AS3636-ZWLT
AS3636-ZWLT
    AMSOSRAM(艾迈斯半导体)
    16-UFBGA,WLCSP
    LED 驱动器 IC 1 输出 DC DC 稳压器 升压(升压) I²C 调光 900mA(开关) 16-WLCSP(2x2.15)
AS3636-ZWLT 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com Datasheet AS3636 Xenon Driver IC with LED Driver and Life Time Counter 1 General Description 2 Key Features Xenon driver - Adjustable recharge timings - Adjustable current limits - In-production trimmable end of charge voltage IGBT Driver - Trimmable IGBT voltages - Trimmable IGBT driving waveform - Internal flash duration timer - External STROBE input DCDC Boost Converter - Autofocus/video LED current source - Voltage supply for IGBT Integrated one time breakable fuse in supply path Integrated system level ESD protection according to IEC-61000-4-2 Level 4 (8kV contact, 15kV air discharge) Available in tiny WL-CSP Packages 4x4 balls 0.5mm pitch, 2.0 x 2.15 x 0.6 mm al id The AS3636 is a highly integrated photoflash charger including IGBT driver, inductive DCDC boost autofocus/ video LED driver, an indicator LED driver and it includes system level ESD protection and a breakable fuse. lv The AS3636 includes flash timeout, over- and undervoltage, overtemperature and LED short circuit protection functions. To reduce production test time a broken transformer or a broken coil is detected. 2 am lc s on A te G nt st il The AS3636 is controlled by an I C interface with a dedicated STROBE input. Additionally the TORCH input controls the torch function. An interrupt output is available to signal an error condition to the controller. The device includes 11 Bytes EEPROM, and an automatic life time counter to count the number of flashes performed. The AS3636 is available in a space-saving WL-CSP package and operates over the -30ºC to +85ºC temperature range. Warning: Lethal voltages are present on applications using AS3636! Do not operate without training to handle high voltages. 3 Applications Xenon Flash with LED Torch for mobile phones Figure 1. AS3636 Typical Operating Circuit      ! ch ! 6&%   ni  $  2 =/*-= 73*0007>7 %>      ca  Te   !  !  *0. 030 7 $+    *+,   *4*05  *-./0 "# $'1%&' 2&(&2  )   $ ! #   59 :*5-:05; "#        !! %&'%&( 8 8 *0. 030  ! AS3636 www.austriamicrosystems.com/AS3636 (ptr) 5080ms FFh Xenon charger time out fault was triggered - see TOF 1. Reading register Interrupt Status Register (see page 36) resets charge_time, therefore read charge_time before reading Interrupt Status Register. Table 14. Xenon SST Pulse Length Register Xenon SST Pulse Length Register Addr: 0Ah Bit Bit Name Xenon strobe test pulse length Default Access Description define Xenon strobe pulse length for register bit STROBE=1 and for Xenon module self testing - see Self Testing on page 18 7:0 xernon_SST_pulse_lengt 1 h NVM R 00h don’t use 01h 1µs 02h 2µs ... FFh 255µs 1. The resulting timing can vary by +1µs/-0µs (excluding the variation of the internal oscillator), therefore use this internal pulse generator only for self testing. Table 15. Xenon Life Time Register MSB Xenon Life Time Register MSB Addr: 0Bh Bit 7:0 Bit Name xenon_life_counter_MSB Default Access xenon_life_counter_MSB www.austriamicrosystems.com/AS3636 NVM R Description Count the number of flash double-pulses performed and store in NVM - see AS3636 operating mode on page 12 counter stops at FFFFh 1.2.2 30 - 45 AS3636 Datasheet - D e t a i l e d D e s c r i p t i o n Table 16. Xenon Life Time Register LSB Xenon Life Time Register LSB Addr: 0Ch xenon_life_counter_LSB Bit Bit Name Default Access 7:0 xenon_life_counter_LSB NVM Description Count the number of flash double-pulses performed and store in NVM - see AS3636 operating mode on page 12 counter stops at FFFFh R Table 17. Xenon Config Register A Xenon Config Register A Addr: 0Dh Bit Define the end of charge detection voltage Bit Name Default Access Description Define the Xenon end of charge detection voltage (measured on pin SW_F) 5:0 charge_voltage_selection NVM R 00h 28.5V 01h 28.6V 02h 28.7V ... 