AS3695C-ZMFT
AS3695C-ZMFT
    AMSOSRAM(艾迈斯半导体)
    VFQFN64_EP
    LED 驱动器 IC 16 输出 线性 SPI 调光 64-QFN(9x9)
AS3695C-ZMFT 数据手册
High Performance Analog IC and Sensor Portfolio Overview January 2014 Light Sensors Sensor Driven Lighting NFC/HF RFID Audio Position Sensors Lightning Sensor Power Management UHF RFID Sensor Interfaces RF Transmitters & Receivers Lighting Management Contents Product Family Page Audio 2 Light Sensors 5 Lighting Management 10 Lightning Sensor 12 NFC/HF RFID 13 Position Sensors 14 Power Management 18 RF Transmitters & Receivers 24 Sensor Driven Lighting 25 Sensor Interfaces 27 UHF RFID 29 Full Service Foundry 30 www.ams.com 1 Audio Active Noise Cancellation Max. Output Power ANC Performance Supply Voltage V (mm) >100dB, 20dB 1.0 - 1.8 QFN-24 (4×4) 125mW >100dB, 25dB 1.0 - 1.8 QFN-24 (4×4) Stereo SE/ Mono BTL w. Bypass 125mW >106dB, 20dB 1.0 - 1.8 QFN-32 (5×5) Receive Path feedforward/Feedback Mono BTL 125mW >100dB, 20dB 1.0 - 1.8 QFN-20 (4×4) BT Accessories Receive Path Feedforward Stereo SE SE : 35mW >100dB, 25dB 1.0 - 1.8 QFN-24 (4×4) AS3422 BT Accessories Receive Path Feedback Stereo SE SE : 35mW >100dB, 20dB 1.0 - 1.8 QFN-32 (5×5) AS3430 Accessories Receive Path Feedback Stereo SE/ Mono BTL 125mW >100dB, 20dB 1.0 - 1.8 QFN-32 (5×5) AS3435 Accessories Receive Path Feedback Stereo SE/ Mono BTL w. Bypass 125mW >106dB, 25dB 1.0 - 1.8 QFN-36 (5×5) AS3501 Embedded Receive Path Feedforward Stereo SE/ Mono BTL 125mW >100dB, 25dB 1.0 - 1.8 QFN-24 (4×4) AS3502 Embedded Receive Path Feedback Stereo SE/ Mono BTL 125mW >100dB, 20dB 1.0 - 1.8 QFN-32 (5×5) Part No. Function Topology Output Type AS3400 Accessories Receive Path feedforward/Feedback Mono BTL 125mW AS3410 Accessories Receive Path Feedforward Stereo SE/ Mono BTL AS3415 Accessories Receive Path Feedforward AS3420 BT Accessories AS3421 SNR, THD BTL, 1.8 V, 32 Ohm SE, 34 mW, 32 Ohm NEW NEW Package Audio Front-Ends Part No. Power Management Main Audio Features Audio Speaker Codec SNR Amplifier AS3510 DC-DC StepUp: 1×150mA @ 3.6V DC-DC StepDown: LDO: 2×50mA, 1×200mA Charge: Current Sink: - Headphone Amp: 1× Line Out: Line In: Microphone In: 1× Audio Mix: yes DAC: 91dB ADC: 83dB AS3515 DC-DC StepUp: 1×60mA @ 12V DC-DC StepDown: LDO: 5×200mA, 1×2mA, 2× MIC Charge Pump: 1× for Core Current Sink: 1×40mA (progr.) Headphone Amp: 1× Line Out: 1× Line In: 2× Microphone In: 2× Audio Mix: yes AS3517 DC-DC StepUp: 1×60mA @ 12V, 1×500mA (USB) DC-DC StepDown: 1×500mA, 2×250mA LDO: 4×200mA, 1×2mA, 2× MIC Charge Pump: 1×10mA (for USB OTG) Current Sink: 1×40mA (prog., log. Dimming) AS3543 DC-DC StepUp: 1×60mA @ 12V DC-DC StepDown: 2×250mA with DVM LDO: 3×100mA, 1×50mA, 1× MIC Charge Pump: Current Sink: 2×36mA (prog., log. Dimming) Main Interfaces and Control USB Charger Boot ROM with Temp. for Start-up Supervision Sequences RTC Package (mm) • Gen. Purpose ADC: I2C & I2S: yes SPDIF: RES & WDT: RES only DRM Enabled (UID): - - - - BGA-49 (7×7) DAC: 94dB ADC: 83dB • Gen. Purpose ADC: 10bit I2C & I2S: yes SPDIF: RES & WDT: yes DRM Enabled (UID): 64bit • 25 • BGA-64 (7×7) Headphone Amp: 1× Line Out: 2× Line In: 2× Microphone In: 2× Audio Mix: yes DAC: 96dB ADC: 90dB - Gen. Purpose ADC: 10bit I2C & I2S: yes SPDIF: yes RES & WDT: yes DRM Enabled (UID): 64bit • 25 • BGA-81 (9×9) Headphone Amp: 1× Line Out: 1×* Line In: 2× Microphone In: 1× Audio Mix: yes DAC: 102/96dB ADC: 85dB - Gen. Purpose ADC: 10bit I2C & I2S: yes SPDIF: RES & WDT: yes DRM Enabled (UID): 64bit + Current Limitation + Battery Switch 5 (25 voltage combinations each) • BGA-64 (6×6) *) with ground noise cancellation 2 www.ams.com Headphone Amplifiers Part No. Topology Power PSRR mW dB AS3560 Class G 30 AS3561 