austriamicrosystems AG
is now
ams AG
The technical content of this austriamicrosystems datasheet is still valid.
Contact information:
Headquarters:
ams AG
Tobelbaderstrasse 30
8141 Unterpremstaetten, Austria
Tel: +43 (0) 3136 500 0
e-Mail: ams_sales@ams.com
Please visit our website at www.ams.com
AS3691
Datasheet
Datasheet
AS3691
4 Precision 400mA Current Sources for RGB and Single Color Leds
1 General Description
2)
15V is sufficient for most applications as the
AS3691 dose not switch off the LED current
completely
am
lc s
on A
te G
nt
st
il
Patent Pending
lv
4 x up to 0.4A constant current outputs
Programmable with external resistors
4 independent PWM inputs
Absolute current accuracy +/-0.5%
Automatic Supply Regulation’ to reduce power
dissipation1)
1)
al
id
2 Key Features
Very wide output voltage current source
voltage compliance
− Down to 0.41V
2)
− Up to 15V
Integrated overtemperature protection
Separate sense pads (Rfb1-Rfb4) for easy and
precise PCB Layout
Package
− DIE
− QFN24 4x4mm
− eP-TSSOP
The AS3691 (AS3691A and AS3691B) features four
high precision current sources for lighting of up to
four LED strings (RGB or single color leds). Each
of the four currents sources can be controlled
independently by PWM inputs. The full scale
current value is set by external resistors.
3 Applications
General Lighting
Backlighting
RGB Backlighting for LCD TV/Monitors with
White Color Balancing
4 Application Diagrams
Figure 1 – Application Diagram of AS3691 for Single Color Lighting
VDD
Csup
100nF
VDD
Rvdd
Cvdd
100nF
ca
UV
VREG
CURR1
ni
UV1
AS3691
UV2
CURR2
Vc
UV3
CURR3
Vc
UV4
UV
CURR4
Vc
Vc
ch
D1
Ref
T1
I1
Te
Overtemp
Pad VSS
T2
I2
R1
ON1
RFB1
T3
R2
RES1 ON2
RFB2
T4
I3
R3
RES2 ON3
Ri1
Ri2
RFB3
I4
R4
RES3 ON4
Ri3
RFB4
RES4
Ri4
VSS
VSS
PWM
PWM
www.austriamicrosystems.com (ptr)
Revision 2.3
1 - 22
AS3691
Datasheet
Figure 2 – Application Diagram of AS3691 for RGB Lighting
VDDG
VDDG
VDDB
VDDB
VDDR
VDDR
Rvdd
al
id
Cvdd
100nF
UVG
UVG
UVB
UVB
UVR
UVR
CURR1
AS3691
UV3
CURR2
Vc
Ref
Vc
T1
Pad
T2
PWMB
Vc
VSS
ON1
RFB1
R2
RES1 ON2
RFB2
T4
I3
R3
RES2 ON3
Ri2
RFB3
I4
R4
RES3 ON4
Ri3
RFB4
RES4
Ri4
VSS
PWMG
PWMB
PWMR
Te
ch
ni
ca
PWMR
CURR4
T3
I2
R1
Ri1
PWMG
UV4
Vc
I1
Overtemp
VSS
CURR3
am
lc s
on A
te G
nt
st
il
D1
UV2
lv
UV1
VREG
Revision 2.3
2 - 22
AS3691
Datasheet
Table of Contents
1
General Description ......................................................................................................................................... 1
2
Key Features.................................................................................................................................................... 1
3
Applications...................................................................................................................................................... 1
4
Application Diagrams ....................................................................................................................................... 1
5
Pinout............................................................................................................................................................... 4
Pin Assignments ....................................................................................................................................... 4
5.2
Pin Descriptions........................................................................................................................................ 4
6
al
id
5.1
Characteristics ................................................................................................................................................. 6
Absolute Maximum Ratings ...................................................................................................................... 6
6.2
Operating Conditions ................................................................................................................................ 6
6.3
Electrical Characteristics........................................................................................................................... 7
7
lv
6.1
Typical Operation Characteristics .................................................................................................................... 8
8
Detailed Functional Description ..................................................................................................................... 12
Shunt Regulator...................................................................................................................................... 12
8.2
