NCT7904D
NCT7904D
    NUVOTON(新唐)
    LQFP48
NCT7904D 数据手册
NCT7904D H/W Monitor Date: 2017/07/25 Revision: 1.45 NCT7904D Table of Content1. 2. 3. 4. 5. 6. GENERAL DESCRIPTION ......................................................................................................... 7 FEATURES ................................................................................................................................. 8 2.1 Equipped Specific Interfaces .......................................................................................... 8 2.2 Monitoring Items ............................................................................................................. 8 2.3 PECI (Platform Environment Control Interface) .............................................................. 8 TM 2.4 SMART FAN PWM Output Control ............................................................................. 9 2.5 Alarm Output ................................................................................................................... 9 2.6 Self-initialization .............................................................................................................. 9 2.7 SMBus Master ................................................................................................................ 9 2.8 General ........................................................................................................................... 9 KEY SPECIFICATIONS ............................................................................................................ 10 PIN CONFIGURATION ............................................................................................................. 11 PIN DESCRIPTION................................................................................................................... 12 5.1 Pin Type Description ..................................................................................................... 12 5.2 Pin Description List ....................................................................................................... 12 FUNCTIONAL DESCRIPTION.................................................................................................. 17 6.1 Access Interface ........................................................................................................... 17 6.1.1 6.1.2 6.2 6.3 Data write to the internal register ............................................................................. 17 Data read from the internal register ......................................................................... 17 Address Setting............................................................................................................. 18 Temperature Monitor Data Format ............................................................................... 18 The temperature data with 11-bit 2`s complement format ........................................................... 18 6.4 6.5 6.6 6.7 Voltage Sense Data Format ......................................................................................... 18 FAN_IN Count Calculation ............................................................................................ 19 FAN_OUT Duty Cycle/DC output Calculation .............................................................. 19 Fan Speed Control ........................................................................................................ 19 6.7.1 6.7.2 6.7.3 6.7.4 6.8 PECI .............................................................................................................................. 22 6.8.1 6.8.2 6.8.3 6.8.4 6.9 Temperature ............................................................................................................ 25 Voltage .................................................................................................................... 27 Fan .......................................................................................................................... 27 EEPROM Self-Initialization ........................................................................................... 28 6.10.1 6.10.2 6.11 Operation Mode ....................................................................................................... 22 CPU Temperature and Power Reporting ................................................................. 22 DRAM Thermal Data Reporting ............................................................................... 23 PECI Listening ......................................................................................................... 24 SMI# Output .................................................................................................................. 25 6.9.1 6.9.2 6.9.3 6.10 Step Up Time / Step Down Time ............................................................................. 19 Fan Output Nonstop Value ...................................................................................... 19 Smart Fan Control Table ......................................................................................... 19 DTS (Sensor) Based Fan Control ............................................................................ 21 EEPROM Format ..................................................................................................... 28 Chip Initialization...................................................................................................... 28 PCH Thermal Data Report ............................................................................................ 29 6.11.1 6.11.2 Nuvoton Confidential PCH Thermal Read ................................................................................................. 29 PCH Thermal Data Format ...................................................................................... 29 - ii – 2017/7/25 Revision 1.45 NCT7904D 6.12 SMBus Master Auto Read External Thermal Sensor ................................................... 29 6.12.1 6.12.2 6.13 PROCHOT# Behavior ................................................................................................... 29 6.13.1 6.13.2 6.14 Output Signaling ...................................................................................................... 30 BEEP Activation....................................................................................................... 30 THERMTRIP# Function ................................................................................................ 30 6.16.1 6.16.2 7. Event Trigger LED ................................................................................................... 30 Programmable LED ................................................................................................. 30 BEEP Function.............................................................................................................. 30 6.15.1 6.15.2 6.16 PROCHOT# Input .................................................................................................... 29 PROCHOT# Output ................................................................................................. 29 LED Behavior ................................................................................................................ 30 6.14.1 6.14.2 6.15 External Thermal Sensor Setting ............................................................................. 29 Temperature Read Process ..................................................................................... 29 Power by VSB.......................................................................................................... 30 Power Only by VBAT ............................................................................................... 30 REGISTER DESCRIPTION ...................................................................................................... 31 7.1 Bank 0 REGISTER DETAIL.......................................................................................... 31 7.1.1 7.1.2 7.1.3 7.1.4 7.1.5 7.1.6 7.1.7 7.1.8 7.1.9 7.1.10 7.1.11 7.1.12 7.1.13 7.1.14 7.1.15 7.1.16 7.1.17 7.1.18 7.1.19 7.1.20 7.1.21 7.1.22 7.1.23 7.1.24 7.1.25 7.1.26 7.1.27 7.1.28 7.1.29 7.1.30 Nuvoton Confidential Global Control Register ........................................................................................... 31 SMB Slave Address Register................................................................................... 31 Nuvoton Vendor ID Register .................................................................................... 32 Nuvoton Chip ID Register ........................................................................................ 32 Nuvoton Device ID Register..................................................................................... 32 Programmable LED Register ................................................................................... 32 Event Control LED Register ..................................................................................... 33 Monitor Enable Control Register .............................................................................. 33 Monitor Configuration Register ................................................................................ 38 Voltage Channel and Temperature Monitored Value Register ................................ 41 PROCHOT Monitored Value Register ..................................................................... 42 Nuvoton Vendor ID Register .................................................................................... 43 Nuvoton Chip ID Register ........................................................................................ 43 Nuvoton Device ID Register..................................................................................... 43 FAN Tachometer Monitored Value Register ............................................................ 43 DTS Temperature Monitored Value Register ........................................................... 44 Virtual Temperature Value Register......................................................................... 46 External and Virtual Temperature Value Register.................................................... 47 SMI Control Register ............................................................................................... 48 SMI Status Register ................................................................................................. 48 SMI Mask Register .................................................................................................. 50 Beep Control Register ............................................................................................. 52 Beep Source Selection Register .............................................................................. 52 Lock Watch Dog Register ........................................................................................ 54 Watch Dog Enable Register .................................................................................... 54 Watch Dog Status Register ..................................................................................... 54 Watch Dog Timer Register ...................................................................................... 55 GPIO Control Register ............................................................................................. 55 PCH DTS Monitored Value Register........................................................................ 57 Bank Select Register ............................................................................................... 60 - iii – 2017/7/25 Revision 1.45 NCT7904D 7.2 Bank 1 REGISTER DETAIL.......................................................................................... 61 7.2.1 7.2.2 7.2.3 7.2.4 7.2.5 7.2.6 7.2.7 7.2.8 7.2.9 7.2.10 7.2.11 7.2.12 7.2.13 7.3 Voltage and Temperature Channel Limitation Register ........................................... 61 PROCHOT Limitation Register ................................................................................ 64 FAN Input Channel Limitation Register.................................................................... 64 DTS Temperature Power Limitation Registers......................................................... 65 PROCHOT Control Registers .................................................................................. 67 PROCHOT Source Selection Registers................................................................... 68 Voltage Fault Control Registers ............................................................................... 70 Voltage Fault Source Selection Registers ............................................................... 70 Fan Fault Control Registers ..................................................................................... 72 Fan Fault Source Selection Registers ..................................................................... 72 Temperature Fault Control Registers....................................................................... 74 Temperature Fault Source Selection Registers ....................................................... 74 THERMTRIP Control and Status Register ............................................................... 75 Bank 2 REGISTER DETAIL.......................................................................................... 77 7.3.1 7.3.2 7.3.3 7.3.4 7.3.5 7.3.6 7.3.7 7.3.8 7.3.9 7.3.10 7.3.11 7.3.12 7.3.13 7.3.14 7.3.15 7.3.16 7.3.17 7.3.18 7.3.19 7.3.20 7.3.21 7.3.22 7.3.23 7.3.24 7.3.25 7.3.26 7.3.27 7.3.28 7.3.29 7.3.30 7.3.31 7.3.32 7.3.33 Nuvoton Confidential PECI Function Enable Register (PFE) ..................................................................... 77 PECI Timing Configure Register (PTC) ................................................................... 77 PECI Agent and Domain Configure Register (PADC).............................................. 78 PECI Relative Temperature Scale Register (PRTS) ................................................ 79 DTS Power Source Control Register ....................................................................... 80 TBit Width Register ( TBW )..................................................................................... 80 PECI Listening Mode Configuration Register ( PLMC ) ........................................... 81 PECI VTT Power Detect Configuration Register ( PVCR ) ...................................... 81 PECI Agent Tbase Temperature Register (PATB)................................................... 82 PECI Power Averaging Configure Register (PPAC) ................................................ 83 Averaging DTS Based Thermal Spec Configure Register (ADBTSC) ..................... 84 PECI Manual Mode Configure Register (PMMC)..................................................... 85 PECI Manual Mode Write Data Register (PMMWD) ................................................ 86 PECI Manual Mode Read Data Register (PMMRD) ................................................ 86 Agent Relative Temperature Registers (ARTR) ....................................................... 89 TSI Control Registers .............................................................................................. 91 TSI Client Enable Registers ..................................................................................... 91 TSI Manual Configuration Registers ........................................................................ 91 TSI Test Mode Registers ......................................................................................... 92 TSI Manual Address Registers ................................................................................ 92 TSI Manual Command Registers ............................................................................. 92 TSI Manual Write Data Registers ............................................................................ 93 TSI Manual Read Data Registers ............................................................................ 93 PCH Read Control Registers ................................................................................... 93 PCH Client Address Registers ................................................................................. 93 PCH Command Registers ....................................................................................... 94 PCH Read Byte Count Registers ............................................................................. 94 SMBUS Master Manual Configuration Registers ..................................................... 94 SMBUS Master Manual Address Registers ............................................................. 95 SMBUS Master Manual Command Registers .......................................................... 95 SMBUS Master Manual Write Data Registers ......................................................... 95 SMBUS Master Manual Read Data Registers ......................................................... 95 External Read Control Registers ............................................................................. 95 - iv – 2017/7/25 Revision 1.45 NCT7904D 7.3.34 7.3.35 7.3.36 7.3.37 7.3.38 7.3.39 7.3.40 7.3.41 7.3.42 7.3.43 7.3.44 7.4 Bank 3 REGISTER DETAIL........................................................................................ 112 7.4.1 7.4.2 7.4.3 7.4.4 7.4.5 7.4.6 7.4.7 7.4.8 7.4.9 7.4.10 7.4.11 7.4.12 7.4.13 7.4.14 7.4.15 7.4.16 7.4.17 7.4.18 7.4.19 7.4.20 7.4.21 7.4.22 7.4.23 7.4.24 7.4.25 7.4.26 7.4.27 7.5 Temperature to Fan Mapping Relationships (TFMR) ............................................. 112 Default Fan Speed at Power-on (DFSP)................................................................ 112 SmartFan Output Step Up Time (SFOSUT) .......................................................... 113 SmartFan Output Step Down Time (SFOSDT) ...................................................... 113 3-Wire Fan Enable and Fan Output Mode Control (FOMC) ................................... 113 Close-Loop Fan control RPM mode and Tolerance (CLFR) .................................. 114 Temperature Source Selection (TSS) .................................................................... 114 Power Accumulate Enable (PAE) .......................................................................... 116 Close-Loop Fan Control RPM mode for High Speed Fan Register (RHSF) .......... 117 PROCHOT Fan Select (PFS) ................................................................................ 117 Fan Output Value (FOV) ........................................................................................ 118 Fan Output PWM Frequency Prescalar (FOPFP) .................................................. 118 Fan Output Nonstop Enable (FONE) ..................................................................... 119 Fan Tachometer Source Selection (FTSS) ............................................................ 119 Fan Tachometer Source Selection (FTSS) ............................................................ 120 Critical Temperature to Full Speed all fan (CTFS) ................................................. 121 Hysteresis of Temperature (HT) ............................................................................ 121 Fan Output Nonstop Value(FONV) ........................................................................ 122 TM SMART FAN IV Temperature and DC/PWM Table (SFIV)................................. 122 Configure Register of PECI Error (CRPE) ............................................................. 123 Fan Output Min Value when PECI Error (FOMV) .................................................. 124 Mask Register of PECI Error (MRPE) .................................................................... 124 PECI T_DTS Slope Value (PTSV) ......................................................................... 124 PECI T_DTS Offset Value (PTOV) ........................................................................ 125 Tcontrol_Offset Value for CPU Agent (Address : 30h ~ 33h) (TOV) ...................... 125 DTS Delta Tolerance Value (DDTV) ...................................................................... 126 DTS Margin Divisor (DMD) .................................................................................... 127 Bank 4 REGISTER DETAIL........................................................................................ 128 7.5.1 7.5.2 7.5.3 7.5.4 7.5.5 8. External Read Address and Command Register ..................................................... 96 Power Unit Status .................................................................................................... 97 Energy Unit Status ................................................................................................... 98 Retrieving Margin Status Control Registers ............................................................. 98 Tjmax Temperature Target Read/Write for CPU Agent (Address : 30h ~ 33h) ........ 99 Tcontrol Temperature Target Read/Write for CPU Agent (Address : 30h ~ 33h)... 100 Thermal Design Power (TDP) Status for CPU Agent (Address : 30h ~ 33h) ......... 100 Margin Status for CPU Agent (Address : 30h ~ 33h) ............................................. 101 Power Reporting Factor for CPU Agent (Address : 30h ~ 33h) ............................. 101 DTS DRAM Temperature Monitor Enable Control Register................................... 102 DRAM Temperature Value Register (Reterived by PECI RdPkgConfig command) 104 Temperature to Fan Mapping Relationships (TFMR) ............................................. 128 Temperature Source Selection (TSS) .................................................................... 128 Critical Temperature to Full Speed all fan (CTFS) ................................................. 130 Hysteresis of Temperature (HT) ............................................................................ 131 TM SMART FAN IV Temperature and DC/PWM Table (SFIV)................................. 131 ELECTRICAL CHARACTERISTICS ....................................................................................... 133 8.1 Absolute Maximum Ratings ........................................................................................ 133 Nuvoton Confidential -v– 2017/7/25 Revision 1.45 NCT7904D 9. 