Class H 30 Supply Voltage Output Type Shutdown Supply Current mA V (mm) >90 Single ended stereo via I2C 0.9 2.3 - 5.5 WL-CSP-16 >90 Single ended stereo via I2C 0.9 2.3 - 5.5 WL-CSP-16 Supply Voltage Package Package Operational Amplifiers Amplifiers Slew Rate Gain Bandwidth PSRR CMRR # V/µs MHz dB dB mA V (mm) 1 10 10 -85 -70 AS1710A: AS1710B: - 1.6 2.7 - 5.5 SC70-6 Quad Rail to rail Op Amp with shutdown 4 10 10 -85 -70 • 6.4 2.7 - 5.5 TQFN -16 (3×3) Rail to rail Op Amp with shutdown 1 10 10 -70 -60 • 1.6 2.7 - 5.5 MLPD-8 (2×2) Part No. Description AS1710 Single Rail to rail Op Amp with shutdown AS1712 AS1713 Shutdown Supply Current Phones (Feature/Basic) Operating Range Last Number & Memory Dialing Tone Ringer Handsfree Function Package -25 to 70 0 • • TQFP-32, Die on Foil 15 - 150 -25 to 70 0 - • SOIC-28, Die on Foil 3.0 - 5.0 15 - 100 -25 to 70 29 • • TQFP-44, Die on Foil AS2533 3.8 - 5.0 13 - 100 -25 to 70 15 • - SOIC-28, Die on Foil AS2534 3.8 - 5.0 13 - 100 -25 to 70 1 • - SOIC-28, Die on Foil AS2535 3.8 - 5.0 13 - 100 -25 to 70 12 • - SOIC-28, Die on Foil AS2536 3.8 - 5.0 13 - 100 -25 to 70 15 • - SOIC-28, Die on Foil AS2540 3.6 - 5.0 15 - 100 -15 to 60 0 • - SOIC-28, Die on Foil Part No. Supply Voltage V mA °C AS2522B 3.0 - 5.0 15 - 150 AS2523/24 3.0 - 5.0 AS2525 www.ams.com Temperature Range 3 Our mission: Shaping the world with sensor solutions ams sensor solutions take sensing to the next level by providing a seamless interface between humans and technology. We develop high-performance solutions for the most challenging applications in sensors, sensor interfaces, power management and wireless. Simply said, we do the “tough stuff”. We enable our customers to create highly differentiated products that are smarter, safer, easier to use and more eco-friendly. 4 www.ams.com Light Sensors Ambient Light Sensors Part No. Type Operating Voltage I²C Interface TSL25911 Light-to-Digital 2.7 - 3.6 VDD TSL25721 Light-to-Digital 2.4 - 3.6 TSL25723 Light-to-Digital TSL45315 TSL45317 I²C Alternate Address Programmable V NEW Package Gain Integration Time Interrupts CL FN • • 100-600 mS • - • VDD • • • • - • 2.7 - 3.6 1.8V • • • • - • Light-to-Digital 2.3 - 3.3 VDD • Automatic 100, 200 and 400 mS - • - Light-to-Digital 2.3 - 3.3 1.8V • Automatic 100, 200 and 400 mS - • - Ambient Light Sensors and Proximity Detection Part No. Operating Voltage Type I²C Interface I²C Alternate Address IR LED Recommended Operating Distance V Short: < 15 cm Medium: < 46 cm Package NEW TMD27721 Light-to-Digital 2.2 - 3.6 VDD • • • - Module NEW TMD27723 Light-to-Digital 2.2 - 3.6 1.8V • • • - Module TMD27711 Light-to-Digital 2.6 - 3.6 VDD - • • - Module TMD27713 Light-to-Digital 2.6 - 3.6 1.8V - • • - Module TSL27721 Light-to-Digital 2.4 - 3.6 VDD • - • • FN TSL27723 Light-to-Digital 2.4 - 3.6 1.8V • - • • FN Color Sensors Part No. Type Operating Voltage I²C Interface I²C Alternate Address Color Sensor IR Filter Color Filter Array Configuration Ambient Light Sensing Sync Input V Package FN CS SOIC TCS34725 Light-to-Digital 2.7 - 3.6 VDD • RGBC • 4×4 • - • - - TCS34727 Light-to-Digital 2.7 - 3.3 1.8V • RGBC • 4×4 • - • - - TCS34715 Light-to-Digital 2.7 - 3.3 VDD • RGBC - 4×4 • - • - - TCS34717 Light-to-Digital 2.7 - 3.3 1.8V • RGBC - 4×4 • - • - - TCS3103/4 Light-to-Voltage 4.5 - 5.5 - - RGB - 3×3 - - • - - TCS3200 Light-toFrequency 2.7 - 5.5 - - RGBC - 8×8 - - - - • TCS3210 Light-toFrequency 2.7 - 5.5 - - RGBC - 4×6 - - - - • TCS3414 Light-to-Digital 2.7 - 3.6 VDD • RGBC • 2×8 - • • • - www.ams.com 5 Light Sensors Color Sensors and Proximity Detection Part No. Type Operating Voltage I²C Interface I²C Alternate Address IR LED Color Sensor IR