3Fh 7:6 00b 34.8V R always 0, don’t use Table 18. Xenon Config Register B Xenon Config Register B Addr: 0Eh Bit Define the peak current limit for the Xenon charger Bit Name Default Access Description Peak current limit measured on pin SW_F 2:0 switch_current_selection 1 NVM R 000 375mA 001 450mA 010 525mA 011 600mA 100 675mA 101 750mA 110 825mA 111 900mA Extend the timing for the IGBT strobe pulse - see IGBT Pulse Timing adjustment 6:3 extend_pulse www.austriamicrosystems.com/AS3636 NVM R 0h no pulse extension 1h 100ns 2h 200ns 3h 300ns ... ... Eh 1400ns Fh 1500ns 1.2.2 31 - 45 AS3636 Datasheet - D e t a i l e d D e s c r i p t i o n Table 18. Xenon Config Register B (Continued) Xenon Config Register B Addr: 0Eh Bit Define the peak current limit for the Xenon charger Bit Name Default Access Description Define together with IGBT_fall_speed2zero IGBT driver fall speed for final switch-off (VOUTBOOST/2 to 0V) 7 IGBT_fall2zero_slow NVM R/W 0 full current - see IGBT_fall_speed2zero 1 half current - see IGBT_fall_speed2zero 1. Take care to set the peak current limit to fit to the Xenon charger transformer used - if the peak current limit is set too low, efficiency will drop and eventually end of charge will not be reached anymore. Table 19. Xenon Config Register C Xenon Config Register C Addr: 0Fh Bit Define IGBT driver parameters and SW_B switch current limits Bit Name Default Access Description Define IGBT driver fall speed for final switch-off (VOUTBOOST/2 to 0V) IGBT_fall2zero_slow = 0 1 2:0 1 IGBT_fall_speed2zero NVM R 000 1V/µs (10mA) 0.5V/µs (5mA) 001 2V/µs (20mA) 1V/µs (10mA) 010 3V/µs (30mA) 1.5V/µs (15mA) 011 4V/µs (40mA) 2V/µs (20mA) 100 5V/µs (50mA) 2.5V/µs (25mA) 101 6V/µs (60mA) 3V/µs (30mA) 110 7V/µs (70mA) 3.5V/µs (35mA) 111 8V/µs (80mA) 4V/µs (40mA) Define IGBT switch-on speed and switch-off down to VOUTBOOST/2 5:3 IGBT_rise_and_fall_spee 2 d NVM R 000 1V/µs (10mA) 001 2V/µs (20mA) 010 3V/µs (30mA) 011 4V/µs (40mA) 100 5V/µs (50mA) 101 6V/µs (60mA) 110 7V/µs (70mA) 111 8V/µs (80mA) DCDC Boost Coil Peak current setting (pin SW_B) 7:6 coil_peak_current www.austriamicrosystems.com/AS3636 NVM R 00 250mA 01 300mA 10 350mA 11 400mA 1.2.2 32 - 45 AS3636 Datasheet - D e t a i l e d D e s c r i p t i o n 1. Assuming a 10nF capacitance. The timings scale by the gate capacitance of the IGBT 2. Assuming a 10nF capacitance. The timings scale by the gate capacitance of the IGBT Table 20. LED Current Register LED Current Register Addr: 10h Bit AF LED and indicator LED current and PWM settings Bit Name Default Access Description AF LED Current settings 2:0 AF_LED_current 1 000b R/W 000 10mA 001 15mA 010 20mA 011 28mA 100 37mA 101 50mA 110 65mA 111 80mA AF LED PWM setting 5:3 2 AF_LED_PWM 000b R/W 000 1/32 001 2/32 010 3/32 011 5/32 100 8/32 101 12/32 110 20/32 111 32/32 Indicator LED current setting 7:6 IND_LED_current 00b R/W 00 2mA 01 4mA 10 8mA 11 16mA 1. AF_LED_current setting is automatically limited to Max_LED_current (see page 34) 2. The internal PWM generator output frequency is 31.25kHz (to avoid audible noise) www.austriamicrosystems.com/AS3636 1.2.2 33 - 45 AS3636 Datasheet - D e t a i l e d D e s c r i p t i o n Table 21. LED Control Register LED Control Register Addr: 11h Bit Control AF LED and indicator LED operating mode Bit Name Default Access Description Indicator LED on/off 0 0 1 0 IND off R/W if ILP=0: use VLED output with AF_LED_current and AF_LED_PWM duty cycle 1 if ILP=1: use IND output with IND_LED_current 100ms Indicator LED pulse 0 1 INDP 2 0 no pulse if ILP=0: 100ms pulse on VLED output with AF_LED_current and AF_LED_PWM duty cycle R/W 1 if