AS1100WE-T
AS1100WE-T
    AMSOSRAM(艾迈斯半导体)
    SOIC24_300MIL
    IC DRIVER LED 8-DIGIT 24-SOIC
AS1100WE-T 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com D ata she et A S11 00 S e r ia ll y In t er f a c ed , 8 -D ig i t L E D D r iv e r 2 Key Features The device includes a BCD code-B decoder, a multiplex scan circuitry, segment and display drivers, and a 64 Bit memory. The memory is used to store the LED settings, so that continuous reprogramming is not necessary. 10MHz Serial Interface  Individual LED Segment Control  Decode/No-Decode Digit Selection  20µA Low-Power Shutdown (Data Retained)  Extremely low Operating Current 0.5mA in open loop  Digital and Analog Brightness Control  Display Blanked on Power-Up  Drive Common-Cathode LED Display  Software Reset  Optional External clock  24-pin SOIC Package am lc s on A te G nt st il Every individual segment can be addressed and updated separately. Only one external resistor is required to set the current through the LED display. Brightness can be controlled either in an analog or digital way. The user can choose the internal code-B decoder to display numeric digits or to address each segment directly.  al id The AS1100 is an LED driver for 7 segment numeric displays of up to 8 digits. The AS1100 can be programmed via a conventional 4 wire serial interface. lv 1 General Description The AS1100 features an extremely low shutdown current of only 20µA and an operational current of less than 500µA. The number of visible digits can be programmed as well. The AS1100 can be reset by software and an external clock can be used. Several test modes support easy debugging. 3 Applications The AS1100 is an ideal solution for Bar-Graph Displays, Industrial Controllers, Panel Meters, LED Matrix Displays and White Goods such as washing machines and dishwasher. The AS1100 is offered in a 24-pin SOIC package. ca Figure 1. AS1100 - Typical Application Diagram +5V 19 VDD 18 ISET 1 DIN µP I/O 12 LOAD SCK 1 CLK 9 GND www.austriamicrosystems.com/LED-Driver-ICs/AS1100 DIFG0-DIG3 8 Digits AS1100 MOSI Te ch ni 9.53k SEG A-G SEP DP 8 Segments GND 4 8-Digit µP Display Revision 1.37 1 - 16 AS1100 Datasheet - P i n A s s i g n m e n t s 4 Pin Assignments 24 DOUT DIG0 2 23 SEG D DIG4 3 22 SEG DP GND 4 DIG6 5 DIG2 21 SEG E AS1100 20 SEG C DIG3 7 19 VDD 18 ISET DIG7 8 17 SEG G 9 16 SEG B DIG5 10 15 SEG F 14 SEG A 13 CLK GND 6 am lc s on A te G nt st il DIG1 11 lv 1 DIN al id Figure 2. Pin Assignments (Top View) LOAD 12 4.1 Pin Descriptions Table 1. Pin Descriptions Pin Number 1 Pin Name DIN 2, 3, 5:8, 10, 11 DIG 0 : DIG 7 4, 9 GND 12 LOAD/CS 13 CLK 19 VDD DOUT Te ch 24 ISET ni 18 SEGA:G, DP ca 14:17, 20:23 Description Data input. Data is programmed into the 16Bit shift register on the rising CLK edge 8 digit driver lines that sink the current from the common cathode of the display. In shutdown mode the AS1100 switches the outputs to VDD. Both GND pins must be connected. Strobe input. With the rising edge of the LOAD signal the 16 bit of serial data is latched into the register. Clock input. The interface is capable to support clock frequencies up to 10MHz. The serial data is clocked into the internal shift register with the rising edge of the CLK signal. On the DOUT pin the data is applied with the falling edge of CLK. Seven segment driver lines including the decimal point. When a segment is turned off the output is connected to GND. The current into ISET determines the peak current through the segments and therefore the brightness. Positive Supply Voltage (+5V) Serial data output for cascading drivers. The output is valid after 16.5 clock cycles. The output is never set to high impedance. www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 2 - 16 AS1100 Datasheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics on page 4 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 2. Absolute