Filter Ambient Light Sensing Package NEW TMD37821 Light-to-Digital 2.7 - 3.3 VDD - • RGBC • • Module NEW TMD37823 Light-to-Digital 2.7 - 3.3 1.8V - • RGBC • • Module TCS37725 Light-to-Digital 2.7 - 3.6 VDD • - RGBC • • FN TCS37727 Light-to-Digital 2.7 - 3.3 1.8V • - RGBC • • FN TCS37715 Light-to-Digital 2.7 - 3.3 VDD • - RGBC - • FN TCS37717 Light-to-Digital 2.7 - 3.3 1.8V • - RGBC - • FN V Proximity Detection I²C Interface I²C Alternate Address IR LED Short: < 15 cm Medium: < 46 cm 2.2 -3.6 VDD • • • - Module Light-to-Digital 2.2 -3.6 1.8V • • • - Module TMD26711 Light-to-Digital 2.6 - 3.6 VDD - • • - Module TMD26713 Light-to-Digital 2.6 - 3.6 1.8V - • • - Module TSL26721 Light-to-Digital 2.4 - 3.6 VDD • - • • FN TSL26723 Light-to-Digital 2.7 - 3.6 1.8V • - • • FN Part No. Type Operating Voltage NEW TMD26721 Light-to-Digital NEW TMD26723 V Recommended Operating Distance Package Light-to-Digital Part No. Type Operating Voltage I²C Interface I²C Alternate Address V NEW 6 Programmable Package Gain Integration Time Interrupts CL FN TSL25911 Light-to-Digital 2.7 - 3.6 VDD • • 100-600 mS • - • TSL25721 Light-to-Digital 2.4 - 3.6 VDD • • • • - • TSL25723 Light-to-Digital 2.7 - 3.6 1.8V • • • • - • TSL45315 Light-to-Digital 2.3 - 3.3 VDD • Automatic 100, 200 and 400 mS - • - TSL45317 Light-to-Digital 2.3 - 3.3 1.8V • Automatic 100, 200 and 400 mS - • - www.ams.com Light-to-Frequency Maximum Output Frequency IR Sensing Sidelooker DIP SOIC T 790 @ 640 nm 1.1 MHz - - • • - 2.7 - 5.5 625 @ 635 nm 500 KHz - • - - - TSL237 2.7 - 5.5 1200 @ 640 nm 1 MHz - • - - • TSL238 2.7 - 5.5 3400 @ 640 nm 1 MHz - - - • • TSL245 2.7 - 5.5 500 @ 940 nm 500 KHz • • - - - Sidelooker SOIC SM T Part No. Operating Voltage Responsivity V Hz/µW/cm² TSL230 2.7 - 5.5 TSL235 Package Light-to-Voltage Part No. Operating Voltage Fast Response Responsivity Low Noise IR Only Package V Low Medium High Ultra TSL12 2.7 - 5.5 - - • - • - - • - • • TSL13 2.7 - 5.5 - • - - • - - • - • • TSL14 2.7 - 5.5 • - - - • - - • - • - TSL250/60 2.7 - 5.5 - • - - - • TSL260 • • • - TSL251/61 2.7 - 5.5 - • - - - • TSL261 • • • - TSL252/62 2.7 - 5.5 • - - - • • TSL262 • - • - TSL253 2.7 - 5.5 - • - - • - - • - • - TSL254 2.7 - 5.5 • - - - • - - • - • - TSL257/67 2.7 - 5.5 - - - • - - TSL267 • - • • www.ams.com 7 Light Sensors Linear Sensor Arrays Part No. Operating Voltage TSL201CL Pixels Integration MHz CS CL P PCB 4.5 - 5.5 200 64 Start/Stop per Pixel 5 - • - - TSL202R 4.5 - 5.5 200 128 Start/Stop per Pixel 5 - - • - TSL208R 4.5 - 5.5 200 512 Start/Stop per Pixel 5 - - - • TSL210 4.5 - 5.5 200 640 Start/Stop per Pixel 5 - - - • TSL2014 4.5 - 5.5 200 896 Start/Stop per Pixel 5 - - - • TSL1401 3.0 - 5.5 400 128 Frame by Frame 8 • • - - TSL1402R 3.0 - 5.5 400 256 Frame by Frame 8 - - • - TSL1406R 3.0 - 5.5 400 768 Frame by Frame 8 - - - • TSL1410R 3.0 - 5.5 400 1280 Frame by Frame 8 - - - • TSL1412S 3.0 - 5.5 400 1536 Frame by Frame 8 - - - • TSL3301 3.0 - 5.5 300 102 Frame by Frame 10 - • - - V 8 Maximum Frequency DPI Package www.ams.com In everything we do we aim to make technology a more natural experience to the user – however challenging the application. For example: Automotive Sensors: ams’ intelligent battery management devices help to balance the power needs of vehicle systems so that the battery doesn’t break down on a cold night or the air-conditioning doesn’t stop working on a hot day. www.ams.com Medical Sensors & Sensor Interfaces: In medical imaging systems like computer tomography scanners, ams ASICs enable doctors to generate extremely high-resolution images of the human body with dramatically lower doses of x-ray radiation. 