IL3585
IL3585
    NVECORP
    SOIC-16
    DG ISO 2.5KV RS422/RS485 16SOIC
IL3585 数据手册
IL3585 High Speed Isolated RS-485 Transceivers Functional Diagrams DE Features • • • • • • • • • • • • • • ISODE XDE D A B R RE IL3585-3 (narrow-body) 40 Mbps data rate 6 kVRMS Reinforced Isolation / 12.8 kV surge / 1.2 kVRMS WV (IL3585VE) 3 V to 5 V power supplies 20 ns propagation delay 5 ns pulse skew 50 kV/μs typ.; 30 kV/μs min. common mode transient immunity 44000 year barrier life 15 kV bus ESD protection Low EMC footprint Thermal shutdown protection −40 °C to +85 °C temperature range Meets or exceeds ANSI RS-485 and ISO 8482:1987(E) IEC 60747-17 (VDE 0884-17):2021-10 certified; UL 1577 recognized 0.15" or 0.3" True 8™ 16-pin SOIC packages Applications DE • • • • • ISODE D Factory automation Industrial control networks Building environmental controls Equipment covered under IEC 61010-1 Edition 3 5 kVRMS rated IEC 60601-1 medical applications A B R Description RE The IL3585 is a galvanically isolated, high-speed differential bus transceiver, designed for bidirectional data communication on balanced transmission lines. The device uses NVE’s patented* spintronic Giant Magnetoresistance (GMR) technology. IL3585 (wide-body) A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. VID (A-B) DE RE R D ≥ 200 mV L L H X ≤−200mV L L L X Open L L H Notes The part is available in an ultraminiature 0.15" 16-pin SOIC package, a JEDEC-standard 0.3"-wide package, or NVE’s exclusive True 8™ 16pin SOIC package for true 8 millimeter creepage. X A/B failsafe R reads back D information The IL3585 delivers an exceptional 2.3 V differential output into a 54 Ω load over the supply range of 4.5 V to 5.5 V. This provides better data integrity over longer cable lengths, even at data rates as high as 40 Mbps. The device is also compatible with 3 V supplies, allowing interface to standard microcontrollers without additional level shifting. ≥ 1.5 V H L H H ≤−1.5 V H L L L ≥ 1.5 V H H Z H ≤−1.5 V H H Z L X L H Z X Mode Receive Drive R tri-state (no output) Disabled R tri-state; A/B failsafe Current limiting and thermal shutdown features protect against output short circuits and bus contention that may cause excessive power dissipation. Receiver inputs feature a “fail-safe if open” design, ensuring a logic high R-output if A/B are floating. IsoLoop® is a registered trademark of NVE Corporation. *U.S. Patent number 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 REV. W (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Absolute Maximum Ratings(11) Parameter Storage Temperature Junction Temperature Voltage Range at A or B Bus Pins Supply Voltage(1) Digital Input Voltage Digital Output Voltage ESD (all bus nodes) Symbol TS TJ VDD1, VDD2 Min. −55 −55 −7 −0.5 −0.5 −0.5 15 Typ. Min. 3.0 4.5 −40 −40 Typ. Max. 150 150 12 7 VDD + 0.5 VDD + 1 Units °C °C V V V V kV Test Conditions HBM Recommended Operating Conditions Parameter Ambient Operating Temperature Junction Temperature Input Voltage at any Bus Terminal (separately or common mode) Symbol VDD1 VDD2 TA TJ VI VIC High-Level Digital Input Voltage VIH Low-Level Digital Input Voltage Differential Input Voltage(2) High-Level Output Current (Driver) High-Level Digital Output Current (Receiver) Low-Level Output Current (Driver) Low-Level Digital Output Current (Receiver) Digital Input Signal Rise and Fall Times VIL VID IOH Supply Voltage 2.4 3.0 0 Max. 5.5 5.5 85 100 12 −7 Units VDD1 V 0.8 +12 / −7 60 V V mA 8 mA IOH V °C °C V IOL −60 mA IOL −8 mA tIR, tIF Test Conditions VDD1 = 3.3 V VDD1 = 5.0 V DC Stable 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Safety and Approvals IEC 60747-17 (VDE 0884-17):2021-10: IL3585VE version (Reinforced Isolation; VDE File Number 5016933-4880-0002) • Working Voltage (VIORM): 1200 VRMS (1700 VPK) with 20% Safety Factor; pollution degree 2 • Isolation voltage (VISO): 6000 VRMS • Surge immunity (VIOSM): 12.8 kVPK • Surge rating: 8000 V • Transient overvoltage (VIOTM): 6000 VPK • Each part tested at 2387 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 6000 VPK for 60 sec.; then 2122 VPK for 10 sec. with 5 pC partial discharge limit Standard IL3585E versions (Basic Isolation; VDE File Number 5016933-4880-0001) • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating: 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit. • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit. • Working Voltage (VIORM; pollution degree 2): Package QSOP16 Narrow-body SOIC16 Wide-body SOIC16/True 8™ Part No. Suffix -1 -3 None Safety-Limiting Values Safety rating ambient temperature Safety rating power (180 °C) Supply current safety rating (total of supplies) Working Voltage 600 VRMS 700 VRMS 600 VRMS Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) Standard isolation grade 2500 V rating; each part tested at 3000 VRMS (4243 VPK) for 1 second; each lot sample tested at 2500 VRMS (3536 VPK) for 1 minute V-Series isolation grade 6 kV rating; each part tested at 7.2 kVRMS (10.2 kVPK) for 1 second; each lot sample tested at 6 kVRMS (8485 VPK) for 1 minute Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 IL3585-3 (0.15" SOIC Package) Pin Connections 1 VDD1 Input power supply 2 GND1 Input power supply ground return 3 R Output data from bus 4 RE Read data enable (if RE is high, R= high impedance) 5 D Data input to bus VDD1 1 16 VDD2I 6 DE Drive enable GND1 2 15 GND2 7, 8, 9 NC No internal connection R 3 14 ISODE RE 4 13 D 5 12 B 10 XDE Transceiver Device Enable input enables the transceiver from the bus side, or is connected to ISODE to enable the transceiver from the controller-side DE input. (this input should not be left unterminated) VDD2X 11 A Non-inverting bus line DE 6 11 A 12 B Inverting bus line NC 7 10 XDE 13 VDD2X Output transceiver power supply (normally connected to pin 16) NC 8 9 NC 14 ISODE Isolated DE output (normally connected to pin 10) 15 GND2 Output power supply ground return. 16 VDD2I Output isolation power supply (normally connected to pin 13) IL3585-3 IL3585 (0.3" SOIC Package) Pin Connections 1 VDD1 Input power supply 2 GND1 Input power supply ground return (pin 2 is internally connected to pin 8) 3 R Output data from bus 4 RE Read data enable (if RE is high, R= high impedance) 5 DE Drive enable VDD1 1 16 VDD2 6 D Data input to bus GND1 2 15 GND2 7 NC 3 14 NC GND1 Input power supply ground return (pin 8 is internally connected to pin 2) R 8 RE 4 13 B 9 GND2 Output power supply ground return (pin 9 is internally connected to pin 15) DE 5 12 A 6 11 NC ISODE Isolated DE output for use in PROFIBUS applications where the state of the isolated drive enable node needs to be monitored. D 10 NC 7 10 ISODE 11 NC No internal connection GND1 8 9 GND2 12 A Non-inverting bus line 13 B Inverting bus line 14 NC 15 GND2 Output power supply ground return (pin 15 is internally connected to pin 9) 16 VDD2 Output power supply No internal connection IL3585 No internal connection 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Driver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Parameter Symbol Min. Typ. Max. Units Input Clamp Voltage VIK −1.5 V Output voltage VO VDD V Differential Output Voltage(2) |VOD1| VDD V Differential Output Voltage(2) |VOD2| 2.5 3 5 V Differential Output Voltage(2) VOD3 2.3 5 V Change in Magnitude of Differential Δ|VOD| ±0.2 V Output Voltage(4) Common Mode Output Voltage VOC 3 V Change in Magnitude of Common Δ|VOC| ±0.2 V Mode Output Voltage(4) 1 Output Current IO mA −0.8 High Level Input Current IIH 10 μA Low Level Input Current IIL −10 μA Absolute |Short-circuit Output Current| IOS 250 mA Test Conditions IL = −18 mA IO = 0 IO = 0 RL = 54 Ω, VDD = 5 V RL = 54 Ω, VDD = 4.5 V RL = 54 Ω or 100 Ω RL = 54 Ω or 100 Ω RL = 54 Ω or 100 Ω Output Disabled, VO = 12 VO = −7 VI = 3.5 V VI = 0.4 V −7 V < VO < 12 V Receiver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Parameter Symbol