ILP=1: 100ms pulse on IND output with IND_LED_current AF LED PWM enable if AF=1(pin VLED) 2 PWM 0 R/W 0 no PWM 1 AF LED PWM with AF_LED_PWM AF LED on/off (pin VLED) 3 AF 3 7:4 0 0000b R/W 0 off 1 enabled AF LED with AF_LED_current; if PWM=1 use AF_LED_PWM duty cycle R always 0, don’t use 1. If IND=1 and INDP=1, IND=1 has priority 2. After the 100ms pulse, the register INDP is automatically reset 3. Do not operate AF=1 and (IND or INDP=1) at the same time Table 22. LED Configuration Register LED Configuration Register Addr: 12h Bit Bit Name Set maxim AF LED current and configure indicator type Default Access Description AF LED Maximum current limit 2:0 Max_LED_current 6:3 www.austriamicrosystems.com/AS3636 NVM 0h R 000 10mA 001 15mA 010 20mA 011 28mA 100 37mA 101 50mA 110 65mA 111 80mA R always 0, don’t use 1.2.2 34 - 45 AS3636 Datasheet - D e t a i l e d D e s c r i p t i o n Table 22. LED Configuration Register (Continued) LED Configuration Register Addr: 12h Bit Bit Name Set maxim AF LED current and configure indicator type Default Access Description Indicator LED present; applies when indicator is switched on (IND=1) 7 ILP NVM R/W 0 use VLED output with AF_LED_current and AF_LED_PWM duty cycle 1 use IND output with IND_LED_current; ILF (indicator LED fault) detection is enabled Table 23. Password Register Password Register Addr: 13h Bit Bit Name EEPROM writing password lock register Default Access Description Un-lock register for EEPROM writing - see EEPROM Writing Cycle on page 16 7:0 Password_register 00h R/W password 1 code Read: EEPROM writing pending 2 Write: Unlock EEPROM writing for next I C command wrong code EEPROM writing locked 1. Consult austriamicrosystems for the exact value. www.austriamicrosystems.com/AS3636 1.2.2 35 - 45 AS3636 Datasheet - R e g i s t e r M a p 9 Register Map Table 26. Register Map Register Definition Addr Default Name Content b7 b6 b5 b4 b3 b2 b1 b0 0 0 1 0 IC Info Register 00h 12h 0 0 0 1 IC Version Control Register 01h 0Xh 0 0 0 0 Module Info Reg.A 02h NVM User NVM 1 03h NVM Control Register 04h 01h STDBY RESET Interrupt Mask Register 05h FFh SSTFI Interrupt Status 1 Register 06h 00h Xenon Control Register 07h Xenon CAR Interval Register Module_Manufacturer_ID Design_round Module_Generation Module_Type User defined 0 0 TORCH _S MST READY FI AFFI OTPFI TOFI BCFI CTFI ILFI SSTF READY F AFF OTPF TOF BCF CTF ILF 00h 0 0 0 0 CAR STROB READY CHARG E E 08h 01h 0 0 0 0 0 CAR_interval Xenon Charge Time Register 09h 00h charge_time Xenon SST Pulse Length Register 0Ah NVM xernon_SST_pulse_length Xenon Life Time Register MSB 0Bh NVM xenon_life_counter_MSB Xenon Life Time Register LSB 0Ch NVM xenon_life_counter_LSB Xenon Config Register A 0Dh NVM 0 Xenon Config Register B 0Eh NVM IGBT_fall2 zero_slow Xenon Config Register C 0Fh NVM coil_peak_current IGBT_rise_and_fall_speed LED Current Register 10h 00h IND_LED_current LED Control Register 11h 00h 0 LED Configuration Register 12h NVM ILP Password Register 13h 00h Password_register User NVM 2 14h NVM User defined User NVM 3 15h NVM User defined User NVM 4 16h NVM User defined User NVM 5 17h NVM User defined User NVM Area 27h-7Fh NVM User defined www.austriamicrosystems.com/AS3636 0 charge_voltage_selection extend_pulse 0 AFSTR WATCH OBE DOG switch_current_selection AF_LED_PWM 0 0 IGBT_fall_speed2zero AF_LED_current AF PWM INDP IND Max_LED_current 1.2.2 36 - 45 AS3636 Datasheet - R e g i s t e r M a p 1. Reading register Interrupt Status Register resets charge_time, therefore read charge_time before reading Interrupt Status Register. NVM...Non Volatile Memory using internal EEPROM; for programming see EEPROM Writing Cycle on page 16, don’t read or write during life time counter updates Note: When writing to read-only register (in mixed read only / read/write