10. 11. 12. DC Specification ......................................................................................................... 133 8.2 8.3 AC Specification.......................................................................................................... 134 ORDER INFORMATION ......................................................................................................... 136 TOP MARKING SPECIFICATIONS ........................................................................................ 137 PACKAGE DRAWING AND DIMENSIONS ............................................................................ 138 REVISION HISTORY .............................................................................................................. 139 Nuvoton Confidential - vi – 2017/7/25 Revision 1.45 NCT7904D 1. GENERAL DESCRIPTION NCT7904D is an evolving version of the Nuvoton popular Hardware Monitor IC family. NCT7904D provides several innovative features, Intel PECI1.1/2.0/3.0 interface, and PROCESSOR HOT feature. Conventionally, NCT7904D can be used to monitor several critical hardware parameters of the system, including power supply voltages, fan speeds, and temperatures, which are very important for a high-end computer system, such as server, workstation…etc, to work stably and efficiently. A 10-bit analog-to-digital converter (ADC) is built inside NCT7904D. NCT7904D can simultaneously monitor 20 analog voltage inputs (including power 3VDD / 3VSB / VBAT / VTT monitoring), 12 fan tachometer inputs, 4 fan output control, and 4 remote temperature sensor inputs, 2 of which support current mode (dual current source) temperature measurement method, it also supports caseopen detection, Watch Dog Timer function, and GPIO pins. The sense of remote temperature can be performed by thermistors, or directly from thermal diode. NCT7904D provides PWM (pulse width modulation) for each fan control output pin, and DC fan output mode is supported on TM PWM4 pin. Meanwhile, the NCT7904D provides SMART FAN TM control, the  SMART FAN IV  mode equips with 4 sets of temperatures setting point each could control fan’s duty cycle, to make the fans could be operated at the lowest possible speed and the acoustic could be balanced. As for warning mechanism, NCT7904D provides SMI#, TEMP_ALM#, VOLT_ALM#, and FAN_ALM# to protect the system. NCT7904D has 1 specific pin to provide address selection so that 2 NCT7904D could be wired through SMBus interface at the same time. All of the monitored parameters of the system could be read from time to time through the BIOS or any management application software. Nuvoton supports the software – “Health Manager” to provide an easy way to monitor and show the hardware parameters, such as temperature, voltage and fan speed inputs, furthermore, it provides a convenient method to do the fan control. It can also show the alarm message when the monitored hardware parameter exceeds the limit, and recodes the history events. Nuvoton Confidential -7– 2017/7/25 Revision 1.45 NCT7904D 2. FEATURES 2.1 Equipped Specific Interfaces 2  I C / SMBus2.0 Serial Bus Master (max. 400KHz Clock) 2  I C / SMBus2.0 Serial Bus Slave (max. 400KHz Clock)  Intel® PECI (PLATFORM ENVIRONMENT CONTROL INTERFACE) 1.0 / 2.0 / 3.0  AMD SB-TSI 2.2 Monitoring Items VOLTAGE Up to 20 voltage sensing inputs  16 general voltage inputs  4 power pins. (3VDD, 3VSB, VBAT and VTT)  4 multi-functions with thermistor temperature inputs (on VSEN2, VSEN4, VSEN6, VSEN8)  2 multi-functions with thermal diode pair (on VSEN2, VSEN3, VSEN4 and VSEN5) TEMPERATURE Up to 4 methodologies for capturing temperature information  ADC => 2-pair thermal diode channel (current mode) / 4-channel thermistor mode temperature => 1 channel on-chip temperature sensor  Intel® PECI interface => Automatically retrieving CPU temperature  AMD SB-TSI interface => Automatically retrieving CPU temperature  SMBus Master => Reading MCH, PCH, CPU and DIMMs temperature through PCH => Reading specific external at most 4 thermal sensors. FAN SPEED Up to 12 fan tachometer inputs 2.3 PECI (Platform Environment Control Interface)  Support PECI 1.0 / 2.0 / 3.0 full commands  Automatically retrieve CPU temperature and power status  Automatically retrieve DRAM thermal data which is provided by CPU0 and CPU1 only (Address: 30h and 31h)  Support 4 CPU sockets (eq. 4 PECI address) and 2 domains per CPU address Nuvoton Confidential -8– 2017/7/25 Revision 1.45 NCT7904D SMART FANTM PWM Output Control 2.4  Up to 4 PWM Outputs TM  Support 2 modes of fan speed control: SMART FAN Mode ( RPM mode) TM  Provide up to 10 SMART FAN and output fan speed IV mode and Closed Loop Fan Control tables to characterize 10 relationships between temperature  The temperature source of table could come from any of temperature information captured from ADC, PECI, TSI and SMBus Master  Multiple temperature sources could affect multiple fan control outputs  Up to 4 virtual temperature sources feed by host as the parts of fan temperature sources  Up to 4 external temperature sources read from SMBus master I/F which can be the part of fan temperature sources  Support Fan Control for Intel Sandy Bridge-EP/EX DTS specification  Support DTS (Sensor) Based Thermal Ver. 1.0/2.0 Spec to optimize fan speed control and acoustics at processor run time 2.5 Alarm Output  Issue SMI# signal to activate system protection  Issue voltage, temperature and fan alarm signals to activate system protection 2.6 Self-initialization  2.7 Self-configuration by reading external EEPROM with SMBus interface SMBus Master  Support SMBus master function to read EEPROM configuration data and other SMBus devices  Support SMBus master manual byte read and byte write  Support accessing PCH Thermal Reporting  Support accessing external thermal sensors 2.8 General  Provide up to 11 GPIO pins (GPIO13~16, GPIOA~G, multi-function with other function pins)  LED indication with programmable blinking frequency  Event trigger LED by the external signal with programmable blinking frequency 2  I C / SMBus2.0 serial bus interface (max. 400KHz Clock)  Watch Dog Timer function with an output signal(WDT_RSTOUT#)  1 address selection pins provide 2 selectable SMBus addresses  3.3V operationPackage  Packaged in 48-LQFP(7mm x 7mm) type, RoHS-Compliant and Halogen free Nuvoton Confidential -9– 2017/7/25 Revision 1.45 NCT7904D 3. KEY SPECIFICATIONS   Voltage monitoring accuracy VSEN inputs ±10mV Power inputs and VSEN17,18,19 inputs ±60mV Temperature Sensor Accuracy Remote Diode Sensor Accuracy (25~85°C) ± 1°C typ. On-chip Temperature Sensor Accuracy (25~70°C) ± 1°C typ. Remote Diode Sensor Resolution 0.125 ℃ On-chip Temperature Sensor Resolution 0.125 ℃  Supply Voltage 3.3V ± 5%  Operating Supply Current 15 mA typ.  Operating Temperature Range -40°C ~ 120°C *1 *1 Guaranteed by design from -40~120 °C, 100% tested at 85°C. Nuvoton Confidential - 10 – 2017/7/25 Revision 1.45 NCT7904D 4. PIN CONFIGURATION Nuvoton Confidential - 11 – 2017/7/25 Revision 1.45 NCT7904D 5. PIN DESCRIPTION 5.1 Pin Type Description SYMBOL DESCRIPTION TTL TTL level GTL VTT level TSI TSI level I Input O Output ( Push-pull ) OD Open-drain output AIN Input pin(Analog) 5.2 Pin Description List PIN NAME PIN NO. POWER PLANE TYPE DESCRIPTION VREF 1 3VSB AOUT Reference voltage output. This pin is for thermistor application TR1 D1+ Thermistor 1 sensing input 2 3VSB AIN Voltage sensing input. Detection range is 0~2.048V. (default) VSEN2 D1- Thermal diode 1 D3 3VSB AIN 4 3VSB AIN VSEN3 TR2 D2+ Thermistor 2 sensing input Voltage sensing input. Detection range is 0~2.048V.(default) D2- Thermal diode 2 D5 3VSB AIN 6 3VSB AIN VSEN5 Nuvoton Confidential Voltage sensing input. Detection range is 0~2.048V Thermal diode 2 D+ VSEN4 TR3 Thermal diode 1 D+ Voltage sensing input. Detection range is 0~2.048V Thermistor 3 sensing input - 12 – 2017/7/25 Revision 1.45 NCT7904D PIN NAME PIN NO. POWER PLANE TYPE Voltage sensing input. Detection range is 0~2.048V VSEN6 VSEN7 DESCRIPTION 7 3VSB AIN TR4 Voltage sensing input. Detection range is 0~2.048V Thermistor 4 sensing input 8 3VSB AIN VSEN9 9 3VSB AIN Voltage sensing input. Detection range is 0~2.048V VSEN10 10 3VSB AIN Voltage sensing input. Detection range is 0~2.048V VSEN11 11 3VSB AIN Voltage sensing input. Detection range is 0~2.048V VSEN12 12 3VSB AIN Voltage sensing input. Detection range is 0~2.048V VSEN13 13 3VSB AIN Voltage sensing input. Detection range is 0~2.048V VSEN14 14 3VSB AIN Voltage sensing input. Detection range is 0~2.048V VSEN8 3VDD 15 3VSB 16 GPIOF POWE R +3V VDD power. It is also a voltage monitor channel Bypass with the parallel combination of 10µF (electrolytic or tantalum) and 0.1µF (ceramic) bypass capacitors +3V VSB power. It is also a voltage monitor channel Bypass with the parallel combination of 10µF (electrolytic or tantalum) and 0.1µF (ceramic) bypass capacitors - POWE R 3VSB TTL I/OD General Purpose I/O F (default) 3VSB TTL OD System Management Interrupt. CPU1 PROCHOT# signal 17 SMI# Voltage sensing input. Detection range is 0~2.048V P1_PROCHOT# 18 3VSB GTL I/O VTT (VSEN1) 19 -- POWE R VTT power pin. This power will be also monitored as VSEN1 VTT GTL I/O Intel PECI interface signal. The power source is pin 19 (VTT) 3VSB TTL I/OD General Purpose I/O 16 PECI 20 GPIO16 Nuvoton Confidential ® - 13 – 2017/7/25 Revision 1.45 NCT7904D POWER PLANE TYPE SCL_TSI 3VSB TSI OD P1_THERMTRIP# 3VSB GTL I CPU1 THERMTRIP# signal. Pull-down it when unused. 3VSB TSI I/OD Data line of AMD SB_TSI interface PIN NAME PIN NO. 21 SDA_TSI DESCRIPTION ® Clock line of AMD SB_TSI interface ® CLKIN(33M, 14.318M, 48M) 22 3VSB TTL I Clock input. 14.318MHz or 33MHz or 48MHz could be applied to this pin with corresponding register configuration. Default setting is for 33MHz This clock is for PECI and fan speed monitor S_SMB_CLK 23 3VSB TTL I SMBus clock line for this device being slave device S_SMB_DATA 24 3VSB TTL I/OD SMBus data line for this device being slave device TTL OD SMBus clock line for this device being master device TTL I Fan tachometer input LED_EVNT_IN# TTL I An input event to trigger LED_OUT M_SMB_DATA TTL I/OD SMBus data line for this device being master device TTL I Fan tachometer input M_SMB_CLK FANIN_11 FANIN_12 25 26 3VSB 3VSB TTL OD LED_OUT ADDR 27 3VSB WDT_RSTOUT# GPIOG 28 3VSB VSEN17 TTL I When pin LED_EVNT_IN is asserted a low pulse, this pin will output a pulse to drive LED on or blinking SMBus slave address strap selection pin Strapped to low, the 7-bit address is 0101101 Strapped to high, the 7-bit address is 0101110 TTL OD Watch dog timer reset output TTL I/OD General Purpose I/O G (default) AIN Voltage sensing input. Detection range is 0~3.3V FANIN_1 29 3VSB TTL I Fan tachometer input PWM1 30 3VSB TTL OD Fan speed control PWM output. This is 5V tolerant FANIN_2 31 3VSB TTL I Fan tachometer input Nuvoton Confidential - 14 – 2017/7/25 Revision 1.45 NCT7904D PIN NAME PIN NO. POWER PLANE TYPE DESCRIPTION PWM2 32 3VSB TTL OD Fan speed control PWM output. This is 5V tolerant FANIN_3 33 3VSB TTL I Fan tachometer input TTL OD Fan speed control PWM output. This is 5V tolerant AIN Voltage sensing input. Detection range is 0~3.3V PWM3 34 3VSB VSEN18 FANIN_4 35 3VSB TTL I Fan tachometer input 3VSB TTL OD AOUT Fan speed control PWM or DC output. A register bit could be programmed to select PWM or DC mode. DC output is default mode. This is without 5V tolerant AIN Voltage sensing input. Detection range is 0~3.3V PWM4/DCOUT 36 VSEN19 FANIN_5 3VSB TTL I Fan tachometer input.(default) GPIO13 3VSB TTL I/OD General Purpose I/O 13 FANIN_6 3VSB TTL I Fan tachometer input (default) GPIO14 3VSB TTL I/OD General Purpose I/O 14 FANIN_7 3VSB TTL I Fan tachometer input (default) GPIO15 3VSB TTL I/OD General Purpose I/O 15 FANIN_8 3VSB TTL I Fan tachometer input (default) GPIOA 3VSB TTL I/OD General Purpose I/O A VOLT_ALM# 3VSB TTL OD Voltage abnormal alert output signal ( active low ) 3VSB TTL I Fan tachometer input (default) GPIOB 3VSB TTL I/OD General Purpose I/O B FAN_ALM# 3VSB TTL OD Fan speed abnormal alert output signal ( active low ) 3VSB TTL I Fan tachometer input (default) 37 38 39 40 FANIN_9 41 42 FANIN_10 Nuvoton Confidential - 15 – 2017/7/25 Revision 1.45 NCT7904D PIN NAME PIN NO. GPIOC GND POWER PLANE TYPE 3VSB TTL I/OD POWE R 43 DESCRIPTION General Purpose I/O C GROUND TTL OD Temperature abnormal alert output signal ( active low ) GPIOD TTL I/OD General Purpose I/O D (default) LED TTL OD Programmable frequency LED output signal TTL I/OD General Purpose I/O E (default) TTL OD Beeper signal output when over heat event happens TTL I System reset input TTL I Case Open detection input signal. An active low input from an external device when case is opened. This event will be latched even when the case is closed. Pull-down it when unused. POWE R VBAT power for Case Open detection and status log TEMP_ALM# 44 GPIOE 45 3VSB 3VSB BEEP RESETIN# 46 CASEOPEN# 47 VBAT 48 3VSB VBAT * The recommended connection for Unused Pin (1) For digital input pin, pull down to GND. (2) For digital output pin, keep floating. (3) For analog input pin, keep floating. (4) For analog output pin, keep floating. (5) For VTT pin, keep floating. (6) For VBAT pin, connect to 3VSB. Nuvoton Confidential - 16 – 2017/7/25 Revision 1.45 NCT7904D 6. FUNCTIONAL DESCRIPTION 6.1 Access Interface NCT7904D provides SMBus interface, which is compliant with SMBus 2.0 specification. The 7-bit serial address is selected to be 0101101 or 0101110 by pin ADDR. When pin ADDR is strapped to low, the SMBus address is 0x5A(write)/0x5B(read) ; when pin ADDR is strapped to high, the SMBus address is 0x5C(write)/0x5D(read). NCT7904D supports the bus speed with 0~400KHz. 6.1.1 Data write to the internal register 6.1.2 Data read from the internal register Nuvoton Confidential - 17 – 2017/7/25 Revision 1.45 NCT7904D 6.2 Address Setting NCT7904D has one address selection pin, the SMBus address will be strapped when 3VSB ready. The address will be retained as long as the 3VSB of NCT7904D is maintained. The pull-up power plane must be the same as the 3VSB power of NCT7904D. ADDR ADDRESS 0 0101 101X 1 0101 110X X=Read/Write Bit 6.3 Temperature Monitor Data Format The temperature data with 11-bit 2`s complement format TEMPERATURE 8-BIT DIGITAL OUTPUT HIGH BYTE 3-BIT DIGITAL OUTPUT LOW BYTE +127.875°C 0111,1111 XXXX,X111 +25.750°C 0001,1001 XXXX,X110 +2.250°C 0000,0010 XXXX,X010 +1.125°C 0000,0001 XXXX,X001 +0.000°C 0000,0000 XXXX,X000 - 1.125°C 1111,1110 XXXX,X111 - 2.250°C 1111,1101 XXXX,X110 - 25.750°C 1110,0110 XXXX,X010 - 127.875°C 1000,0000 XXXX,X001 6.4 Voltage Sense Data Format VSEN Low Byte together with VSEN High Byte forms the 11-bit count value. If VSEN High Byte readout is read successively, the NCT7904D will latch the VSEN Low Byte for next read. Then voltage readout high byte and low byte are combined to 11-bitVoltageValue. For voltage monitoring, real voltage calculations should follow the formula: VSEN1~14 : Voltage(V) = 11bitCountValue× 0.002 3VSB,3VDD,VBAT,VSEN17,18,19 : Voltage(V) = 11bitCountValue× 0.006 * VSEN17,18,19 are embedded internal voltage divider resistors. Nuvoton Confidential - 18 – 2017/7/25 Revision 1.45 NCT7904D 6.5 FAN_IN Count Calculation The FAN_IN tachometer high byte and low byte are combined to 13-bitCountValue. Real RPM (Rotate per Minute) calculation should follow the formula: FanSpeed ( RPM ) = 1.35 × 10 6 (13 − bitCountValue) × ( FanPoles ) 4 In this formula, FanPole stands for the number of NS pole pairs inside the fan. Normally an N-S-N-S Fan (FanPole=4) generates 2 pulses after completing one rotation. 6.6 FAN_OUT Duty Cycle/DC output Calculation The NCT7904D provides 4 set of PWM and 1 set of DC output for fan speed control. The duty cycle of PWM can be programmed by an 8-bit register. The expression of duty cycle can be represented as follow formula: Programmed 8 - bit Register Value Duty − cycle(%) = × 100% 255 The DC output can be programmed by an 8-bit register. The expression of DC level can be represented as follow formula: Programmed 8 - bit Register Value DC output (V) = 3VDD × 255 6.7 Fan Speed Control Except for traditional Fan Duty control, the latest closed loop fan control (RPM Mode) has been provided by the NCT7904D. Due to PECI negative temperature format, the fan control also supports negative temperature representation. It would be much easy to implement fan control by PECI reading. In addition to PECI CPU temperature, the NCT7904D also supports fan control, which is responded to CPU power. In Smart Fan Mode, there are some Fan control parameters as below descriptions: 6.7.1 Step Up Time / Step Down Time Smart Fan is designed for the smooth operation of the fan. The Up Time / Down Time register defines the time interval between successive duty increases or decreases. If this value is set too small, the fan will not have enough time to speed up after tuning the duty and sometimes may result in unstable fan speed. On the other hand, if Up Time / Down Time is set too large, the fan may not work fast enough to dissipate the heat. This register should never be set to 0, otherwise, the fan duty will be abnormal. 6.7.2 Fan Output Nonstop Value It takes some time to bring a fan from still to working state. Therefore, Nonstop value are designed with a minimum fan output to keep the fan working when the system does not require the fan to help reduce heat but still want to keep the fast response time to speed up the fan. 6.7.3 Smart Fan Control Table TM SMART FAN IV and Close Loop Fan Control Mode offer 4 slopes to control the fan speed. The 3 slopes can be obtained by setting FanDuty/RPM1~FanDuty/RPM4 and T1~T4 through the registers. When the temperature rises, FAN Output will calculate the target Fan Duty/RPM based on the current slope. For example, assuming Tx is the current temperature and Fan Duty/RPMy is the target, then the slope: Nuvoton Confidential - 19 – 2017/7/25 Revision 1.45 NCT7904D X2 = Fan Output: (FanDuty3 / RPM 3) − (FanDuty 2 / RPM 2) (T 3 − T 2) T arg et FanDuty or RPM = (FanDuty 2 or RPM 2 ) + (Tx − T 2 ) ⋅ X 2 SMART FAN TM IV & Close Loop Fan Control Mechanism Fanduty/RPM (unit RPM = 50 ) Critical Hyst. Operation Hyst. FullSpeed (FF, 100%) Fanduty4/RPM4 Fanduty3/RPM3 Ty Fanduty2/RPM2 X3 X2 X1 Fanduty1/RPM1 Temperature T1 T2 Tx T3 T4 TRCritical In TM addition, SMART FAN IV & Close Loop Fan Control can also set up Critical Temperature and Hysteresis. If the current temperature exceeds Critical Temperature, external fan will be forced by maximum Fan Duty to meet the largest target Fan Duty or RPM, Which is 0xFF. The target Fan Duty & RPM value will be determined in accordance to the slope only when the temperature falls below (TCritical – Critical Hyst.) NCT7904D provides several temperature sources selects to map the fan, the algorithm will make a decision to control the fan as below figure: Any Temp request faster Fan?? Yes Speed Up Yes Hold current Speed No Any Temp request f hold current speed?? Slow Down No Nuvoton Confidential - 20 – 2017/7/25 Revision 1.45 NCT7904D 6.7.4 DTS (Sensor) Based Fan Control NCT7904D fully follows Intel latest DTS Based Thermal Spec to come out an easy used fan speed control algorithm which has involved traditional thermal cruise mode concept. Users are supposed to have related document to capture Intel’s concept. The principle of DTS based fan control behavior will be described with the figure in the below. First of all, there are two mainly behaviors, which is distinguished by whether Tsensor is larger than Tcontrol_spec. If Tcontrol_spec is larger than Tsensor, the fan control behavior will obey left plane and thermal cruise mode’s Target_Temp is set as Target_Reg. Once Tsensor > Target_Reg, the fan out duty will continuously increases by one duty until Tsensor is under Target_Reg. In contrary, if Tsensor < (Target_Reg – Tolerance), the fan out duty will continuously decreases by one duty until Tsensor is over (Target_Reg – Tolerance). If Tcontrol_spec is smaller than Tsensor, the fan control behavior will obey right plane and thermal cruise mode’s Target_Temp is set as TDTS which just is Intel’s DTS thermal profile. Once Tsensor > TDTS, the fan out duty will continuously increases by (1+|M|) duty until Tsensor is under TDTS. The symbol of M represents “Margin”. It could be provided by NCT7904D itself. In contrary, if Tsensor < (TDTS – Tolerance), the fan out duty will continuously decreases by (1+|M|) duty until Tsensor is over (TDTS – Tolerance). For both of plane, the gray region means that the fan out duty is unchanged at this moment. Tsensor +1+|M|, +1+|M|, +1+|M|, … or +1+|M|/2, +1+|M|/2, +1+|M|/2, … +1, +1, +1, ... Target_Temp TDTS Keep Fan Target_Reg Tolerance -1, -1, -1, ... Tcontrol_spec > Tsensor => Target_Temp = Target_Reg -1-|M|, -1-|M|, -1-|M|, … or -1-|M|/2, -1-|M|/2, -1-|M|/2, … Tsensor > Tcontrol_spec => Target_Temp = TDTS Thermal Cruise Mode Nuvoton Confidential - 21 – 2017/7/25 Revision 1.45 NCT7904D 6.8 PECI PECI (Platform Environment Control Interface) is a new digital interface to read plentiful information of Intel® CPUs. With a bandwidth ranging from 2 Kbps to 2 Mbps, PECI uses a single wire for self-clocking and data transfer. 6.8.1 Operation Mode NCT7904D provides two operation modes. One is active mode, the other is passive. For active mode, NCT7904D serves as a host to initiate a message transaction. NCT7904D provides automatic polling procedure for CPU temperature, CPU power and DRAM temperature. These thermal data could be continuously updated without any firmware intervention. In contrarily, except for what mentioned above, user still could write out or read in data to / from CPU by practicing manual commands which are pre-configured by external firmware. In passive mode, NCT7904D just monitor the message over the PECI bus with silence and then only extract CPU’s DTS thermal data for its fan speed control purpose. 