Min. Typ. Max. Units Positive-going Input Threshold VIT+ 0.2 V Voltage Negative-going Input Threshold VIT− −0.2 V Voltage Hysteresis Voltage (VIT+ − VIT−) VHYS 40 mV High Level Digital Output Voltage VOH VDD – 0.2 VDD V Low Level Digital Output Voltage VOL 0.2 V High-impedance-state output current Line Input Current IOZ II ±1 1 −0.8 Input Resistance RI μA mA mA kΩ 20 Test Conditions −7 V < VCM < 12 V −7 V < VCM < 12 V VCM = 0 V, T = 25°C VID = 200 mV IOH = −20 μA VID = −200 mV IOH = 20 μA VO = 0.4 to (VDD2−0.5) V VI = 12 V VI = −7 V Power Consumption Parameter Controller-Side Quiescent Current VDD1 = 3.3 V VDD1 = 5 V Tmin to Tmax and VDD2 = 5 V unless otherwise stated Symbol Min. Typ. Max. 3 4 IDD1 4 6 Bus-Side Quiescent Supply Current IDD2 5 Controller-Side Dynamic Supply Current IDD1 0.22 1 0.8 Bus-Side Dynamic Supply Current ΔIDD2/ΔfIN 16 Units mA mA mA/Mbps Test Conditions fIN = 0 Hz Outputs Enabled; RT = ∞; fIN = 0 Hz ; VDD2X connected to VDD2I if applicable VDD1 = 3.3 V RT = ∞ RT = 60 Ω 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Switching Characteristics Parameter Data Rate Symbol Propagation Delay(5) Pulse Skew(6) Skew Limit(3) Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Parameter Data Rate Pulse Skew(6) (3) Skew Limit Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Max. Units Mbps tPD 27 35 ns tSK(P) 1 6 ns tSK(LIM) tPZH tPZL tPHZ tPLZ 2 15 15 15 15 12 25 25 25 25 ns ns ns ns ns |CMH|,|CML| Symbol Propagation Delay(5) VDD1 = 5 V, VDD2 = 5 V Min. Typ. 40 30 50 VDD1 = 3.3 V, VDD2 = 5 V Min. Typ. 40 kV/μs Max. Units Mbps tPD 30 38 ns tSK(P) 1 6 ns tSK(LIM) tPZH tPZL tPHZ tPLZ 4 17 17 17 17 12 27 27 27 27 ns ns ns ns ns |CMH|,|CML| 30 50 kV/μs Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF RL = 54 Ω, CL = 50 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF RL = 54 Ω, CL = 50 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns Magnetic Field Immunity(8) Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) HPF HPM HOSC KX Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) HPF HPM HOSC KX VDD1 = 5 V, VDD2 = 5 V 3500 4500 4500 2.5 VDD1 = 3.3 V, VDD2 = 5 V 1500 2000 2000 2.5 A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz Units Test Conditions Insulation Specifications Parameter Creepage Distance IL3585-3E (external) IL3585E Total Barrier Thickness (internal) Barrier Resistance Barrier Capacitance Leakage Current Comparative Tracking Index High Voltage Endurance AC (Maximum Barrier Voltage for Indefinite Life) DC Surge Immunity (“V” Versions) Symbol Min. 4.0 8.03 0.013 Typ. Max. 8.3 0.016 >1014 3 0.2 mm ≥600 1000 mm Ω pF μARMS VRMS VRMS 1500 12.8 kV VDC VPK RIO CIO CTI VIO VIOSM Barrier Life 44000 Years Per IEC 60601 500 V f = 1 MHz 240 VRMS, 60 Hz Per IEC 60112 At maximum operating temperature Per IEC 61000-4-5 100°C, 1000 VRMS, 60% CL activation energy 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Thermal Characteristics Parameter Symbol Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance QSOP 0.15" SOIC 0.3" SOIC QSOP 0.15" SOIC 0.3" SOIC Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance 0.3" SOIC Power Dissipation QSOP 0.15" SOIC 0.3" SOIC Min. Typ. 100 82 67 9 8 12 θJA θJC θJA 46 θJC 9 Max. Test Conditions Double-sided PCB in free air °C/W 2s2p PCB in free air per JESD51 675 700 1500 PD Units mW Notes: 1. All voltages are with respect to network ground except differential I/O bus voltages. 2. Differential input/output voltage is measured at the noninverting terminal A with respect to the inverting terminal B. 3. Skew limit is the maximum propagation delay difference between any two devices at 25°C. 4. Δ|VOD| and Δ|VOC| are the changes in magnitude of VOD and VOC, respectively, that occur when the input is changed from one logic state to the other. 5. Includes 10 ns read enable time. Maximum propagation delay is 25 ns after read assertion. 6. Pulse skew is defined as |tPLH – tPHL| of each channel. 