9 Lighting Management Camera Flash LED Drivers Part No. Topology DC-DC Freq. Performance LED Channels Safety Features Interfaces Package MHz ILed max VOut max Curr. Sinks Curr. Source Flash LEDs Indicator LED I2C Enable TimeOut TXMask (mm) AS3630 Supercap 4 8000mA 10V 1 High Side 2 1 • • • • WL-CSP-25 (2.5×2.5), pitch 0.5 AS3642 Inductive 4 500mA 5.5V 1 High Side 1 Flash LED • - • - WL-CSP6 (1.5×1.1), pitch 0.5 AS3643 Inductive 4 1300mA 5.5V 2 Low Side 1 Flash LED • - • • WL-CSP-13 (2.25×1.5), pitch 0.5 AS3644 Inductive 4 320mA 5.5V 1 High Side 1 Flash LED • - • - WL-CSP6 (1.5×1.1), pitch 0.5 AS3645A Inductive 2 800/500mA (2/1 LED) 10V 1 High Side 1 or 2 1 • • • • WL-CSP-12 (1.5×2), pitch 0.5 AS3647 Inductive 4 1600mA 5.5V 2 Low Side 1 Flash LED • - • • WL-CSP-13 (2.25×1.5), pitch 0.5 AS3648 Inductive 4 2000mA 5.5V 2 Low Side 1 or 2 Flash LED • - • • WL-CSP-13 (2.25×1.5), pitch 0.5 AS3649 Inductive 4 2500mA 5.5V 2 High Side 1 or 2 Flash LED • • • • WL-CSP16 (2.06×2.02), pitch 0.5 AS3685A Capacitive 1000mA 5.5V 1 Low Side 1 Flash LED - • • • WL-CSP-12 (1.5×2), pitch 0.5 DFN-10 (3×3) AS3685B Capacitive 1000mA 5.5V 1 Low Side 1 Flash LED - • • • DFN-10 (3×3) WL-CSP-12 (2×1.5) AS3685C Capacitive 1000mA 5.5V 1 Low Side 1 Flash LED • - • • WL-CSP-12 (1.5×2), pitch 0.5 NEW Camera Flash XENON Drivers Part No. 10 Topology Supply Voltage VOut max V Safety Features Package V (mm) • 2.5 and 4V charge, done, flash overtemperature, overcurrent WL-CSP-9 (1.5×1.5), pitch 0.5 included, trimmable 2.5V and 4V I2C, strobe, torch one time breakable fuse in supply path, system level ESD protection WL-CSP-16 (2.0×2.15), pitch 0.5 AS3635 Flyback 2.5 - 5.5 330 (in circuit trimmable) AS3636 Flyback 2.5 - 5.5 330 (in circuit trimmable) IGBT Driver IGBT Type Interface www.ams.com LED Driver ICs Part No. Description Outputs LED Current per Output # mA AS1100 8×8 Matrix LED driver 64 AS1101 80mA 2channel direct LED driver AS1102 Features Error Detection Read-back % V (mm) 5 Multiplexed - - 3 5.0 PDIP-24 / SOIC-24 2 80 Simple Drive - - 3 2.2 - 3.6 SC70-6 40mA 3channel direct LED driver 3 40 Simple Drive - - 3 2.2 - 3.6 SC70-6 AS1103 40mA 4channel direct LED driver 4 40 Simple Drive - - 3 2.2 - 3.6 SC70-6 AS1104 40mA 4channel direct LED driver 4 40 Simple Drive - - 3 2.2 - 3.6 MSOP-8 AS1105 4×8 Matrix LED driver 32 10 Multiplexed - - 3 5.0 SOIC-20 AS1106 8×8 Matrix LED driver 64 5 Multiplexed - - 3 2.7 - 5.5 PDIP-24 / SOIC-24 AS1107 8×8 Matrix LED driver with slew rate 64 5 Multiplexed - - 3 2.7 - 5.5 PDIP-24 / SOIC-24 AS1108 4×8 Matrix LED driver 32 10 Multiplexed - - 3 3.0 - 5.5 PDIP-20 / SOIC-20 AS1109 8channel 100mA direct LED driver 8 100 • • 2 3.0 - 5.5 SOIC150-16 / SSOP150-16 / TQFN-16 (4×4) AS1110 16channel 100mA direct LED driver 16 100 • • 3 3.0 - 5.5 SSOP-24 / TQFN-28 (5×5) AS1112 16ch 100mA PWM LED driver 16 100 • • 4.5 3.0 - 5.5 TQFN-32 (5×5) AS1113 16channel 50mA direct LED driver 16 50 • • 3 3.0 - 5.5 SSOP-24 / TQFN-28 (5×5) AS1115 64LED matrix driver with 16keys 64 5 multiplexed; I²C interface • • 3 2.7 - 5.5 QSOP-24 / TQFN-24 (4×4) AS1116 64LED matrix driver 64 5.5 multiplexed • • 3 2.7 - 5.5 QSOP-24 / TQFN-24 (4×4) 8-keys, multiplexed; I²C interface • • 3 2.7 - 5.5 TQFN-24 (4×4) AS1117 12-bit PWM, 6-bit DOT LED---LED Matching Supply Voltage Package 4LED matrix driver with 8keys 64 5 AS1118 64LED matrix driver 64 5.5 multiplexed, 1.8V, EN • • 3 2.7 - 5.5 TQFN-24 (4×4) AS1119 144LED full color crossplexing driver with CP 144 5.5 320mA charge pump; 6 Frames; cross-plexing • • 2 2.7 - 5.5 WL-CSP-36 (3×3) AS1121 16ch 40mA 30V PWM LED driver 16 40 12-bit PWM, 6-bit DOT, low EMI • • 1.5 3.1 - 3.6V Logic; 30V LED TQFN-32 (5×5) AS1122 12ch 40mA 30V PWM LED driver 12 40 