Maximum Ratings Max Units -0.3 7 V -0.3 VDD + 0.3 (max 7V) V DIG 0:DIG 7 Sink Current 500 mA SEG A : SEG G, SEG DP 100 mA Latch-Up Immunity ±200 mA Electrical Parameters VDD to GND All other pins to GND Electrostatic Discharge Norm: JEDEC 78 am lc s on A te G nt st il Current Notes al id Min lv Parameter Digital outputs 500 V All other pins 1000 V 941 mW +150 ºC Norm: MIL 883 E method 3015 Continuous Power Dissipation (TA = +85°C) Wide SOIC Derate 11.8mW/ºC above +70ºC Temperature Ranges and Storage Conditions Storage Temperature Range -55 Package Body Temperature (Wide SOIC) Humidity ºC 85 % Non-condensing 3 Represents a max. floor life time of 168h Te ch ni ca Moisture Sensitive Level 5 +260 The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/ JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 3 - 16 AS1100 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics VDD = 5V, RSET = 9.53kΩ±1%, TA = TMIN to TMAX (unless otherwise specified). All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Table 3. Electrical Characteristics Parameter Conditions Min TAMB Operating Temperature Range -40 VDD Operating Supply Voltage 4.0 IDDSD Shutdown Supply Current All digital inputs at VDD or GND, TA = +25ºC Typ 5.0 20 Operating Supply Current All segments and decimal point on, ISEG = -40mA fOSC Display Scan Rate 8 digits scanned Digit Drive Sink Current IDIGIT +85 ºC 5.5 V 50 µA 500 µA 330 500 800 mA 1300 am lc s on A te G nt st il IDD Units lv RSET = open circuit Max al id Symbol VOUT = 0.65V 320 TA = +25ºC, VOUT = (VDD -1V) -30 Hz mA ISEG Segment Drive Source Current ∆ISEG Segment Drive Current Matching IDIGIT Digit Drive Source Current Digit off, VDIGIT = (VDD -0.3V) -2 mA ISEG Segment Drive Sink Current Segment off, VSEG = 0.3V 5 mA IIH, IIL Input Current DIN, CLK, LOAD VIN = 0V or VDD -1 VIH Logic High Input Voltage VIL Logic Low Input Voltage VOH Output High Voltage DOUT, ISOURCE = -1mA VOL Output Low Voltage DOUT, ISINK = 1.6mA Hysteresis Voltage DIN, CLK, LOAD Logic Inputs Timing Characteristics -40 -45 3.0 1 3.5 0.8 VDD - 1 0.4 1 mA % µA V V V V V CLK Clock Period 100 ns tCH CLK Pulse Width High 50 ns tCL CLK Pulse Width Low 50 ns CLK Rise to LOAD Rise Hold Time 0 ns DIN Setup Time 25 ns 0 ns ch tDS ni tCSH ca tCP DIN Hold Time tDO Output Data Propagation Delay tLDCK LOAD Rising Edge to Next Clock Rising Edge 50 ns tCSW Minimum LOAD Pulse High 50 ns tDSPD Data-to-Segment Delay Te tDH www.austriamicrosystems.com/LED-Driver-ICs/AS1100 CLOAD = 50pF 25 2.25 Revision 1.37 ns ms 4 - 16 AS1100 Datasheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7 Typical Operating Characteristics 50 50 45 45 40 40 30 25 20 15 10 35 30 25 20 15 lv 35 al id Figure 4. Segment Current vs. RSET ISEGMENT (mA). Segment Current (mA). Figure 3. Segment Driver Capability, VDD = 5V, Logic Level = High 10 5 5 0 0.5 1 am lc s on A te G nt st il 0 0 1.5 2 2.5 3 3.5 4 4.5 10 Voltage below VDD at output (V) 100 Te ch ni ca RSET (kOhm) www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 5 - 16 AS1100 Datasheet - D e t a i l e d D e s c r i p t i o n 8 Detailed Description 8.1 Serial-Addressing Modes al id Programming of the AS1100 is done via 4 wire serial interface. A programming sequence consists of 16-bit packages. The data is shifted into the internal 16 Bit register with the rising edge of the CLK signal. With the rising edge of the LOAD signal the data is latched into a digital or control register depending on the address. The LOAD signal must go to high after the 16th rising clock edge. The LOAD signal can also come later but just before the next rising edge of CLK, otherwise data would be lost. The content of the internal shift register is applied 16.5 clock cycles later to the DOUT pin. The data is clocked out at the falling edge of CLK. The Bits of the 16Bit-programming package are described in Table 5. The first 4 Bits D15-D12 