7. Absolute Maximum specifications mean the device will not be damaged if operated under these conditions. It does not guarantee performance. 8. The relevant test and measurement methods are given in the Electromagnetic Compatibility section. 9. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin.” 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Narrow- and Wide-Body Pinout Differences The narrow-body version (IL3585-3E) is designed for application flexibility and minimum board area in densely-populated PCAs. The widebody version (IL3585E) has redundant ground pins for layout flexibility. The narrow-body version provides a separate isolated DE output (ISODE) and Transceiver Device Enable (XDE) input. ISODE follows the Device Enable input (DE). XDE can be used to enable and disable the transceiver from the bus side, or connected to ISODE to enable and disable the transceiver from the DE controller-side input. The narrow-body version also provides separate bus-side power supply pins—VDD2X for the transceiver module and VDD2I for the isolation module. These pins should be externally connected for normal operation, but they can be used separately for testing or troubleshooting. The wide-body version has internal connections between the isolated DE output and the Transceiver Device Enable input, and well as between the two VDD2 bus-side power supply pins. The two internally GND pins for each supply side provide layout flexibility. The ISODE output can be used in PROFIBUS applications where the state of the isolated drive enable node needs to be monitored, or for testing or troubleshooting. Dynamic Power Consumption IsoLoop Isolators achieve their low power consumption from the way they transmit data across the isolation barrier. By detecting the edge transitions of the input logic signal and converting these to narrow current pulses, a magnetic field is created around the GMR Wheatstone bridge. Depending on the direction of the magnetic field, the bridge causes the output comparator to switch following the input logic signal. Since the current pulses are narrow, about 2.5 ns, the power consumption is independent of mark-to-space ratio and solely dependent on frequency. This has obvious advantages over optocouplers, which have power consumption heavily dependent on frequency and time. Data Rate (Mbps) 1 10 20 40 IDD1 150 μA 1.5 mA 3 mA 6 mA IDD2 150 μA 1.5 mA 3 mA 6 mA Table 2. Typical Dynamic Supply Currents. Power Supply Decoupling VDD1 and VDD2 should be bypassed with 0.1 µF typical (47 nF minimum) capacitors as close as possible to the VDD pins. Maintaining Creepage Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. DC Correctness The IL3585 incorporates a patented refresh circuit to maintain the correct output state with respect to data input. At power up, the bus outputs will follow the Function Table shown on Page 1. The DE input should be held low during power-up to eliminate false drive data pulses from the bus. An external power supply monitor to minimize glitches caused by slow power-up and power-down transients is not required. Electromagnetic Compatibility The IL3585 is fully compliant with IEC 61000-6-1 and IEC 61000-6-2 standards for immunity, and IEC 61000-6-3, IEC 61000-6-4, CISPR, and FCC Class A standards for emissions. Immunity to external magnetic fields is even higher if the field direction is “end-to-end” (rather than to “pin-to-pin”) as shown in the diagram at right: 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Application Information Figures 1a and 1b show typical connections to a microcontroller for the narrow-body and wide-body versions. The schematics include typical termination and fail-safe resistors, and power supply decoupling capacitors: VDD2 = 5 V VDD1 = 3.3 V C DD2 C DD1 47nF 1 47nF 13 16 10µF 14 ISODE 6 10 D 5 R 3 RE 4 XDE 11 12 2 GND1 R FS-EXT 560R A RT 120R B R FS-EXT 560R 15 Isolation Boundary Microcontroller DE IL3585-3 + C DD2B GND2 Figure 1a. Typical