Overtemperature Protection.................................................................................................................... 12
8.3
Automatic Supply Regulation.................................................................................................................. 13
9
am
lc s
on A
te G
nt
st
il
8.1
Application Information .................................................................................................................................. 14
9.1
Design Example...................................................................................................................................... 15
9.1.1
Using Automatic Supply Regulation................................................................................................. 16
9.2
Layout Recommendations ...................................................................................................................... 16
10
Package Drawings and Markings ............................................................................................................... 17
10.1
QFN 4x4 Package Drawings and Marking .............................................................................................. 17
10.2
ePTSSOP Package Drawings and Marking............................................................................................ 19
10.3
DIE Delivery............................................................................................................................................ 20
11
Ordering Information .................................................................................................................................. 21
ca
Revision History
Revision
Owner
Description
30.10.2007
ptr
- Added Trays as delivery option (order code AS3691AZQFT)
Te
ch
ni
2.3
Date
Revision 2.3
3 - 22
AS3691
Datasheet
5 Pinout
5.1 Pin Assignments
Figure 3 – Pin Usage
UV1
CURR1
AS3691
UV2
CURR2
Vc
UV3
CURR3
Vc
UV4
CURR4
al
id
VREG
Vc
Vc
D1
T1
I1
Overtemp
R1
T3
I2
R2
T4
I3
R3
I4
R4
am
lc s
on A
te G
nt
st
il
Pad
T2
lv
Ref
VSS
ON1
RES1 ON2
RFB1
RES2 ON3
RFB2
RFB3
RES3 ON4
RFB4
RES4
5.2 Pin Descriptions
Table 1 – Pin Type Descriptions
Pin Type
AI/O
Description
Analog Pin
Analog Input Pin
AO
Analog Output Pin
DI
Digital Input
S
Supply Pin
ca
AI
Table 2 – Pin Descriptions
Pin Number
QFN
Package
Pin Number
ePTSSOP
Package
Pin Name
1
10
Description
CURR1
AI/O
Current Source 1 Output
11
RFB1
AI
Connect to current set resistor R1 directly at
resistor itself
3
12
nc
nc
Leave open
4
13
RFB4
AI
Connect to current set resistor R4 directly at
resistor itself
5
14
CURR4
AI/O
Current Source 4 Output
6
15
RES4
AI/O
Te
ch
2
ni
Type
Revision 2.3
4 - 22
AS3691
Datasheet
Pin Number
QFN
Package
Pin Number
ePTSSOP
Package
Pin Name
Type
Description
16
ON4
DI
8
17
UV4
AO
Automatic supply regulation for CURR4; if not
used, leave open
9
18
TEST
AI
Digital Test input; Leave open or connect to
VSS; internal pulldown to VSS
10
19
UV3
AO
Automatic supply regulation for CURR3; if not
used, leave open
Current source CURR3 control; internal pullup
resistor to VREG (can be left open, if CURR3 is
always switched on)
High … 100% Current
Low … 5% Current
lv
al
id
7
Current source CURR4 control; internal pullup
resistor to VREG (can be left open, if CURR4 is
always switched on)
High … 100% Current
Low … 5% Current
ON3
DI
12
21
RES3
AI/O
Connect to current set resistor R3
13
22
CURR3
AI/O
Current Source 3 Output
14
23
RFB3
AI
Connect to current set resistor R3 directly at
resistor itself
15
24
VREG
S
Shunt regulator supply; connect to Rvdd and
Cvdd
16
1
RFB2
AI
Connect to current set resistor R2 directly at
resistor itself
2
CURR2
AI/O
Current Source 2 Output
3
RES2
AI/O
am
lc s
on A
te G
nt
st
il
11
17
18
19
DI
5
UV2
AO
Automatic supply regulation for CURR2; if not
used, leave open
6
VSS
S
7
ch
8
VSS Supply connection
AO
Automatic supply regulation for CURR1; if not
used, leave open
ON1
DI
Current source CURR1 control; internal pullup
resistor to VREG (can be left open, if CURR1 is
always switched on)
High … 100% Current
Low … 5% Current
UV1
ni
22
23
ON2
ca
21
4
Current source CURR2 control; internal pullup
resistor to VREG (can be left open, if CURR2 is
always switched on)
High … 100% Current
Low … 5% Current
9
RES1
AI/O
Pad
Pad
VSS
S
VSS Supply connection; add as many vias to
ground plane as possible
Te
24
Revision 2.3
5 - 22
AS3691
Datasheet
6 Characteristics
6.1 Absolute Maximum Ratings
Stresses beyond those listed in Table 1 may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated in Section 5
Electrical Characteristics is not implied.