register like Xenon Control Register) write 0 to read-only register bits. For undefined register bits always write ‘0’. Do never write to undefined register addresses (above 15h). Upon delivery the EEPROM default value are set according to Table 27: Table 27. EEPROM default settings Register Definition Addr Default Name Content b7 b6 b5 b4 b2 Module Info Reg.A 02h 05h User NVM 1 03h 00h Xenon SST Pulse Length Register 0Ah 08h xernon_SST_pulse_length Xenon Life Time Register MSB 0Bh 00h xenon_life_counter_MSB Xenon Life Time Register LSB 0Ch 00h xenon_life_counter_LSB Xenon Config Register A 0Dh 1Fh 0 Xenon Config Register B 0Eh 86h IGBT_fall2 zero_slow Xenon Config Register C 0Fh 80h coil_peak_current IGBT_rise_and_fall_speed LED Configuration Register 12h 07h User NVM 2 14h 00h User defined User NVM 3 15h 00h User defined www.austriamicrosystems.com/AS3636 Module_Manufacturer_ID b3 Module_Generation Module_Project_Number 0 b1 b0 Module_Type Module_Major_Version charge_voltage_selection extend_pulse ILP switch_current_selection IGBT_fall_speed2zero Max_LED_current 1.2.2 37 - 45 AS3636 Datasheet - A p p l i c a t i o n I n f o r m a t i o n 10 Application Information External Components Transformers TCHARGE and TTRIG Following transformers are approved for the AS3636 (due to the programming features the output voltage VFLASH can be programmed): Table 28. Approved Transformers Component Part Number N L Size (mm) TTRN-3825H 10.2 7µH 3.8x3.8x2.5 TTRN-3822H 10.2 7µH 3.8x3.8x2.2 1 10.2 7µH 3.2x2.5x1.8 (H is max) 2 10.2 7µH 3.2x2.5x1.6 (H is max) C3-T2.5R 10.2 7µH 3.4x3.4x2.5 3 10.2 7µH 3.2x2.4x1.8 (H is max) C2-T1.6D 4 10.2 7µH 3.2x2.4x1.6 (H is max) LDT4520T-01 10.2 10µH 4.7x4.5x2.0 5 10.2 7µH 3.2x2.5x1.55 (H is max) TTRN2518 TTRN2516 TCHARGE C2-T1.8D ATB322515 TTRIG BO-02 7.3x2.5(3.5)x2.2 Manufacturer Tokyo Coil www.tokyo-coil.co.jp Mitsumi www.mitsumi.co.jp TDK www.tdk.com Tokyo Coil www.tokyo-coil.co.jp 1. Use only for switch_current_selection=825mA or 900mA. 2. Use only for switch_current_selection=825mA or 900mA. 3. Use only for switch_current_selection=825mA or 900mA. 4. Use only for switch_current_selection=825mA. Contact Mitsumi to use for switch_current_selection=900mA. 5. Use only for switch_current_selection=825mA or 900mA. Always check if the voltage on the pin SW_F does never exceed the AS3636 maximum VSW (see Table 3 on page 4) specification during charging. IGBT As the AS3636 has an internal DCDC step up included, 2.5V and 4V IGBT can be used without limit on the supply VVBAT. The IGBT is used for two purposes: 1. Powering of the Xenon tube and generating together with the oscillation circuit consisting of TTRIG, CTRIG, RTRIG a sufficiently high trigger pulse to ignite the Xenon tube (about 3.5kV) - this is accomplished by a fast rising edge of the gate of the IGBT 2. Switching off the current through the Xenon tube at the end of the flash pulse to accurately control the light emitted by the flash. To protect the IGBT the switching off falling edge voltage should be less than 400V/µs (measured on the emitter of the IGBT) www.austriamicrosystems.com/AS3636 1.2.2 38 - 45 AS3636 Datasheet - A p p l i c a t i o n I n f o r m a t i o n Both requirements are achieved with the internal driving circuit of the AS3636. Trimming allows to adopt to different trigger coils and IGBTs. Table 29. Recommended IGBTs Component QIGBT Part Number min. Drive Voltage Size RJP4002ANS 2.5V RJP4003ANS 4.0V VSON-8 3 x 4.8mm 1 2.5V 2.85x2.95mm GT8G133 4.0V TSSOP-8 3.3 x 6.4mm Toshiba www.semicon.toshiba.co.jp 1 4.0V ECH8 2.8 x 2.9mm Sanyo www.sanyo.com RJP4006ANS TIG058E8 Manufacturer Renesas www.renesas.com 1. Requires additional resistor in series with gate. See datasheet of IGBT. Note: The non-volatile registers IGBT_fall_speed2zero, IGBT_rise_and_fall_speed