are don’t care, D11-D8 contain the address and D7-D0 contain the data. The first bit is D15, the most significant bit (MSB). The exact timing is given in Figure 5. lv Figure 5. Timing Diagram tCSW LOAD tCS tCH tCL am lc s on A te G nt st il tCP CLK tLDCK tDH tDS DIN D14 D15 D1 D0 tDO DOUT Table 4. Serial Data Format (16bits) D14 D13 X X X D12 D11 X D10 D9 Address ca D15 D8 D7 MSB D6 D5 D4 Data D3 D2 D1 D0 LSB 8.2 Digit and Control Registers ni The AS1100 incorporates 15 registers, which are listed in Table 5. The digit and control registers are selected via the 4Bit address word. The 8 digit registers are realized with a 64bit memory. Each digit can be controlled directly without rewriting the whole contents. The control registers consist of decode mode, display intensity, number of scanned digits, shutdown, display test, and reset/external clock register. ch 8.3 Shutdown Mode Te The AS1100 features a shutdown mode, where it consumes only 20µA current. The shutdown mode is entered via a write to register 0Ch. Then all segment current sources are pulled to ground and all digit drivers are connected to VDD, so that nothing is displayed. All internal digit registers keep the programmed values. The shutdown mode can either be used for power saving or for generating a flashing display by repeatedly entering and leaving the shutdown mode. The AS1100 needs typically 250µs to exit the shutdown mode. During shutdown the AS1100 is fully programmable. Only the display test function overrides the shutdown mode. 8.4 Initial Power-Up After powering up the system all register are reset, so that the display is blank. The AS1100 starts the shutdown mode. All registers should be programmed for normal operation. The default settings enable only scan of one digit, the internal decoder is disabled, data register and intensity register are set to the minimum value. www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 6 - 16 AS1100 Datasheet - D e t a i l e d D e s c r i p t i o n 8.5 Decode-Mode Register al id In the AS1100 a BCD decoder is included. Every digit can be selected via register 09h to be decoded. The BCD code consists of the numbers 09, E,H, L,P and -. In register 09h a logic high enables the decoder for the appropriate digit. In case that the decoder is bypassed (logic low) the data Bits D7-D0 correspond to the segment lines of the AS1100. In Table 7 some possible settings for register 09h are shown. Bit D7, which corresponds to the decimal point, is not affected by the settings of the decoder. Logic high means that the decimal point is displayed. In Table 8 the font of the Code B decoder is shown. In Table 9 the correspondence of the register to the appropriate segments of a 7 segment display is shown (see Figure 6). 8.6 Intensity Control and Interdigit Blanking lv Brightness of the display can be controlled in an analog way by changing the external resistor (RSET). The current, which flows between VDD and ISET, defines the current that flows through the LEDs. The LED current is 100 times the ISET current. The minimum value of RSET should be 9.53kΩ, which corresponds to 40mA segment current. The brightness of the display can also be controlled digitally via register 0Ah. The brightness can be programmed in 16 steps and is shown in Table 10. An internal pulse width modulator controls the intensity of the display. 