narrow-body connections. VDD2 = 5 V VDD1 = 3.3 V C DD2 C DD1 47nF 1 47nF 16 5 + C DD2B 10µF 10 ISODE D 6 R 3 RE 4 R FS-EXT 560R 12 13 2 or 8 GND1 Isolation Boundary Microcontroller DE IL3585 9 or 15 A RT 120R B R FS-EXT 560R GND2 Figure 1b. Typical wide-body connections. Receiver Features The receiver output “R” has tri-state capability via the active low RE input. Driver Features The RS-485 driver has a differential output and delivers at least 2.1 V across a 54 Ω load. Drivers feature low propagation delay skew to maximize bit width and minimize EMI. Drivers have tri-state capability via the active-high DE input. Receiver Data Rate, Cables and Terminations The IL3585 is intended for networks up to 4,000 feet (1,200 m), but the maximum data rate decreases as cable length increases. Twisted pair cable should be used in all networks since they tend to pick up noise and other electromagnetically induced voltages as common mode signals, which are effectively rejected by the differential receiver. 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Fail-Safe Operation “Fail-safe operation” is defined here as the forcing of a logic high state on the “R” output in response to an open-circuit condition between the “A” and “B” lines of the bus, or when no drivers are active on the bus. Proper biasing can ensure fail-safe operation, that is a known state when there are no active drivers on the bus. IL3000-Series Isolated Transceivers include internal pull-up and pull-down resistors of approximately 30 kΩ in the receiver section (RFS-INT; see figure below). These internal resistors are designed to ensure failsafe operation but only if there are no termination resistors. The entire VDD will appear between inputs “A” and “B” if there is no loading and no termination resistors, and there will be more than the required 200 mV with up to four RS-485 worstcase Unit Loads of 12 kΩ. Many designs operating below 1 Mbps or less than 1,000 feet are unterminated. Termination resistors may not be necessary for very low data rates and very short cable runs because reflections have time to settle before data sampling, which occurs at the middle of the bit interval. In busses with low-impedance termination resistors however, the differential voltage across the conductor pair will be close to zero with no active drivers. In this case the state of the bus is indeterminate, and the idle bus will be susceptible to noise. For example, with 120 Ω termination resistors (RT) on each end of the cable, and four Unit Loads (12 kΩ each), without external fail-safe biasing resistors the internal pull-up and pulldown resistors will produce a voltage between inputs “A” and “B” of only about 5 mV. This is not nearly enough to ensure a known state. External fail-safe biasing resistors (RFS-EXT) at one end of the bus can ensure fail-safe operation with a terminated bus. Resistors should be selected so that under worst-case power supply and resistor tolerances there is at least 200 mV across the conductor pair with no active drivers to meet the input sensitivity specification of the RS-485 standard. Using the same value for pull-up and pull-down biasing resistors maintains balance for positive- and negative going transitions. Lower-value resistors increase inactive noise immunity at the expense of quiescent power consumption. Note that each Unit Load on the bus adds a worst-case loading of 12 kΩ across the conductor pair, and 32 Unit Loads add 375 Ω worst-case loading. The more loads on the bus, the lower the required values of the biasing resistors. In the example with two 120 Ω termination resistors and four Unit Loads, 560 Ω external biasing resistors provide more than 200 mV between “A” and “B” with adequate margin for power supply variations and resistor tolerances. This ensures a known state when there are no active drivers. Other illustrative examples are shown in the table below: Fail-Safe Biasing 5 V RFS-EXT VDD 