cboost 5 GND1 Notes: C boost GND2 is application specific All other capacitors are 47 nF ceramic Isolated RS-485 and RS-422 Receivers Using IL610As Number of Current Limit IL610As can be used as simple isolated RS-485 or RS-422 receivers, terminating signals at Nodes Resistors (Ω Ω) the IL610A for a fraction of the cost of an isolated node. Cabling is greatly simplified by 1 None eliminating the need to power the input side of the receiving board. No current-limiting 2 17 resistor is needed for a single receiver because it will draw less current than the driver 3 22 maximum. Current limiting resistors allow at least eight nodes without exceeding the 4 27 maximum load of the transceiver chip. Placement of the current-limiting resistors on both 5 27 lines provides better dynamic signal balance. There is no need for line termination resistors 6 2 because the IL610A coil resistance of approximately 85 Ω is close to the characteristic 7 30 impedance of most cables. The circuit is intrinsically open circuit failsafe because the 8 30 IL610A is guaranteed to switch to the high state when the coil input current is less than 500 µA. For higher speed, a faster output device (such the CMOS-output IL600-Series Isolators) are needed as well as possibly better impedance matching. IsoLoop® is a registered trademark of NVE Corporation. *U.S. Patent numbers 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 Phone: (952) 829-9217 Fax: (952) 829-9189 www.isoloop.com iso-apps@nve.com IL600A Series Isolators 120V Hot Neutral +5 V 2K 100K 16 8 IL610A 10K 0.5W 47nF 3 6 2 + 2 + 1µF 5 10K 0.5W 3 15 74HC123 13 Monitor Out 14 8 1 Load GND 1 Isolated 120V Line Monitor The wide input voltage range of IL600 Isolators allows connection to line voltage through current-limiting resistors. Unlike optocouplers, input voltage can reverse without damaging the inputs. In this illustrative circuit, “Monitor Out” goes low when line voltage drops significantly. The 74HC123 monostable converts the 60 Hz isolator output to a monitor signal. +5 V RL V1 3 Sensor 1 1K 8 IL610A 2 C1 6 + 5 Cboost V2 3 Sensor 2 1K 2 System Error 8 IL610A C2 6 + 5 Cboost V3 3 Sensor 3 1K 8 IL610A 2 C3 6 + 5 Cboost Notes: Cboost is application specific All other capacitors are 47 nF ceramic GND1 Multi-channel Isolated Alarm Monitor The open-drain outputs of IL600A-Series Isolators allow wired-OR outputs. The inputs can be configured for inverting or noninverting operation (see Applications Information), and a very wide input voltage range is possible. This illustrative circuit provides fail-safe output (logic high output for zero coil current) and typical logic output sink current of 10 mA for each isolator. 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators 5V 5V 2K2 10K 750R ½ P82B96 8 SDA 1 2 270 pF 3 C3 1 3 750R VDD2 C2 4 2 4 SDA_iso 7 8 VDD1 5 6 16 pF 750R IL612A C1 GND1 GND2 Notes: C1, C2, and C3 are 47nF ceramic Resistor values change for 3 V operation Isolation of I2C Nodes This circuit provides bidirectional isolation of I²C bus signals with no restrictions on data rate and none of the I²C bus latch-up problems common with other isolation circuits. The SCL section is similar as shown in the schematic using the other half of the P82B96. 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Package Drawings 8-pin MSOP (-1 suffix) Dimensions in inches (mm); scale = approx. 5X 0.114 (2.90) 0.122 (3.10) 0.016 (0.40) 0.027 (0.70) 0.114 (2.90) 0.122 (3.10) 0.189 (4.80) 0.197 (5.00) 0.032 (0.80) 0.043 (1.10) 0.005 (0.13) 0.009 (0.23) 0.010 (0.25) 0.016 (0.40) 0.024 (0.60) 0.028 (0.70) 0.002 (0.05) 0.006 (0.15) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 8-pin SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.188 (4.77) 0.197 (5.00) 0.016 (0.4) 0.050 (1.3) 0.052 (1.32) 0.062 (1.57) 0.054 (1.37) 0.072 (1.83) 0.150 (3.8) 0.157 (4.0) 0.228 (5.8) 0.244 (6.2) 0.004 (0.1) 0.012 (0.3) 0.050 (1.27) NOM NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.007 (0.2) 0.013 (0.3) 0.013 (0.3) 0.020 (0.5) 8-pin PDIP (-2 suffix) Dimensions in inches (mm); scale = approx. 