and IGBT_fall2zero_slow have to be set to fit to the used IGBT. Failing to do so might cause permanent damage to the IGBT. Photoflash Capacitor CFLASH The photoflash capacitor stores the energy for the flash. Its capacitance define the maximum available energy. Using higher value capacitors as shown in Table 30 is possible, but will increase the charging time. It is recommended to use low ESR capacitors to avoid loosing power during flash (it is also possible to connect two capacitors in parallel to reduce ESR): Table 30. Recommended Photoflash Capacitors Component Part Number Capacitor CFLASH 330FW13A6.3X20 2x13.5µF 1 Voltage rating Size Manufacturer 330V Cylinder 2 x l=24mm, d=7mm Rubycon www.rubycon.co.jp 1. Different capacitor values are possible to be used together with the AS3636. Lower capacitor value will reduce charging time, lower ESR capacitor will improve light output energy and reduce losses in the capacitor during the flash pulse. www.austriamicrosystems.com/AS3636 1.2.2 39 - 45 AS3636 Datasheet - A p p l i c a t i o n I n f o r m a t i o n Photoflash Charger rectification diode DCHARGE The rectification diode should have very low parasitic capacitance reverse voltages. 22 and has to withstand the operating current and Table 31. Recommended Rectification Diodes Component DCHARGE Part Number Parasitic Capacitor Voltage rating Size Manufacturer FVO2R80 5pF 800V 1.25x2.5mm Origin www.origin.co.jp GSD2004S 5pF / 2 2x240V SOT-23 2.4x3.0mm Vishay www.vishay.com BAS21 5pF / 2 2x250V SC-70 2.0x2.1mm OnSemi www.onsemi.com DA2SF650EL 0.7pF 600V 1.2x0.8mm Panasonic www.panasonic.com RFU01SM4S 1.5pF 450V 1.0x0.6mm Rohm www.rohm.com Supply Capacitor CVBAT and DCDC Boost capacitor CVOUTBOOST Low ESR capacitors should be used to minimize VBAT ripple. Multi-layer ceramic capacitors are recommended since they have extremely low ESR and are available in small footprints. The capacitor should be located as close to the device as possible. X5R dielectric material is recommended due to their ability to maintain capacitance over wide voltage and temperature range. Table 32. Recommended CVBAT and CVOUTBOOST Capacitor Part Number C TC Code Rated Voltage Size Manufacturer CVBAT,CVOUTBOOST GRM188R60J106 10µF >5.5µF @1.8V >4µF @5V X5R 6.3V 0603 Murata www.murata.com CVOUTBOOST C1608X5R 0J106M 10µF X5R 6.3V 0603 TDK www.tdk.com Component If a different output capacitor is chosen, ensure low ESR values and voltage ratings. Inductor LDCDC The fast switching frequency (2MHz) of the AS3636 allows for the use of small SMDs for the external inductor. The 2 inductor should have low DC resistance (DCR) to reduce the I R power losses - high DCR values will reduce efficiency. Table 33. Recommended Inductor Part Number L DCR L @ 0.5A Size Manufacturer LQM21PN2R2NGC 2.2µH 240m >1.5µH 2x1.25x0.9mm (0805) Murata www.murata.com BRC1608T2R2M 1 2.2µH 550m >1.5µH @ 0.4A 1.6x0.8x0.8mm (0603) Taiyo Yuden www.t-yuden.com GLCR1608T2R2M 2.2µH 400m >1.5µH 1.6x0.8x0.9mm (0603) TDK www.tdk.com 22.A low parasitic capacitance improves charging efficiency. www.austriamicrosystems.com/AS3636 1.2.2 40 - 45 AS3636 Datasheet - A p p l i c a t i o n I n f o r m a t i o n 1. Use only at 250mA coil_peak_current (see page 32)=00b unless TAMB can be limited. This coil has a temperature rise maximum current of 280mA. If TAMB can be limited coil_peak_current can be increased to 350mA. If a different inductor is chosen, ensure similar DCR values and at least 1.5µH inductance at 0.5A input current. Resistor RTRIG This resistor has to withstand the high voltage on the photoflash capacitor CFLASH. As there is a safety time for the IGBT driver (see IGBT Driver on page 17) the high voltage on this resistor is limited to 2ms. Therefore a smaller resistor size can be used (0402 sized surge or thick film resistor instead of 0805). PCB Layout Guideline Following layout recommendations apply: 1. Keep the path (and area) of GND (SGND directly connected to DGND below the WL-CSP) - CVBAT - VBATINT - TCHARGE(primary) - SW_F - GND as short as possible to minimize the leakage inductance of TCHARGE and ensure a proper supply connection for the AS3636 2. Keep the path (and area) of GND - CVBAT - LBOOST - SW_B - VOUTBOOST - CVOUTBOOST - GND as short as possible. 