6.8.2 CPU Temperature and Power Reporting In NCT7904D, it supports CPU temperature and power reporting. And both of reading could be associated to NCT7904D’s fan control algorithm. ® For CPU temperature, by interfacing to the Digital Thermal Sensor (DTS) in the Intel CPU, PECI reports a negative temperature (in counts) relative to the processor’s temperature at which the thermal control circuit (TCC) is activated. At the TCC Activation temperature, the Intel CPU will operate at reduced performance to prevent the device from thermal damage. The PECI temperature values returning from the CPU are in “counts” which are approximately linear in relation to changes in temperature in degrees centigrade. However, this linearity is approximate and cannot be guaranteed over the entire range of PECI temperatures. For further information, refer to the PECI specification. However NCT7904D has a biasing factor for customer to characterize the relation between “counts” and “temperature”. Figure A shows a typical fan speed (PWM duty cycle) and PECI temperature relationship. SMART TM FAN IV Fan Speed (PWM Duty Cycle) Tcontrol TCC Activation Duty1 Duty2 -20 -10 0 PECI Temperature (counts) Fig. A PECI Temperature Nuvoton Confidential - 22 – 2017/7/25 Revision 1.45 NCT7904D In this illustration, when PECI temperature is -20, the PWM duty cycle for fan control is at Duty2. When CPU is getting hotter and the PECI temperature is -10, the PWM duty cycle is at Duty1. At Tcontrol PECI temperature, the recommendation from Intel is to operate the CPU fan at full speed. Therefore Duty1 is 100% if this recommendation is followed. The value of Tcontrol can be obtained by reading the related Machine Specific Register (MSR) in the Intel CPU. The Tcontrol MSR address is usually in the BIOS Writer’s guide for the CPU family in question. Refer to the relevant CPU documentation from Intel for more information. In this example, Tcontrol is -10. When the PECI temperature is below -20, the duty cycle is fixed at Duty2 to maintain a minimum (and constant) RPM for the CPU fan. For CPU power reporting, the NCT7904D routinely retrieves CPU energy and then convert it to power. The refreshing rate of power is 0.3 sec. In order to minimize the effect of suddenly huge power changing, the running time average algorithm has been implemented. 6.8.3 DRAM Thermal Data Reporting NCT7904D can automatically report all 24 DIMMs thermal status which are provided by Intel CPU0 and CPU1 agent. In addition to each DIMM temperature, NCT7904D also records the highest DIMM temperature in the specific channel. Here is the relationship among CPU, Channel and DIMM. Both the Channel Index and DIMM Index follow PECI3.0 RdPkgConfig() command format. Agent Address Channel_Index Channel_0 Channel_1 CPU0_30h Channel_2 Channel_3 Channel_0 CPU1_31h Channel_1 Channel_2 Nuvoton Confidential DIMM Index Register Location DIMM_0 T_D0C0_C0 DIMM_1 T_D1C0_C0 DIMM_2 T_D2C0_C0 DIMM_0 T_D0C1_C0 DIMM_1 T_D1C1_C0 DIMM_2 T_D2C1_C0 DIMM_0 T_D0C2_C0 DIMM_1 T_D1C2_C0 DIMM_2 T_D2C2_C0 DIMM_0 T_D0C2_C0 DIMM_1 T_D1C2_C0 DIMM_2 T_D2C2_C0 DIMM_0 T_D0C0_C1 DIMM_1 T_D1C0_C1 DIMM_2 T_D2C0_C1 DIMM_0 T_D0C1_C1 DIMM_1 T_D1C1_C1 DIMM_2 T_D2C1_C1 DIMM_0 T_D0C2_C1 DIMM_1 T_D1C2_C1 DIMM_2 T_D2C2_C1 - 23 – 2017/7/25 Revision 1.45 NCT7904D Agent Address Channel_Index Channel_3 6.8.4 DIMM Index Register Location DIMM_0 T_D0C3_C1 DIMM_1 T_D1C3_C1 DIMM_2 T_D2C3_C1 PECI Listening It provides another way to obtain CPU’s DTS thermal data. NCT7904D only recognizes GetTemp() command. Once GetTemp() appears on PECI bus and entire message is without FCS error, the CPU’s DTS temperature will be extracted and recorded. These data could be temperature source of fan speed control. Nuvoton Confidential - 24 – 2017/7/25 Revision 1.45 NCT7904D 6.9 SMI# Output 6.9.1 Temperature SMI# for temperature monitoring provides 3 modes. 6.9.1.1. Comparator Interrupt Mode Temperature exceeding Twarning causes an interrupt and this interrupt will be reset when reading all of the Interrupt Status Registers. Once an interrupt event has occurred by exceeding Twarning, then reset, if the temperature remains above the Twarning Hysteresis, the interrupt will occur again when the next conversion has completed. If an interrupt event has occurred by exceeding Twarning and not reset, the interrupts will not occur again. The interrupts will continue to occur in this manner until the temperature goes below Twarning Hysteresis. 6.9.1.2. Two-Times Interrupt Mode Temperature exceeding Tcritical / Twarning causes an interrupt and then temperature going below Tcritical Hysteresis / Twarning Hysteresis will also cause an interrupt if the previous interrupt has been reset by reading all the Interrupt Status Register. Once an interrupt event has occurred by exceeding Tcritical / Twarning, then reset, if the temperature remains above the Tcritical Hysteresis / Twarning Hysteresis, the interrupt will not occur. 6.9.1.3. One-Time Interrupt Mode Temperature exceeding Tcritical / Twarning causes an interrupt and then temperature going below Tcritical Hysteresis / Twarning Hysteresis will not cause an interrupt. Once an interrupt event has occurred by exceeding Tcritical / Twarning, then going below Tcritical Hysteresis / Twarning Hysteresis, an interrupt will not occur again until the temperature exceeding Tcritical / Twarning. Nuvoton Confidential - 25 – 2017/7/25 Revision 1.45 NCT7904D SMI comparator mode SMI two time mode SMI one time mode Nuvoton Confidential - 26 – 2017/7/25 Revision 1.45 NCT7904D 6.9.2 Voltage SMI# interrupt for voltage is Two-Times Interrupt Mode. Voltage exceeds high limit or going below low limit, it will causes an interrupt if the previous interrupt has been reset by reading all the interrupt Status Register. 6.9.3 Fan SMI# interrupt for fan is Two-Times Interrupt Mode. Fan count exceeds the limit, or exceeding and then going below the limit, it will cause an interrupt if the previous interrupt has been reset by reading all the interrupt Status Register. Nuvoton Confidential - 27 – 2017/7/25 Revision 1.45 NCT7904D 6.10 EEPROM Self-Initialization 6.10.1 EEPROM Format The content of the EEPROM can be loaded to the registers of NCT7904D for self-initialization should obey this data format. An example for Default Fan Speed set to FF(hex) in bank 2 : Address Data Example 00h ID_1 79h 01h ID_2 61h 02h Register Address 1 FFh 03h Register Data 1 02h 04h Register Address 2 04h 05h Register Data 2 FFh … … … … … … ID_1 79h ID_2 61h 6.10.2 Chip Initialization When NCT7904D detects power-on-reset, initialization process will start loading data from EEPROM. NCT7904D SMBUS (M_SMB_CLK, M_SMB_DATA) will be a master and issue consecutive read byte commands (EEPROM address is A0h). NCT7904D will check receive data to decide that which actions should be followed. Case 1 : No acknowledge in first transaction, NCT7904D will terminate the initialization process to normal. And set LD_FAIL and LD_FINISH to 1 to note host the load status. Case 2 : NCT7904D will check first two bytes by ID_1 and ID_2. If match, the process will continue. Otherwise, the process will terminate like Case 1. Case 3 : Two bytes as a unit. NCT7904D will see first as the address of the register and second as the data. Sequentially, NCT7904D will write the data to the specific address. Case 4 : When receiving the unit which store the data (ID_2 following ID_1), NCT7904D will stop initialization and back to normal and set LD_FAIL to 0 and LD_FINISH to 1 to note host the load status. Otherwise, the access will keep going. The EEPROM loading would be started from NCT7904D power-on immediately, when implements the EEPROM self-initialization, the requested 3VSB power rising time must less than 60uS. Note: 1. LD_FAIL and LD_FINISH are in address 00h in bank 0. Nuvoton Confidential - 28 – 2017/7/25 Revision 1.45 NCT7904D 6.11 PCH Thermal Data Report 6.11.1 PCH Thermal Read When enable PCH read function (set EN_PCH_RD to 1), NCT7904D SMBUS (M_SMB_CLK, M_SMB_DATA) will be a master and issue consecutive block read commands (PCH address can be configuration). NCT7904D will store the received data to the registers (F0h~FDh in bank 0) by PCH data format. 6.11.2 PCH Thermal Data Format The PCH Thermal data may appear in either Byte 0 or Byte 1 depending on the specific ME firmware in use. Please contact Intel directly for information on your specific ME Firmware implementation. 6.12 SMBus Master Auto Read External Thermal Sensor 6.12.1 External Thermal Sensor Setting Before using this function, there are several registers must be set: 1. Configuration external sensor SMBus address and command where temperature store in. (6Ch ~ 73h in bank 2). 2. Set relative port enable and enable external temperature read (6Ah in bank 2). 6.12.2 Temperature Read Process After proper setting, NCT7904D will auto read, by setting, external sensor temperature from SMBus master I/F. The read temperature will be stored in the registers (BCh ~ BFh in bank 0), respectively. These temperatures can be the sources of the fan controller in NCT7904D. Any not enable port can normally be the virtual temperature simply written by host to do advanced fan control. 6.13 PROCHOT# Behavior 6.13.1 PROCHOT# Input When enable PROCHOT# input monitor function (set EN_PH1 to 1 in bank 0, PH1_MD to 1 in bank 1), NCT7904D will monitor P1_PROCHOT# pin, count the time between two falling edge as P1_PROCHOT#_DVAL[7:0] and the time between one rising edge to one falling edge P1_PROCHOT#_NVAL[7:0], and stores these two to the registers. System management can monitor these two values to know the thermal status for relative CPU. The timer to the counter is settable from register, and the default is 22us. 6.13.2 PROCHOT# Output When enable PROCHOT# output function (set EN_PH1 to 1 in bank 0, PH1_MD to 0 in bank 1), NCT7904D will drive low to P1_PROCHOT# pin based on several thermal events over heat. There are three temperature sources listed as blow, Source 1 : 4 remote temperature inputs or build-in thermal diode temperature Source 2 : Up to 8 CPU temperatures Source 3 : Up to 4 CPU Powers (by PECI) The frequency and duty cycle of PROCHOT# output are settable by PH1_FSEL[1:0] and PH1_DC[3:0], respectively. Nuvoton Confidential - 29 – 2017/7/25 Revision 1.45 NCT7904D 6.14 LED Behavior 6.14.1 Event Trigger LED When enable LED function (set EN_E_LED to 1), NCT7904D will detect LED_EVNT_IN# pin as the drive condition for LED_OUT. LED pin will be float when LED_EVNT_IN# pin is detected high, and LED pin will drive low when LED_EVNT_IN# is detected low. LED driving low frequency and polarity can be settable. 6.14.2 Programmable LED When enable programmable LED function (set EN_P_LED to 1), NCT7904D will drive register data P_LED_DATA to LED pin. Drive low frequency and polarity can be settable. 6.15 BEEP Function 6.15.1 Output Signaling Output signaling for BEEP is controlled by an internal signal mixer. The baseband signal is a period signal which is at frequency 1Hz with duty cycle 50% (i.e. the period for high and low level is 500ms.) The high level of the baseband signal will mix the signal which is at frequency 700Hz with duty cycle 50%, and the low level of the baseband signal will mix the signal which is at frequency 350Hz with duty cycle 50%, causing the ambulance sound for alarm to users. 6.15.2 BEEP Activation When enable BEEP function (set EN_BEEP to 1), NCT7904D will drive the signal to BEEP pin when BEEP sources selected and over limitation. Otherwise, NCT7904D will float the pin. The sources are defined in relative registers. 6.16 THERMTRIP# Function 6.16.1 Power by VSB When enable THERMTRIP function (set EN_THRM to 1), NCT7904D will detect low and log the signal to THRM_STS register. The THRM_STS register will be cleared by setting the CLR_THRM register to 1 and the CLR_THRM will be auto cleared. 6.16.2 Power Only by VBAT NCT7904D will keep the THRM_STS register when VBAT power-on, losing the data when VBAT power-off. Nuvoton Confidential - 30 – 2017/7/25 Revision 1.45 NCT7904D 7. REGISTER DESCRIPTION 7.1 Bank 0 REGISTER DETAIL 7.1.1 Global Control Register Location: Bank 0 Address 00HEX Type: Read/Write Reset: Power On Reset Default Value: 01HEX BIT DESCRIPTION 7 INIT_RST Registers initial reset (Auto be cleared when reset process completed) 6 Reserved 5 LD_FAIL 0 = EEPROM present and no error happened 1 = EEPROM not present or error happened 4 LD_FINISH 0 = EEPROM data load processing 1 = EEPROM data load finished 3 LOCK 0 = RESETIN# will reset registers 1 = RESETIN# will not reset registers (This bit will be also cleared when set INIT_RST) 2 Reserved 1-0 CLKIN_SEL[1:0] 00BIN = 14.318MHz 01BIN = 33MHz (default) 10BIN = 48MHz 11BIN = Reserved 7.1.2 SMB Slave Address Register Location: Bank 0 Address 0CHEX Type: Read Only Reset: Power On Reset Default Value: 5AHEX/5CHEX BIT 7-0 DESCRIPTION SMB_SLV_ADDR[7:0] 5AHEX = ADDR pin strapped low 5CHEX = ADDR pin strapped high Nuvoton Confidential - 31 – 2017/7/25 Revision 1.45 NCT7904D 7.1.3 Nuvoton Vendor ID Register Location: Bank 0 Address 0DHEX Type: Read Only Reset: Power On Reset Default Value: 50HEX BIT 7-0 DESCRIPTION VENDOR_ID[7:0] 7.1.4 Nuvoton Chip ID Register Location: Bank 0 Address 0EHEX Type: Read Only Reset: Power On Reset Default Value: C5HEX BIT 7-0 DESCRIPTION CHIP_ID[7:0] 7.1.5 Nuvoton Device ID Register Location: Bank 0 Address 0FHEX Type: Read Only Reset: Power On Reset Default Value: 5xHEX BIT 7-0 DESCRIPTION DEVICE_ID[7:0] 7.1.6 Programmable LED Register Location: Bank 0 Address 18HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 4-3 EN_P_LED 0 = Disable 1 = Enable P_LED_POL 0 = LED output active low 1 = LED output active high P_LED_DATA 0 = Output don’t drive 1 = Output drive Reserved 2-0 P_LED_FSEL[2:0] 7 6 5 Nuvoton Confidential - 32 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 000BIN = 4Hz 001BIN = 2Hz 010BIN = 1Hz 011BIN = 0.5Hz 100BIN = 0.25Hz 101BIN = 0.125Hz 110BIN = 0.0625Hz 111BIN = 0Hz 7.1.7 Event Control LED Register Location: Bank 0 Address 19HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 7 EN_E_LED 0 = Disable 1 = Enable (LED_OUT will controlled by LED_EVNT_IN#) 6 E_LED_POL 0 = LED output active low 1 = LED output active high 5-3 Reserved 2-0 E_LED_FSEL[2:0] 000BIN = 4Hz 001BIN = 2Hz 010BIN = 1Hz 011BIN = 0.5Hz 100BIN = 0.25Hz 101BIN = 0.125Hz 110BIN = 0.0625Hz 111BIN = 0Hz 7.1.8 Monitor Enable Control Register Location: VT_ADC_CTRL0 VT_ADC_CTRL1 VT_ADC_CTRL2 PH_CTRL0 FANIN_CTRL0 FANIN_CTRL1 DTS_T_CTRL0 DTS_T_CTRL1 DTS_P_CTRL0 Nuvoton Confidential - Bank 0 Address 20HEX - Bank 0 Address 21HEX - Bank 0 Address 22HEX - Bank 0 Address 23HEX - Bank 0 Address 24HEX - Bank 0 Address 25HEX - Bank 0 Address 26HEX - Bank 0 Address 27HEX - Bank 0 Address 28HEX - 33 – 2017/7/25 Revision 1.45 NCT7904D Type: Reset: Read / Write Power On Reset RESETIN# with LOCK=0 VT_ADC_CTRL0 – Voltage Temperature Monitoring Control Register Location: Bank 0 Address 20HEX Default Value: FFHEX BIT DESCRIPTION 7 EN_VSEN8 – Enable VSEN8 voltage monitoring. 0 = Disable 1 = Enable 6 EN_VSEN7 – Enable VSEN7 voltage monitoring. 0 = Disable 1 = Enable 5 EN_VSEN6 – Enable VSEN6 voltage monitoring. 0 = Disable 1 = Enable 4 EN_VSEN5 – Enable VSEN5 voltage monitoring. 0 = Disable 1 = Enable 3 EN_VSEN4 – Enable VSEN4 voltage monitoring. 0 = Disable 1 = Enable 2 EN_VSEN3 – Enable VSEN3 voltage monitoring. 0 = Disable 1 = Enable 1 EN_VSEN2 – Enable VSEN2 voltage monitoring. 0 = Disable 1 = Enable 0 EN_VSEN1 – Enable VSEN1 voltage monitoring. 0 = Disable 1 = Enable VT_ADC_CTRL1 – Voltage Temperature Monitoring Control Register Location: Bank 0 Address 21HEX Default Value: 7FHEX BIT DESCRIPTION 7 EN_VBAT – Enable VBAT voltage monitoring. 0 = Disable 1 = Enable 6 EN_3VDD – Enable 3VDD voltage monitoring. 0 = Disable 1 = Enable 5 EN_VSEN14 – Enable VSEN14 voltage monitoring. 0 = Disable Nuvoton Confidential - 34 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 = Enable 4 EN_VSEN13 – Enable VSEN13 voltage monitoring. 0 = Disable 1 = Enable 3 EN_VSEN12 – Enable VSEN12 voltage monitoring. 0 = Disable 1 = Enable 2 EN_VSEN11 – Enable VSEN11 voltage monitoring. 0 = Disable 1 = Enable 1 EN_VSEN10 – Enable VSEN10 voltage monitoring. 0 = Disable 1 = Enable 0 EN_VSEN9 – Enable VSEN9 voltage monitoring. 0 = Disable 1 = Enable VT_ADC_CTRL2 – Voltage Temperature Monitoring Control Register Location: Bank 0 Address 22HEX Default Value: 03HEX BIT 7-5 DESCRIPTION Reserved 4 EN_VSEN19 – Enable VSEN19 voltage monitoring. 0 = Disable (This pin will change to PWM4/DCOUT) 1 = Enable 3 EN_VSEN18 – Enable VSEN18 voltage monitoring. 0 = Disable (This pin will change to PWM3) 1 = Enable 2 EN_VSEN17 – Enable VSEN17 voltage monitoring. 0 = Disable (This pin will change to WDT_RSTOUT#/GPIOG) 1 = Enable 1 EN_LTD – Enable local temperature monitoring. 0 = Disable 1 = Enable 0 EN_V3VSB – Enable V3VSB voltage monitoring. 0 = Disable 1 = Enable Nuvoton Confidential - 35 – 2017/7/25 Revision 1.45 NCT7904D PH_CTRL0 – PROCHOT Monitoring Control Register Location: Bank 0 Address 23HEX Default Value: 01HEX BIT 7-1 0 DESCRIPTION Reserved EN_PH1 – Enable P1_PROCHOT# monitoring. 0 = Disable 1 = Enable FANIN_CTRL0 – FANIN Monitoring Control Register Location: Bank 0 Address 24HEX Default Value: FFHEX BIT DESCRIPTION 7 EN_FANIN_8 – Enable FANIN_8 monitoring. 0 = Disable 1 = Enable 6 EN_FANIN_7 – Enable FANIN_7 monitoring. 0 = Disable 1 = Enable 5 EN_FANIN_6 – Enable FANIN_6 monitoring. 0 = Disable 1 = Enable 4 EN_FANIN_5 – Enable FANIN_5 monitoring. 0 = Disable 1 = Enable 3 EN_FANIN_4 – Enable FANIN_4 monitoring. 0 = Disable 1 = Enable 2 EN_FANIN_3 – Enable FANIN_3 monitoring. 0 = Disable 1 = Enable 1 EN_FANIN_2 – Enable FANIN_2 monitoring. 0 = Disable 1 = Enable 0 EN_FANIN_1 – Enable FANIN_1 monitoring. 0 = Disable 1 = Enable Nuvoton Confidential - 36 – 2017/7/25 Revision 1.45 NCT7904D FANIN_CTRL1 – FANIN Monitoring Control Register Location: Bank 0 Address 25HEX Default Value: 03HEX BIT 7-4 DESCRIPTION Reserved 3 EN_FANIN_12 – Enable FANIN_12 monitoring. 0 = Disable 1 = Enable 2 EN_FANIN_11 – Enable FANIN_11 monitoring. 0 = Disable 1 = Enable 1 EN_FANIN_10 – Enable FANIN_10 monitoring. 0 = Disable 1 = Enable 0 EN_FANIN_9 – Enable FANIN_9 monitoring. 0 = Disable 1 = Enable DTS_T_CTRL0 – Digital Temperature Monitoring Control Register Location: Bank 0 Address 26HEX Default Value: 0FHEX BIT 7-4 DESCRIPTION Reserved 3 EN_TCPU4 – Enable DTS CPU4 temperature monitoring (PECI/TSI). 0 = Disable 1 = Enable 2 EN_TCPU3 – Enable DTS CPU3 temperature monitoring (PECI/TSI). 0 = Disable 1 = Enable 1 EN_TCPU2 – Enable DTS CPU2 temperature monitoring (PECI/TSI). 0 = Disable 1 = Enable 0 EN_TCPU1 – Enable DTS CPU1 temperature monitoring (PECI/TSI). 0 = Disable 1 = Enable DTS_T_CTRL1 – Digital Temperature Monitoring Control Register Location: Bank 0 Address 27HEX Default Value: 0FHEX BIT 7-4 DESCRIPTION Reserved 3 EN_TCPU8 – Enable DTS CPU8 temperature monitoring (TSI). 0 = Disable 1 = Enable 2 EN_TCPU7 – Enable DTS CPU7 temperature monitoring (TSI). Nuvoton Confidential - 37 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 0 = Disable 1 = Enable 1 EN_TCPU6 – Enable DTS CPU6 temperature monitoring (TSI). 0 = Disable 1 = Enable 0 EN_TCPU5 – Enable DTS CPU5 temperature monitoring (TSI). 0 = Disable 1 = Enable DTS_P_CTRL0 – Digital Power Monitoring Control Register Location: Bank 0 Address 28HEX Default Value: 0FHEX BIT 7-4 DESCRIPTION Reserved 3 EN_PCPU4 – Enable DTS CPU4 power monitoring (PECI). 0 = Disable 1 = Enable 2 EN_PCPU3 – Enable DTS CPU3 power monitoring (PECI). 0 = Disable 1 = Enable 1 EN_PCPU2 – Enable DTS CPU2 power monitoring (PECI). 0 = Disable 1 = Enable 0 EN_PCPU1 – Enable DTS CPU1 power monitoring (PECI). 0 = Disable 1 = Enable 7.1.9 Monitor Configuration Register Location: VT_ADC_VOL_PO - Bank 0 Address 2CHEX VT_ADC_LTD_PO - Bank 0 Address 2DHEX VT_ADC_MD - Bank 0 Address 2EHEX VT_ADC_PO0 - Bank 0 Address 2FHEX VT_ADC_PO1 - Bank 0 Address 30HEX VT_ADC_PO2 - Bank 0 Address 31HEX VT_ADC_PO3 - Bank 0 Address 32HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 VT_ADC_VOL_PO – Voltage Post Offset Register Location: Bank 0 Address 2CHEX Default Value: 00HEX Nuvoton Confidential - 38 – 2017/7/25 Revision 1.45 NCT7904D BIT 7-0 DESCRIPTION VT_ADC_VOL_PO[7:0] Post offset adjustment in voltage VT_ADC_LTD_PO – LTD Temperature Post Offset Register Location: Bank 0 Address 2DHEX Default Value: 00HEX BIT 7-0 DESCRIPTION VT_ADC_LTD_PO[7:0] Post offset adjustment in LTD temperature VT_ADC_MD – Voltage Temperature Mode Control Register Location: Bank 0 Address 2EHEX Default Value: 00HEX BIT 7-6 5-4 3-2 1-0 DESCRIPTION VSEN89_MD[1:0] 00BIN = Voltage monitoring 01BIN = Reserved 10BIN = Reserved 11BIN = Temperature monitoring (thermistor) When set to thermistor mode, the Pin.8 will be TR4 function, function. VSEN67_MD[1:0] 00BIN = Voltage monitoring 01BIN = Reserved 10BIN = Reserved 11BIN = Temperature monitoring (thermistor) When set to thermistor mode, the Pin.6 will be TR3 function, function. VSEN45_MD[1:0] 00BIN = Voltage monitoring 01BIN = Temperature monitoring (thermal diode current mode) 10BIN = Reserved 11BIN = Temperature monitoring (thermistor) When set to thermistor mode, the Pin.4 will be TR2 function, function. VSEN23_MD[1:0] 00BIN = Voltage monitoring 01BIN = Temperature monitoring (thermal diode current mode) 10BIN = Reserved 11BIN = Temperature monitoring (thermistor) When set to thermistor mode, the Pin.2 will be TR1 function, function. Nuvoton Confidential - 39 – the Pin.9 will be VSEN9 the Pin.7 will be VSEN7 the Pin.5 will be VSEN5 the Pin.3 will be VSEN3 2017/7/25 Revision 1.45 NCT7904D VT_ADC_PO0 – Voltage Temperature Post Offset Register Location: Bank 0 Address 2FHEX Default Value: 00HEX BIT 7-0 DESCRIPTION VSEN23_PO[7:0] Post offset adjustment when VSEN23_MD[1:0] in temperature mode VT_ADC_PO1 – Voltage Temperature Post Offset Register Location: Bank 0 Address 30HEX Default Value: 00HEX BIT 7-0 DESCRIPTION VSEN45_PO[7:0] Post offset adjustment when VSEN45_MD[1:0] in temperature mode VT_ADC_PO2 – Voltage Temperature Post Offset Register Location: Bank 0 Address 31HEX Default Value: 00HEX BIT 7-0 DESCRIPTION VSEN67_PO[7:0] Post offset adjustment when VSEN67_MD[1:0] in temperature mode VT_ADC_PO3 – Voltage Temperature Post Offset Register Location: Bank 0 Address 32HEX Default Value: 00HEX BIT 7-0 DESCRIPTION VSEN89_PO[7:0] Post offset adjustment when VSEN89_MD[1:0] in temperature mode Nuvoton Confidential - 40 – 2017/7/25 Revision 1.45 NCT7904D 7.1.10 Voltage Channel and Temperature Monitored Value Register Location: VSEN1_HV VSEN1_LV VSEN2_HV / TEMP_CH1_HV VSEN2_LV / TEMP_CH1_LV VSEN3_HV VSEN3_LV VSEN4_HV / TEMP_CH2_HV VSEN4_LV / TEMP_CH2_LV VSEN5_HV VSEN5_LV VSEN6_HV / TEMP_CH3_HV VSEN6_LV / TEMP_CH3_LV VSEN7_HV VSEN7_LV VSEN8_HV / TEMP_CH4_HV VSEN8_LV / TEMP_CH4_LV VSEN9_HV VSEN9_LV VSEN10_HV VSEN10_LV VSEN11_HV VSEN11_LV VSEN12_HV VSEN12_LV VSEN13_HV VSEN13_LV VSEN14_HV VSEN14_LV 3VDD_HV 3VDD_LV VBAT_HV VBAT_LV V3VSB_HV V3VSB_LV LTD_HV LTD_LV VSEN17_HV VSEN17_LV VSEN18_HV VSEN18_LV VSEN19_HV VSEN19_LV Nuvoton Confidential - Bank 0 Address 40HEX - Bank 0 Address 41HEX - Bank 0 Address 42HEX - Bank 0 Address 43HEX - Bank 0 Address 44HEX - Bank 0 Address 45HEX - Bank 0 Address 46HEX - Bank 0 Address 47HEX - Bank 0 Address 48HEX - Bank 0 Address 49HEX - Bank 0 Address 4AHEX - Bank 0 Address 4BHEX - Bank 0 Address 4CHEX - Bank 0 Address 4DHEX - Bank 0 Address 4EHEX - Bank 0 Address 4FHEX - Bank 0 Address 50HEX - Bank 0 Address 51HEX - Bank 0 Address 52HEX - Bank 0 Address 53HEX - Bank 0 Address 54HEX - Bank 0 Address 55HEX - Bank 0 Address 56HEX - Bank 0 Address 57HEX - Bank 0 Address 58HE - Bank 0 Address 59HEX X - Bank 0 Address 5AHEX - Bank 0 Address 5BHEX - Bank 0 Address 5CHEX - Bank 0 Address 5DHEX - Bank 0 Address 5EHEX - Bank 0 Address 5FHEX - Bank 0 Address 60HEX - Bank 0 Address 61HEX - Bank 0 Address 62HEX - Bank 0 Address 63HEX - Bank 0 Address 64HEX - Bank 0 Address 65HEX - Bank 0 Address 66HEX - Bank 0 Address 67HEX - Bank 0 Address 68HEX - Bank 0 Address 69HEX - 41 – 2017/7/25 Revision 1.45 NCT7904D Type: Reset: Read Only Power On Reset VOLTAGE HIGH VALUE BIT 7 NAME 6 5 4 3 2 1 0 2 1 0 Voltage High Value 11-bit voltage value bit[10:3] VOLTAGE LOW VALUE BIT 7 6 NAME 5 4 3 Reserved Voltage Low Value 11-bit voltage value bit[2:0] TEMPERATURE HIGH VALUE BIT 7 NAME 6 5 4 3 2 1 0 Temperature High Value. The real temperature value calculation is referred to Temperature Monitor Data Format description. 