2.5X 0.28 (7.1) 0.33 (8.4) 0.24 (6.1) 0.27 (6.9) 0.30 (7.6) 0.38 (9.7) 0 10 0.345 (8.76) 0.40 (10.2) 0.055 (1.40) 0.065 (1.65) 0.13 (3.30) 0.17 (4.32) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.09 (2.3) 0.11 (2.8) 0.008 (0.2) 0.015 (0.4) 0.045 (1.14) 0.070 (1.78) 0.015 (0.38) 0.040 (1.02) 0.030 (0.76) 0.045 (1.14) 0.014 (0.36) 0.023 (0.58) Recommended Pad Layouts 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators 8-pin MSOP Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.120 (3.05) 0.025 (0.65) 0.017 (0.43) 8 PLCS 0.227 (5.77) 8-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.05) 0.050 (1.27) 0.020 (0.51) 8 PLCS 0.275 (6.99) 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Ordering Information and Valid Part Numbers IL 610 A - 1 E TR13 IL610A Valid Part Numbers Bulk Packaging Blank = Tube TR7 = 7'' Tape and Reel TR13 = 13'' Tape and Reel Package E = RoHS Compliant Package Type -1 = MSOP -2 = PDIP -3 = SOIC -5 = Bare die IL611A Valid Part Numbers Output Type Blank = CMOS Output A = Open Drain Output Base Part Number 610 = Single Channel 611 = 2 Transmit Channels 612 = 1 Transmit Channel, 1 Receive Channel Product Family IL = Isolators IL610A-1E IL610A-2E IL610A-3E IL610A-5 IL610A-1ETR7 IL610A-3ETR7 IL610A-1ETR13 IL610A-3ETR13 IL611A-1E IL611A-2E IL611A-3E IL611A-1ETR7 IL611A-3ETR7 IL611A-1ETR13 IL611A-3ETR13 IL612A Valid Part Numbers IL612A-2E IL612A-3E IL612A-3ETR7 IL612A-3ETR13 RoHS COMPLIANT 17 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Revision History ISB-DS-001-IL600A-AB October 2022 ISB-DS-001-IL600A-AA Changes • Upgrade to VDE 0884-17 (p. 3). • Increased Working Voltage ratings based on latest VDE testing (p. 3). • Added VOE logic high and low input voltage specifications (p. 5). • Added thermal characteristics (p. 7). Changes • Corrected 8-pin SOIC package outline dimensions. • ISB-DS-001-IL600A-Z ISB-DS-001-IL600A-Y Changed low temperature specification for IL611A-1E, IL611A-1ETR7 and IL611A-1ETR13. Changes • IEC 60747-5-5 (VDE 0884) certification. • Upgraded from MSL 2 to MSL 1. • Rearranged input threshold specifications so maximum is more than minimum. Changes • Added VDE 0884 pending. • Added monostable to line monitor circuit (p. 11). • Clarified circuit polarities. • Updated package drawings. • Added recommended solder pad layouts (p. 14). ISB-DS-001-IL600A-X Change • Detailed isolation and barrier specifications. ISB-DS-001-IL600A-W Change • Clarified Test Circuit 2 differential operation diagram (p.4). ISB-DS-001-IL600A-V Changes • Separated and clarified Input Specifications. • Added minimum/maximum coil resistance specifications. • Merged and simplified “Operation” and “Applications” sections. ISB-DS-001-IL600A-U Change • Update terms and conditions. ISB-DS-001-IL600A-T Change • Additional changes to pin spacing specification on MSOP package drawing. ISB-DS-001-IL600A-S Change • Changed pin spacing specification on MSOP package drawing. ISB-DS-001-IL600A-R Change • Clarified failsafe operation input current (p. 4). ISB-DS-001-IL600A-Q Change • P. 2—Deleted MSOP IEC61010 approval. ISB-DS-001-IL600A-P Change • Added EMC details. 18 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 19 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL600A Series Isolators An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL600A-AB October 2022 20 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL610A-2E 价格&库存
很抱歉,暂时无法提供与“IL610A-2E”相匹配的价格&库存,您可以联系我们找货