12-bit PWM, 6-bit DOT, low EMI, slim interface • • 1.5 2.7 - 3.6 TQFN-24 (4×4) AS1123 16channel 50mA direct LED driver 16 40 low Vds • • 3 3~5.5V QSOP-24 TQFN-24 (4×4) AS1130 132LED full color crossplexing driver 132 2.5 8-bit PWM & analog current control, dynamic headroom control • • 2 2.7 - 5.5 WL-CSP-20 SSOP-28 AS3691 4×400mA Precision Current Source Driving RGB and White Color LEDs for General Lighting 4 400 Slew rate contr. - - 0.5 Main Supply QFN-24 ePTSSOP-24 www.ams.com 11 Lighting Management Lighting Management Units Part No. # of Current Sinks Max Current (mA) Max Vled Features HV LV CP DC-DC (V) AS3490 3 0 No 100 7.8 - - AS3492 5 0 No 100 7.8 - - AS3675 3 10 300 controller* controller* 1 AS3676 3 10 300 controller* controller* AS3677 3 3 50 AS3687XM 3 3 150 AS3688 2 7 AS3689 3 12 Flash LDOs (#) Auto ALS DLS RGB Pattern Dimming Audio-In LED Test Support max I (mA) • - WL-CSP-12 (1.7×1.4), pitch 0.5 • - - WL-CSP-12 • • • 300 WL-CSP-30 (3×2.5), pitch 0.5 • • • • 300 WL-CSP30 (3×2.5), pitch 0.5 • • - • - - WL-CSP-25 (2.3×2.3), pitch 0.4 - • • • • • 320 WL-CSP-20 (2×2.5), pitch 0.5 - - • • - • • 900 QFN-32 (5×5), pitch 0.5 - - • • - • • 150 WL-CSP-36 (3×3), pitch 0.5 • - - • (2×) - - - - - • • 1 • • • 1 • 2× controller* controller* - - 900 controller* controller* 2 400 controller* controller* 1 25 (mm) - - 50 Package Smart Notification Light Part No. User Memory Performance Performance Features Package # of Current Sinks Charge Pump kbit RGB Pattern Dimming Ext. PWM Ext. Trigger Audio-In LED Test (mm) AS3661 9 150mA 1.5 • log & lin - • - • WL-CSP25 (2.29×2.29), pitch 0.4 AS3665 9 150mA 1.5 • log & lin - • • • WL-CSP25 (2.61×2.67), pitch 0.5 AS3668 4 150mA - • log & lin • • • • WL-CSP12 (1.25×1.68), pitch 0.4 Lightning Sensor Franklin Lightning SensorTM 12 Part No. Description Features Supply (V) Current Consumption V (PD/Listening/Active) µA AS3935 Franklin Lightning Sensor™ IC Distance estimation up to 40 km in 14 steps, embeded Disturber rejection algorithm & auto antenna tuning 2.4 - 5.5 1 / 60 / 350 Interface Temp. Range °C (mm) SPI or I²C -40 to 85 MLPQ-16 Package www.ams.com NFC/HF RFID NFC/HF Booster Part No. Protocols Supported Frequency AS3922 ISO14443A/B 13.56 MHz Antenna Management Supply • 2.7 to 3.6 MHz Sensitivity Data Rate V 5mVpp Temp. Range kbps °C 106 -25 to 85 Package Die NFC/HF Interface and Sensor Tags Part No. Description Frequency Protocol Supply Voltage Temp. Range V °C MHz AS3953 NFC to SPI interface chip 13.56 SL13A RFID sensor tag and data logger IC 13.56 ISO14443A up to level 4 NFCIP-1 target RF field or at 106kbps NFC forum ext. 1.65 to 3.6 tag 4 type emolution ISO15693/NFC-V RF field or 1.2 to 3.3 Interface EEPROM Features Data Rate Package kbits (mm) -40 to 85 ISO14443A 4-wire SPI (slave) up to 5MHz 1 Wake-up interrupt, energy harvest 5mA up to 848 Die; MLPD-10; WL-CSP -40 to 110 SPI (slave), analog input 8 Energy harvest 5mA, temperature sensor up to 26.48 QFN-16 (5×5) or die NFC/HF RFID Reader ICs Frequency Antenna Management Closed Loop Modulation  Depth Adjustment Max. Output Power Data Rate Supply Voltage Temp. Range mW kbps V °C (mm) 2.4 - 3.6 -40 to 125 QFN-32 (5×5) 2.4 - 5.5 -40 to 125 QFN-32 (5×5) Part No. Protocols Supported AS3910 ISO14443 A/B, ISO-15693 (transparent mode), NFCIP-1 (106 kbps) 13.56 • - • 700 up to 848 AS3911 ISO14443 A/B (848kbps), ISO-15693, ISO18092 (NFC active) FeliCa, EMVCo 13.56 • Capacitive & Inductive • 1000 up to 6800 (VHBR) Wakeup MHz www.ams.com Package 13 Position Sensors 3D Absolute Position Sensor Part No. Description Resolution AS5410 14-bit Linear Absolute Position Sensor with Digital (Interface) and PWM Output 14 bit Interfaces Output