11-bit 2’s complement bit[10:3] VALUE SIGN 64 32 16 8 4 2 1 2 1 0 TEMPERATURE LOW VALUE BIT 7 6 5 NAME Reserved VALUE Reserved 7.1.11 4 3 Temperature Low Value 11-bit 2’s complement bit[2:0] 0.5 0.25 0.125 PROCHOT Monitored Value Register Location: P1_PH_NV - Bank 0 Address 70HEX P1_PH_DV - Bank 0 Address 71HEX Type: Read Only Reset: Power On Reset P1_PH_NV – CPU1 PROCHOT# Numerator Value Register Location: Bank 0 Address 70HEX Default Value: N/A BIT 7-0 DESCRIPTION P1_PROCHOT#_NVAL[7:0] CPU1 PROCHOT# Numerator Value P1_PH_DV – CPU1 PROCHOT# Denominator Value Register Location: Bank 0 Address 71HEX Default Value: N/A BIT 7-0 DESCRIPTION P1_PROCHOT#_DVAL[7:0] CPU1 PROCHOT# Denominator Value Nuvoton Confidential - 42 – 2017/7/25 Revision 1.45 NCT7904D 7.1.12 Nuvoton Vendor ID Register Location: Bank X Address 7AHEX Type: Read Only Reset: Power On Reset Default Value: 50HEX BIT DESCRIPTION 7-0 VENDOR_ID[7:0] Duplicate of data found in Bank 0 Address 0Dh. Data at Address 7Ah is available in all Bank Settings. 7.1.13 Nuvoton Chip ID Register Location: Bank X Address 7BHEX Type: Read Only Reset: Power On Reset Default Value: C5HEX BIT DESCRIPTION 7-0 CHIP_ID[7:0] Duplicate of data found in Bank 0 Address 0Eh. Data at Address 7Bh is available in all Bank Settings. 7.1.14 Nuvoton Device ID Register Location: Bank X Address 7CHEX Type: Read Only Reset: Power On Reset Default Value: 5xHEX BIT DESCRIPTION 7-0 DEVICE_ID[7:0] Duplicate of data found in Bank 0 Address 0Fh. Data at Address 7Ch is available in all Bank Settings. 7.1.15 FAN Tachometer Monitored Value Register Location: FANIN1_HV FANIN1_LV FANIN2_HV FANIN2_LV FANIN3_HV FANIN3_LV FANIN4_HV FANIN4_LV FANIN5_HV FANIN5_LV FANIN6_HV FANIN6_LV FANIN7_HV Nuvoton Confidential - Bank 0 Address 80HEX - Bank 0 Address 81HEX - Bank 0 Address 82HEX - Bank 0 Address 83HEX - Bank 0 Address 84HEX - Bank 0 Address 85HEX - Bank 0 Address 86HEX - Bank 0 Address 87HEX - Bank 0 Address 88HEX - Bank 0 Address 89HEX - Bank 0 Address 8AHEX - Bank 0 Address 8BHEX - Bank 0 Address 8CHEX - 43 – 2017/7/25 Revision 1.45 NCT7904D FANIN7_LV - Bank 0 Address 8DHEX FANIN8_HV - Bank 0 Address 8EHEX FANIN8_LV - Bank 0 Address 8FHEX FANIN9_HV - Bank 0 Address 90HEX FANIN9_LV - Bank 0 Address 91HEX FANIN10_HV - Bank 0 Address 92HEX FANIN10_LV - Bank 0 Address 93HEX FANIN11_HV - Bank 0 Address 94HEX FANIN11_LV - Bank 0 Address 95HEX FANIN12_HV - Bank 0 Address 96HEX FANIN12_LV - Bank 0 Address 97HEX Read Only Power On Reset Type: Reset: FANIN HIGH VALUE BIT 7 NAME 6 5 4 3 2 1 0 3 2 1 0 Fan Input Count High Value 13-bit fan count value bit[12:5] FANIN LOW VALUE BIT 7 6 NAME 7.1.16 Location: T_CPU1_HV T_CPU1_LV T_CPU2_HV T_CPU2_LV T_CPU3_HV T_CPU3_LV T_CPU4_HV T_CPU4_LV T_CPU5_HV T_CPU5_LV T_CPU6_HV T_CPU6_LV T_CPU7_HV T_CPU7_LV T_CPU8_HV T_CPU8_LV P_CPU1 P_CPU2 P_CPU3 P_CPU4 5 Reserved 4 Fan Input Count Low Value 13-bit fan count value bit[4:0] DTS Temperature Monitored Value Register - Bank 0 Address A0HEX - Bank 0 Address A1HEX - Bank 0 Address A2HEX - Bank 0 Address A3HEX - Bank 0 Address A4HEX - Bank 0 Address A5HEX - Bank 0 Address A6HEX - Bank 0 Address A7HEX - Bank 0 Address A8HEX - Bank 0 Address A9HEX - Bank 0 Address AAHEX - Bank 0 Address ABHEX - Bank 0 Address ACHEX - Bank 0 Address ADHEX - Bank 0 Address AEHEX - Bank 0 Address AFHEX - Bank 0 Address B0HEX - Bank 0 Address B1HEX - Bank 0 Address B2HEX - Bank 0 Address B3HEX Nuvoton Confidential - 44 – 2017/7/25 Revision 1.45 NCT7904D Type: Reset: Read/Write (Writable DTS Source Selection is host) Power On Reset TEMPERATURE HIGH VALUE BIT NAME VALUE 7 6 5 4 3 2 1 0 Temperature High Value. The real temperature value calculation is referred to Temperature Monitor Data Format description. 11-bit 2’s complement bit[10:3] (From PECI, TSI, or Host) SIGN 64 32 16 8 4 2 1 2 1 0 TEMPERATURE LOW VALUE BIT 7 6 5 NAME Reserved VALUE Reserved 4 3 Temperature Low Value 11-bit 2’s complement bit[2:0] (From PECI, TSI, or Host) 0.5 0.25 0.125 P_CPU1 – CPU1 Power Value Register Location: Bank 0 Address B0HEX Default Value: N/A BIT 7-0 DESCRIPTION POWER_CPU1[7:0] CPU1 Power Value (From PECI or Host) P_CPU2 – CPU2 Power Value Register Location: Bank 0 Address B1HEX Default Value: N/A BIT 7-0 DESCRIPTION POWER_CPU2[7:0] CPU2 Power Value (From PECI or Host) P_CPU3 – CPU3 Power Value Register Location: Bank 0 Address B2HEX Default Value: N/A BIT 7-0 DESCRIPTION POWER_CPU3[7:0] CPU3 Power Value (From PECI or Host) Nuvoton Confidential - 45 – 2017/7/25 Revision 1.45 NCT7904D P_CPU4 – CPU4 Power Value Register Location: Bank 0 Address B3HEX Default Value: N/A BIT 7-0 DESCRIPTION POWER_CPU4[7:0] CPU4 Power Value (From PECI or Host) 7.1.17 Virtual Temperature Value Register Location: VRT_TEMP1_V - Bank 0 Address B8HEX VRT_TEMP2_V - Bank 0 Address B9HEX VRT_TEMP3_V - Bank 0 Address BAHEX VRT_TEMP4_V - Bank 0 Address BBHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION VRT_TEMP1_V[7:0] Virtual Temperature 1 Value (It can be one of temperature sources for the FAN controller) BIT 7-0 DESCRIPTION VRT_TEMP2_V[7:0] Virtual Temperature 2 Value (It can be one of temperature sources for the FAN controller) BIT 7-0 DESCRIPTION VRT_TEMP3_V[7:0] Virtual Temperature 3 Value (It can be one of temperature sources for the FAN controller) BIT 7-0 DESCRIPTION VRT_TEMP4_V[7:0] Virtual Temperature 4 Value (It can be one of temperature sources for the FAN controller) Nuvoton Confidential - 46 – 2017/7/25 Revision 1.45 NCT7904D 7.1.18 External and Virtual Temperature Value Register Location: EXT_VRT_TEMP1_V - Bank 0 Address BCHEX EXT_VRT_TEMP2_V - Bank 0 Address BDHEX EXT_VRT_TEMP3_V - Bank 0 Address BEHEX EXT_VRT_TEMP4_V - Bank 0 Address BFHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION EXT_VRT_TEMP1_V[7:0] External Temperature 1 or Virtual Temperature 5 Value (It can be one of temperature sources for the FAN controller) BIT 7-0 DESCRIPTION EXT_VRT_TEMP2_V[7:0] External Temperature 2 or Virtual Temperature 6 Value (It can be one of temperature sources for the FAN controller) BIT 7-0 DESCRIPTION EXT_VRT_TEMP3_V[7:0] External Temperature 3 or Virtual Temperature 7 Value (It can be one of temperature sources for the FAN controller) BIT 7-0 DESCRIPTION EXT_VRT_TEMP4_V[7:0] External Temperature 4 or Virtual Temperature 8 Value (It can be one of temperature sources for the FAN controller) Nuvoton Confidential - 47 – 2017/7/25 Revision 1.45 NCT7904D 7.1.19 SMI Control Register Location: Bank 0 Address C0HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 10HEX BIT 7 6-5 4 3-2 DESCRIPTION RTSACS. 0 = Read Interrupt status from CRC1~CRCA. (Default) 1 = Read real-time status from CRC1~CRCA. Reserved. SMI_MD. 0 = SMI# outputs low level signal and active high. 1 = SMI# outputs 200 us low pulse signal. (Default) TEMP_SMI_MD. Temperature SMI Mode Select. 00BIN = Comparator Interrupt Mode. (Default) 01BIN = Two Time Interrupt Mode. 10BIN = One Time Interrupt Mode. 11BIN = Two Time Non-related Interrupt Mode. 1 EN_SMI. 0 = disable SMI# signal output. (Default) 1 = enable SMI# signal output. 0 SMI_POL. 0 = SMI# polarity follows SMI_MD. (Default) 1 = SMI# polarity is inverted. 7.1.20 SMI Status Register Location: SMI_STS1 - Bank 0 Address C1HEX SMI_STS2 - Bank 0 Address C2HEX SMI_STS3 - Bank 0 Address C3HEX SMI_STS4 - Bank 0 Address C4HEX SMI_STS5 - Bank 0 Address C5HEX SMI_STS6 - Bank 0 Address C6HEX SMI_STS7 - Bank 0 Address C7HEX SMI_STS8 - Bank 0 Address C8HEX SMI_STS9 - Bank 0 Address C9HEX SMI_STS10 - Bank 0 Address CAHEX Type: Read Only Reset: Power On Reset Nuvoton Confidential - 48 – 2017/7/25 Revision 1.45 NCT7904D SMI_STS1 BIT 7 6 5 4 3 2 1 0 NAME S_VSEN8 S_VSEN7 S_VSEN6 S_VSEN5 S_VSEN4 S_VSEN3 S_VSEN2 S_VSEN1 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS2 BIT 7 6 5 4 3 2 1 0 NAME S_VBAT S_3VDD S_VSEN1 4 S_VSEN1 3 S_VSEN1 2 S_VSEN1 1 S_VSEN1 0 S_VSEN9 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS3 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved S_VSEN1 9 S_VSEN1 8 S_VSEN1 7 S_LTD S_V3VSB DEFAULT 0 0 0 0 0 0 0 0 SMI_STS4 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved Reserved Reserved Reserved S_PH1 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS5 BIT 7 6 5 4 3 2 1 0 NAME S_FANIN 8 S_FANIN 7 S_FANIN 6 S_FANIN 5 S_FANIN 4 S_FANIN 3 S_FANIN 2 S_FANIN 1 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS6 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved S_FANIN 12 S_FANIN 11 S_FANIN 10 S_FANIN 9 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS7 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved S_TCPU4 S_TCPU3 S_TCPU2 S_TCPU1 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS8 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved S_TCPU8 S_TCPU7 S_TCPU6 S_TCPU5 DEFAULT 0 0 0 0 0 0 0 0 Nuvoton Confidential - 49 – 2017/7/25 Revision 1.45 NCT7904D SMI_STS9 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved S_PCPU4 S_PCPU3 S_PCPU2 S_PCPU1 DEFAULT 0 0 0 0 0 0 0 0 SMI_STS10 BIT 7 6 5 4 3 2 1 0 NAME Reserved S_CHAS SIS Reserved Reserved S_TART4 S_TART3 S_TART2 S_TART1 DEFAULT 0 0 0 0 0 0 0 0 *TART: When the Smart fan is driving the fan in full speed over 3 minutes, the TART will be asserted. 7.1.21 SMI Mask Register Location: SMI_MSK1 - Bank 0 Address CBHEX SMI_MSK2 - Bank 0 Address CCHEX SMI_MSK3 - Bank 0 Address CDHEX SMI_MSK4 - Bank 0 Address CEHEX SMI_MSK5 - Bank 0 Address CFHEX SMI_MSK6 - Bank 0 Address D0HEX SMI_MSK7 - Bank 0 Address D1HEX SMI_MSK8 - Bank 0 Address D2HEX SMI_MSK9 - Bank 0 Address D3HEX SMI_MSK10 - Bank 0 Address D4HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 SMI_MSK1 BIT 7 6 5 4 3 2 1 0 NAME M_VSEN 8 M_VSEN 7 M_VSEN 6 M_VSEN 5 M_VSEN 4 M_VSEN 3 M_VSEN 2 M_VSEN 1 DEFAULT 1 1 1 1 1 1 1 1 SMI_MSK2 BIT 7 6 5 4 3 2 1 0 NAME M_VBAT M_3VDD M_VSEN 14 M_VSEN 13 M_VSEN 12 M_VSEN 11 M_VSEN 10 M_VSEN 9 DEFAULT 1 1 1 1 1 1 1 1 SMI_MSK3 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved M_VSEN 19 M_VSEN 18 M_VSEN 17 M_LTD M_V3VS B Nuvoton Confidential - 50 – 2017/7/25 Revision 1.45 NCT7904D DEFAULT 0 0 0 1 1 1 1 1 SMI_MSK4 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved Reserved Reserved Reserved M_PH1 DEFAULT 0 0 0 0 0 0 0 1 SMI_MSK5 BIT 7 6 5 4 3 2 1 0 NAME M_FANIN 8 M_FANIN 7 M_FANIN 6 M_FANIN 5 M_FANIN 4 M_FANIN 3 M_FANIN 2 M_FANIN 1 DEFAULT 1 1 1 1 1 1 1 1 SMI_MSK6 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved M_FANIN 12 M_FANIN 11 M_FANIN 10 M_FANIN 9 DEFAULT 0 0 0 0 1 1 1 1 SMI_MSK7 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved M_TCPU 4 M_TCPU 3 M_TCPU 2 M_TCPU 1 DEFAULT 0 0 0 0 1 1 1 1 SMI_MSK8 BIT NAME DEFAULT 7 6 5 4 3 2 1 0 Reserved Reserved Reserved Reserved M_TCPU 8 M_TCPU 7 M_TCPU 6 M_TCPU 5 0 0 0 0 1 1 1 1 SMI_MSK9 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved M_PCPU 4 M_PCPU 3 M_PCPU 2 M_PCPU 1 DEFAULT 0 0 0 0 1 1 1 1 SMI_MSK10 BIT 7 6 5 4 3 2 1 0 NAME CLR_CH ASSIS M_CHAS SIS Reserved Reserved M_TART4 M_TART3 M_TART2 M_TART1 DEFAULT 0 1 0 0 1 1 1 1 CLR_CHASSIS is clear chassis event. When write 1 , the internal chassis event will be cleared. M_CHASSIS is mask chassis event. When set to 1 , the chassis SMI event will be masked. Nuvoton Confidential - 51 – 2017/7/25 Revision 1.45 NCT7904D 7.1.22 Beep Control Register Location: Bank 0 Address D6HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 7 EN_BEEP 0 = Disable 1 = Enable 6 BEEP_WNC 0 = Temperature BEEP boundary is critical level (Default) 1 = Temperature BEEP boundary is warning level Reserved 5-0 7.1.23 Beep Source Selection Register Location: BEEP_SEL1 - Bank 0 Address D7HEX BEEP_SEL 2 - Bank 0 Address D8HEX BEEP_SEL 3 - Bank 0 Address D9HEX BEEP_SEL 4 - Bank 0 Address DAHEX BEEP_SEL 5 - Bank 0 Address DBHEX BEEP_SEL 6 - Bank 0 Address DCHEX BEEP_SEL 7 - Bank 0 Address DDHEX BEEP_SEL 8 - Bank 0 Address DEHEX BEEP_SEL 9 - Bank 0 Address DFHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 BEEP_SEL1 BIT 7 6 5 4 3 2 1 0 NAME B_VSEN8 B_VSEN7 B_VSEN6 B_VSEN5 B_VSEN4 B_VSEN3 B_VSEN2 B_VSEN1 DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL2 BIT NAME DEFAULT 7 6 5 4 3 2 1 0 B_VBAT B_3VDD B_VSEN1 4 B_VSEN1 3 B_VSEN1 2 B_VSEN1 1 B_VSEN1 0 B_VSEN9 0 0 0 0 0 0 0 0 Nuvoton Confidential - 52 – 2017/7/25 Revision 1.45 NCT7904D BEEP_SEL3 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved B_VSEN1 9 B_VSEN1 8 B_VSEN1 7 B_LTD B_V3VSB DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL4 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved Reserved Reserved Reserved B_PH1 DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL5 BIT 7 6 5 4 3 2 1 0 NAME B_FANIN 8 B_FANIN 7 B_FANIN 6 B_FANIN 5 B_FANIN 4 B_FANIN 3 B_FANIN 2 B_FANIN 1 DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL6 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved B_FANIN 12 B_FANIN 11 B_FANIN 10 B_FANIN 9 DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL7 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved B_TCPU4 B_TCPU3 B_TCPU2 B_TCPU1 DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL8 BIT 7 6 5 4 3 2 1 0 NAME Reserved Reserved Reserved Reserved B_TCPU8 B_TCPU7 B_TCPU6 B_TCPU5 DEFAULT 0 0 0 0 0 0 0 0 BEEP_SEL9 BIT 7 6 5 4 3 2 1 0 NAME Reserved B_CHAS SIS Reserved Reserved B_PCPU4 B_PCPU3 B_PCPU2 B_PCPU1 DEFAULT 0 0 0 0 0 0 0 0 Nuvoton Confidential - 53 – 2017/7/25 Revision 1.45 NCT7904D 7.1.24 Lock Watch Dog Register Location: Bank 0 Address E0HEX Type: Write Only Reset: Power On Reset Default Value: 00HEX BIT 7-0 DESCRIPTION UNLOCK CODE Write 55HEX, Enables Soft Watch Dog Timer Write AAHEX, Disables Soft Watch Dog Timer Write 33HEX, Enables Hard Watch Dog Timer Write CCHEX, Disables Hard Watch Dog Timer 7.1.25 Watch Dog Enable Register Location: Bank 0 Address E1HEX Type: Read Only Reset: Power On Reset Default Value: 00HEX BIT 7-2 DESCRIPTION Reserved. 1 HARD 0 = Hard Watch Dog is disabled 1 = Hard Watch Dog is enabled 0 SOFT 0 = Soft Watch Dog is disabled 1 = Soft Watch Dog is enabled 7.1.26 Watch Dog Status Register Location: Bank 0 Address E2HEX Type: Read Only Reset: Power On Reset Default Value: 00HEX BIT DESCRIPTION 7-4 Reserved 3-2 WDT_ST These 2 bits record last WDT stage for BIOS readout. The information is used to help BIOS to identify WDT timeout issuance 1 HARD_TO 1 = A hard timeout occurs. This bit will be cleared after reading 0 SOFT_TO 1 = A soft timeout occurs. This bit will be cleared after reading Nuvoton Confidential - 54 – 2017/7/25 Revision 1.45 NCT7904D 7.1.27 Watch Dog Timer Register Location: Bank 0 Address E3HEX Type: Read / Write Reset: Power On Reset Default Value: 00HEX BIT 7-0 DESCRIPTION WDT TIMER – Timeout timer To write 00HEX can disable the timer while in Hard Watch Dog Timer mode. To set Timeout Time for SOFT Watch Dog Timer, the unit is minute 7.1.28 Reset: GPIO Control Register Power On Reset RESETIN# with LOCK=0 GPIO G0 EN – GPIO Group 0 I/O Enable Control Register Location: Bank 0 Address E8HEX Default Value: 60HEX Type: Read / Write BIT 7 6-0 DESCRIPTION Reserved GPIO G0 EN – Select GPIOG-GPIOA I/O Enable. 0 = GPIOG-A are disable. 1 = GPIOG-A are enable. GPIO G0 DIR – GPIO Group 0 I/O Direction Control Register Location: Bank 0 Address E9HEX Default Value: 7FHEX Type: Read / Write BIT 7 6-0 DESCRIPTION Reserved GPIO G0 DIR – Select GPIOG-GPIOA I/O Direction. 0 = GPIOG-A are programming as output pins. 1 = GPIOG-A are programming as input pins. (default) GPIO G0 OUT – GPIO Group 0 Output Data Register Location: Bank 0 Address EAHEX Default Value: 00HEX Type: Read / Write BIT DESCRIPTION 7-0 GPIO G0 OUT – Output GPIOG-GPIOA Data. For output ports, it needs to set GPIO_G0_EN register and the respective bits can be read/written and produced to pins. Nuvoton Confidential - 55 – 2017/7/25 Revision 1.45 NCT7904D GPIO G0 IN – GPIO Group 0 Input Data Register Location: Bank 0 Address EBHEX Default Value: N.A. Type: Read Only BIT DESCRIPTION 7-0 GPIO G0 IN – Input GPIOG-GPIOA Data. The respective bits can be read only from pins. Write accesses will be ignored. GPIO G1 EN – GPIO Group 1 I/O Enable Control Register Location: Bank 0 Address ECHEX Default Value: 00HEX Type: Read / Write BIT DESCRIPTION 7-4 Reserved 3-0 GPIO G1 EN – Select GPIO16-GPIO13 I/O Enable. 0 = GPIO16-13 are disable. 1 = GPIO16-13 are enable. GPIO G1 DIR – GPIO Group 1 I/O Direction Control Register Location: Bank 0 Address EDHEX Default Value: 0FHEX Type: Read / Write BIT 7-4 3-0 DESCRIPTION Reserved GPIO G1 DIR – Select GPIO16-GPIO13 I/O Direction. 0 = GPIO16-13 are programming as output pins. 1 = GPIO16-13 are programming as input pins. (default) GPIO G1 OUT – GPIO Group 1 Output Data Register Location: Bank 0 Address EEHEX Default Value: 00HEX Type: Read / Write BIT DESCRIPTION 3-0 GPIO G1 OUT – Output GPIO16-GPIO13 Data. For output ports, it needs to set GPIO_G1_EN register and the respective bits can be read/written and produced to pins. GPIO G1 IN – GPIO Group 1 Input Data Register Location: Bank 0 Address EFHEX Default Value: N.A. Type: Read Only BIT DESCRIPTION 3-0 GPIO G1 IN – Input GPIO16-GPIO13 Data. The respective bits can be read only from pins. Write accesses will be ignored. Nuvoton Confidential - 56 – 2017/7/25 Revision 1.45 NCT7904D 7.1.29 PCH DTS Monitored Value Register Location: PCH_MAX PCH_PCH PCH_CPU_F PCH_CPU_I PCH_MCH PCH_DIMM0 PCH_DIMM1 PCH_DIMM2 PCH_DIMM3 PCH_SN PCH_CPU_EG0 PCH_CPU_EG1 PCH_CPU_EG2 PCH_CPU_EG3 Type: Read Only Reset: Power On Reset - Bank 0 Address F0HEX - Bank 0 Address F1HEX - Bank 0 Address F2HEX - Bank 0 Address F3HEX - Bank 0 Address F4HEX - Bank 0 Address F5HEX - Bank 0 Address F6HEX - Bank 0 Address F7HEX - Bank 0 Address F8HEX - Bank 0 Address F9HEX - Bank 0 Address FAHEX - Bank 0 Address FBHEX - Bank 0 Address FCHEX - Bank 0 Address FDHEX According to different Intel ME firmware version, the PCH temperature could be placed in either address F0h or F1h. PCH_MAX – PCH PCH_0 Temperature Value Register Location: Bank 0 Address F0HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_PCH_0_TEMP[7:0] PCH PCH_0 Temperature Value (It can be one of temperature sources for the FAN controller) PCH_PCH – PCH PCH_1 Temperature Value Register Location: Bank 0 Address F1HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_PCH_1_TEMP[7:0] PCH PCH_1 Temperature Value (It can be one of temperature sources for the FAN controller) PCH_CPU_F – PCH CPU Fractional Temperature Value Register Location: Bank 0 Address F2HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_CPU_FRA_TEMP[7:0] PCH CPU Fractional Temperature Value Nuvoton Confidential - 57 – 2017/7/25 Revision 1.45 NCT7904D PCH_CPU_I – PCH CPU Integer Temperature Value Register Location: Bank 0 Address F3HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_CPU_INT_TEMP[7:0] PCH CPU Integer Temperature Value (It can be one of temperature sources for the FAN controller) PCH_MCH – PCH MCH Temperature Value Register Location: Bank 0 Address F4HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_MCH_TEMP[7:0] PCH MCH Temperature Value (It can be one of temperature sources for the FAN controller) PCH_DIMM0 – PCH DIMM0 Temperature Value Register Location: Bank 0 Address F5HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_DIMM0_TEMP[7:0] PCH DIMM0 Temperature Value (It can be one of temperature sources for the FAN controller) PCH_DIMM1 – PCH DIMM1 Temperature Value Register Location: Bank 0 Address F6HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_DIMM1_TEMP[7:0] PCH DIMM1 Temperature Value (It can be one of temperature sources for the FAN controller) PCH_DIMM2 – PCH DIMM2 Temperature Value Register Location: Bank 0 Address F7HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_DIMM2_TEMP[7:0] PCH DIMM2 Temperature Value (It can be one of temperature sources for the FAN controller) Nuvoton Confidential - 58 – 2017/7/25 Revision 1.45 NCT7904D PCH_DIMM3 – PCH DIMM3 Temperature Value Register Location: Bank 0 Address F8HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_DIMM3_TEMP[7:0] PCH DIMM3 Temperature Value (It can be one of temperature sources for the FAN controller) PCH_SN – PCH Sequence Number Value Register Location: Bank 0 Address F9HEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_SEQ_NUM[7:0] PCH Sequence Number Value PCH_CPU_EG0 – PCH CPU Latest Energy Value Register Location: Bank 0 Address FAHEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_CPU_ERG[7:0] PCH CPU Latest Energy Value PCH_CPU_EG1 – PCH CPU Latest Energy Value Register Location: Bank 0 Address FBHEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_CPU_ERG[15:8] PCH CPU Latest Energy Value PCH_CPU_EG2 – PCH CPU Latest Energy Value Register Location: Bank 0 Address FCHEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_CPU_ERG[23:16] PCH CPU Latest Energy Value PCH_CPU_EG3 – PCH CPU Latest Energy Value Register Location: Bank 0 Address FDHEX Default Value: N/A BIT 7-0 DESCRIPTION PCH_CPU_ERG[31:24] PCH CPU Latest Energy Value Nuvoton Confidential - 59 – 2017/7/25 Revision 1.45 NCT7904D 7.1.30 Bank Select Register Location: Bank 0, 1, 2, 3 Address FFHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 7-3 Reserved. 