8.7 Scan-Limit Register am lc s on A te G nt st il The scan limit register 0Bh selects the number of digits displayed. When all 8 digits are displayed the update frequency is typically 800Hz. If the number of digits displayed is reduced, the update frequency is reduced as well. The frequency can be calculated using 8fOSC/N, where N is the number of digits. Since the number of displayed digits influences the brightness, the resistor RSET should be adjusted accordingly. The Table 12 shows the maximum allowed current, when fewer than 4 digits are used. To avoid differences in brightness the scan limit register should not be used to blank portions of the display (leading zeros). Table 5. Register Address Map No-Op Digit 0 Digit 1 Digit 2 Digit 3 Digit 4 Digit 5 Digit 6 Digit 7 Decode Mode Intensity D15-D12 D11 D10 D9 D8 Hex Code X 0 0 0 0 0xX0 X 0 0 0 1 0xX1 X 0 0 1 0 0xX2 X 0 0 1 1 0xX3 X 0 1 0 0 0xX4 X 0 1 0 1 0xX5 X 0 1 1 0 0xX6 X 0 1 1 1 0xX7 0 0 0 0xX8 X X 1 0 0 1 0xX9 X 1 0 1 0 0xXA 1 X 1 0 1 1 0xXB Shutdown X 1 1 0 0 0xXC Not used X 1 1 0 1 0xXD Reset and ext. Clock X 1 1 1 0 0xXE Display Test X 1 1 1 1 0xXF Te ch ni Scan Limit Address ca Register Table 6. Shutdown Register Format (address (hex) = 0xXC Register Data Mode Address Code (Hex) D7 D6 D5 D4 D3 D2 D1 D0 Shutdown Mode 0xXC X X X X X X X 0 Normal Operation 0xXC X X X X X X X 1 www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 7 - 16 AS1100 Datasheet - D e t a i l e d D e s c r i p t i o n Table 7. Decode-mode Register Examples (address (hex) = 0xX9 Register Data Decode Mode Hex Code D6 D5 D4 D3 D2 D1 D0 No decode for digits 7–0 0 0 0 0 0 0 0 0 0x00 Code B decode for digit 0 No decode for digits 7–1 0 0 0 0 0 0 0 1 0x01 Code B decode for digits 3–0 No decode for digits 7– 4 0 0 0 0 1 1 1 1 Code B decode for digits 7–0 1 1 1 1 1 1 1 1 al id D7 0x0F 0xFF Table 8. Code B font Register Data D7* D6-D4 D3 D2 D1 D0 X 0 0 0 0 DP* A B C 1 1 1 D E F G 1 1 1 0 am lc s on A te G nt st il 0 On Segments = 1 lv 7-Segment Character 1 2 3 4 5 6 7 8 9 -E H L P 0 0 0 1 0 1 1 0 0 0 0 X 0 0 1 0 1 1 0 1 1 0 1 X 0 0 1 1 1 1 1 1 0 0 1 X 0 1 0 0 0 1 1 0 0 1 1 X 0 1 0 1 1 0 1 1 0 1 1 X 0 1 1 0 1 0 1 1 1 1 1 X 0 1 1 1 1 1 1 0 0 0 0 X 1 0 0 0 1 1 1 1 1 1 1 X 1 0 0 1 1 1 1 1 0 1 1 X 1 0 1 0 0 0 0 0 0 0 1 X 1 0 1 1 1 0 0 1 1 1 1 X 1 1 0 0 0 1 1 0 1 1 1 X 1 1 0 1 0 0 0 1 1 1 0 X 1 1 1 0 1 1 0 0 1 1 1 X 1 1 1 1 0 0 0 0 0 0 0 ca blank X ni Note: The decimal point is set by bit D7 = 1 ch Table 9. No-decode Mode Data Bits and Corresponding Segment Lines D7 D6 D5 D4 D3 D2 D1 D0 DP A B C D E F G Te Corresponding Segment Line Register Data www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 8 - 16 AS1100 Datasheet - D e t a i l e d D e s c r i p t i o n Figure 6. Standard 7-segment LED A F B al id G C E D Table 10. Intensity Register Format (address (hex) = 0xXA) 1/32 (min on) 3/32 5/32 7/32 9/32 11/32 13/32 15/32 17/32 19/32 21/32 23/32 25/32 D5 D4 D3 D2 D1 D0 Hex Code X X X X 0 0 0 0 0xX0 X X X X 0 0 0 1 0xX1 X X X X 0 0 1 0 0xX2 X X X X 0 0 1 1 0xX3 X X X X 0 1 0 0 0xX4 X X X X 0 1 0 1 0xX5 X X X X 0 1 1 0 0xX6 X X X X 0 1 1 1 0xX7 X X X X 1 0 0 0 0xX8 X X X X 1 0 0 1 0xX9 X X X X 1 0 1 0 0xXA X X X X 1 0 1 1 0xXB X X X X 1 1 0 0 0xXC X X X X 1 1 0 1 0xXD X X X X 1 1 1 0 0xXE X X X X 1 1 1 1 0xXF ni 31/32 (max on) D6 ca 27/32 29/32 D7 am lc s on A te G nt st il Duty Cycle lv DP Table 11. Scan-limit Register Format (address (hex) = 0xXB) Decode Mode Register Data Hex Code D6 D5 D4 D3 D2 D1 D0 Display digit 0 only X X X X X 0 0 0 0xX0 Display digit 0 & 1 X X X X X 0 0 1 0xX1 Display digit 0 1 2 X X X X X 0 1 0 0xX2 Display digit 0 1 2 3 X X X X X 0 1 1 0xX3 Display digit 0 1 2 3 4 X X X X X 1 0 0 0xX4 Display digit 0 1 2 3 4 5 X X X X X 1 0 1 0xX5 Display digit 0 1 2 3 4 5 6 X X X X X 1 1 0 0xX6 Display digit 0 1 2 3 4 5 6 7 X X X X X 1 1 1 0xX7 Te ch D7 www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 9 - 16 AS1100 Datasheet - D e t a i l e d D e s c r i p t i o n 8.8 Display Test Register With the display test register 0Fh all LED can be tested. In the test mode all LEDs are switched on at maximum brightness (duty cycle 31/32). All programming of digit and control registers are maintained. The format of the register is given in Table 13. Table 12. Maximum Segment Current for 1-, 2-, or 3-digit Displays Maximum Segment Current (mA) 1 10 2 20 3 30 al id Number of digits Displayed Table 13. Display-test Register Format (address (hex) = 0xXF) D6 D5 D4 D3 Normal Operation X X X X X Display Test Mode X X X X X D2 D1 D0 X X 0 X X 1 am lc s on A te G nt st il D7 lv Register Data Mode Note: The AS1100 remains in display-test mode until the display-test register is reconfigured for normal operation. 