Redundant SPI, PWM Digital (Interface) / PWM - Supply Voltage Temperature Range V °C 3.3 -40 to 105 Package AUT Qualified TSSOP-16 - EasyPoint™ Joystick Position Sensor Part No. Description Resolution AS5013 Two-Dimensional Magnetic Position Sensor with Digital Coordinates Output Overvoltage Redundant Protection Interfaces Output I²C Digital Coordinates (Interface) 8-bit (x and y) - Supply Voltage Temperature Range V °C 3.0 -20 to 80 - Package AUT Qualified QFN-16 - Linear Incremental Magnetic Position Sensors Resolution Min Pole Pair Length Part No. Description AS5304 160-step Linear Incremental Position Sensor with ABI output 160 step 4 AS5306 160-step Linear Incremental Position Sensor with ABI output 160 step 2.4 AS5311 12-bit Linear Incremental Position Sensor with Digital Interface and PWM output 12-bit AS5510 10-bit Linear Position Sensor with Digital Position (Interface) Output 10-bit NSE-5310 12-bit Linear Position Sensor with Digital Interface and PWM output 12-bit Interfaces AUT qualified -40 to 125 TSSOP-20 - -40 to 125 TSSOP-20 - Supply Voltage Temp. Range m/s V °C ABI 20 5.0 ABI 12 5.0 mm 14 Package Max Speed Output Remark for linear: use magnetic strip for off-axis: use ring magnet 2 2 SSI PWM I²C Digital position (Interface) output I²C PWM 0.65 0.65 3.3 or 5.0 -40 to 125 TSSOP-20 - 2.5 - 3.6 -30 to 85 WL-CSP - standard axial magnet 3.3 or 5.0 -40 to 125 TSSOP-20 - for linear: use magnetic strip for off-axis: use ring magnet www.ams.com Rotary Magnetic Position Sensors Part No. Description Resolution Interfaces AS5030 8-bit Rotary Position Sensor with Digital Angle(Interface) and PWM output 8-bit SSI AS5035 8-bit Rotary Position Sensor with ABI output 8-bit AS5040 10-bit Rotary Position Sensor with Digital Angle(Interface), ABI, UVW and PWM output AS5043 Output Max Speed Supply Overvoltage Redundant Voltage Protection rpm Temp. Range Package AUT qualified V °C - 5.0 -40 to 125 TSSOP-16 - - - 3.3 or 5.0 -40 to 125 SSOP-16 - 30000 - - 3.3 or 5.0 -40 to 125 SSOP-16 - 30000 - - 3.3 or 5.0 -40 to 125 SSOP-16 - Digital Angle (Interface) / PWM - - 3.3 or 5.0 -40 to 125 SSOP-16 - SSI Digital Angle (Interface) / ABI / PWM - - 3.3 or 5.0 -40 to 125 SSOP-16 - 14-bit SPI Digital Angle (Interface) / PWM - - 3.3 or 5.0 -40 to 150 TSSOP-14 - 14-bit Rotary Position Sensor with Digital Angle(Interface) and PWM output 14-bit I²C Digital Angle (Interface) / PWM - - 3.3 or 5.0 -40 to 125 TSSOP-14 - AS5050 10-bit Rotary Position Sensor with Digital Angle(Interface) output 10-bit SPI Digital Angle (Interface) - - 3.3 -40 to 85 QFN-16 - AS5055 12-bit Rotary Position Sensor with Digital Angle(Interface) output 12-bit SPI Digital Angle (Interface) - - 3.3 -40 to 85 QFN-16 - AS5115 Rotary Position Sensor with Sin/ Cos signal Output - SSI sin/cos - - 5.0 -40 to 150 SSOP-16 • AS5130 8-bit Rotary Position Sensor with Digital Angle(Interface) and PWM output 8-bit SSI Digital Angle (Interface) / PWM 30000 - - 5.0 -40 to 125 SSOP-16 • AS5132 8.5-bit Rotary Position Sensor with Digital Angle(Interface), ABI, UVW (up to 6 Pole pairs) and PWM output 8.5-bit SSI Digital Angle (Interface) / ABI / UVW (up to 6 Pole Pairs) / PWM 72900 - - 5.0 -40 to 150 SSOP-20 • AS5134 8.5-bit Rotary Position Sensor with Digital Angle (Interface), ABI, UVW and PWM Output 8.5-bit SSI Digital Angle (Interface) / ABI / UVW (up to 6 Pole Pairs) / PWM 82000 - - 5.0 -40 to 140 SSOP-20 • AS5140H 10-bit Rotary Position Sensor with Digital Angle (Interface) Output, ABI and PWM Output 10-bit SSI Digital Angle (Interface) / ABI / PWM 10000 - - 3.3 or 5.0 -40 to 150 SSOP-16 • AS5145A 12-bit Rotary Position Sensor with Digital Angle (Interface), PWM and ABI Output 