2-0 BANK_SEL[2:0] 000BIN = Bank 0 001BIN = Bank 1 010BIN = Bank 2 011BIN = Bank 3 100BIN = Bank 4 101BIN ~ 111BIN = Reserved Nuvoton Confidential - 60 – 2017/7/25 Revision 1.45 NCT7904D 7.2 Bank 1 REGISTER DETAIL 7.2.1 Voltage and Temperature Channel Limitation Register Location: VSEN1_HV_HL VSEN1_LV_HL VSEN1_HV_LL VSEN1_LV_LL VSEN2_HV_HL / TEMP_CH1_C VSEN2_LV_HL / TEMP_CH1_CH VSEN2_HV_LL / TEMP_CH1_W VSEN2_LV_LL / TEMP_CH1_WH VSEN3_HV_HL VSEN3_LV_HL VSEN3_HV_LL VSEN3_LV_LL VSEN4_HV_HL / TEMP_CH2_C VSEN4_LV_HL / TEMP_CH2_CH VSEN4_HV_LL / TEMP_CH2_W VSEN4_LV_LL / TEMP_CH2_WH VSEN5_HV_HL VSEN5_LV_HL VSEN5_HV_LL VSEN5_LV_LL VSEN6_HV_HL / TEMP_CH3_C VSEN6_LV_HL / TEMP_CH3_CH VSEN6_HV_LL / TEMP_CH3_W VSEN6_LV_LL / TEMP_CH3_WH VSEN7_HV_HL VSEN7_LV_HL VSEN7_HV_LL VSEN7_LV_LL VSEN8_HV_HL / TEMP_CH4_C VSEN8_LV_HL / TEMP_CH4_CH VSEN8_HV_LL / TEMP_CH4_W VSEN8_LV_LL / TEMP_CH4_WH VSEN9_HV_HL VSEN9_LV_HL VSEN9_HV_LL VSEN9_LV_LL VSEN10_HV_HL VSEN10_LV_HL VSEN10_HV_LL VSEN10_LV_LL VSEN11_HV_HL Nuvoton Confidential - Bank 1 Address 00HEX - Bank 1 Address 01HEX - Bank 1 Address 02HEX - Bank 1 Address 03HEX - Bank 1 Address 04HEX - Bank 1 Address 05HEX - Bank 1 Address 06HEX - Bank 1 Address 07HEX - Bank 1 Address 08HEX - Bank 1 Address 09HEX - Bank 1 Address 0AHEX - Bank 1 Address 0BHEX - Bank 1 Address 0CHEX - Bank 1 Address 0DHEX - Bank 1 Address 0EHEX - Bank 1 Address 0FHEX - Bank 1 Address 10HEX - Bank 1 Address 11HEX - Bank 1 Address 12HEX - Bank 1 Address 13HEX - Bank 1 Address 14HEX - Bank 1 Address 15HEX - Bank 1 Address 16HEX - Bank 1 Address 17HEX - Bank 1 Address 18HEX - Bank 1 Address 19HEX - Bank 1 Address 1AHEX - Bank 1 Address 1BHEX - Bank 1 Address 1CHEX - Bank 1 Address 1DHEX - Bank 1 Address 1EHEX - Bank 1 Address 1FHEX - Bank 1 Address 20HEX - Bank 1 Address 21HEX - Bank 1 Address 22HEX - Bank 1 Address 23HEX - Bank 1 Address 24HEX - Bank 1 Address 25HEX - Bank 1 Address 26HEX - Bank 1 Address 27HEX - Bank 1 Address 28HEX - 61 – 2017/7/25 Revision 1.45 NCT7904D VSEN11_LV_HL VSEN11_HV_LL VSEN11_LV_LL VSEN12_HV_HL VSEN12_LV_HL VSEN12_HV_LL VSEN12_LV_LL VSEN13_HV_HL VSEN13_LV_HL VSEN13_HV_LL VSEN13_LV_LL VSEN14_HV_HL VSEN14_LV_HL VSEN14_HV_LL VSEN14_LV_LL 3VDD_HV_HL 3VDD_LV_HL 3VDD_HV_LL 3VDD_LV_LL VBAT_HV_HL VBAT_LV_HL VBAT_HV_LL VBAT_LV_LL V3VSB_HV_HL V3VSB_LV_HL V3VSB_HV_LL V3VSB_LV_LL LTD_HV_HL LTD_LV_HL LTD_HV_LL LTD_LV_LL VSEN17_HV_HL VSEN17_LV_HL VSEN17_HV_LL VSEN17_LV_LL VSEN18_HV_HL VSEN18_LV_HL VSEN18_HV_LL VSEN18_LV_LL VSEN19_HV_HL VSEN19_LV_HL VSEN19_HV_LL VSEN19_LV_LL Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - Bank 1 Address 29HEX - Bank 1 Address 2AHEX - Bank 1 Address 2BHEX - Bank 1 Address 2CHEX - Bank 1 Address 2DHEX - Bank 1 Address 2EHEX - Bank 1 Address 2FHEX - Bank 1 Address 30HEX - Bank 1 Address 31HEX - Bank 1 Address 32HEX - Bank 1 Address 33HEX - Bank 1 Address 34HEX - Bank 1 Address 35HEX - Bank 1 Address 36HEX - Bank 1 Address 37HEX - Bank 1 Address 38HEX - Bank 1 Address 39HEX - Bank 1 Address 3AHEX - Bank 1 Address 3BHEX - Bank 1 Address 3CHEX - Bank 1 Address 3DHEX - Bank 1 Address 3EHEX - Bank 1 Address 3FHEX - Bank 1 Address 40HEX - Bank 1 Address 41HEX - Bank 1 Address 42HEX - Bank 1 Address 43HEX - Bank 1 Address 44HEX - Bank 1 Address 45HEX - Bank 1 Address 46HEX - Bank 1 Address 47HEX - Bank 1 Address 80HEX - Bank 1 Address 81HEX - Bank 1 Address 82HEX - Bank 1 Address 83HEX - Bank 1 Address 84HEX - Bank 1 Address 85HEX - Bank 1 Address 86HEX - Bank 1 Address 87HEX - Bank 1 Address 88HEX - Bank 1 Address 89HEX - Bank 1 Address 8AHEX - Bank 1 Address 8BHEX - 62 – 2017/7/25 Revision 1.45 NCT7904D HIGH VALUE HIGH LIMITATION Default Value: FFHEX BIT NAME 7 6 5 4 3 2 1 0 2 1 0 High Value High Limitation 11-bit voltage value bit[10:2] LOW VALUE HIGH LIMITATION Default Value: 07HEX BIT 7 6 NAME 5 4 3 Reserved High Value High Limitation 11-bit voltage value bit[2:0] HIGH VALUE LOW LIMITATION Default Value: 00HEX BIT NAME 7 6 5 4 3 2 1 0 2 1 0 High Value Low Limitation 11-bit voltage value bit[10:2] LOW VALUE LOW LIMITATION Default Value: 00HEX BIT 7 6 NAME 5 4 3 Reserved High Value Low Limitation 11-bit voltage value bit[2:0] CRITICAL TEMPERATURE Default Value: FFHEX BIT NAME 7 6 5 4 3 2 1 0 Critical Temperature The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. CRITICAL TEMPERATURE HYSTERESIS Default Value: 07HEX BIT NAME 7 6 5 4 3 2 1 0 Critical Temperature Hysteresis The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. WARNING TEMPERATURE Default Value: 00HEX BIT NAME 7 6 5 4 3 2 1 0 Warning Temperature The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. Nuvoton Confidential - 63 – 2017/7/25 Revision 1.45 NCT7904D WARNING TEMPERATURE HYSTERESIS Default Value: 00HEX BIT 7 NAME 6 5 4 3 2 1 0 Warning Temperature Hysteresis The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. 7.2.2 PROCHOT Limitation Register Location: Bank 1 Address 50HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: FFHEX BIT 7-0 DESCRIPTION P1_PROCHOT#_NV_HL[7:0] CPU1 PROCHOT# Numerator High Limitation 7.2.3 FAN Input Channel Limitation Register Location: FANIN1_HV_HL - Bank 1 Address 60HEX FANIN1_LV_HL - Bank 1 Address 61HEX FANIN2_HV_HL - Bank 1 Address 62HEX FANIN2_LV_HL - Bank 1 Address 63HEX FANIN3_HV_HL - Bank 1 Address 64HEX FANIN3_LV_HL - Bank 1 Address 65HEX FANIN4_HV_HL - Bank 1 Address 66HEX FANIN4_LV_HL - Bank 1 Address 67HEX FANIN5_HV_HL - Bank 1 Address 68HEX FANIN5_LV_HL - Bank 1 Address 69HEX FANIN6_HV_HL - Bank 1 Address 6AHEX FANIN6_LV_HL - Bank 1 Address 6BHEX FANIN7_HV_HL - Bank 1 Address 6CHEX FANIN7_LV_HL - Bank 1 Address 6DHEX FANIN8_HV_HL - Bank 1 Address 6EHEX FANIN8_LV_HL - Bank 1 Address 6FHEX FANIN9_HV_HL - Bank 1 Address 70HEX FANIN9_LV_HL - Bank 1 Address 71HEX FANIN10_HV_HL - Bank 1 Address 72HEX FANIN10_LV_HL - Bank 1 Address 73HEX FANIN11_HV_HL - Bank 1 Address 74HEX FANIN11_LV_HL - Bank 1 Address 75HEX FANIN12_HV_HL - Bank 1 Address 76HEX FANIN12_LV_HL - Bank 1 Address 77HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - 64 – 2017/7/25 Revision 1.45 NCT7904D FANIN HIGH VALUE HIGH LIMITATION BIT 7 NAME 6 5 4 3 2 1 0 2 1 0 Fan Input Count High Value High Limitation 13-bit voltage value bit[12:5] FANIN LOW VALUE HIGH LIMITATION BIT 7 NAME 6 5 Reserved 4 3 Fan Input Count Low Value High Limitation 13-bit voltage value bit[4:0] 7.2.4 DTS Temperature Power Limitation Registers Location: DTS_T_CPU1_C DTS_T_CPU1_CH DTS_T_CPU1_W DTS_T_CPU1_WH DTS_T_CPU2_C DTS_T_CPU2_CH DTS_T_CPU2_W DTS_T_CPU2_WH DTS_T_CPU3_C DTS_T_CPU3_CH DTS_T_CPU3_W DTS_T_CPU3_WH DTS_T_CPU4_C DTS_T_CPU4_CH DTS_T_CPU4_W DTS_T_CPU4_WH DTS_T_CPU5_C DTS_T_CPU5_CH DTS_T_CPU5_W DTS_T_CPU5_WH DTS_T_CPU6_C DTS_T_CPU6_CH DTS_T_CPU6_W DTS_T_CPU6_WH DTS_T_CPU7_C DTS_T_CPU7_CH DTS_T_CPU7_W DTS_T_CPU7_WH DTS_T_CPU8_C DTS_T_CPU8_CH DTS_T_CPU8_W DTS_T_CPU8_WH DTS_P_CPU1_C Nuvoton Confidential - Bank 1 Address 90HEX - Bank 1 Address 91HEX - Bank 1 Address 92HEX - Bank 1 Address 93HEX - Bank 1 Address 94HEX - Bank 1 Address 95HEX - Bank 1 Address 96HEX - Bank 1 Address 97HEX - Bank 1 Address 98HEX - Bank 1 Address 99HEX - Bank 1 Address 9AHEX - Bank 1 Address 9BHEX - Bank 1 Address 9CHEX - Bank 1 Address 9DHEX - Bank 1 Address 9EHEX - Bank 1 Address 9FHEX - Bank 1 Address A0HEX - Bank 1 Address A1HEX - Bank 1 Address A2HEX - Bank 1 Address A3HEX - Bank 1 Address A4HEX - Bank 1 Address A5HEX - Bank 1 Address A6HEX - Bank 1 Address A7HEX - Bank 1 Address A8HEX - Bank 1 Address A9HEX - Bank 1 Address AAHEX - Bank 1 Address ABHEX - Bank 1 Address ACHEX - Bank 1 Address ADEX - Bank 1 Address AEHEX - Bank 1 Address AFHEX - Bank 1 Address B0HEX - 65 – 2017/7/25 Revision 1.45 NCT7904D DTS_P_CPU1_CH - Bank 1 Address B1HEX DTS_P_CPU1_W - Bank 1 Address B2HEX DTS_P_CPU1_WH - Bank 1 Address B3HEX DTS_P_CPU2_C - Bank 1 Address B4HEX DTS_P_CPU2_CH - Bank 1 Address B5HEX DTS_P_CPU2_W - Bank 1 Address B6HEX DTS_P_CPU2_WH - Bank 1 Address B7HEX DTS_P_CPU3_C - Bank 1 Address B8HEX DTS_P_CPU3_CH - Bank 1 Address B9HEX DTS_P_CPU3_W - Bank 1 Address BAHEX DTS_P_CPU3_WH - Bank 1 Address BBHEX DTS_P_CPU4_C - Bank 1 Address BCHEX DTS_P_CPU4_CH - Bank 1 Address BDHEX DTS_P_CPU4_W - Bank 1 Address BEEX DTS_P_CPU4_WH - Bank 1 Address BFHEX Reset: Power On Reset RESETIN# with LOCK=0 CRITICAL TEMPERATURE BIT NAME VALUE 7 6 5 4 3 2 1 0 Critical Temperature The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. SIGN 64 32 DEFAULT 16 8 4 2 1 2 1 0 64HEX (100℃) CRITICAL TEMPERATURE HYSTERESIS BIT NAME VALUE 7 6 5 4 3 Critical Temperature Hysteresis The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. SIGN 64 32 DEFAULT 16 8 4 2 1 5FHEX (95℃) WARNING TEMPERATURE BIT NAME VALUE 7 6 5 4 3 2 1 0 Warning Temperature The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. SIGN DEFAULT 64 32 16 8 55HEX (85 ℃) 4 2 1 WARNING TEMPERATURE HYSTERESIS BIT NAME 7 6 5 4 3 2 1 0 Warning Temperature Hysteresis The format of Temperature is 8-bit 2’s complement and the range is –128℃~127℃. Nuvoton Confidential - 66 – 2017/7/25 Revision 1.45 NCT7904D VALUE SIGN 64 32 DEFAULT 16 8 4 2 1 50HEX (80 ℃) 7.2.5 PROCHOT Control Registers Location: Bank 1 Address D0HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 4FHEX BIT 7 6 5-4 3-0 DESCRIPTION Reserved PH1_MD – Set the PROCHOT1# mode. 0 = Output mode 1 = Input mode (default) PH1_FSEL – Set the PROCHOT1# sample period time. 00 = 22us (default) 01 = 44us 10 = 88us 11 = 176us PH1_DC – Set the PROCHOT1# output duty cycle. 0000 = 1 sample time low 0001 = 2 sample times low 0010 = 3 sample times low 0011 = 4 sample times low 0100 = 5 sample times low 0101 = 6 sample times low 0110 = 7 sample times low 0111 = 8 sample times low 1000 = 9 sample times low 1001 = 10 sample times low 1010 = 11 sample times low 1011 = 12 sample times low 1100 = 13 sample times low 1101 = 14 sample times low 1110 = 15 sample times low 1111 = all low (default) Nuvoton Confidential - 67 – 2017/7/25 Revision 1.45 NCT7904D 7.2.6 PROCHOT Source Selection Registers Location: PH1_VT_ADC - Bank 1 Address D1HEX PH1_DTS_T0 - Bank 1 Address D2HEX PH1_DTS_T1 - Bank 1 Address D3HEX PH1_DTS_P - Bank 1 Address D4HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PH1_VT_ADC – P1_PROCHOT Temperature Select Register Location: Bank 1 Address D1HEX Default Value: 20HEX BIT 7-5 4 3 2 1 0 DESCRIPTION Reserved PH1_LTD – Enable P1_PROCHOT# for LTD 0 = Disable 1 = Enable PH1_VSEN89 – Enable P1_PROCHOT# for VSEN89 0 = Disable 1 = Enable PH1_VSEN67 – Enable P1_PROCHOT# for VSEN67 0 = Disable 1 = Enable PH1_VSEN45 – Enable P1_PROCHOT# for VSEN45 0 = Disable 1 = Enable PH1_VSEN23 – Enable P1_PROCHOT# for VSEN23 0 = Disable 1 = Enable PH1_DTS_T0 – P1_PROCHOT DTS Temperature 0 Select Register Location: Bank 1 Address D2HEX Default Value: 00HEX BIT 7-4 3 2 1 DESCRIPTION Reserved PH1_TCPU4 – Enable P1_PROCHOT# for TCPU4 0 = Disable 1 = Enable PH1_TCPU3 – Enable P1_PROCHOT# for TCPU3 0 = Disable 1 = Enable PH1_TCPU2 – Enable P1_PROCHOT# for TCPU2 0 = Disable 1 = Enable Nuvoton Confidential - 68 – 2017/7/25 Revision 1.45 NCT7904D BIT 0 DESCRIPTION PH1_TCPU1 – Enable P1_PROCHOT# for TCPU1 0 = Disable 1 = Enable PH1_DTS_T1 – P1_PROCHOT DTS Temperature 1 Select Register Location: Bank 1 Address D3HEX Default Value: 00HEX BIT 7-4 3 2 1 0 DESCRIPTION Reserved PH1_TCPU8 – Enable P1_PROCHOT# for TCPU8 0 = Disable 1 = Enable PH1_TCPU7 – Enable P1_PROCHOT# for TCPU7 0 = Disable 1 = Enable PH1_TCPU6 – Enable P1_PROCHOT# for TCPU6 0 = Disable 1 = Enable PH1_TCPU5 – Enable P1_PROCHOT# for TCPU5 0 = Disable 1 = Enable PH1_DTS_P – P1_PROCHOT DTS Power Select Register Location: Bank 1 Address D4HEX Default Value: 00HEX BIT 7-4 3 2 1 0 DESCRIPTION Reserved PH1_PCPU4 – Enable P1_PROCHOT# for PCPU4 0 = Disable 1 = Enable PH1_PCPU3 – Enable P1_PROCHOT# for PCPU3 0 = Disable 1 = Enable PH1_PCPU2 – Enable P1_PROCHOT# for PCPU2 0 = Disable 1 = Enable PH1_PCPU1 – Enable P1_PROCHOT# for PCPU1 0 = Disable 1 = Enable Nuvoton Confidential - 69 – 2017/7/25 Revision 1.45 NCT7904D 7.2.7 Voltage Fault Control Registers Location: Bank 1 Address D8HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7 6-0 DESCRIPTION EN_VFAULT – Enable voltage fault function. 0 = Disable 1 = Enable Reserved 7.2.8 Voltage Fault Source Selection Registers Location: VF_SEL0 - Bank 1 Address D9HEX VF_SEL1 - Bank 1 Address DAHEX VF_SEL2 - Bank 1 Address DBHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 VF_SEL0 – Voltage Fault Select Register Location: Bank 1 Address D9HEX Default Value: 00HEX BIT DESCRIPTION 7 VF_VSEN8 – Enable VOLT_ALM# for VSEN8 0 = Disable 1 = Enable 6 VF_VSEN7 – Enable VOLT_ALM# for VSEN7 0 = Disable 1 = Enable 5 VF_VSEN6 – Enable VOLT_ALM# for VSEN6 0 = Disable 1 = Enable 4 VF_VSEN5 – Enable VOLT_ALM# for VSEN5 0 = Disable 1 = Enable 3 VF_VSEN4 – Enable VOLT_ALM# for VSEN4 0 = Disable 1 = Enable 2 VF_VSEN3 – Enable VOLT_ALM# for VSEN3 0 = Disable 1 = Enable Nuvoton Confidential - 70 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 VF_VSEN2 – Enable VOLT_ALM# for VSEN2 0 = Disable 1 = Enable 0 VF_VSEN1 – Enable VOLT_ALM# for VSEN1 0 = Disable 1 = Enable VF_SEL1 – Voltage Fault Select Register Location: Bank 1 Address DAHEX Default Value: 00HEX BIT 7 6 5 4 3 2 1 0 DESCRIPTION VF_VBAT – Enable VOLT_ALM# for VBAT 0 = Disable 1 = Enable VF_3VDD – Enable VOLT_ALM# for 3VDD 0 = Disable 1 = Enable VF_VSEN14 – Enable VOLT_ALM# for VSEN14 0 = Disable 1 = Enable VF_VSEN13 – Enable VOLT_ALM# for VSEN13 0 = Disable 1 = Enable VF_VSEN12 – Enable VOLT_ALM# for VSEN12 0 = Disable 1 = Enable VF_VSEN11 – Enable VOLT_ALM# for VSEN11 0 = Disable 1 = Enable VF_VSEN10 – Enable VOLT_ALM# for VSEN10 0 = Disable 1 = Enable VF_VSEN9 – Enable VOLT_ALM# for VSEN9 0 = Disable 1 = Enable VF_SEL2 – Voltage Fault Select Register Location: Bank 1 Address DBHEX Default Value: 00HEX BIT 7-5 4 3 DESCRIPTION Reserved VF_VSEN19 – Enable VOLT_ALM# for VSEN19 0 = Disable 1 = Enable VF_VSEN18 – Enable VOLT_ALM# for VSEN18 Nuvoton Confidential - 71 – 2017/7/25 Revision 1.45 NCT7904D BIT 2 1 0 DESCRIPTION 0 = Disable 1 = Enable VF_VSEN17 – Enable VOLT_ALM# for VSEN17 0 = Disable 1 = Enable Reserved VF_V3VSB – Enable VOLT_ALM# for 3VSB 0 = Disable 1 = Enable 7.2.9 Fan Fault Control Registers Location: Bank 1 Address DCHEX Type: Read / Write Reset: Power On Reset Default Value: 00HEX BIT 7 6-0 DESCRIPTION EN_FFAULT – Enable fan fault function. 0 = Disable 1 = Enable Reserved 7.2.10 Fan Fault Source Selection Registers Location: FF_SEL0 - Bank 1 Address DDHEX FF_SEL1 - Bank 1 Address DEHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FF_SEL0 – Fan Fault Select Register Location: Bank 1 Address DDHEX Default Value: 00HEX BIT DESCRIPTION 7 FF_FANIN8 – Enable FAN_ALM# for FANIN8 0 = Disable 1 = Enable 6 FF_FANIN7 – Enable FAN_ALM# for FANIN7 0 = Disable 1 = Enable 5 FF_FANIN6 – Enable FAN_ALM# for FANIN6 0 = Disable 1 = Enable 4 FF_FANIN5 – Enable FAN_ALM# for FANIN5 Nuvoton Confidential - 72 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 0 = Disable 1 = Enable 3 FF_FANIN4 – Enable FAN_ALM# for FANIN4 0 = Disable 1 = Enable 2 FF_FANIN3 – Enable FAN_ALM# for FANIN3 0 = Disable 1 = Enable 1 FF_FANIN2 – Enable FAN_ALM# for FANIN2 0 = Disable 1 = Enable 0 FF_FANIN1 – Enable FAN_ALM# for FANIN1 0 = Disable 1 = Enable FF_SEL1 – Fan Fault Select Register Location: Bank 1 Address DEHEX Default Value: 00HEX BIT 7-4 3 2 1 0 DESCRIPTION Reserved FF_FANIN12 – Enable FAN_ALM# for FANIN12 0 = Disable 1 = Enable FF_FANIN11 – Enable FAN_ALM# for FANIN11 0 = Disable 1 = Enable FF_FANIN10 – Enable FAN_ALM# for FANIN10 0 = Disable 1 = Enable FF_FANIN9 – Enable FAN_ALM# for FANIN9 0 = Disable 1 = Enable Nuvoton Confidential - 73 – 2017/7/25 Revision 1.45 NCT7904D 7.2.11 Temperature Fault Control Registers Location: Bank 1 Address E0HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 7 EN_TFAULT – Enable temperature fault function. 0 = Disable (Default) 1 = Enable 6 TF_WNC 0 = Temperature fault boundary is critical level (Default) 1 = Temperature fault boundary is warning level 5-0 Reserved. 7.2.12 Temperature Fault Source Selection Registers Location: TF_SEL0 - Bank 1 Address E1HEX TF_SEL1 - Bank 1 Address E2HEX TF_SEL2 - Bank 1 Address E3HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 TF_SEL0 – Temperature Fault Select Register Location: Bank 1 Address E1HEX Default Value: 00HEX BIT 7-5 4 3 2 1 0 DESCRIPTION Reserved TF_LTD – Enable TEMP_ALM# for LTD 0 = Disable 1 = Enable TF_VSEN89 – Enable TEMP_ALM# for VSEN89 0 = Disable 1 = Enable TF_VSEN67 – Enable TEMP_ALM# for VSEN67 0 = Disable 1 = Enable TF_VSEN45 – Enable TEMP_ALM# for VSEN45 0 = Disable 1 = Enable TF_VSEN23 – Enable TEMP_ALM# for VSEN23 0 = Disable Nuvoton Confidential - 74 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 = Enable TF_SEL1 – Temperature Fault Select Register Location: Bank 1 Address E2HEX Default Value: 00HEX BIT 7-4 3 2 1 0 DESCRIPTION Reserved TF_TCPU4 – Enable TEMP_ALM# for TCPU4 0 = Disable 1 = Enable TF_TCPU3 – Enable TEMP_ALM# for TCPU3 0 = Disable 1 = Enable TF_TCPU2 – Enable TEMP_ALM# for TCPU2 0 = Disable 1 = Enable TF_TCPU1 – Enable TEMP_ALM# for TCPU1 0 = Disable 1 = Enable TF_SEL2 – Temperature Fault Select Register Location: Bank 1 Address E3HEX Default Value: 00HEX BIT 7-4 3 2 1 0 DESCRIPTION Reserved TF_TCPU8 – Enable TEMP_ALM# for TCPU8 0 = Disable 1 = Enable TF_TCPU7 – Enable TEMP_ALM# for TCPU7 0 = Disable 1 = Enable TF_TCPU6 – Enable TEMP_ALM# for TCPU6 0 = Disable 1 = Enable TF_TCPU5 – Enable TEMP_ALM# for TCPU5 0 = Disable 1 = Enable 7.2.13 THERMTRIP Control and Status Register Location: Bank 1 Address E8HEX Default Value: 00HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - 75 – 2017/7/25 Revision 1.45 NCT7904D BIT 7-3 DESCRIPTION Reserved. 2 CLR_THRM – Clear the thermal trip status. If write 1, to clear thermal trip status. 1 EN_THRM – Enable thermal trip event. 0 = Disable 1 = Enable 0 THRM_STS – Thermal trip event status. (Read Only) (Power by VBAT) 0 = Thermal trip event not occurred or be cleared. 1 = Thermal trip event occurred. (It will always be shown no matter what EN_THRM is) Nuvoton Confidential - 76 – 2017/7/25 Revision 1.45 NCT7904D 7.3 Bank 2 REGISTER DETAIL 7.3.1 PECI Function Enable Register (PFE) Location: PFE - Bank 2 Address 00HEX Read / Write Power On Reset RESETIN# with LOCK=0 Type: Reset: PFE BIT 7 NAME PECI_En 6 5 4 3 Reserved 2 1 0 Manual_En BiasRTH_En GetPower_En DEFAULT 18HEX BIT DESCRIPTION Enable PECI Host Function. (PECI_En) 7 6-3 Reserved 2 Enable PECI Manual Mode Transaction (Manual_En) Fill in command content into PMMC and PMMWD registers defined in 7.3.8 and 7.3.9 section before enable this bit. 1 Enable function of weighting “Count” retrieved from GetTemp() to form CPU temperature 0BIN => Disable ( It means that Temperature = “Count” ) 1BIN => Enable ( It means that Temperature = “Count” * Scale, Scale is defined by Scale_Sel[2:0] in Bank2 Index03) 0 Get Power Function (GetPower_En) This function can routinely return the total energy consumed by the processor. 0BIN = Disable get CPU Power Function. 1BIN = Enable get CPU Power Function. 7.3.2 PECI Timing Configure Register (PTC) Location: Type: Reset: PTC - Bank 2 Address 01HEX Read / Write Power On Reset RESETIN# with LOCK=0 PTC BIT 7 6 NAME RtHigher Clamp 5 4 3 ATR 1 0 Reserved DEFAULT 01HEX BIT DESCRIPTION Nuvoton Confidential 2 - 77 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 7 Return Higher Temperature between Doamin0 and domain1.(RtHigher) 0BIN = The temperature of each agent is returned from domain 0 or domain 1. It depends on control register Bit[3:0] in Bank 2 Address 03HEX. 1BIN = Return the higher temperature between domain 0 and domain 1 6 PECI clamping function to filter the unreasonable DTS “count” value. (Clamp) 0 = DTS values are fully transparent. 1 = DTS values are clamped in -128 ~ 0. Adjust Transaction Tbit Rate. (ATR) 5-4 3-0 CLKIN 14.318MHz 33MHz 48MHz 00BIN Tbit = 1.1us Tbit = 0.5us Tbit = 0.5us 01BIN Tbit = 2.2us Tbit = 1us Tbit = 1us 10BIN Tbit = 4.5us Tbit = 2us Tbit = 2us 11BIN Tbit = 8.9us Tbit = 4us Tbit = 4us Reserved 7.3.3 PECI Agent and Domain Configure Register (PADC) Location: Type: Reset: PADC - Bank 2 Address 02HEX Read / Write Power On Reset RESETIN# with LOCK=0 PADC BIT 7 NAME 6 5 4 3 En_Agt[3:0] 1 0 Dmn1_Agt[3:0] DEFAULT 00HEX BIT DESCRIPTION 7-4 Assign which agent will be approached by PECI host [Bit7] = CPU agent 3 [Bit6] = CPU agent 2 [Bit5] = CPU agent 1 [Bit4] = CPU agent 0 3-0 Indicate which agent equips with domain1. [Bit3] = Agent 3 with / without Domain1 [Bit2] = Agent 2 with / without Domain1 [Bit1] = Agent 1 with / without Domain1 [Bit0] = Agent 0 with / without Domain1 Nuvoton Confidential 2 - 78 – 2017/7/25 Revision 1.45 NCT7904D 7.3.4 PECI Relative Temperature Scale Register (PRTS) Location: Type: Reset: PRTS - Bank 2 Address 03HEX Read / Write Power On Reset RESETIN# with LOCK=0 PRTS BIT 7 NAME Reserved 6 5 4 3 Scale_Sel[2:0] 1 0 RtDmn_Agt[3:0] DEFAULT 40HEX BIT DESCRIPTION 7 2 Reserved 6-4 Weighting “count” to form temperature. It is available only while BIASRTH (Bank 2 Address 00HEX Bit[1]=1) is asserted, Through this, the final Temperature = “count” * Scale_Sel[2:0]. 000BIN = 0.78125 001BIN = 0.84375 010BIN = 0.90625 011BIN = 0.96875 100BIN = 1.03125 101BIN = 1.09375 110BIN = 1.15625 111BIN = 1.21875 3-0 Agent 3 – Agent 0 always return relative temperature in ARTR registers defined by 7.3.11. These bits specify that these relative temperatures are come from domain 0 or domain1. However this configuration is available only while RtHigher (Bank 2 Address 01HEX Bit[7]) is de-asserted. [bit3] = 0 / 1 => Agent3 will return the relative temperature from domain 0 / domain 1. [bit2] = 0 / 1 => Agent2 will return the relative temperature from domain 0 / domain 1. [bit1] = 0 / 1 => Agent1 will return the relative temperature from domain 0 / domain 1. [bit0] = 0 / 1 => Agent0 will return the relative temperature from domain 0 / domain 1. Nuvoton Confidential - 79 – 2017/7/25 Revision 1.45 NCT7904D 7.3.5 DTS Power Source Control Register Location: Bank 2 Address 04HEX Default Value: 01HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 DPSC BIT 7 6 NAME 5 4 3 2 Reserved 1 0 DTS_SRC_SEL DEFAULT 01HEX BIT DESCRIPTION T_RTA_EN 7-3 Reserved. 