Table 3 – Absolute Maximum Ratings
Note
al
id
Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Symbol
Parameter
Min
Max
Unit
VDDMAX
Supply for LEDs
-0.3
>17
V
See notes1
VINVREG
VREG Supply voltage
-0.3
7.0
V
Applicable for pin VREG
V
Applicable for 5V pins2
V
Applicable for CURR1, CURR2,
CURR3 and CURR4
5V Pins
-0.3
VIN15V
15V Pins
-0.3
17
IIN
Input Pin Current
-25
+25
mA At 25ºC, Norm: Jedec 17
TSTRG
Storage Temperature Range
-55
125
°C
Humidity
5
85
Non condensing
VESD
Electrostatic Discharge
-2000
2000
V
Norm: MIL 883 E Method 3015
PT
Total Power Dissipation
2.0
W
At 50ºC, no airflow for QFN24 on
3
two layer FR4-Cu PCB
PDERATE
PT Derating Factor
23
TBODY
Body Temperature during
Soldering
260
am
lc s
on A
te G
nt
st
il
Notes:
1.
2.
3.
lv
VIN5V
VREG+
0.3V
mW/
See notes3
°C
°C
according to IPC/JEDEC J-STD020C
As the AS3691 is not directly connected to this supply. Only the parameters VINVREG, VIN5V and
VIN15V have to be guaranteed by the application
All pins except CURR1, CURR2, CURR3 and CURR4
Depending on actual PCB layout and especially number of vias below the exposed pad – see layout
recommendations; can be improved e.g. with Al-PCB or airflow
ca
6.2 Operating Conditions
Symbol
Parameter
Te
VDDTOL Main Supply Voltage Tolerance
VREGINT
Min
Typ
Main Supply
ch
VDD
ni
Table 4 – Operating Conditions
Supply (shunt regulated by
AS3691)
VREGEXT
IVREG
Supply Current
TAMB
Ambient Temperature
-20
Max
Unit
Note
Not
Limited
V
Supply is not directly connected to
the AS3691 – see section ‘Shunt
Regulator’
+20
Applies only for supply VREG is
connected via Rvdd
5.0
5.2
5.4
V
If internally (shunt-)regulated by
D1
4.5
4.75
5.0
V
If externally supplied
-20
25
Revision 2.3
2.5
Excluding current through shunt
mA regulator (D1) – see section
‘Shunt Regulator’
85
°C
6 - 22
AS3691
Datasheet
6.3 Electrical Characteristics
Table 5 – Analog Electrical Characteristics
Current Source CURR1 to
CURR4 Voltage Compliance
VCURR
ICURR
Current Source Range
ICURR,
Min
Typ
Max
Unit
0.9
15.0
V
0.41
15.0
V
at 100mA
10
400(1)
mA
-0.5
+0.5
@25C TJUNCTION, excluding
variation of external resistors;
V(CURRx)
很抱歉,暂时无法提供与“AS3691A-ZQFP”相匹配的价格&库存,您可以联系我们找货