12-bit SSI Digital Angle (Interface) / ABI / PWM - - 3.3 or 5.0 -40 to 150 SSOP-16 • AS5145B 12-bit Rotary Position Sensor with Digital Angle (Interface), PWM and ABI Output 12-bit SSI Digital Angle (Interface) / ABI / PWM - - 3.3 or 5.0 -40 to 150 SSOP-16 • AS5145H 12-bit Rotary Position Sensor with Digital (Angle) Interface and PWM Output 12-bit SSI Digital Angle (Interface) / PWM - - 3.3 or 5.0 -40 to 150 SSOP-16 • Digital Angle (Interface) / PWM 30000 - - ABI 30000 10-bit SSI Digital Angle (Interface) / ABI / UVW / PWM 10-bit Rotary Position Sensor with Digital Angle(Interface) and Linear analog output 10-bit SSI Digital Angle (Interface) / Linear analog AS5045 12-bit Rotary Position Sensor with Digital Angle(Interface) and PWM output 12-bit SSI AS5045B 12-bit Rotary Position Sensor with Digital Angle(Interface) and PWM and ABI Output 12-bit AS5048A 14-bit Rotary Position Sensor with Digital Angle(Interface) and PWM output AS5048B www.ams.com - 15 Position Sensors Rotary Magnetic Position Sensors Resolution Interfaces Max Speed Output Supply Overvoltage Redundant Voltage Protection Part No. Description AS5161 12-bit Rotary Position Sensor with PWM Output and Overvoltage Protection 12-bit PWM • AS5162 12-bit Rotary Position Sensor with Linear Analog Output and Overvoltage Protection 12-bit Linear analog AS5163 12-bit Rotary Position Sensor with Lienar Analog or PWM Output and Overvoltage Protection 12 bit AS5215 Redundant Rotary Position Sensor with Sin/Cos Output - AS5245 Redundant 12-bit Rotary Position Sensor with Digital Angle (Interface) and ABI Output 12-bit AS5261 Redundant 12-bit Rotary Position Sensor with PWM Output and Overvoltage Protection AS5262 AS5263 rpm Temp. Range Package AUT qualified V °C - 5.0 -40 to 150 SOIC-8 • • - 5.0 -40 to 150 SOIC-8 • Linear analog / PWM • - 5.0 -40 to 150 TSSOP-14 • SSI sin/cos - - 5.0 -40 to 150 MLF-32 • SSI Digital Angle (Interface) / ABI / PWM - • 3.3 or 5.0 -40 to 150 QFN-32 • 12-bit PWM • • 5.0 -40 to 150 MLF-16 • Redundant 12-bit Rotary Position Sensor with Linear Analog Output and Overvoltage Protection 12-bit Linear analog • • 5.0 -40 to 150 MLF-16 • Redundant 12-bit Rotary Position Sensor with Linear Analog or PWM Output and Overvoltage Protection 12-bit Linear analog / PWM • • 5.0 -40 to 150 MLF-32 • SQUIGGLE® Motor Drivers Part No. NSD-1202 Description 2 Phase Ultrasonic Piezo Motor Driver IC, Output for Two SQUIGGLE® motors Ultrasonic Piezo Motor Driver IC, Output for NSD-2101 one SQL-RV Series Reduced Voltage SQUIGGLE® RV 16 Input Control I²C I²C Input Voltage Output Voltage VDC V 2.8 - 5.5 2.8 - 5.5 24 - 40 2.3 - 5.5 Current Output Frequency Output Efficiency Features Package 65% @ 2.8V Voltage control over 2.8 to 5.5VDC, step-up converter to high-voltage, programmable voltage 24 to 40V, pulse width duty cycle control for slower speed control, 4 independently addressable output drivers with defined rise/fall time, I²C interface, on-chip registers store driver instructions, powerdown mode for minimal power consumption in stand-by QFN-16 (4×4) - Control of 2.3 to 5.5 VDC input voltage allowing pulse width duty cycle control of one SQL-RV-1.8 SQUIGGLE® motor. I²C interface provides controls for two independently addressable full bridge output drivers with defined rise/fall time, on-chip WL-CSP-16 (1.8×1.8), QFN-16 (4×4) (mm) 25mA DC max 1600mA DC max 140 to 180kHz typical, min 80kHz 50 to 200 kHz www.ams.com The most natural sensors are the human senses. These are our inspiration. Our products should strive to be as refined, efficient and natural as they are. For example: Ambient Light Sensors: Automatically adjusting the display brightness on screens depending on the ambient light, ams sensors reduce the strain on our eyes and give us a more natural user-experience while reducing energy consumption. www.ams.com MEMS microphones in mobile devices like smartphones rely on ams sensor interface solutions to make it sound like the people talking are standing right next to each other. 