2-1 DTS_SRC_SEL – DTS Source Selection 00 = All from PECI 01 = All from Host (LSN_EN must be disable) 10 = Reserved 11 = Temperature from PECI and Power from Host (LSN_EN must be enable) T_RTA_EN – PECI Temperature Running Time Average Enable 0 = Disable 1 = Enable (Default) 0 7.3.6 TBit Width Register ( TBW ) Location: Bank 2 Address 05HEX Type: Read Reset: Power On Reset RESETIN# with LOCK=0 TBW BIT 7 6 5 4 3 2 1 0 NAME LSN_RST_CNT[6:0] DEFAULT 00HEX BIT DESCRIPTION 7-0 Record TBit time in PECI Listening mode. The allowable lowest PECI transaction speed is 125Kz. Nuvoton Confidential - 80 – 2017/7/25 Revision 1.45 NCT7904D 7.3.7 PECI Listening Mode Configuration Register ( PLMC ) Location: Bank 2 Address 06HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 TBW BIT 7 NAME 6 5 Reserved 4 3 2 LSN_CMD_ERR Reserved LSN_EN DEFAULT 01HEX BIT DESCRIPTION 7-5 1 0 LSN_TBIT_LW[1:0] Reserved 4 LSN_CMD_ERR: Indicator for command error while PECI listening mode is active 3 Reserved 2 LSN_EN: Enable PECI listening mode 1-0 LSN_TBIT_LW: Idle state period selection 00b = 2-TBit 01b = 3-TBit 10b = 4-TBit 11b = 5-TBit 7.3.8 PECI VTT Power Detect Configuration Register ( PVCR ) Location: Bank 2 Address 07HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 TBW BIT 7 NAME VTT_OK 6 5 4 Reserved 3 2 1 0 VTT_CRC VTT_CLR VTT_INIT_STS DEFAULT 03HEX BIT DESCRIPTION 7 6-3 VTT_OK : VTT power OK indicator. (read only) ‘0’ : VTT is not OK. ‘1’ : VTT is OK. Reserved 2 VTT_CRC : CRC input source selection ‘0’ : The input source of CRC is purely from PECI physical bus ‘1’ : The input source of CRC comes from host’s internal write-out data and PECI physical bus 1 VTT_CLR : Retention control for absolute temperature data Nuvoton Confidential - 81 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION ‘0’ : Keep last data while VTT is loss ‘1’ : Clear absolute temperature data to default value while VTT is loss 0 VTT_INIT_STS : PECI transaction control while VTT is shut off ‘0’ : PECI transaction never stop even though VTT is loss ‘1’ : Suspend PECI transaction while VTT is power loss 7.3.9 PECI Agent Tbase Temperature Register (PATB) Location: PATB 0 - Bank 2 Address 08HEX PATB 1 - Bank 2 Address 09HEX PATB 2 - Bank 2 Address 0AHEX PATB 3 - Bank 2 Address 0BHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PATB0 BIT 7 NAME Reserved 6 5 4 3 2 1 0 2 1 0 2 1 0 2 1 0 Tbase0[6:0] DEFAULT 00HEX PATB1 BIT 7 NAME Reserved 6 5 4 3 Tbase1[6:0] DEFAULT 00HEX PATB2 BIT 7 NAME Reserved 6 5 4 3 Tbase2[6:0] DEFAULT 00HEX PATB3 BIT 7 NAME Reserved 6 5 4 3 Tbase3[6:0] DEFAULT 00HEX BIT DESCRIPTION 7 6-0 Reserved Agent0 ~ Agent3 Tbase Temperature setting. With these setting, the PECI negative temperature format could be translated into positive format. Nuvoton Confidential - 82 – 2017/7/25 Revision 1.45 NCT7904D 7.3.10 PECI Power Averaging Configure Register (PPAC) Location: Address - Bank 2 Address 0CHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PPAC BIT 7 6 5 4 NAME RST_PECI DTS_En IvyBridge_ En GetDRAM_ En DEFAULT 0FHEX BIT DESCRIPTION 3 2 Reserved 1 0 P_AVG_SE L[1:0] 7 Reset PECI Function 6 Enabling DTS (Sensor) Based Thermal Spec supporting; in addition to PECI transaction, it also affects fan speed control. 1: Enable supporting DTS based thermal spec 0: Disable supporting 5 Margin source selection of DTS (Sensor) Based fan control. 1: Margin is provided by CPU directly 0: Margin is calculated by NCT7904D 4 Enable Get DRAM Temperature 1: Enable 0: Disable (Default) 3-2 Reserved 1-0 Running Time Average algorithm has been involved in CPU power reporting. 00BIN = PowerN +1 = Power _ Inst 1 1 PowerN +1 = ( PowerN ⋅ ) + ( Power _ Inst ⋅ ) 2 2 1 3 10BIN = PowerN +1 = ( PowerN ⋅ ) + ( Power _ Inst ⋅ ) 4 4 7 1 11BIN = PowerN +1 = ( PowerN ⋅ ) + ( Power _ Inst ⋅ ) 8 8 01BIN = Nuvoton Confidential - 83 – 2017/7/25 Revision 1.45 NCT7904D 7.3.11 Averaging DTS Based Thermal Spec Configure Register (ADBTSC) Location: Alpha_f Alpha_s Factor_C Type: Reset: - Bank 2 Address 0DHEX - Bank 2 Address 0EHEX - Bank 2 Address 0FHEX Read / Write Power On Reset RESETIN# with LOCK=0 Alpha_f / Alpha_s / Factor_C BIT 7 NAME 5 4 3 2 1 0 Alpha_f / Alpha_s / Factor_C DEFAULT FFHEX / BIT 7-0 6 12HEX / 62HEX DESCRIPTION Alpha_f / Alpha_s: the time constant coefficient ( unit : 1/second ) Factor_C: The scale factor for each average The averaging formula is as following. Tdts_f = Alpha_f X Tdts_max + Tdts_f_previous X ( 1 – Alpha_f ) Tdts_s = Alpha_s X Tdts_max + Tdts_s_previous X ( 1 – Alpha_s ) Tdts_ave = Factor_C X Tdts_f + ( 1 – Factor_C ) X Tdts_s Where: Tdts_max is the instantaneous DTS Based Thermal Spec. NCT7904D will automatically calculate it. Tdts_f_previous is the previous value of Tdts_f. Tdts_s_previous is the previous value of Tdts_s. The parameter value is to sum up each bit weighting. The weighting of each bit is defined as following. [7] = 0.5 [6] = 0.25 [5] = 0.125 [4] = 0.0625 [3] = 0.03125 [2] = 0.015625 [1] = 0.0078125 [0] = 0.00390625 Nuvoton Confidential - 84 – 2017/7/25 Revision 1.45 NCT7904D 7.3.12 PECI Manual Mode Configure Register (PMMC) Location: Address - Bank 2 Address 10HEX Write_Length - Bank 2 Address 11HEX Read_Length - Bank 2 Address 12HEX Command_Code - Bank 2 Address 13HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PMMC BIT 7 6 5 4 NAME Address DEFAULT 00HEX BIT 7 6 5 4 3 2 1 0 3 2 1 0 2 1 0 2 1 0 NAME Write Length DEFAULT 00HEX BIT 7 6 5 4 3 NAME Read Length DEFAULT 00HEX BIT 7 6 5 4 3 NAME Command Code DEFAULT 00HEX BIT DESCRIPTION 7-0 These settings are necessary while manual mode transaction is required. Please refer to formal PECI spec for more information on them. It should be setup in advance before Manual Mode enable ( Bank 2 Address 00HEX Bit[2] =1), Nuvoton Confidential - 85 – 2017/7/25 Revision 1.45 NCT7904D 7.3.13 PECI Manual Mode Write Data Register (PMMWD) Location: PMMWD 1 - Bank 2 Address 14HEX PMMWD 2 - Bank 2 Address 15HEX PMMWD 3 - Bank 2 Address 16HEX PMMWD 4 - Bank 2 Address 17HEX PMMWD 5 - Bank 2 Address 18HEX PMMWD 6 - Bank 2 Address 19HEX PMMWD 7 - Bank 2 Address 1AHEX PMMWD 8 - Bank 2 Address 1BHEX PMMWD 9 - Bank 2 Address 1CHEX PMMWD 10 - Bank 2 Address 1DHEX PMMWD 11 - Bank 2 Address 1EHEX PMMWD 12 - Bank 2 Address 1FHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PMMWD1 ~ PMMWD12 BIT 7 6 5 4 3 2 1 0 NAME Write Data 1 ~ Write Data 12 DEFAULT 00HEX BIT DESCRIPTION 7-0 These settings are necessary while manual mode transaction is required. Please refer to formal PECI spec for more information on them. It should be setup in advance before Manual Mode enable ( Bank 2 Address 00HEX Bit[2] =1), 7.3.14 PECI Manual Mode Read Data Register (PMMRD) Location: PMMRD 1 - Bank 2 Address 20HEX PMMRD 2 - Bank 2 Address 21HEX PMMRD 3 - Bank 2 Address 22HEX PMMRD 4 - Bank 2 Address 23HEX PMMRD 5 - Bank 2 Address 24HEX PMMRD 6 - Bank 2 Address 25HEX PMMRD 7 - Bank 2 Address 26HEX PMMRD 8 - Bank 2 Address 27HEX PMMRD 9 - Bank 2 Address 28HEX Type: Read Only Reset: Power On Reset Nuvoton Confidential - 86 – 2017/7/25 Revision 1.45 NCT7904D PMMRD1 ~ PMMRD9 BIT 7 6 5 4 3 2 1 0 NAME Read Data 1 ~ Read Data 9 DEFAULT 00HEX BIT DESCRIPTION 7-0 These data are meaningful just after manual mode transaction is finished. Please refer to formal PECI spec for more information on them. PECI Manual Mode Support Command and Data Write Length CR 11HEX Read Length CR 12HEX Ping 00 00 Get DIB 01 08 F7 Get Temp 01 02 01 06 02 / 03 / 05 61 08 / 09 / 0B 01 65 05 02 / 03 / 05 E1 07 / 08 / 0A 01 E5 PKGRd30 05 02 / 03 / 05 A1 PKGWr30 07 / 08 / 0A 01 A5 IAMSRRd30 05 02 / 03 / 05 / 09 B1 IAMSRWr30 07 / 08 / 0A / 0E 01 B5 Command Bank 2 Address CR 10HEX PCIRd30 30/ 31/ 32/ 33 PCIWr30 PCIRdLocal30 PCIWrLocal30 Command Code CR 13HEX PECI Manual Mode Read Data Table Command PCI Rd30 PCI Wr30 PCIRd Local3 0 PCIWr Local30 PKG Rd30 PKG Wr30 IAMSR Rd30 IAMSR Wr30 GetDIB GetTe mp Command Code 61 65 E1 E5 A1 A5 B1 B5 F7 01 RdData 1 CR 20HEX Ccode Ccode Ccode Ccode Ccode Ccod e Ccode Ccode * * RdData 2 CR 21HEX * * * * * * Data LSB_1 * Device Info * RdData 3 CR 22HEX * * * * * * Data LSB_2 * Revision Number * RdData 4 CR 23HEX * * * * * * Data LSB_3 * Reserved 1 * RdData 5 * * * * * * Data * Reserved * Nuvoton Confidential - 87 – 2017/7/25 Revision 1.45 NCT7904D Command PCI Rd30 PCIRd Local3 0 PCI Wr30 PCIWr Local30 PKG Rd30 PKG Wr30 IAMSR Rd30 IAMSR Wr30 LSB_4 CR 24HEX GetTe mp GetDIB 2 RdData 6 CR 25HEX Data LSB_1 * Data LSB_1 * Data LSB_1 * Data LSB_5 * Reserved 3 * RdData 7 CR 26HEX Data LSB_2 * Data LSB_2 * Data LSB_2 * Data LSB_6 * Reserved 4 * RdData 8 CR 27HEX Data LSB_3 * Data LSB_3 * Data LSB_3 * Data LSB_7 * Reserved 5 Temp_ LB RdData 9 CR 28HEX Data MSB * Data MSB * Data MSB * Data MSB * Reserved 6 Temp_ HB *mean do not care PECI Manual Command Write Data Table Command PCI Rd30 PCI Wr30 PCIRd Local30 PCIWr Local30 PKG Rd30 PKG Wr30 IAMSR Rd30 IAMSR Wr30 Command Code 61 65 E1 E5 A1 A5 B1 B5 WrData 1 CR 14HEX Host ID Host ID Host ID Host ID Host ID Host ID Host ID Host ID WrData 2 CR 15HEX Addr LSB_1 Addr LSB_1 Addr LSB_1 Addr LSB_1 Index Index Processor ID Processor ID WrData 3 CR 16HEX Addr LSB_2 Addr LSB_2 Addr LSB_2 Addr LSB_2 Param LSB Param LSB Addr LSB Addr LSB WrData 4 CR 17HEX Addr LSB_3 Addr LSB_3 Addr MSB Addr MSB Param MSB Param MSB Addr MSB Addr MSB WrData 5 CR 18HEX Addr MSB Addr MSB * Data LSB_1 * Data LSB_1 * Data LSB_1 WrData 6 CR 19HEX * Data LSB_1 * Data LSB_2 * Data LSB_2 * Data LSB_2 WrData 7 CR 1AHEX * Data LSB_2 * Data LSB_3 * Data LSB_3 * Data LSB_3 WrData 8 CR 1BHEX * Data LSB_3 * Data MSB * Data MSB * Data LSB_4 WrData 9 CR 1CHEX * Data MSB * * * * * Data LSB_5 WrData10 CR 1DHEX * * * * * * * Data LSB_6 WrData11 CR 1EHEX * * * * * * * Data LSB_7 Nuvoton Confidential - 88 – 2017/7/25 Revision 1.45 NCT7904D Command PCI Rd30 PCI Wr30 PCIRd Local30 PCIWr Local30 PKG Rd30 PKG Wr30 IAMSR Rd30 IAMSR Wr30 WrData12 CR 1FHEX * * * * * * * Data MSB *mean do not care 7.3.15 Agent Relative Temperature Registers (ARTR) Location: A0D0RTH - Bank 2 Address 30HEX A0D0RTL - Bank 2 Address 31HEX A0D1RTH - Bank 2 Address 32HEX A0D1RTL - Bank 2 Address 33HEX A1D0RTH - Bank 2 Address 34HEX A1D0RTL - Bank 2 Address 35HEX A1D1RTH - Bank 2 Address 36HEX A1D1RTL - Bank 2 Address 37HEX A2D0RTH - Bank 2 Address 38HEX A2D0RTL - Bank 2 Address 39HEX A2D1RTH - Bank 2 Address 3AHEX A2D1RTL - Bank 2 Address 3BHEX A3D0RTH - Bank 2 Address 3CHEX A3D0RTL - Bank 2 Address 3DHEX A3D1RTH - Bank 2 Address 3EHEX A3D1RTL - Bank 2 Address 3FHEX Type: Read Only Reset: Power On Reset BIT NAME 15 14 13 12 9 8 Temperature[8:2] DEFAULT NAME 10 A0D0RTH – A3D0RTH : Agent 0- Agent 3 Domain0 Relative Temperature High byte A0D1RTH – A3D1RTH : Agent 0- Agent 3 Domain1 Relative Temperature High byte Refer the PECI Temperature format to calculate temperature data. Sign BIT 11 F8HEX 7 6 5 4 3 2 1 0 A0D0RTL – A3D0RTL : Agent 0- Agent 3 Domain0 Relative Temperature Low byte A0D1RTL – A3D1RTL : Agent 0- Agent 3 Domain1 Relative Temperature Low byte Refer the PECI Temperature format to calculate temperature data. Temperature[1:0] DEFAULT Nuvoton Confidential TEMP_2 TEMP_4 TEMP_8 TEMP_1 6 TEMP_3 2 TEMP_6 4 80HEX - 89 – 2017/7/25 Revision 1.45 NCT7904D GetTemp() PECI Temperature format: BIT DESCRIPTION 15 Sign Bit. (Sign) In PECI Protocol, this bit should always be 1 to represent a negative temperature. 14-6 The integer part of the relative temperature. (Temperature[8:0]) 5 TEMP_2. 0.5℃ unit. 4 TEMP_4. 0.25℃ unit. 3 TEMP_8. 0.125℃ unit. 2 TEMP_16. 0.0625℃ unit. 1 TEMP_32. 0.03125℃ unit. 0 TEMP_64. 0.015625℃ unit. GetTemp() Response Definition: RESPONSE MEANING General Sensor Error (GSE) Thermal scan did not complete in time. Retry is appropriate. 0x0000 Processor is running at its maximum temperature or is currently being reset. All other data Valid temperature reading, reported as a negative offset from the TCC activation temperature. The valide temperature reading is referred to GetTemp() PECI Temperature format On some occasions, PECI will return the abnormal states of the PECI bus in addition to the temperature. All the information will be recorded. In some cases, the NCT7904D will also do further processing for the alert mechanism. The following describes these codes and their effects to the NCT7904D. Error Code Description NCT7904D host operation 8000HEX General Sensor Error 8001HEX Sensing Device Missing 8002HEX Operational, but the temperature is lower than the sensor operation range (underflow). Compulsorily write -128℃ back to the temperature readouts. 8003HEX Operational, but the temperature is higher than the sensor operation range. (overflow) compulsorily write 127℃ back to the temperature readouts. Reserved. No further operation. No further processing. 8004HEX ≀ 81FFHEX Nuvoton Confidential - 90 – 2017/7/25 Revision 1.45 NCT7904D 7.3.16 TSI Control Registers Location: Bank 2 Address 50HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 7 EN_TSI – Enable TSI function 0 = Disable 1 = Enable (* Set Bank2 Addr[53h] to 00h , before set EN_TSI=1) 6 LSN_MD – Enable TSI Listening function 0 = Disable 1 = Enable (Listened temperatures will override the CPU temperatures) 5-4 TSI_SPD[1:0] – TSI channel speed 00BIN = 250KHz 01BIN = 100KHz 10BIN = 50KHz 11BIN = 10KHz 3-0 Reserved 7.3.17 TSI Client Enable Registers Location: Bank 2 Address 51HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: FFHEX BIT 7-0 DESCRIPTION EN_CLIENT[7:0] – Enable TSI clients 0 = Disable 1 = Enable 7.3.18 TSI Manual Configuration Registers Location: Bank 2 Address 52HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 08HEX BIT DESCRIPTION 7 EN_MANU – Enable TSI manual mode 0 = Disable 1 = Enable 6 MANU_RNW – TSI manual read / write 0 = Write Nuvoton Confidential - 91 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 = Read 5 MANU_STEP – Enable TSI manual mode Set to do manual command one time then auto be cleared 4 MANU_STS – Report TSI Status (Read Only) 0 = Transaction OK 1 = Transaction fail 3 MANU_DONE – TSI Manual Done Status (Read Only) 0 = Transaction done 1 = Transaction still processing 2-0 Reserved 7.3.19 TSI Test Mode Registers Location: Bank 2 Address 53HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 02HEX BIT 7-0 DESCRIPTION Internal Test Mode Register[7:0] – Set this register to 00h before enable TSI function. 7.3.20 TSI Manual Address Registers Location: Bank 2 Address 54HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT DESCRIPTION 7-0 MANU_ADDR[7:0] – TSI manual command address 7.3.21 TSI Manual Command Registers Location: Bank 2 Address 55HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION MANU_CMD[7:0] – TSI manual command data Nuvoton Confidential - 92 – 2017/7/25 Revision 1.45 NCT7904D 7.3.22 TSI Manual Write Data Registers Location: Bank 2 Address 56HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION MANU_WDATA[7:0] – TSI manual write data 7.3.23 TSI Manual Read Data Registers Location: Bank 2 Address 57HEX Type: Read Only Reset: Power On Reset Default Value: 00HEX BIT 7-0 DESCRIPTION MANU_RDATA[7:0] – TSI manual read data 7.3.24 PCH Read Control Registers Location: Bank 2 Address 60HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 20HEX BIT DESCRIPTION 7 EN_PCH_RD – Enable PCH read function 0 = Disable 1 = Enable 6 Reserved 5-4 PCH_RD_SPD[1:0] – PCH channel read speed 00BIN = 250KHz 01BIN = 100KHz 10BIN = 50KHz 11BIN = 10KHz 3-0 Reserved 7.3.25 PCH Client Address Registers Location: Bank 2 Address 61HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION PCH_ADDR[7:0] – PCH client address Nuvoton Confidential - 93 – 2017/7/25 Revision 1.45 NCT7904D 7.3.26 PCH Command Registers Location: Bank 2 Address 62HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION PCH_CMD[7:0] – PCH command data 7.3.27 PCH Read Byte Count Registers Location: Bank 2 Address 63HEX Type: Read Only Reset: Power On Reset Default Value: 00HEX BIT 7-0 DESCRIPTION PCH_BYTE_CNT[7:0] – PCH read byte count 7.3.28 SMBUS Master Manual Configuration Registers Location: Bank 2 Address 64HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 08HEX BIT DESCRIPTION 7 EN_SM_MANU – Enable SMBUS Master manual mode 0 = Disable 1 = Enable 6 SM_RNW – SMBUS Master manual read / write 0 = Write 1 = Read 5 SM_STEP – Enable SMBUS Master manual mode Set to do manual command one time then auto be cleared 4 SM_STS – Report SMBUS Master Status (Read Only) 0 = Transaction OK 1 = Transaction fail 3 SM_DONE – SMBUS Master Manual Done Status (Read Only) 0 = Transaction done 1 = Transaction still processing 2-0 Reserved Nuvoton Confidential - 94 – 2017/7/25 Revision 1.45 NCT7904D 7.3.29 SMBUS Master Manual Address Registers Location: Bank 2 Address 65HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION SM_ADDR[7:0] – SMBUS Master manual command address 7.3.30 SMBUS Master Manual Command Registers Location: Bank 2 Address 66HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION SM_CMD[7:0] – SMBUS Master manual command data 7.3.31 SMBUS Master Manual Write Data Registers Location: Bank 2 Address 67HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7-0 DESCRIPTION SM_WDATA[7:0] – SMBUS Master manual write data 7.3.32 SMBUS Master Manual Read Data Registers Location: Bank 2 Address 68HEX Type: Read Only Reset: Power On Reset Default Value: 00HEX BIT 7-0 DESCRIPTION SM_RDATA[7:0] – SMBUS Master manual read data 7.3.33 External Read Control Registers Location: Bank 2 Address 6AHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Default Value: 00HEX BIT 7 DESCRIPTION EN_EXT_RD – Enable External Read function. Nuvoton Confidential - 95 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 0 = Disable 1 = Enable 6-4 Reserved 3 EN_EXT_P3 – Enable EXT_P3 read function. 0 = Disable 1 = Enable 2 EN_EXT_P2 – Enable EXT_P2 read function. 0 = Disable 1 = Enable 1 EN_EXT_P1 – Enable EXT_P1 read function. 0 = Disable 1 = Enable 0 EN_EXT_P0 – Enable EXT_P0 read function. 0 = Disable 1 = Enable 7.3.34 External Read Address and Command Register Location: EXT_ADDR_P0 - Bank 0 Address 6CHEX EXT_CMD_P0 - Bank 0 Address 6DHEX EXT_ADDR_P1 - Bank 0 Address 6EHEX EXT_CMD_P1 - Bank 0 Address 6FHEX EXT_ADDR_P2 - Bank 0 Address 70HEX EXT_CMD_P2 - Bank 0 Address 71HEX EXT_ADDR_P3 - Bank 0 Address 72HEX EXT_CMD_P3 - Bank 0 Address 73HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 EXT_ADDR_P0 – Port 0 external SMBUS address Location: Bank 2 Address 6CHEX Default Value: 00HEX BIT 7-0 DESCRIPTION EXT_ADDR_P0 – Port 0 external SMBUS address EXT_CMD_P0 – Port 0 external SMBUS command Location: Bank 2 Address 6DHEX Default Value: 00HEX BIT 7-0 DESCRIPTION EXT_CMD_P0 – Port 0 external SMBUS command EXT_ADDR_P1 – Port 1 external SMBUS address Location: Bank 2 Address 6EHEX Default Value: 00HEX Nuvoton Confidential - 96 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION EXT_ADDR_P1 – Port 1 external SMBUS address 7-0 EXT_CMD_P1 – Port 1 external SMBUS command Location: Bank 2 Address 6FHEX Default Value: 00HEX BIT DESCRIPTION EXT_CMD_P1 – Port 1 external SMBUS command 7-0 EXT_ADDR_P2 – Port 2 external SMBUS address Location: Bank 2 Address 70HEX Default Value: 00HEX BIT DESCRIPTION EXT_ADDR_P2 – Port 2 external SMBUS address 7-0 EXT_CMD_P2 – Port 2 external SMBUS command Location: Bank 2 Address 71HEX Default Value: 00HEX BIT DESCRIPTION EXT_CMD_P2 – Port 2 external SMBUS command 7-0 EXT_ADDR_P3 – Port 3 external SMBUS address Location: Bank 2 Address 72HEX Default Value: 00HEX BIT DESCRIPTION EXT_ADDR_P3 – Port 3 external SMBUS address 7-0 EXT_CMD_P3 – Port 3 external SMBUS command Location: Bank 2 Address 73HEX Default Value: 00HEX BIT DESCRIPTION EXT_CMD_P3 – Port 3 external SMBUS command 7-0 7.3.35 Power Unit Status Location: Bank 2 Address 80HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Power_Unit BIT 7 NAME 5 4 3 Reserved DEFAULT BIT 7-4 6 2 1 0 Power_Unit[3:0] 03HEX DESCRIPTION Reserved Nuvoton Confidential - 97 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION Power_Unit[3:0] – Unit index for power data retrieved from CPU over PECI The calculation of unit is 1W / 2^Power_Unit. Default is 03h. The manufacture setting will be loaded into as soon as PECI_En assertion. However user could override it by anytime. 3-0 7.3.36 Energy Unit Status Location: Bank 2 Address 81HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Energy_Unit BIT 7 NAME 6 5 4 3 Reserved 2 1 0 Energy_Unit[4:0] DEFAULT 10HEX BIT DESCRIPTION 7-5 Reserved 4-0 Energy_Unit[4:0] – Unit index for energy data retrieved from CPU over PECI The calculation of unit is 1J / 2^Energy_Unit. Default is 10h. The manufacture setting will be loaded into as soon as PECI_En assertion. However user could override it by anytime. 7.3.37 Retrieving Margin Status Control Registers Location: Type: Reset: CFG - Bank 2 Address 84HEX Read / Write Power On Reset RESETIN# with LOCK=0 CFG BIT 7 NAME 6 5 4 3 Reserved DEFAULT BIT 2 1 0 MARGIN_BSEL[1:0] 00HEX DESCRIPTION 7-2 Reserved 1-0 MARGIN_BSEL[1:0]: Pick-up selection of margin value among returned four bytes data from RdPkgConfig(). The pick-up data will be put into CR98 ~ CR9B Bit[1:0] = 11 => Select last retrieved byte, MSB rd Bit[1:0] = 10 => Select 3 retrieved byte Bit[1:0] = 01 => Select second retrieved byte Bit[1:0] = 00 => Select first retrieved byte, LSB Nuvoton Confidential - 98 – 2017/7/25 Revision 1.45 NCT7904D Location: Type: Reset: Default: MARGIN_INDEX - Bank 2 Address 85HEX Read / Write Power On Reset RESETIN# with LOCK=0 00HEX BIT 7-0 DESCRIPTION MARGIN_INDEX: Index data for executing RdPkgConfig() Location: Type: Reset: Default: MARGIN_PARA_L - Bank 2 Address 86HEX Read / Write Power On Reset RESETIN# with LOCK=0 00HEX BIT 7-0 DESCRIPTION MARGIN_PARA_L: Low byte of parameter data for executing RdPkgConfig() Location: Type: Reset: Default: MARGIN_PARA_H - Bank 2 Address 87HEX Read / Write Power On Reset RESETIN# with LOCK=0 00HEX BIT 7-0 DESCRIPTION MARGIN_PARA_H: High byte of parameter data for executing RdPkgConfig() 7.3.38 Tjmax Temperature Target Read/Write for CPU Agent (Address : 30h ~ 33h) Location: Tjmax_CPU0 - Bank 2 Address 88HEX Tjmax_CPU1 - Bank 2 Address 89HEX Tjmax_CPU2 - Bank 2 Address 8AHEX Tjmax_CPU3 - Bank 2 Address 8BHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 BIT 7-0 DESCRIPTION Tjmax_CPU0[7:0] – Tjmax data for agent address 30h Tjmax_CPU1[7:0] – Tjmax data for agent address 31h Tjmax_CPU2[7:0] – Tjmax data for agent address 32h Tjmax_CPU3[7:0] – Tjmax data for agent address 33h The manufacture setting will be loaded into as soon as PECI_En assertion. However user could override it by anytime. Nuvoton Confidential - 99 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION Default 00HEX 7.3.39 33h) Tcontrol Temperature Target Read/Write for CPU Agent (Address : 30h ~ Location: Tjmax_CPU0 - Bank 2 Address 8CHEX Tjmax_CPU1 - Bank 2 Address 8DHEX Tjmax_CPU2 - Bank 2 Address 8EHEX Tjmax_CPU3 - Bank 2 Address 8FHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 BIT DESCRIPTION Tcontrol_CPU0[7:0] – Tcontrol data for agent address 30h Tcontrol_CPU1[7:0] – Tcontrol data for agent address 31h Tcontrol_CPU2[7:0] – Tcontrol data for agent address 32h Tcontrol_CPU3[7:0] – Tcontrol data for agent address 33h The manufacture setting will be loaded into as soon as PECI_En assertion. However user could override it by anytime. 