3. Place CVBAT as close as possible to the AS3636. 4. Ensure wide and short PCB paths for the path GND - CFLASH - XFLASH - QIGBT - GND to allow 150A to flow during the flash pulse. Connect this GND only at a single place to the main GND plane. 5. The IGBT has two ground connections: One ground for the driving input and one ground for the power path. 6. Ensure larger spacings for all high voltage paths; check with the PCB manufacturer to ensure proper minimum spacing for 320V paths and 4kV (Xenon tube trigger pin) paths. 7. Minimize the parasitic capacitance of the PCB on the anode of DCHARGE especially to GND and VFLASH 8. See austriamicrosystems “WLP-CSP-Handling-Guidelines_1V0.pdf” for proper handling, PCB layout and soldering of the WL-CSP AS3636 device. 9. In order to meet system level ESD protection careful routing of the ground lines, supply capacitor CVBAT and supply lines is required. See austriamicrosystems demoboard layout (described in application note ‘AN3636’). www.austriamicrosystems.com/AS3636 1.2.2 41 - 45 AS3636 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 11 Package Drawings and Markings Figure 35. 16pin WL-CSP 2x2.15mm Marking                                 AS3636       Note: Line 1: Line 2: Line 3: austriamicrosystems logo AS3636 Encoded Datecode (4 characters) Figure 36. 16pin WL-CSP 2x2.15mm Package Dimensions   %&' (&)"         ' ' ' ' ' ' '         * * * * * * * * + + + + + + +     +    ,        '    !"#$!  The coplanarity of the balls is 40µm. www.austriamicrosystems.com/AS3636 1.2.2 42 - 45 AS3636 Datasheet - O r d e r i n g I n f o r m a t i o n 12 Ordering Information The devices are available as the standard products shown in Table 34. Table 34. Ordering Information Model Description Delivery Form Package AS3636-ZWLT Xenon Driver IC with LED Driver and Life Time Counter Tape & Reel 16-pin WL-CSP (2mm x 2.15mm) RoHS compliant / Pb-Free / Green Note: All products are RoHS compliant and austriamicrosystems green. Buy our products or get free samples online at ICdirect: http://www.austriamicrosystems.com/ICdirect Technical support is found at http://www.austriamicrosystems.com/Technical-Support For further information and requests, please contact us mailto:sales@austriamicrosystems.com or find your local distributor at http://www.austriamicrosystems.com/distributor Note: AS3636-ZWLT AS3636 Z Temperature Range: -30ºC - 85ºC WL Package: Wafer Level Chip Scale Package (WL-CSP) 2x2.15mm T Delivery Form: Tape & Reel www.austriamicrosystems.com/AS3636 1.2.2 43 - 45 AS3636 Datasheet - O r d e r i n g I n f o r m a t i o n Copyrights Copyright © 1997-2012, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information Headquarters austriamicrosystems AG Tobelbaderstrasse 30 Schloss Premstaetten A-8141 Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com/AS3636 1.2.2 44 - 45 AS3636 Datasheet - O r d e r i n g I n f o r m a t i o n Copyrights Copyright © 1997-2012, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information Headquarters austriamicrosystems AG Tobelbaderstrasse 30 Schloss Premstaetten A-8141 Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com/AS3636 1.2.2 45 - 45 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: ams: AS3636-ZWLT
AS3636-ZWLT 价格&库存
很抱歉,暂时无法提供与“AS3636-ZWLT”相匹配的价格&库存,您可以联系我们找货