8.9 No-Op Register (Cascading of AS1100) The no-operation register 00h is used when AS1100s are cascaded in order to support more than 8 digit displays. The cascading must be done in a way that all DOUT are connected to DINof the following AS1100. The LOAD and CLK signals are connected to all devices. For a write operation for example to the fifth device the command must be followed by four no-operation commands. When the LOAD signal finally goes to high all shift registers are latched. The first four devices have got no-operation commands and only the fifth device sees the intended command and updates its register. 8.10 Reset and External Clock Register This register is addressed via the serial interface. It allows to switch the device to external clock mode (If D0=1 the CLK pin of the serial interface operates as system clock input.) and to apply an external reset (D1). This brings all registers (except reg. E) to default state. For standard operation the register contents should be "00h". Table 14. Reset and External Clock Register (address (hex) = oxXE) Address Mode ca code (Hex) Register Data D7 D6 D5 D4 D3 D2 D1 D0 0xXE X X X X X X 0 0 Normal Operation, external clock 0xXE X X X X X X 0 1 Reset state, internal clock 0xXE X X X X X X 1 0 0xXE X X X X X X 1 1 ch ni Normal Operation, internal clock Te Reset state, external clock www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 10 - 16 AS1100 Datasheet - A p p l i c a t i o n I n f o r m a t i o n 9 Application Information 9.1 Supply Bypassing and Wiring In order to achieve optimal performance the AS1100 shall be placed very close to the LED display to minimize effects of electromagnetic interference and wiring inductance. Furthermore, it is recommended to connect a 10µF electrolytic and a 0.1µF ceramic capacitor between VDD and GND to avoid power supply ripple. Also, both GNDs must be connected to ground. al id 9.2 Selecting RSET Resistor and Using External Drivers lv The current through the segments is controlled via the external resistor RSET. Segment current is about 100 times the current in ISET. The right values for ISET are given in Table 15. The maximum current the AS1100 can drive is 40mA. If higher currents are needed, external drivers must be used. In that case it is no longer necessary that the AS1100 drives high currents. A recommended value for RSET is 47kΩ. In cases that the AS1100 only drives few digits, Table 12 specifies the maximum currents and RSET must be set accordingly. Refer to absolute maximum ratings to calculate acceptable limits for ambient temperature, segment current, and the LED forward-voltage drop. Table 15. RSET vs. Segment Current and LED Forward Voltage VLED(V) ISEG (mA) 2.0 2.5 3.0 3.5 12.2kΩ 11.8kΩ 11.0kΩ 10.6kΩ 9.69kΩ 17.8kΩ 17.1kΩ 15.8kΩ 15.0kΩ 14.0kΩ 29.8kΩ 28.0kΩ 25.9kΩ 24.5kΩ 22.6kΩ 66.7kΩ 63.7kΩ 59.3kΩ 55.4kΩ 51.2kΩ am lc s on A te G nt st il 1.5 40 30 20 10 9.3 8x8 LED Dot Matrix Driver The example in Figure 7 uses the AS1100 to drive an 8x8 LED dot matrix. The LED columns have common cathode and are connected to the DIG0-7 outputs. The rows are connected to the segment drivers. Each of the 64 LEDs can be addressed separately. The columns are selected via the digits as shown in Table 5. The decode mode register (0xX9) has to be programmed to ‘00000000’ as stated in Table 4. The single LEDs in a column can be addressed as stated in Table 9, where D0 corresponds to segment G and D7 corresponds to segment DP. Note: For a multiple-digit dot matrix, multiple AS1100 devices must be cascaded. Figure 