30K RFS-INT A RFS-EXT Internal Only Internal Only 560 Ω 510 Ω RT None 120 Ω 120 Ω 120 Ω B RFS-EXT RFS-INT 30K GND RT RT R Loading Four unit loads (12 kΩ ea.) Four unit loads (12 kΩ ea.) Four unit loads (12 kΩ ea.) 32 unit loads (12 kΩ ea.) Nominal VA-B Fail-Safe Operation? (inactive) 238 mV Yes 5 mV No 254 mV Yes 247 mV Yes 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Package Drawings 0.15" 16-pin SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.013 (0.3) 0.020 (0.5) NOM 0.007 (0.2) 0.013 (0.3) 0.386 (9.8) 0.394 (10.0) Pin 1 identified by either an indent or a marked dot 0.016 (0.4) 0.050 (1.3) 0.054 (1.37) 0.062 (1.58) 0.054 (1.4) 0.072 (1.8) 0.150 (3.81) 0.157 (3.99) 0.049 (1.24) 0.051 (1.30) 0.228 (5.8) 0.244 (6.2) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.004 (0.1) 0.012 (0.3) 0.3" 16-pin SOIC Package (no suffix) Dimensions in inches (mm); scale = approx. 5X 0.033 (0.85)* 0.043 (1.10) 0.260 (6.60)* 0.280 (7.11) 0.013 (0.3) 0.020 (0.5) 0.007 (0.2) 0.013 (0.3) 0.397 (10.08) 0.413 (10.49) 0.017 (0.43)* 0.022 (0.56) 0.016 (0.4) 0.050 (1.3) 0.007 (0.18)* 0.010 (0.25) 0.092 (2.34) 0.105 (2.67) Pin 1 identified by either an indent or a marked dot 0.08 (2.0) 0.10 (2.5) 0.292 (7.42)* 0.299 (7.59) 0.049 (1.24) 0.051 (1.30) 0.394 (10.00) 0.419 (10.64) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate *Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601. 0.004 (0.1) 0.012 (0.3) 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Recommended Pad Layouts 0.15" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.06) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.275 (6.99) 0.3" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.317 (8.05) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.449 (11.40) 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Ordering Information and Valid Part Numbers IL 35 85 -3 V E TR13 Valid Part Numbers IL3585E IL3585E TR13 IL3585-3E IL3585-3E TR13 Bulk Packaging Blank = Tube TR13 = 13'' Tape and Reel Package E = RoHS Compliant IL3585VE IL3585VE TR13 Isolation Grade Blank = 2.5 kV Isolation / 600 WV V = 6 kV Isolation / 1 kV WV Package Type Blank = 0.3'' SOIC -3 = 0.15'' SOIC Channel Configuration 85 = RS-485 Base Part Number 35 = Digital-In, 40 Mbps Transceiver Product Family IL = Isolators RoHS COMPLIANT 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Revision History ISB-DS-001-IL3585-W August 2022 Changes • Clarified truth table (p. 1). • • Upgraded to IEC 60747-17 (VDE 0884-17):2021-10 (p. 3). Increased Working Voltage ratings based on latest VDE testing (p. 3). Separate power consumption specifications section; added dynamic power consumption (p. 5). • Revised thermal characteristics (p. 7). • Updated EMC standards. • Deleted minimum magnetic field immunity specifications (p. 6) since it is not 100% tested. • ISB-DS-001-IL3585-V Change • ISB-DS-001-IL3585-U ISB-DS-001-IL3585-T ISB-DS-001-IL3585-S ISB-DS-001-IL3585-R Changes • Updated VDE certification standard to VDE V 0884-10. • Upgraded “V” Version Surge Immunity specification to 12.8 kV. • Upgraded “V” Version VDE 0884-10 rating to reinforced insulation. Changes • Increased V-Series isolation voltage to 6 kVRMS. • Increased typ. Total Barrier Thickness specification to 0.016 mm. • Increased CTI min. specification to ≥600 VRMS. Changes • Increase V-Series surge voltage specification to 10 kV. • Upgraded V-Series safety and approval from IEC 60747-5-5 (VDE 0884) to VDE 0884-10. Change • ISB-DS-001-IL3585-Q Updated VDE Reinforced Isolation file number and description. Added V-Series versions (5 kVrms isolation / 1000 Vrms working voltage) Changes • IEC 60747-5-5 (VDE 0884) certification. • Upgraded from MSL 2 to MSL 1. 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL3585 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL3585-W August 2022 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL3585 价格&库存
很抱歉,暂时无法提供与“IL3585”相匹配的价格&库存,您可以联系我们找货