17 Power Management Battery Chargers Part No. Description Chemistry # of Cells Charger Current AS3610 USB Compliant Step Down Charger for Li-Ion Portable Devices Li-Ion 1 AS3611 USB Compliant Step Down Charger for Li-Ion Portable Devices Li-Ion 1 Power Path Management USB OTG/ Host boost NTC FC k µA (mm) • 22 - • 10/100 • MLPD-14 (3×3) • 22 - • 10/100 • MLPD-14 (3×3) Switchmode OVP 1.25 1.25 A V Package Battery Stack Monitors/Balancers Part No. NEW Cell Monitoring/Balancing ICs Typical Standby Quiescent Current Balancing Current Temperature Range μA mA °C Number of Cells per IC Cell Voltage Range Package V (mm) AS8506 Cell Monitoring & Balancing IC 17 typically 100 -40 to 85 3-7 1.8 - 4.5 MLF-40 (6×6) AS8506C Cell Monitoring & Balancing IC (non-AUT version) 17 typically 100 -40 to 85 3-7 1.8 - 4.5 MLF-40 (6×6) Comparators Part No. Inputs Output Type # 18 Internal Hysteresis Supply Current Supply Voltage mV µA V Package AS1970 1 Push/Pull 3 10 2.5 - 5.5 SOT23-5 AS1971 1 Open-Drain 3 10 2.5 - 5.5 SOT23-5 AS1972 2 Push/Pull 3 17 2.5 - 5.5 MSOP-8 AS1973 2 Open-Drain 3 17 2.5 - 5.5 MSOP-8 AS1974 4 Push/Pull 3 34 2.5 - 5.5 TSSOP-14 AS1975 4 Open-Drain 3 34 2.5 - 5.5 TSSOP-14 AS1976 1 Push/Pull 3 0.2 1.8 - 5.5 SOT23-5 AS1977 1 Open-Drain 3 0.2 1.8 - 5.5 SOT23-5 www.ams.com DC-DC Buck-Boost Converters Part No. Input Voltage Output Voltage Output Current* AS1331 V V 1.8 - 5.5 2.5 - 3.3 AS1337 0.65 - 4.5 2.5 - 5.0 Efficiency Iq mA % µA 300 90 200 97 Enable/ Reset/ SHDN POK Architecture fmax 22 Hysteretic, Sync 6 V • Find more technical information on our foundry support server at http://asic.ams.com In case of any questions please contact foundry@ams.com www.ams.com 31 Notes 32 www.ams.com ams Headquarters Tobelbader Strasse 30 8141 Unterpremstaetten, Austria Phone: +43 3136 500-0 Email: info@ams.com Web: www.ams.com United Kingdom Stockport so China Hong Kong so Shenzhen so Shanghai so Switzerland Rapperswil so/dc Korea Seoul so Germany Munich so dc = design center tc = test center so = sales office Japan Tokyo so Sweden Sollentuna so Finland Helsinki so USA Cupertino, CA so Austin, TX dc Plano, TX so, dc Raleigh, NC so India Hyderabad dc Spain Valencia dc France Vincennes so Italy Pavia dc Corsico so Pisa dc Singapore so Taiwan Taipei so Philippines Calamba tc Get free samples and buy our products online at: www.ams.com/ICdirect Europe (Headquarters) ams Tobelbader Strasse 30 8141 Unterpremstaetten, Austria Phone: +43 3136 500-0 Email: sales-europe@ams.com Asia/Pacific ams Tomson Commercial Building, Suite 1006 No 710 Dongfang Rd Pudong, Shanghai, China, 200122 Phone: +86 21 6162 7488 Email: sales-asia@ams.com Americas AMS-TAOS USA Inc. 1001 Klein Road, Suite 300 Plano, TX 75074, USA Phone: +1 972 673 0759 Email: sales-americas@ams.com www.ams.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: ams: TSL25721FN AS3900-BQFP AS3560-BWLT-500 AS3695A-ZQFT AS3910-BQFT-100 AS3502 EB AS3502-EQFP AS1374-BWLT1833 AS3608A-BQFP-00 AS3696-ZQFT AS3501 EB AS1374-BWLT1818 AS3910-BQFT-5k AS3400-EQFP AS3420 EK-ST AS3940-BQFT-5k AS3695C-ZLQT AS3420-EQFP AS3695C-ZMFT AS3420-EQFP500 AS3410 EK-ST AS3711-BQFP AS3410-EQFP-500 AS3410-EQFP AS3696-ZTQW AS3430-EQFP-500 AS8223-ASSP-500 AS3400-EB AS1374-BWLT1214 AS3430 EK-ST AS3400-EQFP-500 AS1374BWLT18285
AS3695C-ZMFT 价格&库存
很抱歉,暂时无法提供与“AS3695C-ZMFT”相匹配的价格&库存,您可以联系我们找货