7. Application Example as LED Dot Matrix Driver SEG G SEG F SEG G SEG F SEG D SEG E SEG C SEG D SEG B SEG C SEG A SEG B ni ca SEG E SEG DP SEG A SEG DP DIG 7 Te ch DIG 0 µP 1 12 13 9 DIG 7 DIG 0 SEG A:G SEG DP DIG0:7 DOUT VDD 24 SEG A:G SEG DP 19 DIG0:7 DIN LOAD AS1100 9.53kΩ 1 12 CLK GND ISET 18 13 9 GND 4 VDD 19 DIN LOAD AS1100 9.53kΩ CLK GND ISET 18 GND 4 www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 11 - 16 AS1100 Datasheet - A p p l i c a t i o n I n f o r m a t i o n 9.4 Calculating the Power Dissipation The upper limit for power dissipation (PD) for the AS1100 is determined from the following equation: PD = (VDD x 0.5mA) + (VDD - VLED)(DUTY x ISEG x N) (EQ 1) al id Where: VDD = supply voltage DUTY = duty cycle set by intensity register N = number of segments driven (worst case is 8) VLED = LED forward voltage ISEG = segment current set by RSET Dissipation Example: ISEG = 40mA, N = 8, DUTY = 31/32, VLED = 1.8V at 40mA, VDD = 5.25V lv PD = 5.25V(0.5mA) + (5.25V - 1.8V)(31/32 x 40mA x 8) = 1.07W Thus, for a PDIP package θJA = +75°C/W (from Table 13), the maximum allowed ambient temperature TA is given by: am lc s on A te G nt st il TJ,MAX = TA + PD x θJA = 150°C = TA +1.07W x 75°C/W. Where: TA = +69.7°C. The TA limit for SO Packages in the dissipation example above is +59.0°C. Table 16. Package Thermal Resistance Data Package Thermal Resistance (θJA) 24 Wide SO +85ºC/w Maximum Junction Temperature (TJ) = +150ºC Te ch ni ca Maximum Ambient Temperature (TA) = +85ºC www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 12 - 16 AS1100 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 10 Package Drawings and Markings Table 17. Packaging Code YYWWQZZ WW Q last two digits of the current year manufacturing week plant identifier ZZ free choice / traceability code Te ch ni ca am lc s on A te G nt st il YY lv al id Figure 8. AS1100 Marking www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 13 - 16 AS1100 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s Te ch ni ca am lc s on A te G nt st il lv al id Figure 9. SOIC 24-pin Package Diagram www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 14 - 16 AS1100 Datasheet - O r d e r i n g I n f o r m a t i o n 11 Ordering Information The device is available as the standard products shown in Table 18. Table 18. Ordering Information Marking AS1100WL Description Serially Interfaced, 8-Digit LED Driver Temp Range AS1100WE AS1100WE Serially Interfaced, 8-Digit LED Driver -40ºC to +85ºC Tubes AS1100WL-T AS1100WL Serially Interfaced, 8-Digit LED Driver 0ºC to +70ºC Tape & Reel AS1100WE-T AS1100WE Serially Interfaced, 8-Digit LED Driver -40ºC to +85ºC Tape & Reel 0ºC to +70ºC Delivery Form Tubes Package SOIC 24-pin SOIC 24-pin al id Ordering Code AS1100WL SOIC 24-pin SOIC 24-pin lv Note: All products are RoHS compliant and austriamicrosystems green. Buy our products or get free samples online at ICdirect: http://www.austriamicrosystems.com/ICdirect Technical Support is found at http://www.austriamicrosystems.com/Technical-Support Te ch ni ca am lc s on A te G nt st il For further information and requests, please contact us mailto:sales@austriamicrosystems.com or find your local distributor at http://www.austriamicrosystems.com/distributor www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 15 - 16 AS1100 Datasheet Copyrights Copyright © 1997-2012, austriamicrosystems AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. al id Disclaimer lv Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. ca am lc s on A te G nt st il The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Headquarters ni Contact Information ch austriamicrosystems AG Tobelbaderstrasse 30 A-8141 Unterpremstaetten, Austria Te Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com/LED-Driver-ICs/AS1100 Revision 1.37 16 - 16
AS1100WE-T 价格&库存
很抱歉,暂时无法提供与“AS1100WE-T”相匹配的价格&库存,您可以联系我们找货