7-0 Default 00HEX 7.3.40 Thermal Design Power (TDP) Status for CPU Agent (Address : 30h ~ 33h) Location: TDP_HB_CPU0 - Bank 2 Address 90HEX TDP_LB_CPU0 - Bank 2 Address 91HEX TDP_HB_CPU1 - Bank 2 Address 92HEX TDP_LB_CPU1 - Bank 2 Address 93HEX TDP_HB_CPU2 - Bank 2 Address 94HEX TDP_LB_CPU2 - Bank 2 Address 95HEX TDP_HB_CPU3 - Bank 2 Address 96HEX TDP_LB_CPU3 - Bank 2 Address 97HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 TDP_HB_CPUx BIT 7 NAME Reserved 6 5 DEFAULT BIT 7 6-0 4 3 2 1 0 TDP_HB_CPUx[6:0] 00HEX DESCRIPTION Reserved High Byte Data of TDP[14:8] Nuvoton Confidential - 100 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION The manufacture setting will be loaded into as soon as PECI_En assertion. However user could override it by anytime. TDP_LB_CPUx BIT 7 6 5 4 3 NAME TDP_HB_CPUx DEFAULT 00HEX BIT 2 1 0 DESCRIPTION Low Byte Data of TDP[7:0] The manufacture setting will be loaded into as soon as PECI_En assertion. However user could override it by anytime. 7-0 7.3.41 Margin Status for CPU Agent (Address : 30h ~ 33h) Location: Margin_CPU1 - Bank 2 Address 98HEX Margin_CPU2 - Bank 2 Address 99HEX Margin_CPU3 - Bank 2 Address 9AHEX Margin_CPU4 - Bank 2 Address 9BHEX Type: Read Reset: Power On Reset RESETIN# with LOCK=0 Margin_CPUx BIT 7 6 5 4 3 NAME Margin_CPUx DEFAULT 00HEX BIT 7-0 2 1 0 DESCRIPTION Margin status for DTS (Sensor) Based Thermal Spec. If Margin is positive, then CPU die temperature is in relative safe operating region. If margin is negative, then CPU is working with higher temperature risk. 7.3.42 Power Reporting Factor for CPU Agent (Address : 30h ~ 33h) Location: Factor_CPU1 - Bank 2 Address 9CHEX Factor_CPU2 - Bank 2 Address 9DHEX Factor_CPU3 - Bank 2 Address 9EHEX Factor_CPU4 - Bank 2 Address 9FHEX Type: Read Reset: Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - 101 – 2017/7/25 Revision 1.45 NCT7904D Factor_CPUx BIT 7 6 5 4 3 NAME Factor_CPUx DEFAULT FFHEX 2 1 0 BIT DESCRIPTION 7-0 Factor_CPUx : Power reporting factor. Power reported over PECI is always higher than actual power. The Factor is to sum up each bit weighting. The weighting of each bit is defined as following. [7] = 0.5 [6] = 0.25 [5] = 0.125 [4] = 0.0625 [3] = 0.03125 [2] = 0.015625 [1] = 0.0078125 [0] = 0.00390625 7.3.43 DTS DRAM Temperature Monitor Enable Control Register Location: EN_MT_CTRL0 - Bank 2 Address C0HEX EN_MT_CTRL1 - Bank 2 Address C1HEX EN_T_DM_CTRL - Bank 2 Address C2HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 EN_MT_CTRL0 – Digital Channel Highest Temperature Monitoring Control Register Location: Bank 2 Address C0HEX Default Value: 00HEX BIT DESCRIPTION 7 EN_MT_C3_C1 – Enable DTS CPU1 Channel3 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 6 EN_MT_C2_C1 – Enable DTS CPU1 Channel2 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 5 EN_MT_C1_C1 – Enable DTS CPU1 Channel1 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 4 EN_MT_C0_C1 – Enable DTS CPU1 Channel0 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 3 EN_MT_C3_C0 – Enable DTS CPU0 Channel3 highest DIMM temperature monitoring. 0 = Disable Nuvoton Confidential - 102 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 = Enable 2 EN_MT_C2_C0 – Enable DTS CPU0 Channel2 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 1 EN_MT_C1_C0 – Enable DTS CPU0 Channel1 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 0 EN_MT_C0_C0 – Enable DTS CPU0 Channel0 highest DIMM temperature monitoring. 0 = Disable 1 = Enable EN_MT_CTRL1 – Digital Channel Highest Temperature Monitoring Control Register Location: Bank 2 Address C1HEX Default Value: 00HEX BIT 7-3 DESCRIPTION Reserved 2 EN_MT_SYS – Enable DTS CPU0 and CPU1 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 1 EN_MT_C1 – Enable DTS CPU1 highest DIMM temperature monitoring. 0 = Disable 1 = Enable 0 EN_MT_C0 – Enable DTS CPU0 highest DIMM temperature monitoring. 0 = Disable 1 = Enable EN_T_DM_CTRL – Digital DIMM Temperature Monitoring Control Register Location: Bank 2 Address C2HEX Default Value: 00HEX BIT DESCRIPTION 7 EN_T_C3_C1 – Enable DTS CPU1 Channel3 DIMMs temperature monitoring. 0 = Disable 1 = Enable 6 EN_T_C2_C1 – Enable DTS CPU1 Channel2 DIMMs temperature monitoring. 0 = Disable 1 = Enable 5 EN_T_C1_C1 – Enable DTS CPU1 Channel1 DIMMs temperature monitoring. 0 = Disable 1 = Enable 4 EN_T_C0_C1 – Enable DTS CPU1 Channel0 DIMMs temperature monitoring. 0 = Disable 1 = Enable 3 EN_T_C3_C0 – Enable DTS CPU0 Channel3 DIMMs temperature monitoring. 0 = Disable Nuvoton Confidential - 103 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 = Enable 2 EN_T_C2_C0 – Enable DTS CPU0 Channel2 DIMMs temperature monitoring. 0 = Disable 1 = Enable 1 EN_T_C1_C0 – Enable DTS CPU0 Channel1 DIMMs temperature monitoring. 0 = Disable 1 = Enable 0 EN_T_C0_C0 – Enable DTS CPU0 Channel0 DIMMs temperature monitoring. 0 = Disable 1 = Enable 7.3.44 DRAM Temperature Value Register (Reterived by PECI RdPkgConfig command) Location: MT_C0_C0 MT_C1_C0 MT_C2_C0 MT_C3_C0 MT_C0_C1 MT_C1_C1 MT_C2_C1 MT_C3_C1 MT_C0 MT_C1 MT_SYS T_D0C0_C0 T_D1C0_C0 T_D2C0_C0 EN_C0_C0 T_D0C1_C0 T_D1C1_C0 T_D2C1_C0 EN_C1_C0 T_D0C2_C0 T_D1C2_C0 T_D2C2_C0 EN_C2_C0 T_D0C3_C0 T_D1C3_C0 T_D2C3_C0 EN_C3_C0 T_D0C0_C1 T_D1C0_C1 T_D2C0_C1 EN_C0_C1 Nuvoton Confidential - Bank 2 Address C4HEX - Bank 2 Address C5HEX - Bank 2 Address C6HEX - Bank 2 Address C7HEX - Bank 2 Address C8HEX - Bank 2 Address C9HEX - Bank 2 Address CAHEX - Bank 2 Address CBHEX - Bank 2 Address CCHEX - Bank 2 Address CDHEX - Bank 2 Address CEHEX - Bank 2 Address D0HEX - Bank 2 Address D1HEX - Bank 2 Address D2HEX - Bank 2 Address D3HEX - Bank 2 Address D4HEX - Bank 2 Address D5HEX - Bank 2 Address D6HEX - Bank 2 Address D7HEX - Bank 2 Address D8HEX - Bank 2 Address D9HEX - Bank 2 Address DAHEX - Bank 2 Address DBHEX - Bank 2 Address DCHEX - Bank 2 Address DDHEX - Bank 2 Address DEHEX - Bank 2 Address DFHEX - Bank 2 Address E0HEX - Bank 2 Address E1HEX - Bank 2 Address E2HEX - Bank 2 Address E3HEX - 104 – 2017/7/25 Revision 1.45 NCT7904D T_D0C1_C1 - Bank 2 Address E4HEX T_D1C1_C1 - Bank 2 Address E5HEX T_D2C1_C1 - Bank 2 Address E6HEX EN_C1_C1 - Bank 2 Address E7HEX T_D0C2_C1 - Bank 2 Address E8HEX T_D1C2_C1 - Bank 2 Address E9HEX T_D2C2_C1 - Bank 2 Address EAHEX EN_C2_C1 - Bank 2 Address EBHEX T_D0C3_C1 - Bank 2 Address ECHEX T_D1C3_C1 - Bank 2 Address EDHEX T_D2C3_C1 - Bank 2 Address EEHEX EN_C3_C1 - Bank 2 Address EFHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 MT_C0_C0 – CPU0 Channel0 Highest DIMM Temperature Value Register Location: Bank 2 Address C4HEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C0_C0 [7:0] CPU0 Channel0 Highest DIMM Temperature MT_C1_C0 – CPU0 Channel1 Highest DIMM Temperature Value Register Location: Bank 2 Address C5HEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C1_C0 [7:0] CPU0 Channel1 Highest DIMM Temperature MT_C2_C0 – CPU0 Channel2 Highest DIMM Temperature Value Register Location: Bank 2 Address C6HEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C2_C0 [7:0] CPU0 Channel2 Highest DIMM Temperature MT_C3_C0 – CPU0 Channel3 Highest DIMM Temperature Value Register Location: Bank 2 Address C7HEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C3_C0 [7:0] CPU0 Channel3 Highest DIMM Temperature Nuvoton Confidential - 105 – 2017/7/25 Revision 1.45 NCT7904D MT_C0_C1 – CPU1 Channel0 Highest DIMM Temperature Value Register Location: Bank 2 Address C8HEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C0_C1 [7:0] CPU1 Channel0 Highest DIMM Temperature MT_C1_C1 – CPU1 Channel1 Highest DIMM Temperature Value Register Location: Bank 2 Address C9HEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C1_C1 [7:0] CPU1 Channel1 Highest DIMM Temperature MT_C2_C1 – CPU1 Channel2 Highest DIMM Temperature Value Register Location: Bank 2 Address CAHEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C2_C1 [7:0] CPU1 Channel2 Highest DIMM Temperature MT_C3_C1 – CPU1 Channel3 Highest DIMM Temperature Value Register Location: Bank 2 Address CBHEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C3_C1 [7:0] CPU1 Channel3 Highest DIMM Temperature MT_C0 – CPU0 Highest DIMM Temperature Value Register Location: Bank 2 Address CCHEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C0 [7:0] CPU0 Highest DIMM Temperature MT_C1 – CPU1 Highest DIMM Temperature Value Register Location: Bank 2 Address CDHEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_C1 [7:0] CPU1 Highest DIMM Temperature Nuvoton Confidential - 106 – 2017/7/25 Revision 1.45 NCT7904D MT_SYS – CPU0 and CPU1 Highest DIMM Temperature Value Register Location: Bank 2 Address CEHEX Default Value: 00HEX BIT 7-0 DESCRIPTION MT_SYS [7:0] CPU0 and CPU1 Highest DIMM Temperature T_DxC0_C0 – CPU0 Channel0 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address D0HEX ~ D2HEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C0_C0 [7:0] ~ T_D2C0_C0 [7:0] T_D0C0_C0 : CPU0 Channel0 DIMM0 Temperature T_D1C0_C0 : CPU0 Channel0 DIMM1 Temperature T_D2C0_C0 : CPU0 Channel0 DIMM2 Temperature EN_C0_C0 – Enable Read CPU0 Channel0 DIMM Temperature Register Location: Bank 2 Address D3HEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH0_C0 – Enable DTS CPU0 Channel0 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH0_C0 – Enable DTS CPU0 Channel0 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH0_C0 – Enable DTS CPU0 Channel0 DIMM0 temperature monitoring. 0 = Disable 1 = Enable T_DxC1_C0 – CPU0 Channel1 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address D4HEX ~ D6HEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C1_C0 [7:0] ~ T_D2C1_C0 [7:0] T_D0C1_C0 : CPU0 Channel1 DIMM0 Temperature T_D1C1_C0 : CPU0 Channel1 DIMM1 Temperature T_D2C1_C0 : CPU0 Channel1 DIMM2 Temperature Nuvoton Confidential - 107 – 2017/7/25 Revision 1.45 NCT7904D EN_C1_C0 – Enable Read CPU0 Channel1 DIMM Temperature Register Location: Bank 2 Address D7HEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH1_C0 – Enable DTS CPU0 Channel1 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH1_C0 – Enable DTS CPU0 Channel1 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH1_C0 – Enable DTS CPU0 Channel1 DIMM0 temperature monitoring. 0 = Disable 1 = Enable T_DxC2_C0 – CPU0 Channel2 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address D8HEX ~ DAHEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C2_C0 [7:0] ~ T_D2C2_C0 [7:0] T_D0C2_C0 : CPU0 Channel2 DIMM0 Temperature T_D1C2_C0 : CPU0 Channel2 DIMM1 Temperature T_D2C2_C0 : CPU0 Channel2 DIMM2 Temperature EN_C2_C0 – Enable Read CPU0 Channel2 DIMM Temperature Register Location: Bank 2 Address DBHEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH2_C0 – Enable DTS CPU0 Channel2 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH2_C0 – Enable DTS CPU0 Channel2 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH2_C0 – Enable DTS CPU0 Channel2 DIMM0 temperature monitoring. 0 = Disable 1 = Enable T_DxC3_C0 – CPU0 Channel3 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address DCHEX ~ DEHEX Default Value: 00HEX BIT 7-0 DESCRIPTION T_D0C3_C0 [7:0] ~ T_D2C3_C0 [7:0] Nuvoton Confidential - 108 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION T_D0C3_C0 : CPU0 Channel3 DIMM0 Temperature T_D1C3_C0 : CPU0 Channel3 DIMM1 Temperature T_D2C3_C0 : CPU0 Channel3 DIMM2 Temperature EN_C3_C0 – Enable Read CPU0 Channel3 DIMM Temperature Register Location: Bank 2 Address DFHEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH3_C0 – Enable DTS CPU0 Channel3 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH3_C0 – Enable DTS CPU0 Channel3 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH3_C0 – Enable DTS CPU0 Channel3 DIMM0 temperature monitoring. 0 = Disable 1 = Enable T_DxC0_C1 – CPU1 Channel0 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address E0HEX ~ E2HEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C0_C1 [7:0] ~ T_D2C0_C1 [7:0] T_D0C0_C1 : CPU1 Channel0 DIMM0 Temperature T_D1C0_C1 : CPU1 Channel0 DIMM1 Temperature T_D2C0_C1 : CPU1 Channel0 DIMM2 Temperature EN_C0_C1 – Enable Read CPU1 Channel0 DIMM Temperature Register Location: Bank 2 Address E3HEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH0_C1 – Enable DTS CPU1 Channel0 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH0_C1 – Enable DTS CPU1 Channel0 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH0_C1 – Enable DTS CPU1 Channel0 DIMM0 temperature monitoring. 0 = Disable 1 = Enable Nuvoton Confidential - 109 – 2017/7/25 Revision 1.45 NCT7904D T_DxC1_C1 – CPU1 Channel1 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address E4HEX ~ E6HEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C1_C1 [7:0] ~ T_D2C1_C1 [7:0] T_D0C1_C1 : CPU1 Channel1 DIMM0 Temperature T_D1C1_C1 : CPU1 Channel1 DIMM1 Temperature T_D2C1_C1 : CPU1 Channel1 DIMM2 Temperature EN_C1_C1 – Enable Read CPU1 Channel1 DIMM Temperature Register Location: Bank 2 Address E7HEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH1_C1 – Enable DTS CPU1 Channel1 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH1_C1 – Enable DTS CPU1 Channel1 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH1_C1 – Enable DTS CPU1 Channel1 DIMM0 temperature monitoring. 0 = Disable 1 = Enable T_DxC2_C1 – CPU1 Channel2 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address E8HEX ~ EAHEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C2_C1 [7:0] ~ T_D2C2_C1 [7:0] T_D0C2_C1 : CPU1 Channel2 DIMM0 Temperature T_D1C2_C1 : CPU1 Channel2 DIMM1 Temperature T_D2C2_C1 : CPU1 Channel2 DIMM2 Temperature EN_C2_C1 – Enable Read CPU1 Channel2 DIMM Temperature Register Location: Bank 2 Address EBHEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH2_C1 – Enable DTS CPU1 Channel2 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH2_C1 – Enable DTS CPU1 Channel2 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH2_C1 – Enable DTS CPU1 Channel2 DIMM0 temperature monitoring. 0 = Disable Nuvoton Confidential - 110 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 1 = Enable T_DxC3_C1 – CPU1 Channel3 DIMM0~DIMM2 Temperature Value Register Location: Bank 2 Address ECHEX ~ EEHEX Default Value: 00HEX BIT DESCRIPTION 7-0 T_D0C3_C1 [7:0] ~ T_D2C3_C1 [7:0] T_D0C3_C1 : CPU1 Channel3 DIMM0 Temperature T_D1C3_C1 : CPU1 Channel3 DIMM1 Temperature T_D2C3_C1 : CPU1 Channel3 DIMM2 Temperature EN_C3_C1 – Enable Read CPU1 Channel3 DIMM Temperature Register Location: Bank 2 Address EFHEX Default Value: 07HEX BIT 7-3 2 1 0 DESCRIPTION Reserved EN_T_DIMM2_CH3_C1 – Enable DTS CPU1 Channel3 DIMM2 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM1_CH3_C1 – Enable DTS CPU1 Channel3 DIMM1 temperature monitoring. 0 = Disable 1 = Enable EN_T_DIMM0_CH3_C1 – Enable DTS CPU1 Channel3 DIMM0 temperature monitoring. 0 = Disable 1 = Enable Nuvoton Confidential - 111 – 2017/7/25 Revision 1.45 NCT7904D 7.4 Bank 3 REGISTER DETAIL 7.4.1 Temperature to Fan Mapping Relationships (TFMR) Location: T1FMR - Bank 3 Address 00HEX T2FMR - Bank 3 Address 01HEX T3FMR - Bank 3 Address 02HEX T4FMR - Bank 3 Address 03HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 T1FMR – T4FMR BIT 7 NAME 6 5 4 Reserved 3 2 1 0 F4SF F3SF F2SF F1SF DEFAULT 00HEX BIT DESCRIPTION 7-4 Reserved 3-0 F4SF – F1SF setting involves two purposes. The one is building up the relation between temperature source 1~4 and FANCTL1~4, the other is Fan Control mode assignment. 0 = Related FANCTL will operate in manual mode and have no relationship with temperature (Default) 1 = Related FANCTL will operate with SmartFan control mode and be linked to relative temperature source 1 ~ 4. 7.4.2 Default Fan Speed at Power-on (DFSP) Location: DFSP - Bank 3 Address 04HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 DFSP BIT 7 6 5 4 3 NAME DefaultSpeed DEFAULT 7FHEX BIT 7-0 2 1 0 DESCRIPTION Specify default fan output duty cycle after 3VDD is available Nuvoton Confidential - 112 – 2017/7/25 Revision 1.45 NCT7904D 7.4.3 SmartFan Output Step Up Time (SFOSUT) Location: SFOSUT - Bank 3 Address 05HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 SFOSUT BIT 7 6 5 4 NAME 3 2 1 0 1 0 1 0 UpTime DEFAULT 0AHEX BIT DESCRIPTION 7-0 The update rate for increasing fan output duty cycle. Unit: 0.1sec. 7.4.4 SmartFan Output Step Down Time (SFOSDT) Location: SFOSDT - Bank 3 Address 06HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 SFOSUT BIT 7 6 5 4 3 NAME DownTime DEFAULT 0AHEX BIT DESCRIPTION 7-0 The update rate for decreasing fan output duty cycle. 2 Unit: 0.1sec. 7.4.5 3-Wire Fan Enable and Fan Output Mode Control (FOMC) Location: FOMC - Bank 3 Address 07HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FOMC BIT 7 NAME 6 5 3WireFan_En[3:0] 4 3 F4OMC 2 Reserved DEFAULT 00HEX BIT DESCRIPTION 7-4 Enable ultra-low speed DC fan control. It means that DC fan could be driven by very small PWM output frequency or fewer duty cycles. Nuvoton Confidential - 113 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 3WireFan_En[3]: Enable FANCTL4 with this function 3WireFan_En[2]: Enable FANCTL3 with this function 3WireFan_En[1]: Enable FANCTL2 with this function 3WireFan_En[0]: Enable FANCTL1 with this function F4OMC: FANCTL4 output mode control. 0 = PWM output (Default) 1 = DC output 3 2-0 Reserved 7.4.6 Close-Loop Fan control RPM mode and Tolerance (CLFR) Location: CLFR - Bank 3 Address 08HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 CLFR BIT 7 NAME 6 5 4 3 RPM_En[3:0] 2 1 0 Generic_Tol_RPM DEFAULT 02HEX BIT DESCRIPTION 7-4 Close loop (RPM) or Open loop (Fan Duty) Smart Fan control mode selection RPM_En[3] = 1 => Configure FANCTL4 as Close Loop mode, otherwise, it is open loop mode. RPM_En[2] = 1 => Configure FANCTL3 as Close Loop mode, otherwise, it is open loop mode. RPM_En[1] = 1 => Configure FANCTL2 as Close Loop mode, otherwise, it is open loop mode. RPM_En[0] = 1 => Configure FANCTL1 as Close Loop mode, otherwise, it is open loop mode. 3-0 RPM tracking target tolerance. It could suppress the oscillation phenomenon in target RPM lock period. Generic_Tol_RPM: Tolerance of RPM mode, unit is 50 RPMs. If Enable RHSF - Bank 3 Address 0EHEX, unit is 100 RPM. 7.4.7 Temperature Source Selection (TSS) Location: F1TSS - Bank 3 Address 09HEX F2TSS - Bank 3 Address 0AHEX F3TSS - Bank 3 Address 0BHEX F4TSS - Bank 3 Address 0CHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - 114 – 2017/7/25 Revision 1.45 NCT7904D F1TSS – F4TSS BIT NAME 7 6 5 4 3 Reserved 2 00HEX BIT DESCRIPTION 7-6 Reserved 5-0 TSS: Temperature source selection 00_0000: VSEN2_HV/TEMP_CH1_HV - Bank 0 Address 42HEX 00_0001: VSEN4_HV/TEMP_CH2_HV - Bank 0 Address 46HEX 00_0010: VSEN6_HV/TEMP_CH3_HV - Bank 0 Address 4AHEX 00_0011: VSEN8_HV/TEMP_CH4_HV - Bank 0 Address 4EHEX -Bank 0 Address 62HEX 00_0101: T_CPU1_HV - Bank 0 Address A0HEX 00_0110: T_CPU2_HV - Bank 0 Address A2HEX 00_0111: T_CPU3_HV - Bank 0 Address A4HEX 00_1000: T_CPU4_HV - Bank 0 Address A6HEX 00_1001: T_CPU5_HV - Bank 0 Address A8HEX 00_1010: T_CPU6_HV - Bank 0 Address AAHEX 00_1011: T_CPU7_HV - Bank 0 Address ACHEX 00_1100: PCH_PCH_0 - Bank 0 Address F0HEX 00_1101: PCH_PCH_1 - Bank 0 Address F1HEX 00_1110: PCH_CPU_I - Bank 0 Address F3HEX 00_1111: PCH_MCH - Bank 0 Address F4HEX 01_0000: PCH_DIMM0 - Bank 0 Address F5HEX 01_0001: PCH_DIMM1 - Bank 0 Address F6HEX 01_0010: PCH_DIMM2 - Bank 0 Address F7HEX 01_0011: PCH_DIMM3 - Bank 0 Address F8HEX 01_0100: VRT_TEMP1_V - Bank 0 Address B8HEX 01_0101: VRT_TEMP2_V - Bank 0 Address B9HEX 01_0110: VRT_TEMP3_V - Bank 0 Address BAHEX 01_0111: VRT_TEMP4_V - Bank 0 Address BBHEX 01_1000: MT_C0_C0 - Bank 2 Address C4HEX 01_1001: MT_C1_C0 - Bank 2 Address C5HEX 01_1010: MT_C2_C0 - Bank 2 Address C6HEX 01_1011: MT_C3_C0 - Bank 2 Address C7HEX 01_1100: MT_C0_C1 - Bank 2 Address C8HEX Nuvoton Confidential 0 TSS[5:0] DEFAULT 00_0100: LTD_HV 1 - 115 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 01_1101: MT_C1_C1 - Bank 2 Address C9HEX 01_1110: MT_C2_C1 - Bank 2 Address CAHEX 01_1111: MT_C3_C1 - Bank 2 Address CBHEX 10_0000: MT_C0 - Bank 2 Address CCHEX 10_0001: MT_C1 - Bank 2 Address CDHEX 10_0010: MT_SYS - Bank 2 Address CEHEX 10_0011: EXT_VRT_TEMP1_V - Bank 0 Address BCHEX 10_0100: EXT_VRT_TEMP2_V - Bank 0 Address BDHEX 10_0101: EXT_VRT_TEMP3_V - Bank 0 Address BEHEX 10_0110: EXT_VRT_TEMP4_V - Bank 0 Address BFHEX 10_0111 ~ 11_1111: Reserved 7.4.8 Power Accumulate Enable (PAE) Location: PAE - Bank 3 Address 0DHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PAE BIT 7 NAME 6 5 4 3 Reserved 1 0 PWR_MD[3:0] DEFAULT 00HEX BIT DESCRIPTION 7-4 Reserved. 3-0 Sensor based fan control mode enabling. PWR_MD[3] = 1 => FANCTL4 supports sensor driven by other traditional fan control mode. PWR_MD[2] = 1 => FANCTL3 supports sensor driven by other traditional fan control mode. PWR_MD[1] = 1 => FANCTL2 supports sensor driven by other traditional fan control mode. PWR_MD[0] = 1 => FANCTL1 supports sensor driven by other traditional fan control mode. Nuvoton Confidential 2 - 116 – based fan control. Otherwise, it is based fan control. Otherwise, it is based fan control. Otherwise, it is based fan control. Otherwise, it is 2017/7/25 Revision 1.45 NCT7904D 7.4.9 Close-Loop Fan Control RPM mode for High Speed Fan Register (RHSF) Location: RHSF - Bank 3 Address 0EHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 RHSF BIT 7 NAME SF_TM_U 6 5 4 3 Reserved 2 1 0 RPM_HS[3:0] DEFAULT 00HEX BIT DESCRIPTION 7 Smart FAN IV PWM values update rate. SF_TM_U = 0 => Update rate is 10 times/sec. SF_TM_U = 1 => Update rate is 20 times/sec. 6-4 Reserved. 3-0 Changing default unit of all RPM setting from 50 RPMs to 100 RPMs. It benefits to control ultra-high RPM fan. RPM_HS[3] = 1 => FANCTL4 supports ultra-high RPM fan control. RPM_HS[2] = 1 => FANCTL3 supports ultra-high RPM fan control. RPM_HS[1] = 1 => FANCTL2 supports ultra-high RPM fan control. RPM_HS[0] = 1 => FANCTL1 supports ultra-high RPM fan control. 7.4.10 PROCHOT Fan Select (PFS) Location: PFS - Bank 3 Address 0FHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 PFS BIT 7 NAME 6 5 4 3 Reserved 2 1 0 PHOT_FAN_SEL[3:0] DEFAULT 00HEX BIT DESCRIPTION 7-4 Reserved. 3-0 Select targeted FANCTL to react to specific thermal alert event. PHOT_FAN_SEL[3] = 1 => FANCTL4 will respond to specific thermal alert event. PHOT_FAN_SEL[2] = 1 => FANCTL3 will respond to specific thermal alert event. PHOT_FAN_SEL[1] = 1 => FANCTL2 will respond to specific thermal alert event. PHOT_FAN_SEL[0] = 1 => FANCTL1 will respond to specific thermal alert event. These settings are available only while asserting PH_CTRL0 defined in Bank 0 Address 23HEX Nuvoton Confidential - 117 – 2017/7/25 Revision 1.45 NCT7904D 7.4.11 Fan Output Value (FOV) Location: F1OV - Bank 3 Address 10HEX F2OV - Bank 3 Address 11HEX F3OV - Bank 3 Address 12HEX F4OV - Bank 3 Address 13HEX Type: Read / Write (in Manual Mode) Read Only (in the Smart Fan mode) Reset: Power On Reset RESETIN# with LOCK=0 F1OV – F4OV BIT 7 6 5 4 3 2 1 0 NAME Output Value DEFAULT Depend on DefaultSpeed. 7FHEX. BIT DESCRIPTION 7-0 Output Value involves two meaning. The one is current out fan duty in Smart Fan mode, the other is fixed fan output duty cycle in manual mode. If 3VDD is loss, these registers are set back to zero by hardware. 7.4.12 Fan Output PWM Frequency Prescalar (FOPFP) Location: F1OPFP - Bank 3 Address 14HEX F2OPFP - Bank 3 Address 15HEX F3OPFP - Bank 3 Address 16HEX F4OPFP - Bank 3 Address 17HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 F1OPFP – F4OPFP BIT 7 NAME CKSEL DEFAULT 1 6 5 4 1 0 0 0 0 0 1 0 0 DESCRIPTION CKSEL – Clock source select. CLKSEL 0 1 6-0 2 Divisor BIT 7 3 14.318MHz 1.024KHz 55.93Kz CLKIN Frequency 33MHz 1.024KHz 130.21KHz 48MHz 1KHz 125KHz Divisor – Clock frequency Divisor. Nuvoton Confidential - 118 – 2017/7/25 Revision 1.45 NCT7904D The clock source selected by CKSEL will be divided by the divisor and used as a fan PWM output frequency. There are 2 divisors depending on CKSEL. If CKSEL equals 1, then the output clock is simply equal to 130.21/ (Divisor+1) KHz (@ frequency of CLKIN is 33MHz). If CKSEL equals 0, the output clock is 1KHz/MappedDivisor. MappedDivisor depends on Divisor[3:0] and is described in the table below. Divisor[3:0] Mapped Divisor Output Frequency Divisor[3:0] Mapped Divisor Output Frequency 0000 1 1024Hz 1000 12 85Hz 0001 2 512Hz 1001 16 64Hz 0010 3 341Hz 1010 32 32Hz 0011 4 256Hz 1011 64 16Hz 0100 5 205Hz 1100 128 8Hz 0101 6 171Hz 1101 256 4Hz 0110 7 146Hz 1110 512 2Hz 0111 8 128Hz 1111 1024 1Hz 7.4.13 Fan Output Nonstop Enable (FONE) Location: FONE - Bank 3 Address 18HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FONE BIT 7 NAME 6 5 4 3 Reserved 2 1 0 NON_STOP_En[3:0] DEFAULT 00HEX BIT DESCRIPTION 7-4 Reserved. 3-0 Enabling the feature that fan could be stopped with special condition. This feature also requires other setting, including Bank 3 Address 2CHEX , 2DHEX , 2EHEX and 2FHEX in FONV (Fan Output Nonstop Value) NON_STOP_En[3] = 1 => Enable FANCTL4 stop function. NON_STOP_En[2] = 1 => Enable FANCTL3 stop function. NON_STOP_En[1] = 1 => Enable FANCTL2 stop function. NON_STOP_En[0] = 1 => Enable FANCTL1 stop function. 7.4.14 Fan Tachometer Source Selection (FTSS) Location: FTSS - Bank 3 Address 1BHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FTSS Nuvoton Confidential - 119 – 2017/7/25 Revision 1.45 NCT7904D BIT 7 NAME 6 5 4 3 FAN2_SEL 2 1 0 FAN1_SEL DEFAULT 00HEX BIT DESCRIPTION 7-4 F2FTSS: Fan2 Tachometers Source Selection 3-0 F1FTSS: Fan1 Tachometers Source Selection 0000: Source Select FANIN_1 0001: Source Select FANIN_2 0010: Source Select FANIN_3 0011: Source Select FANIN_4 0100: Source Select FANIN_5 0101: Source Select FANIN_6 0110: Source Select FANIN_7 0111: Source Select FANIN_8 1000: Source Select FANIN_9 1001: Source Select FANIN_10 1010: Source Select FANIN_11 1011: Source Select FANIN_12 7.4.15 Fan Tachometer Source Selection (FTSS) Location: FTSS - Bank 3 Address 1CHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FTSS BIT 7 NAME 6 5 4 3 FAN4_SEL 1 0 FAN3_SEL DEFAULT 00HEX BIT DESCRIPTION 7-4 F4FTSS: Fan4 Tachometers Source Selection 3-0 F3FTSS: Fan3 Tachometers Source Selection 0000: Source Select FANIN_1 0001: Source Select FANIN_2 0010: Source Select FANIN_3 0011: Source Select FANIN_4 0100: Source Select FANIN_5 0101: Source Select FANIN_6 0110: Source Select FANIN_7 0111: Source Select FANIN_8 1000: Source Select FANIN_9 1001: Source Select FANIN_10 1010: Source Select FANIN_11 1011: Source Select FANIN_12 Nuvoton Confidential 2 - 120 – 2017/7/25 Revision 1.45 NCT7904D 7.4.16 Critical Temperature to Full Speed all fan (CTFS) Location: T1CTFS - Bank 3 Address 20HEX T2CTFS - Bank 3 Address 21HEX T3CTFS - Bank 3 Address 22HEX T4CTFS - Bank 3 Address 23HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 T1CTFS – T4CTFS BIT 7 6 5 4 3 2 1 0 NAME Critical Temperature DEFAULT 5AHEX (90℃) BIT DESCRIPTION 7-0 Critical Temperature setting for each Smart Fan Table. While temperature source exceeds the critical temperature, the relative FANCTL will output full duty cycle. Unit in ℃. 7.4.17 Hysteresis of Temperature (HT) Location: HT1 - Bank 3 Address 24HEX HT2 - Bank 3 Address 25HEX HT3 - Bank 3 Address 26HEX HT4 - Bank 3 Address 27HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 HT1 – HT4 BIT 7 NAME Reserved DEFAULT 6-4 3 5 4 Hysteresis of Critical Temperature 3 Reserved 5HEX (5℃) BIT 7 6 2 1 0 Hysteresis of Operation Temperature 3HEX (3℃) DESCRIPTION Reserved Hysteresis of Critical Temperature: Hysteresis for critical temperature on Smart Fan Table 1 ~ 4. The range is 0℃~7℃ Reserved Nuvoton Confidential - 121 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 2-0 Hysteresis of Operation Temperature: Hysteresis for normal temperature on Smart Fan Table 1 ~ 4. The range is 0℃~7℃ 7.4.18 Fan Output Nonstop Value(FONV) Location: FONV1 - Bank 3 Address 2CHEX FONV2 - Bank 3 Address 2DHEX FONV3 - Bank 3 Address 2EHEX FONV4 - Bank 3 Address 2FHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FONV1 –FONV4 BIT 7 6 5 4 3 2 1 0 NAME Fan Output Nonstop Value DEFAULT 14HEX BIT DESCRIPTION 7-0 Fan Output Nonstop Value for each FANCTL output. If enable FONE - Bank 3 Address 18HEX, the relative FANCTL will output FONV duty cycle. 7.4.19 SMART FANTM IV Temperature and DC/PWM Table (SFIV) Location: Relative Register-at SMART FAN RELATIVE TEMPERAUTRE Temp1 Temp2 Temp3 Temp4 Type: Reset: TM IV Control Mode Table NNEMONIC ADD (Hex) TYPE T1 – T4 30-33 RW PWM1 – PWM4 34-37 RW T1 – T4 38-3B RW PWM1 – PWM4 3C-3F RW T1 – T4 40-43 RW PWM1 – PWM4 44-47 RW T1 – T4 48-4B RW DC/PWM1 – DC/PWM4 4C-4F RW Read / Write Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - 122 – 2017/7/25 Revision 1.45 NCT7904D T1 – T4 BIT 7 6 5 NAME 4 SMART FAN 3 TM 2 1 0 2 1 0 2 1 0 IV Temperature Table T1 = 19HEX (25℃) DEFAULT Table T2 = 23HEX (35℃) Table T3 = 2DHEX (45℃) Table T4 = 37HEX (55℃) DC/PWM1 – DC/PWM4 BIT 7 6 5 NAME 4 3 SMART FAN TM IV DC/PWM Table P1 = 8CHEX (140 Duty) DEFAULT Table P2 = AAHEX (170 Duty) Table P3 = C8HEX (200 Duty) Table P4 = E6HEX (230 Duty) 7.4.20 Configure Register of PECI Error (CRPE) Location: CRPE - Bank 3 Address 50HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 CRPE BIT NAME 7 6 5 PECI_ERR_FAN4 BIT[1-0] 4 3 PECI_ERR_FAN3 BIT[1-0] PECI_ERR_FAN2 BIT[1-0] PECI_ERR_FAN1 BIT[1-0] Refer to PECI Error Condition Table for fan output value. DEFAULT 00HEX BIT DESCRIPTION 7-6 FANCTL4 output state selection while PECI served as temperature source happens any abnormal condition. 5-4 FANCTL3 output state selection while PECI served as temperature source happens any abnormal condition. 3-2 FANCTL2 output state selection while PECI served as temperature source happens any abnormal condition. 1-0 FANCTL1 output state selection while PECI served as temperature source happens any abnormal condition. PECI Error Condition Table: BIT [1-0] 00BIN 01BIN 1xBIN PECI Error Condition Fan output value keeps at its current value. Fan output value will be set to FOMV (Fan Output Min Value when PECI Error). Fan output value will be set to the full speed value (FFh). Nuvoton Confidential - 123 – 2017/7/25 Revision 1.45 NCT7904D 7.4.21 Fan Output Min Value when PECI Error (FOMV) Location: FOMV - Bank 3 Address 51HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 FOMV BIT 7 6 5 4 3 2 1 0 NAME FanMin DEFAULT 80HEX BIT DESCRIPTION 7-0 FanMin: control the FANCTL1-FANCTL4 fan output min value when PECI error condition is occurred. Also see CRPE (Configure Register of PECI Error) 7.4.22 Mask Register of PECI Error (MRPE) Location: MRPE - Bank 3 Address 52HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 MRPE BIT 7 NAME 6 5 4 3 Reserved 2 1 0 PECI_ERR_MSK[3:0] DEFAULT 00HEX BIT DESCRIPTION 7-4 Reserved. 3-0 PECI_ERR_MSK[3:0]: Mask CRPE setting for FANCTL1-FANCTL4. It means that Fan output value keeps at its current value. 7.4.23 PECI T_DTS Slope Value (PTSV) Location: P1TSV - Bank 3 Address 64HEX P2TSV - Bank 3 Address 65HEX P3TSV - Bank 3 Address 66HEX P4TSV - Bank 3 Address 67HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 P1TSV – P4TSV BIT 7 NAME Nuvoton Confidential 6 5 4 3 2 1 0 PECI T_DTS_Slope - 124 – 2017/7/25 Revision 1.45 NCT7904D DEFAULT 00HEX BIT DESCRIPTION 7-0 This setting is used to define slope of specific CPU’s DTS Thermal Profile. DTS Thermal profile need to be configured before enabling sensor based fan control algorithm. PECI T_DTS_Slope: Slope[7]=0.5 Slope[3]=0.03125 Slope[6]=0.25 Slope[2]=0.015625 Slope[5]=0.125 Slope[1]=0.0078125 Slope[4]=0.0625 Slope[0]=0.00390625 Example: PECI T_DTS_Slope[7:0]=8’h46, mean slope=0.273 7.4.24 PECI T_DTS Offset Value (PTOV) Location: P1TOV - Bank 3 Address 68HEX P2TOV - Bank 3 Address 69HEX P3TOV - Bank 3 Address 6AHEX P4TOV - Bank 3 Address 6BHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 P1TOV – P4TOV BIT 7 6 5 4 3 2 1 0 NAME PECI T_DTS Offset DEFAULT 00HEX BIT DESCRIPTION 7-0 This setting is used to define initial offset temperature of specific CPU’s DTS Thermal Profile. DTS Thermal profile need to be configured before enabling sensor based fan control algorithm. 7.4.25 Tcontrol_Offset Value for CPU Agent (Address : 30h ~ 33h) (TOV) Location: TOV1 - Bank 3 Address 70HEX TOV2 - Bank 3 Address 71HEX TOV3 - Bank 3 Address 72HEX TOV4 - Bank 3 Address 73HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 Nuvoton Confidential - 125 – 2017/7/25 Revision 1.45 NCT7904D TOV1 – TOV4 BIT 7 6 5 4 3 2 1 0 NAME Tcontrol_Offset DEFAULT 00HEX BIT DESCRIPTION 7-0 Tcontrol_Offset value is required to adjust the Tcontrol_spec desined in DTS(Sensor) Based Thermal Spec. Tcontrol_Offset: Unit in ℃ and 2’s complement representation. 7.4.26 DTS Delta Tolerance Value (DDTV) Location: DDTV1 - Bank 3 Address 80HEX DDTV2 - Bank 3 Address 81HEX DDTV3 - Bank 3 Address 82HEX DDTV4 - Bank 3 Address 83HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 DDTV1 – DDTV4 BIT 7 6 5 4 3 NAME DTS Delta Tolerance Value DEFAULT 00HEX BIT DESCRIPTION 7-0 2 1 0 This setting is used to define Tolerance of DTS (Sensor) Based Fan Control. Nuvoton Confidential - 126 – 2017/7/25 Revision 1.45 NCT7904D 7.4.27 DTS Margin Divisor (DMD) Location: DMD - Bank 3 Address 84HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 DMD BIT 7 NAME 6 5 4 3 DTS_M_DIV[3:0] 1 0 Reserved DEFAULT 00HEX BIT DESCRIPTION 7-4 Enabling the DTS Margin Divisor. DTS_M_DIV [3] = 1 => Enable FANCTL4 Margin/2. DTS_M_DIV [2] = 1 => Enable FANCTL3 Margin/2. DTS_M_DIV [1] = 1 => Enable FANCTL2 Margin/2. DTS_M_DIV [0] = 1 => Enable FANCTL1 Margin/2. 3-0 Reserved. Nuvoton Confidential 2 - 127 – 2017/7/25 Revision 1.45 NCT7904D 7.5 Bank 4 REGISTER DETAIL 7.5.1 Temperature to Fan Mapping Relationships (TFMR) Location: T5FMR - Bank 4 Address 00HEX T6FMR - Bank 4 Address 01HEX T7FMR - Bank 4 Address 02HEX T8FMR - Bank 4 Address 03HEX T9FMR - Bank 4 Address 04HEX T10FMR - Bank 4 Address 05HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 T5FMR – T10FMR BIT 7 6 NAME 5 4 Reserved 3 2 1 0 F4SF F3SF F2SF F1SF DEFAULT 00HEX BIT DESCRIPTION 7-4 Reserved 3-0 F4SF – F1SF setting involves two purposes. The one is building up the relation between temperature source 5~10 and FANCTL1~4, the other is Fan Control mode assignment. 0 = Related FANCTL will operate in manual mode and have no relationship with temperature (Default) 1 = Related FANCTL will operate with SmartFan control mode and be linked to relative temperature source 5 ~ 10. 7.5.2 Temperature Source Selection (TSS) Location: TSS5 - Bank 4 Address 08HEX TSS6 - Bank 4 Address 09HEX TSS7 - Bank 4 Address 0AHEX TSS8 - Bank 4 Address 0BHEX TSS9 - Bank 4 Address 0CHEX TSS10 - Bank 4 Address 0DHEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 F5TSS – F10TSS BIT NAME 7 6 5 4 3 Reserved DEFAULT Nuvoton Confidential 2 1 0 TSS[5:0] 00HEX - 128 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 7-6 Reserved. 5-0 TSS: Temperature source selection 00_0000: VSEN2_HV/TEMP_CH1_HV - Bank 0 Address 42HEX 00_0001: VSEN4_HV/TEMP_CH2_HV - Bank 0 Address 46HEX 00_0010: VSEN6_HV/TEMP_CH3_HV - Bank 0 Address 4AHEX 00_0011: VSEN8_HV/TEMP_CH4_HV - Bank 0 Address 4EHEX 00_0100: LTD_HV -Bank 0 Address 62HEX 00_0101: T_CPU1_HV - Bank 0 Address A0HEX 00_0110: T_CPU2_HV - Bank 0 Address A2HEX 00_0111: T_CPU3_HV - Bank 0 Address A4HEX 00_1000: T_CPU4_HV - Bank 0 Address A6HEX 00_1001: T_CPU5_HV - Bank 0 Address A8HEX 00_1010: T_CPU6_HV - Bank 0 Address AAHEX 00_1011: T_CPU7_HV - Bank 0 Address ACHEX 00_1100: PCH_PCH_0 - Bank 0 Address F0HEX 00_1101: PCH_PCH_1 - Bank 0 Address F1HEX 00_1110: PCH_CPU_I - Bank 0 Address F3HEX 00_1111: PCH_MCH - Bank 0 Address F4HEX 01_0000: PCH_DIMM0 - Bank 0 Address F5HEX 01_0001: PCH_DIMM1 - Bank 0 Address F6HEX 01_0010: PCH_DIMM2 - Bank 0 Address F7HEX 01_0011: PCH_DIMM3 - Bank 0 Address F8HEX 01_0100: VRT_TEMP1_V - Bank 0 Address B8HEX 01_0101: VRT_TEMP2_V - Bank 0 Address B9HEX 01_0110: VRT_TEMP3_V - Bank 0 Address BAHEX 01_0111: VRT_TEMP4_V - Bank 0 Address BBHEX 01_1000: MT_C0_C0 - Bank 2 Address C4HEX 01_1001: MT_C1_C0 - Bank 2 Address C5HEX 01_1010: MT_C2_C0 - Bank 2 Address C6HEX 01_1011: MT_C3_C0 - Bank 2 Address C7HEX 01_1100: MT_C0_C1 - Bank 2 Address C8HEX 01_1101: MT_C1_C1 - Bank 2 Address C9HEX 01_1110: MT_C2_C1 - Bank 2 Address CAHEX 01_1111: MT_C3_C1 - Bank 2 Address CBHEX 10_0000: MT_C0 - Bank 2 Address CCHEX 10_0001: MT_C1 - Bank 2 Address CDHEX Nuvoton Confidential - 129 – 2017/7/25 Revision 1.45 NCT7904D BIT DESCRIPTION 10_0010: MT_SYS - Bank 2 Address CEHEX 10_0011: EXT_VRT_TEMP1_V - Bank 0 Address BCHEX 10_0100: EXT_VRT_TEMP2_V - Bank 0 Address BDHEX 10_0101: EXT_VRT_TEMP3_V - Bank 0 Address BEHEX 10_0110: EXT_VRT_TEMP4_V - Bank 0 Address BFHEX 10_0111 ~ 11_1111: Reserved 7.5.3 Critical Temperature to Full Speed all fan (CTFS) Location: T5CTFS - Bank 4 Address 10HEX T6CTFS - Bank 4 Address 11HEX T7CTFS - Bank 4 Address 12HEX T8CTFS - Bank 4 Address 13HEX T9CTFS - Bank 4 Address 14HEX T10CTFS - Bank 4 Address 15HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 T5CTFS – T10CTFS BIT 7 6 5 4 3 2 1 0 NAME Critical Temperature DEFAULT 5AHEX (90℃) BIT DESCRIPTION 7-0 Critical Temperature setting for each Smart Fan Table 5 ~ 10. While temperature source exceeds the critical temperature, the relative FANCTL will output full duty cycle. Unit in ℃. Nuvoton Confidential - 130 – 2017/7/25 Revision 1.45 NCT7904D 7.5.4 Hysteresis of Temperature (HT) Location: HT5 - Bank 4 Address 20HEX HT6 - Bank 4 Address 21HEX HT7 - Bank 4 Address 22HEX HT8 - Bank 4 Address 23HEX HT9 - Bank 4 Address 24HEX HT10 - Bank 4 Address 25HEX Type: Read / Write Reset: Power On Reset RESETIN# with LOCK=0 HT5 – HT10 BIT 7 NAME Reserved DEFAULT 6 5 Hysteresis of Critical Temperature 6-4 3 2-0 3 2 Reserved 1 0 Hysteresis of Operation Temperature 5HEX (5℃) BIT 7 4 3HEX (3℃) DESCRIPTION Reserved Hysteresis of Critical Temperature: Hysteresis for critical temperature on Smart Fan Table 5 ~ 10. The range is 0℃~7℃ Reserved Hysteresis of Operation Temperature: Hysteresis for normal temperature on Smart Fan Table 5 ~ 10. The range is 0℃~7℃ 7.5.5 SMART FANTM IV Temperature and DC/PWM Table (SFIV) Location: Relative Register-at SMART FAN Temp6 Temp7 Temp8 Temp9 Nuvoton Confidential IV Control Mode Table ADD (Hex) TYPE T1 – T4 30-33 RW PWM1 – PWM4 34-37 RW T1 – T4 38-3B RW PWM1 – PWM4 3C-3F RW T1 – T4 40-43 RW PWM1 – PWM4 44-47 RW T1 – T4 48-4B RW DC/PWM1 – DC/PWM4 4C-4F RW T1 – T4 50-53 RW DC/PWM1 – DC/PWM4 54-57 RW RELATIVE TEMPERAUTRE Temp5 TM NNEMONIC - 131 – 2017/7/25 Revision 1.45 NCT7904D ADD (Hex) TYPE T1 – T4 58-5B RW DC/PWM1 – DC/PWM4 5C-5F RW RELATIVE TEMPERAUTRE Temp10 Type: Reset: NNEMONIC Read / Write Power On Reset RESETIN# with LOCK=0 T1 – T4 BIT 7 6 5 NAME 4 SMART FAN DEFAULT 3 TM 2 1 0 2 1 0 IV Temperature Table T1 = 19HEX (25℃) Table T2 = 23HEX (35℃) Table T3 = 2DHEX (45℃) Table T4 = 37HEX (55℃) DC/PWM1 – DC/PWM4 BIT 7 NAME DEFAULT 6 5 4 SMART FAN 3 TM IV DC/PWM Table P1 = 8CHEX (140 Duty) Table P2 = AAHEX (170 Duty) Table P3 = C8HEX (200 Duty) Table P4 = E6HEX (230 Duty) Nuvoton Confidential - 132 – 2017/7/25 Revision 1.45 NCT7904D 8. ELECTRICAL CHARACTERISTICS 8.1 Absolute Maximum Ratings PARAMETER Power Supply Voltage RATING UNIT 3VSB,3VDD,VBAT 3.3 ± 5% V VTT 2.048 Input Voltage -0.3 to +3.6 Operating Temperature -40 to +120 Storage Temperature V *1 °C °C -55 to +150 *1 Guaranteed by design from -40~120 degree C, 100% tested at 85 degree C. 8.2 DC Specification (Ta = 0° C to 70° C, 3VDD = 3.3V ± 5%, 3VSB =3.3V ± 5%, GND = 0V) PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS OD – Open-drain output pin with source-sink capability of 12 mA Output Low Voltage VOL 0.4 TSI – For AMD TM V IOL = 12 mA TSI design Input Low Voltage VIL 0.6 V Input High Voltage VIH 1 V Output Low Voltage VOL 0.285 TM PECI – Bi-direction pin for INTEL V PECI Input Low Voltage VIL 0.275Vtt 0.5Vtt V Input High Voltage VIH 0.55Vtt 0.725Vtt V Output Low Voltage VOL 0.25Vtt V Output High Voltage VOH 0.75Vtt V GTL –For PROCHOT,THERMTRIP Input Low Voltage VIL Input High Voltage VIH Nuvoton Confidential 0.4 0.8 V V - 133 – 2017/7/25 Revision 1.45 NCT7904D PARAMETER SYM. Output Low Voltage VOL I- Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH Input Low Leakage ILIL MIN. TYP. MAX. UNIT 0.2 V CONDITIONS TTL level Schmitt-triggered input pin 0.8 V 3VSB = 3.3V V 3VSB = 3.3V +10 µA VIN=3.3V -10 µA VIN=0V 2.0 AIN - Analog input pin Input High Leakage ILIH +1 µA VIN=3.3V Input Low Leakage ILIL -1 µA VIN=0V AIN – VSEN17 , VSEN18 , VSEN19 Input High Leakage ILIH +36 µA VIN=3.3V Input Low Leakage ILIL -10 µA VIN=0V 8.3 AC Specification SMBus Interface t SCL tR t R SCL t HD;SDA t SU;STO t SU;DAT VALID DATA SDA IN t HD;DAT SDA OUT Serial Bus Timing Diagram PARAMETER SYMBOL - MIN. MAX. UNIT SCL clock period t SCL 10 uS Start condition hold time tHD;SDA 4.0 uS Stop condition setup-up time tSU;STO 4.0 uS Nuvoton Confidential - 134 – 2017/7/25 Revision 1.45 NCT7904D DATA to SCL setup time tSU;DAT 150 nS DATA to SCL hold time tHD;DAT 270 nS SCL and SDA rise time tR 1.0 uS SCL and SDA fall time tF 300 nS Clock Input Timing DESCRIPTION CLKIN MIN TYP MAX Clock cycle time (1/CLKIN) x0.97 1/CLKIN (1/CLKIN) x1.03 Duty cycle 45% Nuvoton Confidential 55% - 135 – 2017/7/25 Revision 1.45 NCT7904D 9. ORDER INFORMATION PART NO. PACKAGE NCT7904D 48 LQFP (Halogen free) Nuvoton Confidential - 136 – REMARKS 2017/7/25 Revision 1.45 NCT7904D 10. TOP MARKING SPECIFICATIONS NCT7904D 28201234-01 138GBBA 1st line: Nuvoton logo 2nd line: part number: NCT7904D 3rd line: wafer production series lot number: 28201234-01 4th line: tracking code: 138GBBA 138: packages made in '11, week 38 G: assembly house ID B: Chip Version BA: Nuvoton internal use Nuvoton Confidential - 137 – 2017/7/25 Revision 1.45 NCT7904D 11. PACKAGE DRAWING AND DIMENSIONS 48-pin LQFP (7 mm X7 mm X1.4mm) Nuvoton Confidential - 138 – 2017/7/25 Revision 1.45 NCT7904D 12. REVISION HISTORY VERSION DATE 0.2 08/17/2010 0.3 10/12/2010 ALL Fixed the typos. 0.4 02/25/2011 ALL Updated for new A2 version sample. 0.8 05/04/2011 ALL Updated Top Marketing & Part No. 0.9 08/08/2011 ALL Update for new A3 version sample. 0.91 09/21/2011 The content is the same as v0.9. Just update the version to v0.91 for new A4 version sample. 0.95 11/15/2011 29, 31, 32, 39, 40, 43, 114, 127, 134 1. Update PCH thermal data description (section 6.11.2) 2. Update Device ID information 3. Update LOCK description 4. Update Bank0 Addr[2Eh] Mode Control Register description. 5. Change Temperature Source Selection Table configuration of 00_1100 : from Bank0 Address AEh to F0h 6. Update Order Information (Item 1, 2, 5 are updated for rev.B chip) 1.0 1/5/2012 ALL Public Released. All versions before 1.0 are preliminary versions 1.1 5/31/2012 11,93 1. Fixed the typo. 2. Added External Read Control Register description. 1.2 7/20/2012 114 1.3 2/4/2013 87,88 1.41 4/11/2013 10,14,15,18,12 9 1.42 4/29/2013 27,128 1.Added power ramp request on EEPROM self-initialization function. 2.Modified Absolute Maximum Ratings. 1.43 6/24/2013 13,16 Added recommendations for unused pin. 1.44 2/10/2014 80 Updated description of PECI Power Averaging Configure Register Bit[5]. 1.45 07/25/2017 10 Update the operating temperature range Nuvoton Confidential PAGE DESCRIPTION Preliminary Released. 1.Updated Fan Output Pre-scalar register. PWM Frequency 1. Fixed typo. 2. Updated TSI register descriptions. 1.Modified descriptions for VSEN17,18,19. 2.Fixed typo of VSEN17,18,19 formula. 3.Added DC specification for VSEN17,18,19. - 139 – 2017/7/25 Revision 1.45 NCT7904D Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Nuvoton Confidential - 140 – 2017/7/25 Revision 1.45
NCT7904D 价格&库存
很抱歉,暂时无法提供与“NCT7904D”相匹配的价格&库存,您可以联系我们找货
